Official OPPO BDP-103 Owner's Thread - Page 864 - AVS Forum | Home Theater Discussions And Reviews
 10244Likes
post #25891 of 25899 Old 02-06-2020, 03:28 AM
fmalczewski's Avatar
Quoted: 242 Post(s)
Liked: 83
Originally Posted by Flemi View Post
Hi Oppo enthusiasts!
I'm planning on buying a mod to make my 103 region free for blu-rays. I've done some research and found the following non-soldiering solutions:
Bluraychip's version: http://bluraychip.dk/product.php?id_product=26
jvbdigital's version: http://www.jvbdigital.nl/jvb.asp?lev...tle&title=1234
ebay: https://ebay.us/Om1BUi (this requires no opening up of the player chassis)
Does anyone have any recommendations or thoughts on the above options or if there are any other better options? The eBay option doesn't require me to open up the player chassis but is the priciest option - how hard is it to open up the oppo?
Are there software options to making the player region free?
My Oppo is installed with the latest firmware update.
Thanks for your comments!
You could get the last one a lot cheaper through avsdigital (https://www.ebay.com/itm/Oppo-BDP-10...t/162101335749), ships to US "and many other countries"... (My two from them work great.)
I've not done it, but supposedly opening up the Oppo is easy as pie. If you want region free for dvds only, there is a software option (http://www.multi-region.net/oppo_bdp-83), but the only option for blu-rays is a hardware kit (at least as far as I know and as far as what can be discussed here).
fgsouza and Flemi like this.
fmalczewski is offline
post #25892 of 25899 Old 02-06-2020, 03:52 AM
Flemi's Avatar
Quoted: 12 Post(s)
Thanks fmalczewski, for your suggestion of avsdigital's product, can that be installed externally without opening the 103?
Flemi is offline
post #25893 of 25899 Old 02-06-2020, 08:20 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5869 Post(s)
Liked: 8403
^ You will need a hardware mod (such as the ones you've spotted) for Blu-ray Region Free.
If all you need is Region Free for standard DVDs you can do that for free with the Super Disc software mod. See the FAQ for the 103 (link at the top of the first post of this thread).
--Bob
Flemi likes this.
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #25894 of 25899 Old 02-06-2020, 08:24 AM
Paul H's Avatar
Quoted: 62 Post(s)
Liked: 64
Ebay: Oppo BDP-103 Region Code Upgrade USB Kit
This external mod works on my 103, 103D, and 203.
Flemi likes this.
Avatar: IMAX Header
BD 3D, BD, HD DVD, DVD collection
Paul H is online now
post #25895 of 25899 Old 02-06-2020, 08:35 PM
Quoted: 242 Post(s)
Liked: 83
Yup, what Paul H said, can be installed externally (or internally, which I've never bothered with), 103, 103D, 105, 203, 205, works with all of them externally... which is what I've done starting with the 103.
(The 205 and perhaps the 105 might be a problem if somebody wanted to install it internally, more than just opening it up and easily installing it, might have to remove a board or something to get at where it needs to be installed, but those are beyond my pay grade, just something I remember reading about the 205 once upon a time.)
Flemi likes this.
post #25896 of 25899 Old 02-08-2020, 05:44 AM
looun's Avatar
hello, there is a documentation/SKD/Q&A about all IP/http commands ?
example::getglobalinfo, playnormalfile ecc..
looun is offline
post #25897 of 25899 Old 02-08-2020, 08:26 AM
Read the FAQ!
Liked: 8403
^ OPPO has published the details of its RS232 serial port commands, but not its IP commands.
I suggest you get in touch with OPPO Tech Support and see if they can get those details to you. I don't know if they've ever been written up for other than OPPO's own, internal use.
You can use the Email Us link on OPPO's Support page for the player:
https://www.oppodigital.com/support/...3-Support.aspx
--Bob
post #25898 of 25899 Old 02-20-2020, 12:28 AM
jojojava's Avatar
Cool Oppo bdp103d compatible with epson 5040ub?
Hi, sorry to drop in on the conversation like this, i just have a quick question, somewhat related (i hope) to the discussion. I have an oppo bdp103d and interested in upgrading to the epson 5040ub mfr refurb. Will the projector display properly in the oppo, or do i need an oppo firmware upgrade in order to do so? I have the monoprice dynamicview 4k hdmi cable. Thanks in advance!
Jojo
Ascend Acoustics Sierra Towers R/L fronts, sierra center, rythmik sub and cbm-170s in a 7.1 config
Epson 5020ub
Marantz 7011 receiver
Xbox one
jojojava is offline
post #25899 of 25899 Old 02-24-2020, 09:54 AM
ckronengold's Avatar
Quoted: 325 Post(s)
Liked: 130
what do you mean by "display correctly"? The 5040 is a 4k pixel shifter. Are you asking if the projector will display 4k from the Oppo 103?
The Oppo 103 will only upscale 1080p content to 4k, and then feed the 4k signal to the projector. The 5040 will have no problem playing that. But the Oppo 103 wont play a 4k disc.
You'll have to experiment for yourself if you prefer the Oppo or the Epson to do the upscaling.
If you're asking if an epson 5040 will play content from an Oppo 103, the answer is yes.
Video: Epson 6050 / Panny DP-UB420 / OPPO-103
Audio: Marantz 7010 / MartinLogan Motion 40 (LR), 50XT (center), M2 (surrounds)
Streaming: nVidia Shield / Roku Ultra / Chromecast Ultra
NAS: Synology 1515+ Server: Ubuntu 18.04, i7-8700 CPU
HTPC: Win10 Pro 64-bit, i5 750 Radeon HD 5850
ckronengold is offline
Reply Blu-ray Players
Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 105 Blu Ray Player , Oppo Bdp 93 Blu Ray Player , Oppo Digital Inc
