Official OPPO BDP-105 Owner's Thread - Page 482 - AVS Forum | Home Theater Discussions And Reviews
 1912Likes
post #14431 of 14440 Old 01-19-2020, 10:31 AM
gelly's Avatar
Originally Posted by Redrum69 View Post
can you elaborate a bit on your setup, and what exactly is happening?
Oppo connected into my Marantz sr7005 via RCA. Running test vs of Audirvana on my Mac (Catalina). Music stored on a separate HD connect to my Mac. Using Oppo suppled WiFi dongle. So the problem is when I close down the Audirvana, and turn off my Oppo. Next day I launch everything and the Audirvana does not see my Oppo as a listed item to use. I then need to unplug the Oppo for a minute or so, and then the Audirvana will see the DAC and everything is fine. Until the next time I turn everything on again.
gelly is offline
post #14432 of 14440 Old 01-20-2020, 11:32 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5869 Post(s)
Liked: 8403
^ Try setting the OPPO to Energy Efficient. This will cause the OPPO to reboot its networking on each power up.
—Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #14433 of 14440 Old 01-20-2020, 12:02 PM
gelly's Avatar
—Bob
Thanks Bob, I'll give that a shot.
gelly is offline
post #14434 of 14440 Old 01-28-2020, 06:23 PM
bordo32's Avatar
Quoted: 30 Post(s)
Liked: 24
Curious if OPPO 105 can be used as a DAC that would receive multichannel hirez audio (PCM, DSD) through one of HDMI inputs?
I am planning to use OPPO 105 as a DAC and Pioneer LX500 as a transport.
bordo32 is offline
post #14435 of 14440 Old 01-28-2020, 07:10 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4743 Post(s)
Liked: 4619
According to the FAQ, What are the specs of the digital inputs?
HDMI
  • The inputs support stereo and 5.1 LPCM up to 192KHz, 7.1 LPCM up to 96KHz.
  • Lossy Dolby Digital and DTS up to 7.1.
  • Dolby Digital Plus up to 7.1.
  • They do not support input of DSD, Dolby TrueHD or DTS-HD MA.
  • If fed Stereo LPCM originating from an HDCD disc, then the HDCD decoder in the OPPO can be used.
  • Note that as with all HDMI, audio can only be carried embedded in a video signal (which can be a black image). To use high bit rate LPCM, that signal must be 720p or higher.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #14436 of 14440 Old 01-28-2020, 09:19 PM
bordo32's Avatar
Quoted: 30 Post(s)
Liked: 24
HDMI
-Bill
Thank you Bill.
If Pioneer LX500 would convert Dolby TrueHD or DTS-HD MA to multichannel PCM and pass it over HDMI - OPPO 105 would be a good option as an external DAC for hirez multichannel audio.
bordo32 is offline
post #14437 of 14440 Old 02-09-2020, 01:55 PM
gelly's Avatar
Hello, for some reason my settings have resettled to factory default on my 105. I think I got most of the video settings. Can someone share the optimal settings for using the USB DAC input to get the best sound out of the DAC?
gelly is offline
post #14438 of 14440 Old 02-09-2020, 07:02 PM
Read the FAQ!
Liked: 8403
^ I don’t have answers off the top of my head for your DAC question, but if you find this problem repeats with your Settings you should get in touch with OPPO Tech Support for service, as there is likely a hardware problem with your Settings memory.
—Bob
post #14439 of 14440 Old 02-16-2020, 12:17 PM
gelly's Avatar
—Bob
Thanks Bob. I will look into that.
gelly is offline
post #14440 of 14440 Old 02-16-2020, 12:23 PM
gelly's Avatar
Thank you Bill.
Hello,Have tried this set up yet? If so how did you find the results? I'm about to connect a Roon Server the Oppo HDMI in.
Thx
gelly is offline
Reply Blu-ray Players
Oppo Bdp 105 Blu Ray Player
