Region Free Blu Ray player discussion - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 165Likes
post #241 of 244 Old 05-31-2019, 02:35 AM
Liked: 0
Originally Posted by unretarded View Post
I decided to just buy a player from the region I wanted.....rather than all the mumbo jumbo.........
Try converting your player to multi-region. It's not that difficult. Or you can use a DVD converter to digitize your DVDs. I ripped all my DVDs using WinX DVD Ripper Platinum and stored them on NAS drive for streaming.
Rico Rodriguez is offline
post #242 of 244 Old 07-29-2019, 03:13 PM
Liked: 0
Originally Posted by new2015 View Post
I just purchased the Azend Maxmade BDP-M1061 player and would like to change the region to play a DVD purchased in Europe. Do you have an idea on how to do this? SETUP and 8520 would bring the factory settings but that's all I can do so far.
thanks.
I have the same problem. Love to find a solution. Anyone find anything?
Thomas Underhaug Fosseli is offline
post #243 of 244 Old 07-29-2019, 03:15 PM
Liked: 0
Originally Posted by Big C View Post
If an AVS multi-region Blu-ray player thread already exists, please delete this one and shoot me a link to the existing thread. Assuming it doesn't, I would like to begin with some multi-region issues I'm having.
I own a few players with which when you press SETUP followed by 8520, a factory menu appears. It shows the BD and DVD region codes. Using the arrow keys, I can reset the password and erase the internal BD data storage. I would like to know how to determine whether you want to change the BD or DVD region. I would also like to know how you change the BD or DVD region from the current region to a region of my choice. How is this done with Seiki and Toshiba players? I have a Yamaha BD-A1010 and an Envizen Digital/Azend Group, Corp./Maxmade BDP-M1061. Maybe there's something I'm forgetting or not doing exactly right. At least if you own one of the Seikis or Toshibas, you'd probibly know what I'm talking about and might be able to tell me what I'm forgetting or what hasn't been explained as precisely elsewhere.
Same problem. Did you figure it out?
post #244 of 244 Old 07-30-2019, 03:53 PM
mdavej's Avatar
Quoted: 3019 Post(s)
Liked: 1367
For players that use the 8520 procedure, press 1 for A, 2 for B or 3 for C.
mdavej is offline
Reply Blu-ray Players
blu ray , dvd , Lg 55lw5600 55 Inch Class 3d Led Tv Full Hd 1080p Resolution Includes 10 Pairs Of Lg 3d Glasses , Lg Bd590 250gb Hd Network Blu Ray Disc Player , Lg Bd630 Network Blu Ray Disc Player , Lg Bd640 Network Wireless Blu Ray Disc Player , multi region , Oppo Bdp 83 Blu Ray Player , player , region free , Toshiba Bdx1200 Blu Ray Disc Player
