Official OPPO BDP-103D (Darbee Edition) Owner's Thread - Page 299 - AVS Forum | Home Theater Discussions And Reviews
 1692Likes
post #8941 of 9465 Old 09-13-2016, 11:35 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4642 Post(s)
Liked: 4492
Originally Posted by Cipher View Post
I store most of my Blu-rays in a lossless MKV file format that gets played by one of my two BDP-103D players. However, a few of the titles have audio tracks that result in the "Audio format not supported" error message. I just took a look at two of the MKV files that cause this error message to appear and this is what I found:
1) Andrea Bocelli: Vivere - LPCM 5.1, 48kHz, 16-bit
2) Tinker Bell (Disney) - LPCM 5.1, 48kHz, 24-bit
You're right, I get the same thing. Dolby 5.1 in MKV plays but LPCM 5.1 produces an "Audio Not Supported" message.
You should get the details to OPPO support; I'll do the same via the beta test forum.
Here is the mediainfo report for my LPCM track:
Audio #2
ID in the original source medium : 4353 (0x1101)
Format : PCM
Codec ID : 00001000-0000-0100-8000-00AA00389B71
Duration : 2 h 28 min
Bit rate mode : Constant
Bit rate : 4 608 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 30.000 FPS (1600 spf)
Bit depth : 16 bits
Stream size : 4.79 GiB (25%)
Title : Surround 5.1
Language : English
Default : No
Forced : No
Originally Posted by PeterTHX View Post
"Frame rate : 30.000 FPS (1600 spf)" Isn't it supposed to be 23.97?
The video track does report 23.967; I don't know why mediainfo reports a different value for audio. Is that even meaningful?
-Bill
Cipher likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #8942 of 9465 Old 09-13-2016, 11:47 AM
PeterTHX's Avatar
Quoted: 569 Post(s)
Liked: 431
-Bill
I'm just wondering if it's not playing at the proper rate (maybe misflagged?) the Oppo may get confused.\
OR: it might not support 5.1 PCM in MKV, just 2 channel?
My opinions do not reflect the policies of my company
PeterTHX is offline
post #8943 of 9465 Old 09-13-2016, 11:55 AM
wmcclain's Avatar
Liked: 4492
I suspect that's it.
-Bill
post #8944 of 9465 Old 09-13-2016, 12:05 PM
Cipher's Avatar
Quoted: 44 Post(s)
Liked: 24
Audio #2
Format : PCM
Bit depth : 16 bits
Language : English
Default : No
Forced : No
-Bill
Thanks for the quick test, Bill! I'm happy you confirmed the issue, but I guess the negative side is waiting for a possible fix from Oppo. At least there aren't too many titles where this is an issue for most people.
I submitted this issue to Oppo using the online support form.
PeterTHX, I also noticed that frame rate for the audio streams so I checked some other files and it's all over the place. I'm also not sure what it's reporting, but it definitely different than the video frame rate of 23.976 (24000/1001) FPS that I see from the files.
PeterTHX likes this.
Cipher is offline
post #8945 of 9465 Old 09-13-2016, 02:34 PM
Quoted: 560 Post(s)
Liked: 220
Oppo's 4K Ultra Blu Ray player news.....
I dont know if this news has already made the rounds on this Forum but I thought I would post it anyway....Oppo's 4K Ultra Blu Ray player news....
I have a buddy who works at Oppo and he just informed me that their 4K Ultra Blu Ray player will be released before end of this year and will be priced in line with their 103D at $599.00
You can also be put on their E-Mail list so you will be informed when released. Just call Cust Svc at Oppo.
I will wait till then before I make any 4K Ultra Blu Ray player purchase (example-the new Panasonic).
JasonQG, ambesolman and grtuck like this.
aflorida is offline
post #8946 of 9465 Old 09-13-2016, 04:33 PM
Cipher's Avatar
Quoted: 44 Post(s)
Liked: 24
I received the following reply from Oppo regarding the PCM 5.1 issue with MKV files:
It appears that these files have an invalid Codec ID. So the player does not know how to handle the audio for decoding.
Given this reply, I did a quick search online for the "00001000-0000-0100-8000-00AA00389B71" codec string and came across the following AVSForum post:
Originally Posted by Lush78 View Post
This post is to share some information and the solution to the problems I was having with MakeMKV and Blu-rays with LPCM audio. When remuxing Blu-rays containing LPCM audio with MakeMKV, I would not be able to playback the LPCM audio track using anything, including VLC on PC, Popcorn Hour c200, Boxee Box, etc. MakeMKV sets the Codec ID to "A_MS/ACM" which is a very uncommon codec. To solve this problem, open MKVmerge GUI, and go to File -> Header Editor. Then go to File -> Open and browse to your MKV. Scroll down to the audio track that contains the LPCM audio and change the Codec ID from "A_MS/ACM" to "A_PCM/INT/LIT". Then File -> Save. Your MKV will now contain an LPCM audio track that should be compatible with any software or hardware capable of playing MKV files... Hope this helps...
I tried this fix on my Tinker Bell file using MKVToolnix and it now plays properly on the Oppo. The BDP-103D also correctly shows the track as 'English LPCM 5.1'.
I also found this thread - MakeMKV picks wrong LPCM codec-id - from 2011 on the MakeMKV forums so it looks like this issue has existed for at least 5 years and still hasn't been fixed. Given the ubiquity of the MKV file format, I wonder if Oppo would be able to add that codec string to it's lookup table so that we don't have to make this header conversion to our files. I agree that the programmer(s) for MakeMKV should be handling this, but after this amount of time I'm not holding my breath.
gsr and wmcclain like this.
Cipher is offline
post #8947 of 9465 Old 09-13-2016, 05:27 PM
tngiloy's Avatar
Quoted: 491 Post(s)
Liked: 309
Any news whether this will also be a Darbee unit?
"When all else fails, read the manual."
tngiloy is offline
post #8948 of 9465 Old 09-13-2016, 05:36 PM
David Susilo's Avatar
Quoted: 778 Post(s)
Liked: 664
I hope you are right with the $599 price. I'd get one in a heartbeat provided it has Darbee and multiple HDMI inputs just like the 103D. My sources told me otherwise (regarding the price).
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is online now
post #8949 of 9465 Old 09-13-2016, 05:39 PM
Quoted: 778 Post(s)
Liked: 664
Logically the $599 doesn't make sense when the 103D is also $599.
my home theatre
post #8950 of 9465 Old 09-13-2016, 05:47 PM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1936 Post(s)
Liked: 2321
^ Guys, there's already a thread for discussing a future Oppo UHD player. Please use it for discussing the upcoming player so we can stay focused on the current player here.
Vader424242, tngiloy and JohnAV like this.
gsr is online now
post #8951 of 9465 Old 09-13-2016, 08:17 PM
Quoted: 778 Post(s)
Liked: 664
Didn't know. Thanks for the info
post #8952 of 9465 Old 09-14-2016, 07:08 AM
ArthurL's Avatar
Is anyone having issues playing Captain America Civil War?
When I inserted the 3D disc, message popped up saying that a 3D blu-ray player was not detected or a firmware update was required. When I inserted the 2D version of the disc, the previews and featurettes played without issue, but the feature film played without sound. I had to switch it to LPCM in order to hear the movie.
ArthurL is offline
post #8953 of 9465 Old 09-14-2016, 07:27 AM
pacman9270's Avatar
Quoted: 109 Post(s)
Liked: 72
My plan is to watch the movie either Friday or Saturday night. If no one else responds, I'll respond then. Hope you get an answer earlier than that.
Theater Setup: 5.2.5 (10.1 Auro3D) / ~3100 cu.ft. / Vaulted Ceiling
Projector:JVC DLA-X570R Screen:SI Performance Series 16:9 100" Source Player:Oppo BDP-103D/UDP-203 Pre/Pro:Marantz AV8802A Amps:Emotiva XPA-5(Fronts/Surrounds) and BasX A500(Heights) Fronts/Surrounds:Sonus Faber Venere 2.0 Center:Sonus Faber Venere Center Front/Rear Heights:Definitive Technology PM1000 / ProCenter1000(VOG) Subwoofer:Dual SVS SB-2000 Speaker Wire:Monoprice CL2 12-AWG w/Bananas ICs:BlueJeanCables/Mediabridge
pacman9270 is offline
post #8954 of 9465 Old 09-14-2016, 01:32 PM
Deucedriver's Avatar
Quoted: 25 Post(s)
It is working fine for me. I checked and my firmware version ends with -0715 if you want to check yours.
Hope this helps.
Deucedriver is offline
post #8955 of 9465 Old 09-14-2016, 06:13 PM
ArthurL's Avatar
Hope this helps.
Well, this is odd, everything works now! Even the 3D disc! It seems that, for me at least, switching the HDMI AUDIO from AUTO to BITSTREAM fixed my issues.
aflorida likes this.
ArthurL is offline
post #8956 of 9465 Old 09-15-2016, 10:45 AM
SeeMoreDigital's Avatar
Quoted: 1005 Post(s)
Liked: 770
MakeMKV Muxing Issues
I received the following reply from Oppo regarding the PCM 5.1 issue with MKV files....
It might also be worth mentioning that MakeMKV appears to mux Dolby TrueHD audio streams differently to MKVtoolNix, which can cause greater 'bit-streaming' issues (than MKVtoolNix) with the Oppo's
Cheers
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 2No Audiolab 8000A, 2No Audiolab M-PWR | SPEAKERS: 4No KEF 103.2, 3No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: DS212+
SeeMoreDigital is offline
post #8957 of 9465 Old 09-15-2016, 06:37 PM
Quoted: 145 Post(s)
Liked: 212
It makes no sense to carry a $599 price tag. Just a gut feeling. Unless there is so much profit in the 103d that they can absorb the extra cost and inflation indexing as well as cheapening some of the internals (ie. Newer generation elements that aggregate some of the older elements in cheaper fewer element setup)....
partcrash is offline
post #8958 of 9465 Old 09-15-2016, 07:33 PM
ambesolman's Avatar
Quoted: 1164 Post(s)
Liked: 975
Hasn't the pricing for the new gens stayed in the same ballpark as as the older ones? How much were the 93/95 when released?
Sent using Tapatalk since the mobile version is still
"Rockbiter" DO SI18 sub build - https://www.avsforum.com/forum/155-d...o-si-18-a.html
Ambesolman's Cleverly Titled Theater build - https://www.avsforum.com/forum/19-de...ter-build.html
ambesolman is offline
post #8959 of 9465 Old 09-16-2016, 06:49 AM
hernanu's Avatar
Quoted: 1279 Post(s)
Liked: 2121
Same (about) as the 10X's. The 83's were the same. You pay a premium for the audiophile analog stage.
Of course there was an extra 100 for Darbee, but to me that was a bargain, since the actual Darbee was about 300.
hernanu is offline
post #8960 of 9465 Old 09-16-2016, 06:54 AM
asere's Avatar
Quoted: 1924 Post(s)
Liked: 597
I have darbee on my Oppo but I don't think it's a must have. If you don't have it you won't miss it and if you have it, once it's set you forget and won't tell the diff.
Sent from my SM-G900P using Tapatalk
Samsung PN F8500 60'' TV, Denon AVR X4200W, Onkyo TX SR805, Parasound HCA 1500A, SVS Prime Towers and Center, SVS Prime satellites, Proficient Surrounds, Duo Kreisel DXD subs, PSA S3000i sub, Oppo 103D player, Panamax M5300 PM, Monster HTR 3600
asere is offline
post #8961 of 9465 Old 09-16-2016, 06:57 AM
hernanu's Avatar
Liked: 2121
For me it's a plus - it seems to (subtly) improve both disks and cable.
It's a personal preference but does get a vote from me.
hernanu is offline
post #8962 of 9465 Old 09-16-2016, 07:01 AM
asere's Avatar
Liked: 597
Yes, once you set it you immediately see the difference but once set with time you forget and the before or after won't matter unless you tinker with it on/off, on/off.
But correct a personal choice.
asere is offline
post #8963 of 9465 Old 09-16-2016, 07:04 AM
asere's Avatar
Liked: 597
Sometimes I wish I would have gotten the Oppo with the QDEO instead. I always heard the PQ Is really nice.
asere is offline
post #8964 of 9465 Old 09-16-2016, 09:28 AM
hernanu's Avatar
Liked: 2121
Hard to find, man - people just don't give their Oppos up easily.
I got my parents a BDP-80 a long while ago and it's still cranking along.
asere likes this.
hernanu is offline
post #8965 of 9465 Old 09-17-2016, 05:03 AM
Quoted: 560 Post(s)
Liked: 220
Get ready Oppo's 4K Ultra BluRay player is here....
As I stated in my earlier post..I just received a Priv Message confirming the news I reported here a week or so back...
Oppo's 4K Ultra Blu Ray player at CEDIA unveiled..
and the price is better than I was told for their 1st 4K Ultra Blu Ray player:
Oppo officially unveiled the 4k player (and it looks massive...bigger than a Buick !)
$499
No darbee (my guess if their will be a Darbee version it will be unveiled next)
No info on chips yet.
Pictures in link
https://mobile.twitter.com/chrisheinonen
sschen likes this.
aflorida is offline
post #8966 of 9465 Old 09-17-2016, 06:09 AM
wmcclain's Avatar
Liked: 4492
There is an anticipation thread for the UDP-203: https://www.avsforum.com/forum/149-bl...on-thread.html
-Bill
sschen and aflorida like this.
post #8967 of 9465 Old 09-17-2016, 10:06 AM
pacman9270's Avatar
Quoted: 109 Post(s)
Liked: 72
On the contrary, you can miss it. I do when it's turned off. The effects of the Darbee processing are not evident when you first turn it on. Once activated give it a week of watching and then turn it off and you can notice a significant difference. The purpose of the processor is to enhance the image not change it.
post #8968 of 9465 Old 09-18-2016, 04:58 PM
bjhess's Avatar
Quoted: 49 Post(s)
Liked: 26
I just got my Oppo today. Enjoying setting it up.
Is it true that you cannot use Darbee on the streaming services like Netflix? When I push the button on the remote there is no response. If that's the case, kind of a bummer.
(Also, one more data point with the Netflix audio problem. Selecting a different language from the Netflix audio menu and back again seems to fix it here. Though that's no solution for my family. )
bjhess
bjhess is offline
post #8969 of 9465 Old 09-18-2016, 05:05 PM
wmcclain's Avatar
Liked: 4492
No, it works. You have to set it before you run Netflix, whose app takes over the player blocking certain controls.
-Bill
pacman9270 likes this.
post #8970 of 9465 Old 09-18-2016, 05:16 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5833 Post(s)
Liked: 8309
^ If you get OPPO's free iOS or Android MediaControl app, you can use it to adjust Darbee even while Netflix is running. Go to the app's Settings page and you can adjust anything that's in the player's Setup menu.
--Bob
Bob Pariseau is offline
Reply Blu-ray Players
Oppo , Oppo Bdp 103 3d Blu Ray Player , Oppo Bdp 103d Universal 3d Blu Ray Player Darbee Edition , Oppo Brand , Oppo Digital , Oppo Digital Inc
