Yamaha BD-S677 - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 15Likes
post #91 of 106 Old 09-28-2016, 09:01 AM
3db
3db's Avatar
Quoted: 734 Post(s)
Liked: 527
I see this player available used for $100 Cdn. Do you think its worth getting for that price?
AVR Yamaha RX-V 1800/1900/1500
TT/Cassette ProJect Xpression III/Yamaha KX1200/KX800
BR Yam. BD-S681/Sony X800/Pan. BD30 DPL Sam. 65"/ 55"/50"
Speakers PSB T-45,8C,1B/ PSB 500,200C,RBH A600/Alphas
Subs Rythmic LV12-R/PSB Subsonic 6/5
3db is offline
post #92 of 106 Old 09-28-2016, 10:35 AM
Brenda Johnson's Avatar
Liked: 4
Sure -- mine's held up well, and I think you'll be very pleased with it for that price.
Brenda Johnson is offline
post #93 of 106 Old 10-05-2016, 12:37 PM
3db
3db's Avatar
Quoted: 734 Post(s)
Liked: 527
Someone else bought it before I had a chance to offer teh seller money. I'm going through Amazon.ca and I see teh BDSP681 on sale for 309.23 Cdn which appears to be a very good price.
3db is offline
post #94 of 106 Old 10-08-2016, 01:25 PM
Liked: 0
BD-S677 dolby TrueHD and DTS HD master via MKV files
Hi,
Do you known if the yamaha BD-S677 can play MKV files with audio dolby TrueHD and DTS HD master via USB or LAN ?
Apart this, the USB ports support hardisk more then 2 TB ?
alex5671 is offline
post #95 of 106 Old 10-09-2016, 06:03 AM
gymnos's Avatar
Quoted: 28 Post(s)
Liked: 29
Originally Posted by alex5671 View Post
Hi,
It doesn´t have any problems with HD audio via USB, but I haven´t tried with HDD bigger than 2TB.
Regards.
gymnos is offline
post #96 of 106 Old 10-09-2016, 10:23 AM
Liked: 0
Regards.
Thank you !!
Have you tested file MKV with audio Dolby TrueHD or DTS HD Master ?
For example sony and Marantz support both HD audio, but MKV with audio Dolby TrueHD or DTS HD Master is not supported.
Actually seem only pioneer and OPPO support this, but I hope that yamaha also support it.
alex5671 is offline
post #97 of 106 Old 10-11-2016, 04:00 PM
gymnos's Avatar
Quoted: 28 Post(s)
Liked: 29
Thank you !!
Have you tested file MKV with audio Dolby TrueHD or DTS HD Master?
Yes, I have tested MKV files over 20GB and DTS-HD or Dolby TrueHD and haven´t found any bug, even with 7.1 audio tracks.
Regards.
gymnos is offline
post #98 of 106 Old 11-28-2016, 07:50 AM
Liked: 0
Bd-s677 sacd 5.1 playback error
Why does the unit not play hybrid MULTICH SACD as 5.1? It plays the SACD layer, but stereo only.
Please take into account that pure audio BD and DVD-A are both rendered 5.1 EVERYTIME. Why not SACD?
Bogdan ONOFREI,MBE is offline
post #99 of 106 Old 12-08-2016, 11:03 AM
Zcars's Avatar
Quoted: 168 Post(s)
Liked: 112
Sorry for the delayed response, but I haven't had a chance to test this until today. I had to go into the Setup menu, Audio, and select SACD priority as Multichannel for it to work. Hybrid must be set to SACD as priority also. The default was set to stereo and CD. I am getting 5.1 from my Linn surround sampler disc after making this change.
Brenda Johnson likes this.
Zcars is offline
post #100 of 106 Old 12-12-2016, 08:39 AM
Liked: 0
Thanks, Zcars!
I had already tried that, but unfortunatelly still did not work. Judging from your quote, I might have an issue with my old Sony AV Receiver which does not have an HDMI input. It receives the S/PDIF signal from an HDMI converter which probably only knows 2.1 SACD, although it delivers 5.1 pure audo BD.
Is there a 5.1 decoder for the SACD signal that you could suggest?
Thanks again!
post #101 of 106 Old 12-12-2016, 09:42 AM
Zcars's Avatar
Quoted: 168 Post(s)
Liked: 112
I'm not sure why the converter would treat a SACD signal differently from a BD, but this is beyond my technical knowledge. If your settings on the Yamaha are correct, then the issue may be of a general nature and you could ask in the audio theory section.
Zcars is offline
post #102 of 106 Old 12-14-2016, 05:35 AM
j.t.k.'s Avatar
Anybody had this happen?
I'm watching the show 11/22/63 on bd. I watched the first disc without issue, and then the first ep on disc 2, also without issue. When I went to continue watching, I turned on the player (disc was still in there), got the menu, but could not get the player to respond to any remote input besides "open" and "close". I turned it off and then on via front panel, and then the display read "FW CHECK" (note: no messages at all on tv screen). I left it at that for an hour while I watched something else, but after that nothing had changed (ie, open and close only). To turn it off I had to hold the power button.
This player has always been a bit unstable, but all of this is a first for me. Anything to do besides unplugging?
j.t.k. is offline
post #103 of 106 Old 12-14-2016, 06:16 AM
videobruce's Avatar
Quoted: 893 Post(s)
Liked: 345
Was there a F/W update done?
Recording free OTA TV for 'time shifting' has been here since 1975. Will there be DVR's to do the same when ATSC3 obsoletes existing DVR's??
videobruce is offline
post #104 of 106 Old 12-14-2016, 06:44 AM
j.t.k.'s Avatar
I don't think so. I checked a few months ago to see if there was an update and there wasn't, and now that it's discontinued, I don't think there will be any more.
Late edit: working fine this evening. So I guess just a glitch.
j.t.k. is offline
post #105 of 106 Old 05-01-2017, 10:40 AM
tvdrew's Avatar
Yeah . . . I had that last night (watching Homeland S5). I got a "continue from where you stopped" message (or something to that effect) but it wouldn't let me choose yes or no, or respond in any other way. Had to power cycle to get it to work. Same FW check message in display, but nothing in menu (which said it has latest firmware).
mickboy likes this.
tvdrew is offline
post #106 of 106 Old 04-26-2020, 01:32 AM
Liked: 0
Hi guys,
I've got my Yamaha BDS677 hooked up to a RXV581 via HDMI (Audioquest Pearl). I am playing a SACD with DSD multichannel sound, but it only reads PCM on the receivers display. Got the settings right (SACD HDMI bitrate & priority SACD multichannel). Am i doing something wrong, or is this normal that it reads PCM on the receivers display?
Also got a Yamaha Aventage series receiver + bd/SACD player and it properly reads DSD on the receivers display. That's why i am confused.
Any help is appreciated.
Mzeb is offline
Reply Blu-ray Players
oppo bdp-103
