Sony S1500/ S3500 / S4500 / S5500 / S6500 Blu-ray players - Page 21 - AVS Forum | Home Theater Discussions And Reviews
 1486Likes
post #601 of 2246 Old 06-22-2015, 11:10 AM
Alex F.'s Avatar
Quoted: 1031 Post(s)
Liked: 617
Owners of the 5500, 3500, or 1500: Can you confirm that your player has an IP Noise Reduction setting in the main menu under Screen Settings or in the Options menu while you are streaming?
Thank you!
Alex F. is offline
post #602 of 2246 Old 06-22-2015, 11:12 AM
UHD Addict
aaronwt's Avatar
Quoted: 9901 Post(s)
Liked: 6548
Originally Posted by Alex F. View Post
Thank you, Aaron.
I tried again today while streaming Netflix. As usual, while streaming, the Options menu will not open. It opens during disc playback only (during which, as expected, IP NR is not listed). Apparently my 5100 just does not have IP NR. I appreciate your help trying.
It doesn't show up when using Netflix. It will show up when streaming from Amazon. Not sure what other streaming apps it shows up with. I only tested it quickly with Netflix and then Amazon. I guess I should have mentioned in my post that I didn't see it with Netflix streaming.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #603 of 2246 Old 06-22-2015, 11:38 AM
Alex F.'s Avatar
Liked: 617
Thank you for checking it and providing an update. That explains it.
It does not make much sense to have IP NR and not be able to use it with the most popular streaming service.
I am glad the feature is now available while streaming Netflix with the 6500. I wish I knew if the non-Pro version of it is included in the 5500 and usable on Netflix before I purchase one.
Again, thank you.
Alex F. is offline
post #604 of 2246 Old 06-22-2015, 11:49 AM
mdavej's Avatar
Quoted: 3279 Post(s)
Liked: 1499
Netflix doesn't need IP NR, Youtube and other low bitrate videos do. If you have Netflix problems, then you need to look at your internet speed, not dubious NR band-aids.
mdavej is offline
post #605 of 2246 Old 06-22-2015, 12:07 PM
Quoted: 1142 Post(s)
Liked: 466
Again, thank you.
The marketing specs indicate that those models have it. The manual does not show it and no method to set it which could mean it's there but fixed. Sorry, not much help. The S6500 "manual" doesn't mention it either, but the specs show it(Pro version). Sony often has a disconnect between the product and the documentation.
JoeKustra is online now
post #606 of 2246 Old 06-22-2015, 01:10 PM
UHD Addict
aaronwt's Avatar
Liked: 6548
That makes no snese. It's available for Amazon streaming and Amazon has some 1080P content that is better than Netflix. ANd Ip Noise reduction Pro seemed to easily improve what I saw from Netflix 1080P streaming. At least when compared to TiVo Roamio and Roku3. All stream the highest 1080P encodes.
JoeKustra likes this.
aaronwt is offline
post #607 of 2246 Old 06-22-2015, 01:15 PM
mdavej's Avatar
Liked: 1499
Would it be possible to post any screenshots, just of Roku vs. Sony with IP NR Pro?
Problem is, no matter how hard I look, I don't see much noise to begin with. Sony says they have, "incorporated IP Content Noise Reduction Pro technology to improve the appearance of low-resolution clips streamed from the web." So, like I said, it isn't meant for Netflix. I have no idea why it would be available for Amazon even. Applying this to high resolution content with virtually no noise to begin with seems that it would detect detail as noise, hence reduce it, giving everything a possibly sharper, yet artificial, almost cartoonish look. That's why I'd love to see some examples. On all my previous Sony's it had an overall negative effect to my eyes.
mdavej is offline
post #608 of 2246 Old 06-22-2015, 01:21 PM
UHD Addict
aaronwt's Avatar
Liked: 6548
The noise isn't from streaming it's just from the source. i found the image was a little cleaner after the IP nOise Reduction Pro(at least I'm assuming that is why it looked cleaner from my S6500) and then once going through the Darbee Darblet it looked better since it had a slightly cleaner image to work with.
aaronwt is offline
post #609 of 2246 Old 06-22-2015, 02:01 PM
Alex F.'s Avatar
Liked: 617
Indeed, Sony's info is a mess. That is why I am hoping an owner of a 5500, 3500, or 1500 can check if their player actually offers IP NR when streaming Netflix.
Sony's website is so disorganized that the 6500's manual is not available in their support section (it has only a brief setup guide). But a link to the manual can be found on the 6500's main information page, here (see In the Box):
http://store.sony.com/3d-streaming-b...pfm%3Dcategory
The manual has info about IP NR Pro on page 30.
As for the 5500, the Sony USA manual does not include IP NR. But I just discovered the feature is in the Sony Europe manual on page 24:
http://download.sony-europe.com/pub/...4549800112.pdf
If the U.S. version of the 5500 has IP NR, the question remains whether it works on Netflix.
Alex F. is offline
post #610 of 2246 Old 06-22-2015, 05:14 PM
Alex F.'s Avatar
Liked: 617
Unless hands-on word to the contrary appears here, I will assume that the 5500's application of IP NR (if it has the feature) is the same as on the 5100. I learned today that my 5100 fails to provide IP NR on both Netflix and Hulu, my favorite streaming apps.
Sony Europe's user manual for the 5500 shows that IP NR is accessed via the Options menu, the same as I'm told here with the 5100. It is thus reasonable to conclude it likely works the same way on both players. The 6500 has its version, IP Content NR Pro, in the main menu instead, where it noticeably improved detail with no ill effects with Netflix and Hulu.
I really liked the superior picture quality via IP NR Pro. Thus, I will wait for the 6500 that will replace the glitch-ridden one that was returned to Best Buy. I pre-ordered a 6500 about 10 days ago from the good folks at Crutchfield. It is not listed yet on their website, but they are taking telephone orders for a guaranteed price of $129.99 with free shipping.
After having so many problems with my 6500, Crutchfield's generous 60-day refund policy is more reassuring than Best Buy's 15 days.
Thank you, Aaron and Joe, for your input.
Alex F. is offline
post #611 of 2246 Old 06-22-2015, 06:20 PM
steve1971's Avatar
Quoted: 567 Post(s)
Liked: 517
Well my wife ordered the S5500 for me this morning and it will ship tomorrow. Before I had her order it I checked out the online reviews and alot of them were very very positive so I had a choice between the 6500 and the 5500 and went with the 5500. My reason's are that both units are almost identicle in performance and appearance save for the 4K upscaling of the 6500 which I have no need for since 4K is not in my future plans. So its the 5500 and hopefully it arrives this weekend for my birthday.
steve1971 is offline
post #612 of 2246 Old 06-22-2015, 07:23 PM
aaranddeeman's Avatar
Quoted: 1874 Post(s)
Liked: 678
Congrats and Happy Birthday..
My 5500 arrives Wednesday from Dell..
It is replacing the PS3, so should better be good (in PQ)..
steve1971 likes this.
aaranddeeman is offline
post #613 of 2246 Old 06-23-2015, 01:07 PM
raymondeast's Avatar
Quoted: 14 Post(s)
can anyone test this for me..can the 6500 fast forward and rewind a blu ray movie perfectly from a external hard drive
raymondeast is offline
post #614 of 2246 Old 06-23-2015, 01:44 PM
greaser's Avatar
Quoted: 120 Post(s)
Liked: 78
Sony is soooo *DI S CON NE CT ED* that when i tried to register my S5500 on their website ~2wks.ago,they didn't even have the S5500 listed.
Got A message that Sony Reps.would try to determine if the S5500 was actually a Sony product!!
Had to register it by phone.
greaser is offline
post #615 of 2246 Old 06-23-2015, 03:40 PM
Zaim's Avatar
Quoted: 54 Post(s)
Could someone do a test with DTS-HD MKV Remuxes and let me know if you can Pause, forward, rewind etc?
Also does anyone know if this years model's passthrough TruHD via External hdd/network?
TV: Sony KD55XD9305, AV Receiver: Denon AVR-X4300H, Speakers/Sub: Tannoy Mercury V4i / v1i (Rear) + Tannoy Mercury VCi (Center), SVS PB-1000 (Sub), ELAC Dolby Atmos Speakers Front+Rear 4K Blu-ray: Sony UBP-X800
Zaim is offline
post #616 of 2246 Old 06-23-2015, 06:13 PM
Dreamliner's Avatar
Quoted: 1520 Post(s)
Liked: 805
Originally Posted by MidnightWatcher View Post
Great shots. Do you have Superman Returns on Blu-ray? If so, can do you comparison of the underwater shot around the 105-minute mark that displays heavy color banding? I'm curious to know if SBM on the 6500 will make a difference or not.
Can you double check the time stamps. I'll let you know.
Dreamliner is offline
post #617 of 2246 Old 06-23-2015, 07:34 PM
MidnightWatcher's Avatar
Quoted: 264 Post(s)
Liked: 262
There's a shot around 1:45:45 and another around 1:46:22.
MidnightWatcher is offline
post #618 of 2246 Old 06-23-2015, 09:09 PM
Dreamliner's Avatar
Liked: 805
Here you go. It really didn't do anything. There are slight "differences" at full resolution, but nothing worth mentioning. Not better, just different...SBM is a joke.
I also revised my earlier post to have the downloadable image file names in the correct order.
***This site really compresses the image, I HIGHLY recommend downloading full resolution images at the link below***
Full resolution download link here.
ID:	793010   Click image for larger version
ID:	793018   Click image for larger version
ID:	793026   Click image for larger version
ID:	793034   Click image for larger version
Spock1234 likes this.
post #619 of 2246 Old 06-24-2015, 12:04 PM
Quoted: 264 Post(s)
Liked: 262
Thanks Dreamliner. Yeah, looks like SBM doesn't do a heck of a lot, if anything. The S5500 is looking more appealing ...
post #620 of 2246 Old 06-24-2015, 12:47 PM
UHD Addict
aaronwt's Avatar
Liked: 6548
SBM is another one of the features I turn off. The dual core of the S6500 doe smake a difference, but that is with the loading of Java BDs. I have most definitely seen a difference with that. Although you are still only talking a second or three faster than my S5100. When there is a noticeable difference in speed.
aaronwt is offline
post #621 of 2246 Old 06-24-2015, 04:36 PM
Liked: 678
Mine arrived today. Did a quick check and looks okay. Weekend is gonna be busy..
for $48 (effectively), I don't have to complain. Hope it does not die on me suddenly..
post #622 of 2246 Old 06-24-2015, 07:37 PM
Dreamliner's Avatar
Liked: 805
I'm curious if anyone else has the vertical line on the left or right side? I have a vertical green line on the left side during loading screens, and you can see in the comparison pics from my earlier post that there is a slight image shift on the 5500...
post #623 of 2246 Old 06-25-2015, 01:50 PM
steve1971's Avatar
Quoted: 567 Post(s)
Liked: 517
My 5500 arrives this Saturday and I'm so looking forward to it. Cant wait to see for myself what this little player can do!
post #624 of 2246 Old 06-27-2015, 07:45 AM
chip387's Avatar
Liked: 77
Thank you!
Well, I have a new 6500 and it does not have it in settings or while I stream amazon. Options button does nothing while streaming. Just FYI
Chip
chip387 is offline
post #625 of 2246 Old 06-27-2015, 08:15 AM
Liked: 466
Chip
I wonder why they took IP Noise Reduction Pro away from your new S6500? I have it in my old S6500 under Setup/Screen Settings, just like my S6200.
post #626 of 2246 Old 06-27-2015, 12:09 PM
steve1971's Avatar
Quoted: 567 Post(s)
Liked: 517
I got my S5500 today and now I cant touch it because my loving wife who ordered it for me a week ago says I have to wait until tomorrow because its my birthday gift!!!! Oh the torcher this is now causing me!! LOL
post #627 of 2246 Old 06-27-2015, 12:22 PM
Liked: 678
Tell her like Christmas Eve, New Year's Eve, it's the BirthDay Eve and it's allowed..
post #628 of 2246 Old 06-27-2015, 12:51 PM
Alex F.'s Avatar
Liked: 617
Chip
Thank you, Chip, but I was asking about the Sony 5500, 3500, or 1500.
Your 6500 does have IP Content NR Pro, though. You'll find it in the main menu under Screen Settings. Scroll down near the end of the list and you will see it.
Give it a try, you might like the small but worthwhile improvement it makes to the picture while streaming. So far, I've preferred a setting of Film 2.
Alex F. is offline
post #629 of 2246 Old 06-27-2015, 12:57 PM
steve1971's Avatar
Quoted: 567 Post(s)
Liked: 517
LOL.......I will give that a try but I dont think it will work.
post #630 of 2246 Old 06-27-2015, 06:20 PM
jcsaleme's Avatar
Hello,
If money were not a problem (but it is) which blu-ray player should I buy? (I already have Darbee) S66000, S7200, Oppo, ???
Thank you
jcsaleme is offline
Reply Blu-ray Players
7.1 , bdp-s3500/5500 , bdp-s6500 , hdmi to s-video , pcm , S1500 , S4500 , sony bdp-s1500 , sony_bdp-s3500/5500 , sony_bd_player , Terminator 2 Judgment Day Skynet Edition Blu Ray
