Sony S1500/ S3500 / S4500 / S5500 / S6500 Blu-ray players - Page 75 - AVS Forum | Home Theater Discussions And Reviews
 1486Likes
post #2221 of 2246 Old 05-13-2018, 05:57 AM
Quoted: 138 Post(s)
Liked: 144
I had an update on my 6500 last night.
Flickpal is offline
post #2222 of 2246 Old 05-13-2018, 07:38 AM
andyross63's Avatar
Quoted: 366 Post(s)
Liked: 148
What version? Online, they show M26.R.0222 as the latest on the 6500. The M26 will vary with the model, it's the 0222 that is important. 0222 was released in February.
andyross63 is offline
post #2223 of 2246 Old 11-01-2018, 05:50 AM
Quoted: 1146 Post(s)
Liked: 468
Just noticed that as of 2/28/2019 there will no longer be Gracenote service for internet searches and titles.
JoeKustra is online now
post #2224 of 2246 Old 11-01-2018, 06:59 AM
Selden Ball's Avatar
Quoted: 4823 Post(s)
Liked: 2874
Yup
Gracenote once was owned by Sony. Now they're owned by Nielsen. Sony probably doesn't want to pay their license fees.
Selden
Selden Ball is offline
post #2225 of 2246 Old 03-06-2019, 08:22 PM
prsman's Avatar
Quoted: 221 Post(s)
Audio Decoding issue
Where is my audio decoding issue?
Setup: I play moves from a USB thumb drive over a USB interface on a Sony Blu-ray player BDP-S3500. It connects to the receiver by the coax digital input. The receiver is 12 year old 7.1 Pioneer VS-1016. The Bluray player a little newer but out of mfr. Most of the time I can only decode stereo with the Pioneer even though the USB video info shows 5.1 audio.
Is the issue with the older receiver, the Blueray player or the USB files? Any clues or some trouble shooting thoughts to help isolate? Thanks!
prsman is offline
post #2226 of 2246 Old 03-07-2019, 03:56 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 630
Coax digital can only carry 2-ch stereo PCM, DTS 5.1 or Dolby Digital 5.1. Nothing else. So, if your audio track is not DD or DTS 5.1, the player won't be able to send anything other than 2.0 over that connection. Also, make sure the settings for Digital Audio output is set to auto or bitstream, not PCM.
Foxbat121 is online now
post #2227 of 2246 Old 03-07-2019, 01:26 PM
prsman's Avatar
Quoted: 221 Post(s)
OK. Thanks. Ive tried 5 of 5 .mp4 files with 5.1 audio all only provide stereo. The audio file data when viewing its data shows its 5.1. Also I used VLC to look at the codecs and shows 5.1...see attached. So.............
For more insight into the issue Ive changed the setup as follows:
Coax from a brand new Sony Blueray UDP-X700 into the Pioneer VSX-1016TXV receiver.
Fiber audio from a brand new Sony TV X900F into the Pioneer.
When playing any of the five .mp4 files and when selecting either receiver audio input, TV (fiber) or the Bluray Player (coax), I only get stereo
Perhaps Im left with replacing the receiver? Does the receiver do the decoding?. If so, the Pionneer is 12 years old and maybe just doesnt have the decoding capability.
What do you think?
thanks!
prsman is offline
post #2228 of 2246 Old 03-07-2019, 01:28 PM
prsman's Avatar
Quoted: 221 Post(s)
What do you think?
thanks!
oh and I also played with the Blueray settings like you mentioned and still after many tests only getting stereo out of the receiver.
prsman is offline
post #2229 of 2246 Old 03-07-2019, 05:16 PM
prsman's Avatar
Quoted: 221 Post(s)
After trying several files it seems that the files encoded at .mp4 and with audio codecs AAC .mp4a are the ones that do not provide surround sound.
Either via the x900F Sony TV over the fiber or from the Sony Blueray x700 player over the coax.
I do get surround when I view a .avi or .mkv file both with A52 AC3 coding from both of the sources above.
Any thoughts?
prsman is offline
post #2230 of 2246 Old 03-08-2019, 03:28 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 630
AAC audio is not supported by any receivers and certainly won't pass coax or optical connection as they are neither DD nor DTS.
The only way to play these in 5.1 is for player to fully decide it and pass out 5.1 LPCM via HDMI to a HDMI receiver.
Sent from my Pixel 3 using Tapatalk
galonzo likes this.
post #2231 of 2246 Old 03-08-2019, 07:32 AM
prsman's Avatar
Quoted: 221 Post(s)
ahhhh. ok. thanks. So using a new receiver that takes hdmi audio from the x700 would probably work?
prsman is offline
post #2232 of 2246 Old 03-08-2019, 07:52 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 630
That depends if your player can fully decide AAC 5.1 or only decode 2.0 out of AAC 5.1 tracks.
post #2233 of 2246 Old 03-08-2019, 03:17 PM
prsman's Avatar
Quoted: 221 Post(s)
can i assume that a 2018 reciever in the $800 range would do that?
prsman is offline
post #2234 of 2246 Old 03-08-2019, 04:01 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 630
I don't know. AAC is not a commonly supported format via HDMI. You have to check the specific receiver spec sheet.
post #2235 of 2246 Old 03-08-2019, 05:56 PM
prsman's Avatar
Quoted: 221 Post(s)
ok. thanks for the insight!
prsman is offline
post #2236 of 2246 Old 04-01-2019, 01:33 PM
Liked: 468
I checked and found an update for my S6500. One item is the removal of Gracenote. The apps still say Gracenote is gone. Here's the web site:
https://www.sony.com/electronics/sup...loads/00015976
M26.R.0357
galonzo likes this.
post #2237 of 2246 Old 05-14-2019, 03:27 PM
Anode's Avatar
Quoted: 41 Post(s)
What is the officially and fully supported HDMI version of the BDP-S6500 ?
There is no mention of it in the specs or the manual and Sony is tight lipped about it, hard to get any info on it. I wonder why.
Sony X900F
Sony S6500
Marantz SR7007
KEF R500
Analog: Realistic Lab 420, Nakamichi CR-3A, Akai GX-635D
Anode is offline
post #2238 of 2246 Old 05-15-2019, 05:19 AM
Greg B.'s Avatar
The most recent software update on S6500 removed the MLB TV app, and I note that the MLB website no longer lists any Sony device as being supported. The list of usable and worthwhile streaming apps available for this device is now rather short, especially if you do not use Netflix.
galonzo likes this.
Greg B. is offline
post #2239 of 2246 Old 05-15-2019, 08:34 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 630
It won't be HDMI 2.0 for sure. HDMI 1.3/1.4 have been out for many many years now. Why would you care about whether Sony lists it out explicitly or not?
post #2240 of 2246 Old 05-15-2019, 10:35 AM
Anode's Avatar
Quoted: 41 Post(s)
Dont you think HDMI version is important for compatibility between devices ? Why would I buy something that I am not sure if it will get along well with other devices or not ?
For example, this whole question came up when I had an issue where my Marantz receiver would not display pixel bit depth when this blu ray player is set to 4:2:2 output. The audio video works but this issue raises the question if the two devices are working together properly or not. The pixel bit depth displays fine when the player is set to 4:4:4 or rgb. Obviously they are not talking to each other well enough. Marantz lists the supported hdmi version in their specs but sony does not (for this player), even after asking specifically, twice. That tells me they have something to hide in this matter.
Sony X900F
Sony S6500
Marantz SR7007
KEF R500
Anode is offline
post #2241 of 2246 Old 05-15-2019, 11:37 AM
galonzo's Avatar
Quoted: 1550 Post(s)
Liked: 2157
@Anode , this is a known issue with all D/M AVRs (i.e., when incoming chroma resolution is 4:2:2, bit depth isn't displayed correctly); I get the same thing with my Oppo as well as a Sammy UHD player.
Anode likes this.
Main: XBR-85X950H | X4500H (5.1.4) | UDP-203 | TiVo Bolt | 2019 Shield Pro | PS4 Pro | CCU
2nd: XBR-65X950G | LG LAS855M | UBD-K8500 | TiVo Mini | ATV (4thGen)
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K | Roku P+ (4630)
FS - Dr. Strangelove (1964) and other UHD Digital codes (and some HD codes)
galonzo is offline
post #2242 of 2246 Old 05-15-2019, 12:25 PM
Anode's Avatar
Quoted: 41 Post(s)
Thanks for the information. Hopefully D&M will fix this eventually.
galonzo likes this.
Sony X900F
Sony S6500
Marantz SR7007
KEF R500
Anode is offline
post #2243 of 2246 Old 05-15-2019, 08:17 PM
AVfile's Avatar
Quoted: 363 Post(s)
Liked: 182
Not as important as you would think. More often you are fighting HDMI cable limitations or implementation bugs in one device or the other.
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
post #2244 of 2246 Old 05-16-2019, 05:34 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 630
HDMI versions are not that important in this case. As I mentioned HDMI 1.3 or 1.4 (for 3D video) has been around for ages. But that doesn't mean all HDMI 1.3 /1.4 devices can work together flawlessly, far from it. Most issues are not related to HDMI versions at all.
post #2245 of 2246 Old 11-13-2019, 03:27 PM
Arizzo's Avatar
Liked: 0
SACD no sound over ARC
Did a search for this issue but couldn't find anything.
Samsung Q70
Denon 3313 AVR
Sony BD6500 Blu-ray.
Hooked up new TV and discovered I have to run audio through ARC because AVR will not pass newer protocol HDMI video to TV.
When I do this, the SACD layer of a SACD in the Sony will not play.  If I toggle to the CD layer, it works.  I have tried setting audio to PCM, DSD...nothing works.
Any suggestions? I like my Denon and don't feel like upgrading the AVR, although I know that's the cleanest solution.
THANKS!
Sent from my SM-G973U using Tapatalk
Arizzo is online now
post #2246 of 2246 Old 11-13-2019, 05:51 PM
mdavej's Avatar
Quoted: 3306 Post(s)
Liked: 1526
I would try digital coax direct from player to AVR. If you don't have a cable, RCA should work fine. On the Denon you can set the video source to HDMI and audio source to coax.
mdavej is offline
Reply Blu-ray Players
7.1 , bdp-s3500/5500 , bdp-s6500 , hdmi to s-video , pcm , S1500 , S4500 , sony bdp-s1500 , sony_bdp-s3500/5500 , sony_bd_player , Terminator 2 Judgment Day Skynet Edition Blu Ray
