Samsung UBD-K8500 4K HDR Ultra HD Blu-Ray Player- - Page 120 - AVS Forum | Home Theater Discussions And Reviews
 2635Likes
post #3571 of 4063 Old 02-28-2016, 07:03 AM
fjerina's Avatar
Quoted: 286 Post(s)
Liked: 71
First time I saw Best Buy advertising the Samsung 4K player. Guess it is getting a little mainstream. Unfortunately, not in my local store but you can order one on-line. I got my from Best Buy on-line. Now if we can get more 4K BluRays with top quality (4K source through 4K disc, with no resolution downgrading) I will really get excited.
I am glad to see our local Best Buy store in Albuquerque having a dedicated area for 4K discs in the store (next to the regular BluRay discs) and hopefully they will be quick to stock the new releases.
fjerina is offline
post #3572 of 4063 Old 02-28-2016, 08:27 AM
cmdrdredd's Avatar
Quoted: 4262 Post(s)
Liked: 4574
I ordered one online but checked the local store and they had one left so I grabbed it. Now I am heading to the other store that had more movies available. The player that I ordered online can't be cancelled yet as it is being prepped for shipping already so I'll just return it to the store.
ray0414 likes this.
LG 65" B7A OLED, Samsung 55" JS9000, Sony 43" x800e, Denon AVR-X2200w 5.1.2, PS4 Pro, Nintendo Switch, Gaming PC(GTX 1080ti + 4.7Ghz 8700k), Sony UBP-x800, Philips BDP-7501, Oppo BDP-203, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #3573 of 4063 Old 02-28-2016, 09:12 AM
Dan Hitchman's Avatar
Quoted: 4996 Post(s)
Liked: 3019
Originally Posted by gskinusa View Post
Thank you for providing the details. As I am replacing my Oppo wanted to make sure the files I have can be played by this player.
Also, I have a follow up question. I have Marantz AV8802A and will be getting this player. Now my projector is JVC 4810 which is a 1080p projector. I read somewhere that the UHD content in some cases will be downgraded and in some cases it may be unplayable as that is controlled by the studio releasing the content. Is there any verification done at least on the first part of playing UHD content and able to view it using a 1080p in the chain?
Thank you for your time.
It shows that the projector has HDMI 1.4a ports. I cannot state that this will work on all UHD discs going forward. Much depends on the AACS flags placed on the disc.
You may want to search for the HDFury and see if it can trick this HDMI 2.0a with HDCP 2.2 UHD player into believing you're plugging it into a compatible device. Though... you may end up having bandwidth issues due to the lower grade HDMI port on the projector.
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is offline
post #3574 of 4063 Old 02-28-2016, 09:30 AM
matrix123's Avatar
Quoted: 373 Post(s)
Liked: 142
Originally Posted by ajgale1975 View Post
Amazon has shipped my unit. Will be here Tuesday.
So what's been the consensus on settings? My TV is the JS8500
Player Settings
DC - Off
BD Wise - Off
Resolution - 2160
Sound - Bitstream
TV settings
UHD Color - On
Color Space - Native
Read to use USER in picture mode too. Also some are turning on dynamic contrast to medium. I haven't tried that yet.
matrix123 is offline
post #3575 of 4063 Old 02-28-2016, 10:05 AM
cmdrdredd's Avatar
Liked: 4574
I am finding setting the picture mode in the player to dynamic helps bring out the colors better. Though it is probably not technically correct.
ray0414 likes this.
post #3576 of 4063 Old 02-28-2016, 12:01 PM
ray0414's Avatar
Quoted: 12883 Post(s)
Liked: 12256
Same here. It bumps up contrast and color. U can tone it down on the user setting by putting contrast at +2 or 3, dynamic is probably in the 5-7 range. I'm liking it at 5 myself.
Seems to me that having more information on the disc allows you to play more with the settings whereas with a regular bd playing with settings hurts the picture much faster.
82Q90R*75Q9FN(RIP)*55C8OLED*Galaxy Note10+*Ub820 fed into Oppo 203*XB1X*4k DenonX4200
MASTER LIST OF HDR CONTENT THREAD HERE, UPDATED OFTEN
ray0414 is offline
post #3577 of 4063 Old 02-28-2016, 12:05 PM
cmdrdredd's Avatar
Liked: 4574
Have you adjusted any of the other settings in the user picture mode? Any comments on them?
post #3578 of 4063 Old 02-28-2016, 12:07 PM
gskinusa's Avatar
Quoted: 78 Post(s)
Liked: 32
Thank you for the reply. I guess until I change the projector to a 4k unit, as long as normal "red box" blu-rays work I should be good. Let us see.
-Sen
gskinusa is offline
post #3579 of 4063 Old 02-28-2016, 12:11 PM
ray0414's Avatar
Liked: 12256
I bumped up color a couple notches.
My mind keeps wandering and fantasizing about what an oppo with darbee would do with these discs
I think darbee would help out the 2k discs. Overall though I'm pleased with the upgrade over blu ray with both.
ThePrisoner likes this.
ray0414 is offline
post #3580 of 4063 Old 02-28-2016, 01:06 PM
NoBodyH0mE's Avatar
Quoted: 41 Post(s)
Liked: 26
Originally Posted by Darkknightman View Post
Alright guys what am I missing here. I see no difference between the 4k and the regular blu ray. I have a sony 900a with a oppo 103d and the new samsung 4k player. The first set of pictures is 1080 and the second is 4k. To me theres a little bit more detail in the 1080p set. Look at the squares of the solar panels. Do you guys have any suggestions?
That tv is not capable of playing 4K UHD movie because it doesn't have HDPC 2.2. I believe the next model 900b has it.
NoBodyH0mE is offline
post #3581 of 4063 Old 02-28-2016, 01:18 PM
Quoted: 566 Post(s)
Liked: 106
Wrong, I have also have a Sony xbr 900a and there is one port that supports hdcp 2.2
I also have a lg 79inch UB9800 uhd 4k
That being said I've watched the maze runner scorch trails on the Samsung 4k player, and not much difference between that and the blue-ray
ultraflexed is offline
post #3582 of 4063 Old 02-28-2016, 01:23 PM
cmdrdredd's Avatar
Liked: 4574
You probably aren't watching HDR right? That's the biggest benefit IMO.
post #3583 of 4063 Old 02-28-2016, 02:34 PM
jnnt29's Avatar
Quoted: 164 Post(s)
Liked: 157
Originally Posted by thrang View Post
For those near the Best Buy in west nyack ny, as of yesterday afternoon their inventory system showed two in stock there. I was able to buy the last one in one Paramus NJ store, and put a hold on a second unit for a fellow member at the other Paramus store, so we each got one yesterday and didn't have to take the drive up to the palisades mall...
Thanks for the info, I picked one up in the East Hanover store. So far the picture is great with my 65JS8500.
My set up: Samsung UN82nu8000 LED TV, Marantz SR7012, Emotiva XPA3, Sony UBP-X800
Roku 4k Premier, Panamax MR4000, 2 Marantz MA-500U, Klipsch KLF10 (L/R),
RC62II (center), R-1650-W (surrounds), RB81II (Rear Surrounds),
Monoprice 6.5" in ceiling speaker (top front/rear), Two Klipsch R-10SW subwoofer
https://www.avsforum.com/forum/show....php?t=1227096
jnnt29 is offline
post #3584 of 4063 Old 02-28-2016, 03:19 PM
jeep05's Avatar
Quoted: 260 Post(s)
Liked: 259
Since there is very little info floating around on my particular Sharp TV, I have asked this question in a couple threads in hopes of getting a more defined answer even though Sharp Support has vaguely answered.
My K8500 won't be delivered until Tues. Mar. 1 and ahead if that i'm trying to learn as much about it as I can. I will be running it straight to a Sharp LC-60UE30 4K with no HDR. Even without this, I elected to get the 8500 anyway and possibly an HDR capable TV later. Here's my question.............
All four inputs on the Sharp are 2.0/2.2 and I believe it is a 10-bit panel without HDR. On these four inputs there is a setting for "FULL" or "LIMITED". The owners manual states: Set to "FULL" when an HDMI 4K 60p 4:4:4 device is connected and "LIMITED" when an HDMI 4K 24p 4:2:0 device is connected. To further clarify this, I contacted Sharp and they said to always use "FULL" for the best 4K experience. What setting do any of you guys suggest I use on the port that I connect the K8500 to, Full or Limited?
jeep05 is offline
post #3585 of 4063 Old 02-28-2016, 03:26 PM
ray0414's Avatar
Liked: 12256
Time to throw a big wrench in everyone's viewing experience.
We've discovered that turning RBG enhanced on the player makes a big impact on picture quality!
Still experimenting, but so far:
Brighter
More vibrant colors
Less black crush
For those with bad black crush, this setting opened up my hdmi black level setting on mt tv, which if adjusted can fix crush.
ThePrisoner and StanGeek like this.
ray0414 is offline
post #3586 of 4063 Old 02-28-2016, 03:46 PM
ThePrisoner's Avatar
Quoted: 346 Post(s)
Liked: 251
Brighter
More vibrant colors
Less black crush
Will check that out! I almost set-up a date today for my calibration of my JS8500 but I'm currently enjoying experimenting with all these options!
I assume UHD Color Off? Correct?
ThePrisoner is offline
post #3587 of 4063 Old 02-28-2016, 03:57 PM
cmdrdredd's Avatar
Liked: 4574
I use UHD color on and auto color on the player with the same result as setting the player to rgb enhanced and UHD color off.
post #3588 of 4063 Old 02-28-2016, 04:14 PM
ray0414's Avatar
Liked: 12256
The Difference is that with uhd color off, turning on RBG enhanced causes highlight blowout, so it's not the same.
ray0414 is offline
post #3589 of 4063 Old 02-28-2016, 04:41 PM
Musician's Avatar
Quoted: 2726 Post(s)
Liked: 5667
Brighter
More vibrant colors
Less black crush
Ray, ray, ray... you are only going to confuse people even more. It's spelled RGB, lol.
tbrown187 likes this.
Samsung UN78HU9000 & SEK-3500U/ZA - Firmware 1550.0
Samsung UN40HU7000 & SEK-3500U/ZA - Firmware 1550.0
Samsung UBD-K8500 UHD Blu-ray Player; Apple TV 4K; Acer 4K HTPC
Arris VIP5662W UHD Whole Home DVR; Chromecast Ultra
Marantz SR7005 Receiver; Magnepan Speakers; Martin Logan Subwoofer
Musician is offline
post #3590 of 4063 Old 02-28-2016, 04:53 PM
Quoted: 346 Post(s)
Liked: 251
Try RGB Enhanced with UHD Color On. I'm preferring that at the moment.
post #3591 of 4063 Old 02-28-2016, 04:57 PM
CCsoftball7's Avatar
Quoted: 1704 Post(s)
Liked: 1304
From reading all the Samsung comments, I really am glad I bought the Sony. I leave the K8500 at default, pop in a disc and watch.
aaronwt and tbrown187 like this.
Sony XBR75X940C & XBR65A1E Samsung UBD K8500
My Recommended Daytime Settings Apps(Video), My Recommended Daytime Settings Apps, My non-HDR and HDR Settings, Setting HDMI to show no overscan
Sony XBR75X940C, Samsung UBD K8500, Roku Ultra, DirecTV RVU and C61K, Chromecast Ultra
CCsoftball7 is offline
post #3592 of 4063 Old 02-28-2016, 05:16 PM
cmdrdredd's Avatar
Liked: 4574
It's the same to my eyes once you set the correct HDMI black level for it. Auto defaults to low which crushes the blacks for me.
post #3593 of 4063 Old 02-28-2016, 05:20 PM
fatboypup's Avatar
Quoted: 77 Post(s)
Liked: 85
Ive been using it like that looks better to me
Sent from my SM-N920P using Tapatalk
fatboypup is offline
post #3594 of 4063 Old 02-28-2016, 05:45 PM
drock2k1's Avatar
Quoted: 95 Post(s)
Liked: 35
So is it time for a K8500 calibration thread?
buist likes this.
drock2k1 is offline
post #3595 of 4063 Old 02-28-2016, 05:47 PM
cmdrdredd's Avatar
Liked: 4574
I think it's just a matter of finding what combination removes the black crush so many people have been seeing.
post #3596 of 4063 Old 02-28-2016, 06:05 PM
OzHDHT's Avatar
Quoted: 1317 Post(s)
Liked: 818
Originally Posted by Tiktokape View Post
Dear k8500 users, 1) is the player in 110v voltage and 2) it is provided with IEC inlet or figure 8 inlet? Will be good if anyone of you can post picture of the power inlet. Thanks!
Both of these could be answered from very simple search here in this thread or in case of question 2 googling it. Given it's 110v as we know, what benefit does knowing it's got a figure 8 power cable make seeing as that there's one type of 110v plug??
OzHDHT is offline
post #3597 of 4063 Old 02-28-2016, 06:10 PM
Tiktokape's Avatar
Liked: 1
Originally Posted by OzHDHT View Post
Both of these could be answered from very simple search here in this thread or in case of #2 googling it. Given it's110v as we know, what benefit does knowing it's got a figure 8 power cable make seeing as that there's one type of 110v plug??
I'm based in Singapore, wants to import this player back to my country, which is in 230/240v. Anyway I found my answers elsewhere.
Tiktokape is online now
post #3598 of 4063 Old 02-28-2016, 06:29 PM
priuscat's Avatar
Quoted: 395 Post(s)
Liked: 176
It's kinda difficult to discern the difference when the Jpeg's you're showing us is max resolution of 1200 x 1200 pixels
Musician likes this.
UN65JS8500FXZA and UBD-K8500/ZA
Slim Port Nano Console
UHD Content CY-SUC05SF/ZA WD Western Digital My Passport Cinema
UHD Video Pack CY-SUC10SH1/ZA Tivo Bolt Roku 4
Sennheiser RS175 Digital Wireless Headphone System
Etekcity 4K x 2K 4 Port High-Speed HDMI Switch 4 Port USB 3.0 Hub
priuscat is offline
post #3599 of 4063 Old 02-28-2016, 07:07 PM
OzHDHT's Avatar
Liked: 818
Yep and same applies for guys like me based in Australia and waiting on my order from B&H. Still a moot point knowing the power connector is figure 8 when we know its 110v, unless you enjoy blowing up equipment on 230v - I'd call it a 'cart before the horse' kinda question that as know didn't need to asked again !
OzHDHT is offline
post #3600 of 4063 Old 02-28-2016, 07:14 PM
Tiktokape's Avatar
Liked: 1
Well, this dude has proved it otherwise. https://www.avsforum.com/forum/149-bl...l#post41975745
Closed Thread Blu-ray Players
ces 2016 , Samsung , UBD-K8500 , ultra hd blu-ray
