Panasonic DMP-UB900 thread. - Page 110 - AVS Forum | Home Theater Discussions And Reviews
 5306Likes
post #3271 of 4761 Old 04-02-2017, 10:15 AM
Stanton's Avatar
Quoted: 1764 Post(s)
Liked: 893
Originally Posted by JimmyC_NZ View Post
If I may solve my own problem, it was the cable. I plugged in the short cable supplied with the player directly into the projector and we have a very nice looking picture...
And you picked up an extra post!
Seriously, I think 50% of the problems with this player are cable related, and the other 50% are settings related. Obviously, there have been a few hardware failures--but nothing like some of the other UHD players. Overall, this player is pretty solid.
Enjoy!
Yamaha RX-A2050 AVR [v1.81], LG 65EF9500 4K OLED [v4.25.70]
5.0.2 set-up: (4) Polk Monitor 10B's, (2) Polk Monitor 4's, Polk CS300 center
B&O TX2 Turntable, Nakamichi Cassette Deck 1
Pioneer CLD-99 LD, Panasonic DMP-UB900 UHD [v1.80]
Stanton is offline
post #3272 of 4761 Old 04-06-2017, 11:08 AM
Mark Booth's Avatar
Quoted: 126 Post(s)
Liked: 98
Later today, I will be connecting a new UB900 to my Vizio M75-C1 4K TV and new Pioneer SC-LX801 receiver. My original plan was to connect the UB900's main HDMI output to the receiver and then the receiver to HDMI port #5 on the Vizio TV. Port #5 on the Vizio is [email protected] 4:2:2. However, I think I've read that non 4K playback should go through a different port. The Vizio's HDMI ports 1 & 2 are [email protected] (not sure if they are also 4:2:2).
I purchased the receiver specifically to get a 4K compatible model. But now I'm thinking that I should run an HDMI cable directly from the UB900 to the Vizio's HDMI #5 ([email protected] 4:2:2) and run a second cable from the UB900 to the receiver.
I'm sure the answers are in this very long thread. I've done a bit of searching and can't find it immediately. If someone could throw me a bone, it would be appreciated...
Will my new Pioneer SC-LX801 do all of the necessary upscaling/conversion so that I can run EVERYTHING through the receiver and then to HDMI #5 ([email protected] 4:2:2) on the Vizio? I'll also have three standard HD sources (HD DVD player, Mac mini home theater PC, and Channel Master OTA DVR) connected to the receiver. Will all of that play okay through the receiver to HDMI #5 on the TV?
It would be better for me if I can put ALL sources through the receiver. On movie nights in the Booth Bijou Garage Theater, I used the same equipment. I simply connect the HDMI output of the A/V receiver to the projector in the garage. If I have to run a separate HDMI cable from the UB900 then it will defeat my ability to easily switch sources in the garage.
If running HD DVD, Mac mini, and Channel Master DVR through the receiver to the [email protected] port on the TV is a bad idea, then now much 4K Blu-ray quality will I lose if I simply use one of the TV's [email protected] ports?
Man, this stuff is very confusing!
Mark
Mark Booth is offline
post #3273 of 4761 Old 04-06-2017, 11:56 AM
Stanton's Avatar
Liked: 893
You only get (1) video signal out of the UB900, so you should go to the AVR and let it scale as necessary...especially if you're going to be using the second output for a PJ. The caveat here is:
  • I don't know the scaling capabilities of your AVR
  • I don't know the limitations of the other TV ports
Theoretically, the HDMI signal chain/ports should handshake to the maximum capabilities of the link; alternatively, you could always "force" the AVR to scale to a certain resolution (I know my can...but my TV is UHD compatible on all ports).
Stanton is offline
post #3274 of 4761 Old 04-08-2017, 04:57 AM
Liked: 0
audio dropping out on random movies
Hopefully someone can help point me in the right direction in correcting this annoying problem - I am only assuming it is the Panasonic player and not the TV? A couple Blu-ray movies - Rogue One and Zargoz come to mind immediately have had the audio drop out. Going back to the spot where it dropped and resuming sometimes corrects the issue, sometime I have to "rewind" more than once to get the audio to work. Then no other drop outs in the movie. My setup is simple Panasonic DMP-UB900 and an LG OLED65B6P. HDMI 4K capable cable interconnect. Both pieces have most recent firmware. Bad disks? Something else? Any help would be appreciated. Thanks
Suribachi is offline
post #3275 of 4761 Old 04-08-2017, 06:40 AM
skypop's Avatar
Quoted: 366 Post(s)
Liked: 251
Never happened on mine,I would return the disc for a new one,if it happens again maybe player issues.
2 Channel: Fi 2A3 mono's,Hovland HP100,Technics SP10MK2/SME/Benz....HT:126" Seymour AT Screen,JBL Studio 590's for LCR, Side and Rear Surrounds. Jbl SCS8'S for Fr Heights, and Rear Heights,2 Epik Empire Subs,2 Behringer B1200D Midbass Subs,Marantz 7702MK2,Proceed Amp-5,Outlaw 7125,Panasonic UB820 ,Toshiba HD35,JVC RS600. Black Velvet.
skypop is offline
post #3276 of 4761 Old 04-08-2017, 03:31 PM
Quoted: 50 Post(s)
Liked: 34
Originally Posted by groberg View Post
Has anyone gotten the Sing UHD disk to play?
I see the Universal Logo, the TV says UHD, then the splash screen displays something Like "This disk will play best on a 4K TV"
No issues on the Australian release, though they likely all come out of the same plant. Maybe just a bad disc.
andyaustralia is offline
post #3277 of 4761 Old 04-08-2017, 05:11 PM
rick900's Avatar
Quoted: 78 Post(s)
UB900 excellent player picture quality is slightly better on UHD Bluray than oppo-203 and cheaper
rick900 is offline
post #3278 of 4761 Old 04-12-2017, 05:38 PM
aristokratika's Avatar
Panny and DTS 7.1
Panny connected with HDMI WireLogic cables to Dennon 7200WA to Sammy 85 inch 7100. Latest firmware everywhere. Having a problem - I do not see Panny outputting 7.1 only 5.1 on Arrival 4K and some other blu-rays. I think it is the issue of handshake between Panny and Denon. Interstellar stops on chapter where main character arrive to his daughters' Principal office in the school. I went to BestBuy and played my disc in their Panny (with much older firmware) - same hiccup. Anybody see something similar ?
aristokratika is offline
post #3279 of 4761 Old 04-12-2017, 08:26 PM
HTPCat's Avatar
Quoted: 782 Post(s)
Liked: 490
Are you seeing 7.1 on any disc? Have you made sure of your audio settings in panny and Denon are set properly to receive 7.1?
Sent from my SM-N910P using Tapatalk
HTPCat
"I have a need to feed the hole with more Audio & Video toys"
HTPCat is offline
post #3280 of 4761 Old 04-12-2017, 10:19 PM
alebonau's Avatar
Quoted: 1812 Post(s)
Liked: 1234
a new firmware update for the pana v1.73 to upgrade from the last which was 1.69
not sure what the update is all about... but i will not question...
"Technology is a drug. We can't get enough of it."
Welcome to my lounge room :)
alebonau is offline
post #3281 of 4761 Old 04-12-2017, 10:41 PM
Quoted: 32 Post(s)
Liked: 3
13/Apr/2017
Ver 1.73
HEVC MKV/TS file playback support (Information)
HDR picture adjustment support (Information)
Network service compatibility
Playability of Blu-ray Disc™ and DVD Disc
Anyone confirm that 10 bit support is now available?
HD2k15 is offline
post #3282 of 4761 Old 04-12-2017, 11:46 PM
Manuxs1806's Avatar
Quoted: 308 Post(s)
Liked: 130
New 1.73 update available , with 10 bits HDR support
Manuxs1806 is online now
post #3283 of 4761 Old 04-13-2017, 12:02 AM
hasta666's Avatar
Quoted: 461 Post(s)
Liked: 152
Could you be more specific? 10-bit HDR support is a bit vague.
hasta666 is offline
post #3284 of 4761 Old 04-13-2017, 12:16 AM
Manuxs1806's Avatar
Quoted: 308 Post(s)
Liked: 130
There was an option many asked for a long time : the possibility to display UHD movies in 10 bits instead of 12 bits. This is supposed to help those who have color banding.
alebonau likes this.
post #3285 of 4761 Old 04-13-2017, 12:31 AM
hasta666's Avatar
Quoted: 461 Post(s)
Liked: 152
hasta666 is offline
post #3286 of 4761 Old 04-13-2017, 12:41 AM
alebonau's Avatar
Liked: 1234
now have to find that options
alebonau is offline
post #3287 of 4761 Old 04-13-2017, 12:53 AM
Manuxs1806's Avatar
Quoted: 308 Post(s)
Liked: 130
In video output setting
Very self explanatory
post #3288 of 4761 Old 04-13-2017, 05:12 AM
alebonau's Avatar
Liked: 1234
I notice the Auto(10bit Priority) option and with explanation between both
this is very smart in my opinion as I know the oppo was having banding issues on auto and because of the chroma upsampling. this pana option still gives an auto option but can allow pegging to 12 or 10 bit which his native for UHD
Stanton and chunon like this.
alebonau is offline
post #3289 of 4761 Old 04-13-2017, 02:00 PM
healthnut's Avatar
Quoted: 924 Post(s)
Liked: 910
New update just became available, I'm not sure what it brings to the table...
healthnut is offline
post #3290 of 4761 Old 04-13-2017, 02:01 PM
chunon's Avatar
Quoted: 3785 Post(s)
Liked: 3615
look up
dannybee likes this.
LG 77C8
LG 55B7A
DirectTV/ ATV4k/Panasonic UB820/Sony Z9F Soundbar
Calman Enthusiast, Lightspace, C6 HDR 2000 I1Pro2
chunon is online now
post #3291 of 4761 Old 04-13-2017, 02:07 PM
thrang's Avatar
Quoted: 2506 Post(s)
Liked: 2034
Originally Posted by HD2k15 View Post
13/Apr/2017
Ver 1.73
What do they mean by network service support? IP control?
UPDATED 4/29/17 Thrang's Home Theater (for now...)
Sony VPL-VW5000es • Panamorph Paladin DCR • Trinnov Altitude 16 • Crown DCIn amplifiers • JBL M2 (LCR-LW-RW) • JBL S2S-EX subwoofers x2 • JBL SCL-4 (side/rear surrounds) • JBL SCS12 (x4) SCS8 (x2) TH/RH/TM • Lumagen Radiance Pro • Panasonic UB820 • Apple TV 4k • Synology RAID (45 TB total storage) • RTI control system
thrang is offline
post #3292 of 4761 Old 04-13-2017, 03:46 PM
Dave Harper's Avatar
Quoted: 3159 Post(s)
Liked: 1723
I wonder if this will also help with playing Billy Lynn's Long halftime walk at 60p 10 bit for those that have lesser cables that crap out at 12 bit like I think mine is doing to my JVC RS600.
I say that because the exact same set up was used when I had my Sony VW675 in place of the JVC and I had no issues at all. I think that was due to the 10 bit EDID limit on 60p rates on the Sony, so the ub900 never tried sending 12 bit.
Dave Harper is offline
post #3293 of 4761 Old 04-13-2017, 05:56 PM
1.73 Firmware fixes sound issues!
Just loaded new Firmware 1.73. BINGO! All sound modes work correctly 7.1 Dolby True HD, DTS Master, ATMOS. Kudos to Panny for "being on top of things"! As a perk 12 bit and 10 bit processing. I still see a bit of "sky banding" in 10 bit mode as my Sammy is a 8 bit panel. I guess I can live with it - it is not too bad! Thanks everybody who tried to help!
Panny DMP-UB900, Dennon AVR-X7200WA, Sammy 85UN7100, Multiple Bose speakers, Panamax M5400-PM, WireLogic HDMI cables.
post #3294 of 4761 Old 04-13-2017, 10:03 PM
Manuxs1806's Avatar
Quoted: 308 Post(s)
Liked: 130
Really ??
post #3295 of 4761 Old 04-13-2017, 11:45 PM
Nima's Avatar
Quoted: 231 Post(s)
Liked: 135
Could someone please try out 1080p and 4K mkv/m2ts support? Does it work in 24hz?
TIA
N.
Nima is online now
post #3296 of 4761 Old 04-14-2017, 06:32 AM
Iamjcl's Avatar
Quoted: 501 Post(s)
Liked: 106
TIA
N.
Glad they fixed a few issues it seems (none of which I had) - still no Vudu though, for any that are interested in that.
Iamjcl is offline
post #3297 of 4761 Old 04-14-2017, 08:07 AM
Ken Ross's Avatar
Quoted: 7281 Post(s)
Liked: 8052
I'm looking at this player and I'm wondering if any of you guys have ever used the SD card reader for playing 4K files from a 4K camera. That would be a great bonus for me as none of the other UHD BluRay players have this ability. But the fact that it has a card reader doesn't guarantee that it will play 4K files well.
Ken Ross is offline
post #3298 of 4761 Old 04-14-2017, 12:13 PM
Evan201's Avatar
Quoted: 276 Post(s)
Liked: 188
How does the new HDR brightness adjustment look in the new firmware update? Wondering if it will help with dim looking HDR on my Epson 5040ub projector. Could someone with a projector post a video of how that new function looks on a dark UHD disc like Revenant or Batman V. Superman?
CURRENT SETUP:
Sony X940E / Denon AVR-S730h /
NVIDIA SHIELD TV 2017 / PANASONIC UB820 UHD PLAYER / MAudio BX8a front mains / Klipsch R‑15PM rear left/right / Emotiva C1 center / Polk Audio OWM3 height left/right.
Evan201 is offline
post #3299 of 4761 Old 04-14-2017, 04:40 PM
Stanton's Avatar
Liked: 893
The HDR adjustment is great! I tried it on the only UHD movie that was really too dim for me: Star Trek Beyond. I put it half way to max (+6) and it looks great; now I can change back-and-forth between "standard" and "Set 1" if I have a "dark" disc. I also changed the video output mode to 10 bit (instead of 12 bit) and checked the only movie I saw any banding on (The Martian) and it looks great.
This player rocks! It's nice to see a flagship player treated like a...flagship player.
wxman, chunon, healthnut and 1 others like this.
Stanton is offline
post #3300 of 4761 Old 04-14-2017, 05:26 PM
hnupe's Avatar
Quoted: 69 Post(s)
Silly questions, with the new option should I now set it to 10 bit? Does 4K movies look better in 10 bit? With the new update...can someone please explain the best setting to maximize a great picture? I have a 5040UB Epson projector.
hnupe is offline
Reply Blu-ray Players
4k player hdmi input , 900 , DMP-UB900 , trying to get atmos engaged.
