Panasonic DMP-UB900 thread. - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 5306Likes
post #901 of 4784 Old 08-13-2016, 04:58 PM
timc1475's Avatar
Quoted: 952 Post(s)
Liked: 813
Originally Posted by gadgtfreek View Post
yeah, its a cluster. Im liking the xbone S so far, since it does so many other things, but I still have to decide on Panny or PS4 Neo.
I am also conflicted between the UB900 vs PS4k. It appears the PS4K will be less expensive by 200 buks AFAIK. PS4K is slated to be released soon by October - November.
Per the below product link it shows the USB choice is 2.0. Really? Brand new with USB 3.o tech available and they chose 2.0?? SMH
IMHO 3.0 is needed for optimum 4k HDR transfer rate.
Link: http://shop.panasonic.com/audio-and-...DMP-UB900.html
If you always do what you always did, you'll always get what you always got.
timc1475 is offline
post #902 of 4784 Old 08-14-2016, 01:53 AM
SeeMoreDigital's Avatar
Quoted: 1104 Post(s)
Liked: 932
Nah... USB3.0 is a waste of time on any media playback device. As technically USB2.0 is able to offer data transfer speeds as high as 480 Mbps.
The new 100GB UHD disc's have a maximum data rate of 128 Mbps regardless of the frame-rate the video has been encoded at. Primarily because the UHD disc's can't currently spin any faster than this reliably - Which means this is well within the technical limit of USB2.0...
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 1No Audiolab 6000A, 3No Audiolab M-PWR | SPEAKERS: 2No KEF 103.2, 6No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: Synology DS212+
SeeMoreDigital is offline
post #903 of 4784 Old 08-14-2016, 04:02 AM
mt14942's Avatar
Quoted: 845 Post(s)
Liked: 241
Originally Posted by WOLVERNOLE View Post
Can you comment on the audio quality? How does it compare to other decks you have had in the past? Thanks !
I am also interested in the audio quality when using the analog outputs and also the separate two channel analog outputs, since I play a lot of cd's.
WOLVERNOLE and Panson like this.
Sony A9G
Oppo UDP-205 4k Universal Player
Classe SSP-800 Pre/Pro
Parasound Halo 5 Channel Amp
mt14942 is offline
post #904 of 4784 Old 08-14-2016, 09:44 AM
magicvinny's Avatar
Quoted: 119 Post(s)
Panasonic will be coming with a cheaper version. In Europe it will be called the DMP-UB700.
The difference with the 900 would be no analog outputs and no THX certification, price 499€.
aaronwt likes this.
magicvinny is offline
post #905 of 4784 Old 08-14-2016, 10:12 AM
Liked: 932
wrong device!
post #906 of 4784 Old 08-14-2016, 02:52 PM
aaranddeeman's Avatar
Quoted: 1874 Post(s)
Liked: 678
Link? Source? Details?
Edit: Ok found something.
aaronwt likes this.
aaranddeeman is offline
post #907 of 4784 Old 08-15-2016, 12:48 AM
Bandyka's Avatar
Quoted: 2399 Post(s)
Liked: 1474
I will be testing this with electrostatic headphones shortly. That will be revealing.
WOLVERNOLE likes this.
JVC RS620/X9500 in bat cave Anthem MRX-720 + 3xpower amps = 7.1.4, Martin Logan Motion 60XT fronts, ML FX rears, ML Motion 50XT centre, 4 x ML Motion 2 on ceiling Atmos, ML Balanced force 210 as the beast. Panasonic UB900, STAX-3170 earspeakers, HTPC, PS4, PS3, Amiga 500 etc..Epson LS10000 calibration and WCG SDR settings: https://www.avsforum.com/forum/24-dig...l#post50298297
Bandyka is offline
post #908 of 4784 Old 08-15-2016, 05:53 AM
Bandyka's Avatar
Liked: 1474
OK so done some critical listening using these:
https://www.turramusic.com.au/pages/...aspx?CIID=5632
Thing to know about these cans is that they reveal any flaw in the source and are some of the cleanest sounding electrostats out there.
Used some pure audio 96Khz bluray and various lossless 192Khz files and CD.
Well all I can say is its definitely no false advertising or hype, this thing does deliver the goods. Its clean, natural sounding and delivers the full dynamics. I especially love the way it can mimic a Tube amp if you turn that option on. The sound is very spacious and dynamic just as it should be.
I did not notice much of a difference using the High Clarity sound option which turns the video off to send the cleanest sound only.
There is no noise whatsoever from this source. These headphones pick up the current flowing through the power supply of the HTPC if I crank them up high but no noise here.
I found myself turning the screen off and settling into a listening session, this had not happened in a while.
This thing really delivers when it comes to audio as well as video.
One very happy user here
Hope this helps some of you guys.
RonF and Polarcircle like this.
Bandyka is offline
post #909 of 4784 Old 08-15-2016, 06:36 AM
mt14942's Avatar
Quoted: 845 Post(s)
Liked: 241
Thanks Bandyka, I was hoping that this player would be a decent cd player and it sounds like it's more than decent. I have the Samsung 8500 4K player and have had no issues with it, and will probably move it to the master bedroom.
Bandyka likes this.
Sony A9G
mt14942 is offline
post #910 of 4784 Old 08-15-2016, 06:45 AM
mt14942's Avatar
Quoted: 845 Post(s)
Liked: 241
Did you use the separate 2-channel analog outputs for your testing?
Sony A9G
mt14942 is offline
post #911 of 4784 Old 08-15-2016, 06:41 PM
JKR1963's Avatar
Quoted: 346 Post(s)
Liked: 155
I broke down and ordered this unit and will have it on Wednesday from BB Canada. I will get them to match and beat Trutone and get it for $780 CAN. I have the Yamaha 3050 which I got last week for a very incredible price, but do not have a 4K display yet. Still deciding what to get and may just go with a projector (JVC X550). In the meantime, I will play The Martian in Atmos from the 4K disc to my Panasonic 65ST60 ..... so it will be a downrezed version of an up-scaled 2K source......but Atmos. I will have to see what that looks like .... hard to stay out of 4K ...... but the hardest part is finding a display that I can tolerate at a price that is affordable (I want to see the new Sony 75").
cdnscg and Bandyka like this.
JKR1963 is offline
post #912 of 4784 Old 08-15-2016, 07:18 PM
Dan Hitchman's Avatar
Quoted: 4906 Post(s)
Liked: 2915
Not exactly. The Martian and its Extended Cut received newer 4k masters from the raw 6k and 4k digital camera source files with 2k SFX upscaled to 4k and re-comped. It's mostly a 4k disc rather than purely a 2k upconvert. This was done specifically for HDR archival and UHD Blu-ray home video purposes.
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is online now
post #913 of 4784 Old 08-15-2016, 08:35 PM
Bandyka's Avatar
Liked: 1474
No worries, even if you don't have issues with the Samsung the features and quality set them way apart. Not a single thought of regret here even given the high price tag.
Bandyka is offline
post #914 of 4784 Old 08-15-2016, 08:36 PM
Bandyka's Avatar
Liked: 1474
Sure did.
Polarcircle likes this.
Bandyka is offline
post #915 of 4784 Old 08-15-2016, 08:39 PM
Bandyka's Avatar
Liked: 1474
The beauty of the Panny is that it will perfectly match your display and even has settings to make SDR HDR like but of course you want native HDR 4K with it it really.
Bandyka is offline
post #916 of 4784 Old 08-15-2016, 08:41 PM
Bandyka's Avatar
Liked: 1474
Definitely go with a projector.
kohe321 likes this.
Bandyka is offline
post #917 of 4784 Old 08-17-2016, 11:47 AM
UHD Addict
aaronwt's Avatar
Quoted: 9817 Post(s)
Liked: 6486
USB 3.0 is not needed for streaming. You can stream content over USB 2.0 speeds and will see no difference over a USB 3.0 port. Since the bitrate is far below what USB 2.0 is capable of.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #918 of 4784 Old 08-17-2016, 11:57 AM
timc1475's Avatar
Quoted: 952 Post(s)
Liked: 813
I get what you mention spec wise, but if offered the choice 2.0 USB vs 3.0 USB, count my vote for 3.0 USB especially in today's tech that is growing daily exponentially. I therefore choose to buy forward future whenever possible since tech becomes obsolete faster than years prior and will continue to do so.
USB 3.0 is backwards compatible with 2.0 so there is no rational reason on a new 4k HDR BD player going with an older tech except to save costs. IMO
As you can see in my sig I have a JS9500 and bought the 4k media pack that utilized 3.0 on the OCB. There are indeed sound reasons why devices are putting 3.0 ports on devices. So again I will vote 3.0 in my future purchases...that is until 3.1 USB becomes the primo choice in the marketplace.
USB Speed test video 3min:
timc1475 is offline
post #919 of 4784 Old 08-17-2016, 12:02 PM
UHD Addict
aaronwt's Avatar
Liked: 6486
Don't get me wrong. I will certainly take USB 3.0 over 2.0 if given a choice for future proofing or for higher transfer speeds.
aaronwt is offline
post #920 of 4784 Old 08-17-2016, 12:21 PM
timc1475's Avatar
Quoted: 952 Post(s)
Liked: 813
USB 3.0 is not needed for streaming. You can stream content over USB 2.0 speeds and will see no difference over a USB 3.0 port. Since the bitrate is far below what USB 2.0 is capable of. // Don't get me wrong. I will certainly take USB 3.0 over 2.0 if given a choice for future proofing or for higher transfer speeds.
Ok you take 3.0 and I'll take 3.1. lol
I just updated my post here (https://www.avsforum.com/forum/149-bl...l#post46123449 ) with a 3min speed test comparison that is interesting.
Tech moves fast although it does take a lot of time from development to actual implementation. Same goes for HDMI 1.4 / 2.0 / 2.0a / 2.0b / 2.1 etc. Link: http://www.flatpanelshd.com/news.php...&id=1457513362
Development dates:
USB 2.0 year 2000
USB 3.0 year 2008
USB 3.1 year 2013
timc1475 is offline
post #921 of 4784 Old 08-17-2016, 12:44 PM
Liked: 932
As would I...
But as we've both intimated, if a media player only offers a USB2 connection it's certainly not going to effect my decision whether or not to buy it. As it will be a few years yet before we'll actually need media players with USB3 file transfer speeds
post #922 of 4784 Old 08-18-2016, 04:30 AM
Bandyka's Avatar
Liked: 1474
I've tested HDR demos just fine running off a USB stick.
Bandyka is offline
post #923 of 4784 Old 08-18-2016, 10:01 AM
hasta666's Avatar
Quoted: 564 Post(s)
Liked: 202
Can't wait for the HEVC update though :-)
hasta666 is offline
post #924 of 4784 Old 08-18-2016, 11:25 AM
videofx's Avatar
Quoted: 286 Post(s)
Liked: 159
Yay! Finally got an email saying my UB900 will ship the end of next week!!
Comcast Xfinity with 200MB/s
75" TCL Series 8/LG OLED65E6P 65" OLED 4K 3D
OPPO UHD-203/TOSHIBA HD-XA2 HDDVD
SWISS TURNTABLE/TECHNICS 1520 REEL TO REEL
EVERY PLAYSTATION/EVERY XBOX
videofx is offline
post #925 of 4784 Old 08-18-2016, 11:57 AM
CJArciola, III's Avatar
Quoted: 188 Post(s)
Liked: 159
Likewise....sent my payment in less than a minute.
CJArciola, III is offline
post #926 of 4784 Old 08-18-2016, 03:31 PM
ApolloCreed's Avatar
Quoted: 522 Post(s)
Liked: 965
You guys ordering through Best Buy or Value Elec.....or somewhere else?? My birthday is coming up and my wife is asking me what I want.
OG October Horrorfest Contributor
ApolloCreed is offline
post #927 of 4784 Old 08-18-2016, 03:44 PM
videofx's Avatar
Quoted: 286 Post(s)
Liked: 159
Value Elec as they are a couple of weeks ahead of Best buy
ApolloCreed likes this.
videofx is offline
post #928 of 4784 Old 08-18-2016, 05:06 PM
OzHDHT's Avatar
Quoted: 1274 Post(s)
Liked: 782
Ok interesting, I tested that when I got my Panny back in late May and it wouldn't play HDR or 4K demos off USB at all, unlike the Samsung that did out right out of the box. There have been about 5 firmware updates since then so I would have to conclude that one of them addressed that. I'm assuming you are talking the clips available on demo-uhd.com like Sony Camp and non HDR like Sony Aquarium, non HDR like LG wonders, etc? I'll go back and try them again tonight.
OzHDHT is offline
post #929 of 4784 Old 08-18-2016, 07:21 PM
timc1475's Avatar
Quoted: 952 Post(s)
Liked: 813
I am on the fence between the UB900 & the PS4k (NEO) that they will show on 9/7/16.
timc1475 is offline
post #930 of 4784 Old 08-18-2016, 07:30 PM
Quoted: 25 Post(s)
Liked: 5
I own the Xbox One S and the UB900. I have a very dedicated 5.1.4 Dolby Atmos so the Xbox One S was really just for 4K and future HDR gaming. It does not support more than 5.1 uncompressed.
When I watch San Andreas and The Watchmen on one 4k (One S) vs the other UB900 the richness of colours especially reds and orange (fire/explosions) is noticeable.
You should check out some UK sites that have specified a contest BTW the two in their reviews.
Not sure what sound options will be with the PSNEO but let's hope better the Microsoft video only offering to 4k glory.
Warden1969 is offline
Reply Blu-ray Players
4k player hdmi input , 900 , DMP-UB900 , trying to get atmos engaged.
