Panasonic DMP-UB900 thread. - Page 33 - AVS Forum | Home Theater Discussions And Reviews
 5306Likes
post #961 of 4774 Old 08-22-2016, 06:00 AM
Bandyka's Avatar
Quoted: 2327 Post(s)
Liked: 1422
Originally Posted by CJArciola, III View Post
When I contacted Panasonic regarding the upcoming US model they told me Netflix, YouTube, VUDU, but no Amazon.
Sorry my bad I keep mixing up Amazon with Netflix Only Netfilx on the Panny as yet.
JVC RS620/X9500 in bat cave Anthem MRX-720 + 3xpower amps = 7.1.4, Martin Logan Motion 60XT fronts, ML FX rears, ML Motion 50XT centre, 4 x ML Motion 2 on ceiling Atmos, ML Balanced force 210 as the beast. Panasonic UB900, STAX-3170 earspeakers, HTPC, PS4, PS3, Amiga 500 etc..Epson LS10000 calibration and WCG SDR settings: https://www.avsforum.com/forum/24-dig...l#post50298297
Bandyka is offline
post #962 of 4774 Old 08-22-2016, 11:28 AM
JKR1963's Avatar
Quoted: 328 Post(s)
Liked: 150
Originally Posted by zaockle View Post
So we know that the unit will take an HDR/WCG signal and tone map/range compress to SDR/709 for non HDR/WCG 4K displays, but will it do the same for a 1080p display? Or is going to lockout completely due to HDCP? Not sure if any of the euro's have tried this or if this has been asked, so forgive me.
Yes, I am playing the 4K Martian disc with this player right now.......through my Yamaha 3050 and to my Panasonic 65ST60 (1080P) with the D-Nice Calibration settings.......killer picture, and the Atmos sounds great.
The Picture is better than any theater that I have seen. Panasonic call this "Dynamic Range Conversion Output" (shows on Status screen).
My intention at this point was to get Atmos sound in cases where the Blu ray does not have it (and I want it).......without buying a new display (still waiting for something that will exceed my calibrated 65ST60 ..... and that is affordable).
Bandyka likes this.
JKR1963 is offline
post #963 of 4774 Old 08-22-2016, 04:37 PM
Lozin's Avatar
Quoted: 336 Post(s)
Liked: 163
Question for you guys
I've been using this player for a month now and I'm not sure if I'm getting HDR. It looks like I am but when I hit info on the player is see . It says HDR at the top but under HDMI video it says SDR/BT.709. I'm using the duel connection method as my AVR is on hold till I see the new Onkyo's I wasn't sure if I was missing a setting. My tv is the Panasonic TC-65DX900 with HDR enabled on HDMI input 1.
Lozin is offline
post #964 of 4774 Old 08-22-2016, 05:04 PM
sillysally's Avatar
Quoted: 1178 Post(s)
Liked: 1053
You are inputting HDR BT.2020 10bit, you want to see that as your output also.
You are outputting SDR BT.709 8bit.
Try and set your source at YCbCr 2:2:2 as output setting.
ss
"Don't worry be happy"
LG77C8, Klein K10-A, Jeti 1211, CMS Lightspace, Calman home plus licence for K10-A, Murideo 6G.
sillysally is offline
post #965 of 4774 Old 08-22-2016, 05:47 PM
Bandyka's Avatar
Liked: 1422
Is the HDMI 1 port definitely HDMI 2.0a compatible? Is your cable compatible? (18Gbps?) Is your player set to auto settings? It seems the player is down-converting due to some incompatibility in the chain.
Bandyka is offline
post #966 of 4774 Old 08-22-2016, 05:55 PM
Lozin's Avatar
Quoted: 336 Post(s)
Liked: 163
I think the cable is 18gps. Although I'm not using the one that came with the player. I'm assuming I also want deep color output off like I did with the Samsung? With the Samsung I was getting HDR as the info had HDR light up with the same cable.
Lozin is offline
post #967 of 4774 Old 08-22-2016, 05:59 PM
Lozin's Avatar
Quoted: 336 Post(s)
Liked: 163
ss
I just tried this and it's working now with HDR. Thanks to the both of you
Lozin is offline
post #968 of 4774 Old 08-23-2016, 12:48 AM
Bandyka's Avatar
Liked: 1422
Great.
I would use the cable the it came with just to be sure.
So what output are you getting now in the info display?
Bandyka is offline
post #969 of 4774 Old 08-23-2016, 09:57 AM
COACH2369's Avatar
Quoted: 1207 Post(s)
Liked: 1006
Good Afternoon.
I am looking for someone who might have had the Samsung player before they got the Panasonic that could give a good comparison review.
Since they are available today through Value Electronics, I am thinking about grabbing one..
COACH2369 is online now
post #970 of 4774 Old 08-23-2016, 10:36 AM
Quoted: 380 Post(s)
Liked: 652
Originally Posted by COACH2369 View Post
Good Afternoon.
Thanks for the notification. Just ordered one from Value and cancelled my Best Buy order.
Larry Little is offline
post #971 of 4774 Old 08-23-2016, 10:41 AM
COACH2369's Avatar
Liked: 1006
Glad I could help.
post #972 of 4774 Old 08-23-2016, 11:38 AM
Lozin's Avatar
Quoted: 336 Post(s)
Liked: 163
Good Afternoon.
I have both players and had the Samsung for a short while first. The build quality and ease of use & features of the Panasonic put it miles ahead of the Samsung. Now picture quality is close enough between the two on 4K BD that I couldn't tell the difference personally. But with the Panasonic there is no red smear and other issues that Samsung has with 2K BD. Also I really like a front panel display. I ended up getting this player for free with my TV and since I was using a separate BD player for BD's I probably wouldn't have bought this player right away. However if it's your only player in your setup then you can't go wrong.
WOLVERNOLE and Bandyka like this.
Lozin is offline
post #973 of 4774 Old 08-23-2016, 11:42 AM
COACH2369's Avatar
Liked: 1006
Interesting that you brought up the red push for regular Blurays. I haven't noticed that problem with the Samsung.
atabea likes this.
post #974 of 4774 Old 08-23-2016, 02:45 PM
Lozin's Avatar
Quoted: 336 Post(s)
Liked: 163
It was minimal but I did notice it. It wouldn't have been enough for me to purchase this player though if it wasn't free
Lozin is offline
post #975 of 4774 Old 08-23-2016, 02:52 PM
ApolloCreed's Avatar
Quoted: 495 Post(s)
Liked: 839
Good Afternoon.
Yep, ordered mine over the weekend and it shipped out today.
WOLVERNOLE likes this.
OG October Horrorfest Contributor
ApolloCreed is offline
post #976 of 4774 Old 08-23-2016, 03:02 PM
bos617's Avatar
Quoted: 56 Post(s)
Liked: 108
Does anyone know if the player comes with 2 movies? Thanks.
Sent from my SAMSUNG-SM-G928A using Tapatalk
bos617 is offline
post #977 of 4774 Old 08-23-2016, 04:05 PM
Quoted: 59 Post(s)
Are you in NA, and does the player have Amazon Video (seems to be conflicting reports)?
If the US version doesn't have Amazon Video... why would they do that when the European Player (certainly UK and Germany) have had it all along?
Cheers!
Brataccas is offline
post #978 of 4774 Old 08-23-2016, 04:14 PM
CJArciola, III's Avatar
Quoted: 188 Post(s)
Liked: 159
I received a notice from FedEx this morning that it was scheduled to ship today but as of 7:15 pm EDT I haven't received anything saying it has shipped. Do you definitely know yours has shipped?
CJArciola, III is offline
post #979 of 4774 Old 08-23-2016, 07:15 PM
Lozin's Avatar
Quoted: 336 Post(s)
Liked: 163
Cheers!
I am in NA. Canada to be exact so I can't help you on that one as we don't have Amazon Video here.
Lozin is offline
post #980 of 4774 Old 08-23-2016, 07:16 PM
Lozin's Avatar
Quoted: 336 Post(s)
Liked: 163
Originally Posted by Bandyka View Post
Great.
All is good now.
Bandyka likes this.
Lozin is offline
post #981 of 4774 Old 08-23-2016, 08:29 PM
Quoted: 495 Post(s)
Liked: 839
Yep. Got my tracking number. Its scheduled to arrive on Friday between 1:30 and 3:30.
WOLVERNOLE and Lozin like this.
post #982 of 4774 Old 08-23-2016, 08:31 PM
Lozin's Avatar
Quoted: 336 Post(s)
Liked: 163
I think you will thoroughly enjoy it. This player is the finest BD player on the market so far.
ApolloCreed and Bandyka like this.
Lozin is offline
post #983 of 4774 Old 08-23-2016, 08:38 PM
Quoted: 495 Post(s)
Liked: 839
Honestly, just trying to be ahead of the game. Between my theater room projector and my tvs upstairs, I'm not set up for 4k. But I've been using my PS3 as my theater room Blu-ray player for too long and it was time to start preparing for the future.
Looking forward to maximizing this player's capabilities at some point in the near future though.
post #984 of 4774 Old 08-23-2016, 08:41 PM
Quoted: 188 Post(s)
Liked: 159
I finally got confirmation that it shipped. Will arrive on Wed. Don't have a two hour window as you do. FedEx just says will deliver by 8 pm.
ApolloCreed likes this.
post #985 of 4774 Old 08-23-2016, 09:08 PM
PioManiac's Avatar
Quoted: 3341 Post(s)
Liked: 8448
I ordered my UB900 from Best Buy (in Canada) after work today. $799 CAN$ (~$699 USD)
They had none in store, on-line only, 10 available yesterday, down to 6 left now across Canada.
It may arrive by Friday, but most likely Monday
I'm already setup with a 4K AVR for Atmos/DTS:X 7.4.4
New JVC X750 (RS500) projector arrives this Thursday by FedEx.
I looked at the Sammy and could not bring myself to pay that much for what they offered.
I don't mind paying high dollars, but it has to ooze high quality inside and out!
The DMP UB900 is almost as sexy as the new JVC
picked up my first batch of 4K UHD's too
aaronwt, Lozin and Bandyka like this.
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #986 of 4774 Old 08-24-2016, 01:29 AM
Quoted: 59 Post(s)
I noticed it myself. There was definitely some red push for standard blus when I used Samsung.
Just revisited a couple of X Files episodes and really the presentation with Panasonic is way ahead of Samsung! Less noise, no crush, grain looking more natural. The presentation took a turn for worse when I upgraded to 4K but now it looks much closer to my original presentation on 1080p display.
ohnder is offline
post #987 of 4774 Old 08-24-2016, 02:27 AM
JKR1963's Avatar
Quoted: 328 Post(s)
Liked: 150
I am having an issue with Blu ray DTS Master tracks on played on the Panny. For some reason they are playing as "DTS" and not DTS MA. It seems to be on some of my Fox Blu rays. The Martian.........X-Men Days of Future Past. Other non Fox disc's with DTS Master tracks play fine (so far).
I did a bunch of testing with the player settings and can't identify the issue yet. I don't yet know for sure if it is all Fox DTS Master Blu rays or just some........and not sure about other studio's............but I did notice my Rush 2112 Blu ray Audio was doing the same thing. Any of the problem disc's played normally when transferred to my Oppo 103. I need to investigate further and see if I can figure out a solution to this problem. My receiver is the Yamaha 3050...........I wonder if anyone else has noticed any issues like this.......could be a problem isolated to my setup.
nucky likes this.
JKR1963 is offline
post #988 of 4774 Old 08-24-2016, 04:32 AM
whmacs's Avatar
Quoted: 106 Post(s)
Liked: 66
Hi JKR1963,
Could you check in the Panasonic audio menu that who have:
– Dolby D/Dolby D +/Dolby TrueHD: “Bitstream”
– DTS/DTS-HD: “Bitstream”
– BD-Video Secondary Audio: “Off”
Also see page 31 in the manual.
Stephen
whmacs is offline
post #989 of 4774 Old 08-24-2016, 04:43 AM
Manuxs1806's Avatar
Quoted: 308 Post(s)
Liked: 135
The Panasonic UB900 is an amazing piece of technology, but it is a true pity that it is lagging behind its competition on 2 key features :
- support for 10 bits UHD discs
- Netflix HDR
How come the Nvidia Shield and Xbox One S both support Netflix HDR, when Panasonic releases the most expensive UHD player on the market, but without Netflix HDR ???!
For information, no 2015 Samsung TV (that fully support HDR) supports Netflix in HDR because Samsung apparently has forgotten they ever had a TV lineup in 2015.
So if I, owner of a 2015 Samsung TV, want to have Netflix in HDR, I have to wait for Panasonic to allow the UB900 to support it !
Manuxs1806 is offline
post #990 of 4774 Old 08-24-2016, 06:59 AM
alebonau's Avatar
Quoted: 1892 Post(s)
Liked: 1291
congrats....but am not sure am comfortable that we have to choose between the sammy curvy front and the panny's blingy shiny plastic flap thing...both of which completely form over function if ask me !
I bet you when the oppo comes it neither has a curvy front or useless blingy flap thing on the front !
anyways time will ... but can tell you I hope I am not proven wrong with the oppo
"Technology is a drug. We can't get enough of it."
Welcome to my lounge room :)
alebonau is offline
Reply Blu-ray Players
4k player hdmi input , 900 , DMP-UB900 , trying to get atmos engaged.
