Official Samsung UBD-K8500 4K HDR Ultra HD Blu-Ray Player Owner's Thread - Page 153 - AVS Forum | Home Theater Discussions And Reviews
 40335Likes
post #4561 of 14194 Old 04-05-2016, 08:04 PM
ingramba's Avatar
Quoted: 157 Post(s)
Liked: 140
Originally Posted by dshetler View Post
Are you hooked up with 2 hdmi, one from the BD to your OCB & another from your BD to your receiver or just 1 HDMI to your receiver?
One HDMI cable to receiver only.
ingramba is offline
post #4562 of 14194 Old 04-05-2016, 08:16 PM
metalsaber's Avatar
Quoted: 1048 Post(s)
Liked: 858
Originally Posted by buju22 View Post
Wow, that is a coincidence! My firmware is 1003 on the KS8500 and 1443 on the JS8500. So you're saying that it doesn't smear while viewing on your PS4 as oppsed to you K8500? What are your settings on the K8500?
Sent from my SM-G900P using Tapatalk
Does not smear on my ps4 but does on the ks8500
Settings
Resolution 2160
HDMI color format auto
HDMI deep color off
metalsaber is offline
post #4563 of 14194 Old 04-05-2016, 08:24 PM
Quoted: 845 Post(s)
Liked: 364
Yeah mine are:
BD Wise On
Resolution BD Wise
Movie Frame (Greyed Out)
DVD 24Fs (Greyed Out)
HDMI Color YCBCR
HDMI Deep Color Off
So besides the smearing does it look better on the K8500 or PS4?
buju22 is offline
post #4564 of 14194 Old 04-05-2016, 08:25 PM
ramcharger1979's Avatar
Quoted: 107 Post(s)
Liked: 503
BD Wise seems to make the settings unreal
Sent from my XT1575 using Tapatalk
ramcharger1979 is offline
post #4565 of 14194 Old 04-05-2016, 08:32 PM
Quoted: 845 Post(s)
Liked: 364
I tried it with BD Wise off and 1080p resolution and it made no difference.
buju22 is offline
post #4566 of 14194 Old 04-05-2016, 08:34 PM
metalsaber's Avatar
Liked: 858
Yeah mine are:
BD Wise On
Resolution BD Wise
HDMI Color YCBCR
HDMI Deep Color Off
Little better on the k8500.
I tried different settings on the Samsung player to see if I could eliminate the smearing but no luck.
post #4567 of 14194 Old 04-05-2016, 08:36 PM
dshetler's Avatar
Quoted: 103 Post(s)
Liked: 48
I take it you have done the update on your 7200.
Sony OLED 65A8F & LG OLED 55B7A
Denon AVRS740H & Denon AVRX2200W
Direct TV, PS4, PS, & XBoxS
Pioneer Elite Atmos SP-EBS73 x 2 & 2 Centers
Sony X-700 BD & Samsung K8500 BD
dshetler is offline
post #4568 of 14194 Old 04-05-2016, 09:20 PM
galonzo's Avatar
Quoted: 1308 Post(s)
Liked: 1652
Watching Star Wars bluray on the K8500 and there is some weird smearing/ghosting going on. Especially when Han Solo confronts Kylo on the bridge. I have the 65JS8500 with the following settings:
Dynamic Contrast Low
Black Tone Dark
Flesh Tone 0
Color Space Native
Gamma 0
Color Tone Warm 1
Digital Clean Off
MPEG Off
Auto Motion Off
Smart LED High
Cinema Black On
My setting are the same except auto motion clear and it looks good on the JS9000
Yeah mine are:
BD Wise On
Resolution BD Wise
HDMI Color YCBCR
HDMI Deep Color Off
Your K8500 settings look good, try Black Tone=Off , AMP=Clear and SmartLED=Standard on your TV
Edit: you might also consider setting UHD HDMI Color=Off for the TV and setting Resolution to 1080 in the player for normal 1080p Blu-ray watching
Main: UN78HU9000/SEK-3500 | X4200W (Klipsch/HSU 5.1.2) | UDP-203 (fw 65-0131) | TiVo Bolt | Roku P+
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | AppleTV4K | TiVo Mini
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - UHD Digital codes (and some HD codes)
galonzo is offline
post #4569 of 14194 Old 04-05-2016, 09:44 PM
UHD Addict
aaronwt's Avatar
Quoted: 8967 Post(s)
Liked: 5747
I saw the same red smearing from my K8500 that was upscaling the Force Awakens movie to my Sony 850C. I never tried it at 1080P output or from my Sony BD player. It was only a rental plus only a 2K BD so I didn't really care too much about it. I plan on buying the movie when it comes out on 3D BD later this year.
Maybe I'll take a look again before sending the disc back to 3d-blurayrental tomorrow.
EDIT: I just checked the scene again with the K8500 set for 1080P output and see the same red smearing.
Then I checked from my Sony S6500 BD player set for 1080P output and didn't see any smearing. Then I set the S6500 for 2160P output and again I didn't see any smearing. So it is definitely something specific to the K8500.
dmercer3, Tomcup and King Richard like this.
49TB unRAID1a--53TB unRAID2--73TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #4570 of 14194 Old 04-06-2016, 03:59 AM
cmdrdredd's Avatar
Quoted: 4227 Post(s)
Liked: 4520
THX cmd for the tip! I'll try it out soon once the boss (aka wife) goes to sleep! Will Atmos & DTS:X still work in this setup?
Yes the audio will still output lossless.
LG 65" B7A OLED, Samsung 55" JS9000, Sony 43" x800e, Denon AVR-X2200w 5.1.2, PS4 Pro, Nintendo Switch, Gaming PC(GTX 1080ti + 4.7Ghz 8700k), Sony UBP-x800, Philips BDP-7501, Oppo BDP-203, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #4571 of 14194 Old 04-06-2016, 04:00 AM
cmdrdredd's Avatar
Liked: 4520
Originally Posted by metalsaber View Post
I found a major issue with version 1.04. I was watching the new Star Wars movie and noticed that in scenes with deeper red against blacks that major smearing occurs as if it was noise reduction. This was most evident in the scene with Han and Ren on the bridge. You could just see smearing all over Hans face.
I then put the movie into my PS4 and there was no smearing. I haven't played a UHD movie since the upgrade so they might be fine however this was a major bug that hopefully gets remedied.
The smearing did not occur in any other colors but red.
I have watched UHD discs since the update and didn't see this issue. I'll check TFA and see if I notice it.
edit: yes there is definitely something going on with the picture on standard Blu-Rays. I can't say what it is but there is like a double image that looks like a shadow moving in Han's face in the scene you mentioned. Neither my PS4, Xbox One, or mkv file had this. UHD movies look fine and don't have these issues, it's just standard Blu-Ray for some reason. Wonder if someone on 1003 could tell us if they have it too.
post #4572 of 14194 Old 04-06-2016, 04:04 AM
Rino13's Avatar
Quoted: 46 Post(s)
Originally Posted by Freddie Harb View Post
Hi Guys,
I have the K8500 with the Sony 940c. Unfortunately, my AVR (Sony STR-DN1060) does not support HDR. I'm furious. When I use the K8500 2nd HDMI Out slot and connect it to my receiver, I get so many handshake issues. Sounds like it might be hte player that's causing the problems?
Was just curious if anyone had an Audio Receiver (AVR) recommendations that are sub $1000?
Thank you all for your help!!!
Freddie
I just returned my Denon x4200 and picked up Pioneer elite sc95 at Best Buy Magnolia on sale this week for $999.99, awesome deal !! Have not had any handshake issues at all with the elite so far .
Freddie Harb likes this.
Samsung 75" JU7100
Pioneer Elite SC95
Samsung UBDK8500 4K player
KEF XQ speakers
Rino13 is offline
post #4573 of 14194 Old 04-06-2016, 04:19 AM
metalsaber's Avatar
Liked: 858
Yeah i tried different resolutions on the K8500 without any luck. I was also thinking that setting the resolution to 2160 was causing issues but didnt seem to make a difference.
Well at least its repeatable but multiple people now and also proven that other BD devices play it back fine, so its not something wrong with the discs. Definitely something going on with the player.
Though it makes me wonder now if this is doing this in UHD movies as well but with different results? I know others have mentioned that Mad Max looked SOFT compared to the BD version. MM has a strong push to red/orange, so maybe the player isn't processing reds/oranges properly and making them look soft/smearing/ghosting/noise reducting the color.
Again, the only time I noticed this was during deep red scenes. Other colors and scenes were just fine.
post #4574 of 14194 Old 04-06-2016, 04:23 AM
dmercer3's Avatar
Quoted: 788 Post(s)
Liked: 420
A couple of us reported this exact issue when we rented Crimson Peak. I saw this problem with that movie, and again last night as you guys did with Star Wars.
Its either a specific production flaw, or a k8500 flaw.
Video: 75X940E/60E8000 Plasma (Formerly; 78JS9500/58c8000/75hu8550/78ju7500) BD Player: OPPO UDP-203
Audio: Marantz 7010 / SVS PB-13 Ultra / Klipsch RF-7ii RC-64ii Polk M70's IC-5800 (5.1.4)
dmercer3 is offline
post #4575 of 14194 Old 04-06-2016, 04:24 AM
cmdrdredd's Avatar
Liked: 4520
I watched part of Mad Max after the 1004 update to see if I got any HDCP errors etc since it is one of the discs I had the most problems with when I went through my AVR. Didn't see anything that I would say looked soft or out of place. It definitely did not have any double images and shadows moving in faces etc. I watched up until about 45minutes remaining.
post #4576 of 14194 Old 04-06-2016, 04:40 AM
metalsaber's Avatar
Liked: 858
Cant be a production flaw with the disc as some of us have tried the disc in other devices and can not replicate the smearing/ghosting. Seems isolated to the K8500.
post #4577 of 14194 Old 04-06-2016, 04:55 AM
dmercer3's Avatar
Quoted: 788 Post(s)
Liked: 420
in general that should be the case. I am just not about to make that claim with all the new variables in play. There could be new information on these discs that is needed to determine 4:2:2 vs. 4:4:4 for example that traditional blu rays never really needed because players would just assume everything was 4:2:2... just too many variables now.
dmercer3 is offline
post #4578 of 14194 Old 04-06-2016, 05:04 AM
metalsaber's Avatar
Liked: 858
you can change the color format to RGB Standard and such as well. I know I was getting 1080p and 4:2:2 at some point during my testing last night. Didn't make a difference.
post #4579 of 14194 Old 04-06-2016, 05:07 AM
cmdrdredd's Avatar
Liked: 4520
As you know the k8500 has an option for 4:4:4 and rgb but not 4:2:2. Perhaps in the conversion of the color information from standard Blu-Ray there is a software error. I wonder if setting the player to rgb will make any difference. I doubt it will but maybe I'll give that a try and report back.
post #4580 of 14194 Old 04-06-2016, 05:14 AM
metalsaber's Avatar
Liked: 858
Humor me and put in the DVD and go to the bridge scene and see if you see the smearing issue. I just tested it out and theres definitely the same issue happening. Its less pronounced as you have lower resolution to contend with but its there. I can see it in han's cheeks, Ren's top eye lids and lips.
Again, put the DVD in my PS4 and no smearing issues.
buju22 likes this.
post #4581 of 14194 Old 04-06-2016, 06:08 AM
ingramba's Avatar
Quoted: 157 Post(s)
Liked: 140
Yup! Day it came out. I notice when i get no connection that the speaker indicators on receiver flash on & off like its trying to handshake. I wonder if that is whats going on. Last nite before going to bed i tried again & it worked. This morming, mo go. Lights on receiver flicker then shut off. Im usind new high end Monster cables (got cheap).
ingramba is offline
post #4582 of 14194 Old 04-06-2016, 06:11 AM
Freddie Harb's Avatar
Quoted: 169 Post(s)
Liked: 118
wow...congrats on the Pioneer Elite receiver. That looks bad-ass. I don't know if I could drop 1k on a receiver. It will take me some time to get there...but I am jealous.
Freddie Harb is offline
post #4583 of 14194 Old 04-06-2016, 06:11 AM
cmdrdredd's Avatar
Liked: 4520
Yeah it does the same thing and setting the player to RGB didn't help either. What I did notice is when I turned on the digital clean view in my TV the effect was exaggerated even more.
This player doesn't seem to play nice with standard Blu-Rays, like it's always applying noise filtering on them. I have never seen this happen with UHD discs though.
post #4584 of 14194 Old 04-06-2016, 06:28 AM
Quoted: 692 Post(s)
Liked: 616
Ive noticed from day one regular blus look better on my regular sony blu ray player regardless of which resolution i choose so i use this one just for 4k discs. is this smearing just on that one scene or is it present throughout the whole movie?
wmoss35 is online now
post #4585 of 14194 Old 04-06-2016, 06:30 AM
metalsaber's Avatar
Liked: 858
I saw it in about 6 - 8 scenes throughout the movie. for me its only present on scenes where reds/deep reds occur. I never see this in any other color.
post #4586 of 14194 Old 04-06-2016, 06:51 AM
rlb
rlb's Avatar
Quoted: 2250 Post(s)
Liked: 1900
Originally Posted by ahro View Post
I can't see why people would use the dual cable approach, but it seems there are more of them that have no issues with the update Any one cable people that have no issues with the update?
One advantage of dual cables is that you have a dedicated display input for the UHD player. If the player is used only for UHD blu-ray disks, you can maintain unique settings (e.g., UHD color "on" for the Samsungs) and not have to change settings when switching back and forth from standard blu-rays/DVDs to UHD blu-rays.
Musician and tbrown187 like this.
Sony XBR75Z9D, Samsung 65F9000 , Yamaha CX-A5200 & Outlaw 770
Samsung K8500, OPPO 103-D, Genie 2 and C61Ks, Roku Ultra, ATV4K, and Harmony Elite
rlb is offline
post #4587 of 14194 Old 04-06-2016, 07:25 AM
dshetler's Avatar
Quoted: 103 Post(s)
Liked: 48
Have you tried 2 hdmi's? You may want to go to the Denon x7200 thread and talk to jdsmoothie, he is really knowledgeable and it sounds like a receiver issue.
dshetler is offline
post #4588 of 14194 Old 04-06-2016, 07:50 AM
sikclown's Avatar
Quoted: 1681 Post(s)
Liked: 831
Hmmm I have a similar setup with my K8500 going to my Denon x7200WA via one HDMI (on the Bluray input; not that it matters) and the only issue I have involves Netflix freezing up from time to time and blanking the screen but a quick reboot fixes it. Do you leave everything on all the time or do you shut it off when done and turn everything back on as needed? I have seen some weird color issues with my x7200wa when I switch between 4k devices (I also have an Nvidia Shield Pro running) and 1080p devices but I think it is my UN65F9000 with SEK-3500U that gets screwy.
LG OLED 65C7P, Denon AVR-X7200WA, Apple 4K, Oppo UDP-203, PS4, Xbox One X
Nvidia Sheild Pro, HTPC, (2) Klipsch RF-82IIs, (4)RS-52IIs,, (1)RP-450CA,
(4) RP-140SA, SVS PB12-Plus, Emotiva XPA-100, XPA-200, Emotiva A-700
LG OLED 55C8PUA, Denon x4400h, Apple TV 4K, Panasonic DP-UB820,
Nvidia Shield, Klipsch G-42,(2) R-3650-W-II,(4) RSL-C34E, SVS SB-1000, UPA-200
sikclown is offline
post #4589 of 14194 Old 04-06-2016, 07:51 AM
galonzo's Avatar
Liked: 1652
Have you tried setting UHD HDMI Color=Off in the TV for standard (1080) Blu-ray viewing?
King Richard likes this.
galonzo is offline
post #4590 of 14194 Old 04-06-2016, 08:06 AM
amblinfan's Avatar
Quoted: 240 Post(s)
Liked: 118
I noticed the same red smearing mess on Force Awakens via my 8500. Viewing on a Sony X850A non HDR tv thru a Marantz sr6010. Bit annoyed with this player, i'm hooking my Sony 6200 player back up to view regular blu ray on from now on.
Tomcup likes this.
amblinfan is offline
Reply Blu-ray Players
color calibration , hdr player , member , settings
