Official Samsung UBD-K8500 4K HDR Ultra HD Blu-Ray Player Owner's Thread - Page 202 - AVS Forum | Home Theater Discussions And Reviews
 40335Likes
post #6031 of 14194 Old 05-10-2016, 08:28 PM
RROSEN's Avatar
Originally Posted by Bubba3 View Post
I hope one of you veterans can help me. I hooked up my K8500 today for the first time . K8500 to Onkyo TX-NR646 at br/dvd port that is HDCP 2.2 compliant then out of the AVR to a Vizio D55u-D1 into HDMI 1 port that is HDCP 2.2 compliant.
I used Amazon "high speed HDMI 2.0" cables for both connections .
After updating the K8500 I tried Deadpool and Spider-man 2. The Vizio showed 1080P for both discs, the Atmos led was on at the AVR.
Open to your suggestions as to how to get 2160.
Bubba
I have a similar setup, Onkyo & Vizio. After a little playing around trying to route through the AVR (it actually worked intermittently), I changed to HDMI 1 > Vizio and HDMI 2 > AVR and never looked back. Never had a problem after that.
Cheers
RROSEN is offline
post #6032 of 14194 Old 05-10-2016, 10:38 PM
darinp2's Avatar
Quoted: 1135 Post(s)
Liked: 1767
I was using my K8500 for UHD discs, but I wanted to try the HDR content from Amazon, so I enabled the wired connection and enabled the Amazon app. I ended up having some issues and rebooted the K8500. Now all I can get is a flashing red power light. I've tried the 4K input to my projector that was working and also tried hooking up to a 1080p, but can't get up to the home screen now.
I tried holding the stop button after boot up, but never go to the home screen and the player doesn't reset.
Anybody know how to get things reset or have any good ideas?
Darin
darinp2 is offline
post #6033 of 14194 Old 05-10-2016, 11:01 PM
Dave Vaughn's Avatar
Quoted: 1430 Post(s)
Liked: 2187
Darin...try unplugging the player for 5 minutes or so. Also, try booting it up with the HDMI cable unplugged, then shut it down, plug the HDMI cable back in and see if it can reset the EDID. Not 100% certain that will work, but worth a shot.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
For Sale: JVC X750R Projector (RS500 Equivalent) https://www.avsforum.com/forum/252-f...l#post58241092
Dave Vaughn is online now
post #6034 of 14194 Old 05-10-2016, 11:15 PM
Wilson Laidlaw's Avatar
Quoted: 61 Post(s)
Liked: 35
Darin
Reset to factory settings is by holding the stop button on the player (square), not the remote for five seconds. There must be no disc in the tray. You should get a message onscreen that the reset is taking place. You will lose any passwords you have entered for wireless networks and Samsung account and have to re-enter those. I cannot recall if you have to do it with player switched on or on standby but think it was on.
Wilson Laidlaw is offline
post #6035 of 14194 Old 05-11-2016, 05:01 AM
Liked: 1
Deadpool glitch?
Watching Deadpool I noticed that if I skip a chapter or pause, the on screen menu flashes 10-15 times. The PLAY icon then stays on screen. I have to pause (menu flashes again) then press play for PLAY to disappear. I also I have noticed a small black box that stays on screen occasionally until I repeat PAUSE then PLAY.
This is the only title I've had any buggy play back issues with. Anyone else see the same thing?
With 65JS9500
Software 1005
Cole LED is offline
post #6036 of 14194 Old 05-11-2016, 05:07 AM
metalsaber's Avatar
Quoted: 1048 Post(s)
Liked: 858
I never paused the movie, so i didn't see anything like that.
metalsaber is offline
post #6037 of 14194 Old 05-11-2016, 06:20 AM
dave trimble's Avatar
Quoted: 38 Post(s)
Originally Posted by dave trimble View Post
OK, I just got my K8500 today, and am having issues playing movies in 2160p. I hope you guys can help me out here. My TV is a Vizio M-75 (2015), and my surround receiver is a Denon x2200 (fully HDCP 2.2 compliant).
First, I just tried replacing my existing BD player with this one. That would mean that it goes through the Denon, and on to HDMI 1 on the Vizio. This input is only rated for 2160/24p, but I only plan to watch movies with this player anyway. When I tried to start up The Revenant, the player told me to attach it to an HDCP 2.2 compliant TV in order to watch in 4K. So I went for simplicity. I tried a direct connection to HDMI 1, bypassing the Denon, and still got the no go for 4K. Connected it directly to HDMI 5, which is 2160/60p compliant, and the Player automatically switched to 2160p in the menu. But when I tried to play the movie, the TV just says "no signal."
I'm not sure what the problem is at this point. The TV is capable, the HDMI cable is good (after all, it's passing 2160/60p in the menus just fine), but actually playing a disc seems to be problematic. I would really, really appreciate it if someone could shed some light on the situation or make some suggestions.
A little more information, if it helps: When I played a regular Blu-Ray, it upscaled to 4K and played just fine on the TV, and when I forced the player into 1080p mode, it played the Revenant's 4K Blu-Ray disc just fine. For whatever reason, I still get no picture when playing the 4K Blu-Ray with the player outputting 4K. I'll get audio, but no picture. Deadpool comes today, so I will at least have another 4K Blu-Ray to try out.
dave trimble is offline
post #6038 of 14194 Old 05-11-2016, 08:59 AM
beastaudio's Avatar
Quoted: 5507 Post(s)
Liked: 5324
Anyone here pair this player with the Epson ls10000? I know it's a long shot, since I think there's only about 10 of us that have it around here....
beastaudio is offline
post #6039 of 14194 Old 05-11-2016, 09:03 AM
Rudy1's Avatar
Quoted: 1957 Post(s)
Liked: 3254
Have you tried HDMI 1 from BDP to TV HDMI 5, and HDMI 2 from BDP to AVR?
Rudy1 is offline
post #6040 of 14194 Old 05-11-2016, 09:06 AM
Quoted: 38 Post(s)
That's how I currently have it set up. It'll send 4K to the tv when in the player's menu, but when I try to play The Revenant in 4K, I get sound but no picture.
post #6041 of 14194 Old 05-11-2016, 09:14 AM
Rudy1's Avatar
Liked: 3254
That is odd...I don't suppose there is a particular setting you must use on the TV when inputting a 4K/60 HDR signal, is there? Are you able to play 4K content through the apps? If you are, there may be something wrong with the UHD disc itself.
Rudy1 is offline
post #6042 of 14194 Old 05-11-2016, 09:30 AM
3DMamper's Avatar
Quoted: 49 Post(s)
Liked: 36
Hey everyone. Just recieved my K8500. I watched Exodus and The Martian. Both HDR movies.
Inmitally a bit dissapointed. As they are both fake 4k movies so the resolution and sharpness is not actually better but worse than the best 4k streams im used to watching on netfliks, amazon and youtube.
HDR wise i cant actually see much difference between HDR and the bluray version.
What is obvious is the slightly washed out dark details and blacks. Thats definately dissapointing. So i would like to ask, how can i disable HDR. Forced upon us is annoying. I know HDR would be great on a 2016 OLED. But on my x940c the blacks suffer.
What i am impressed with UHD versions is the lack of motion artifacts in fights and high speed motion. Where as the normal bluray version can look really badly compressed in such scenes.
Another dissapointment for me was the Martain in fake 4k is nowjere as good as watching it in 3D.
Larry Rosenberg likes this.
3DMamper is offline
post #6043 of 14194 Old 05-11-2016, 09:40 AM
BeyondHD's Avatar
Quoted: 61 Post(s)
Liked: 47
WOW Deadpool is a perfect example of 4K HDRichness. Deadpool's red costume pops out of the screen and blacks are from outer space. A wonderful 4K transfer from 20th Century Fox. By the way, the Dolby Atmos mix really rocks.
BeyondHD is offline
post #6044 of 14194 Old 05-11-2016, 09:43 AM
bluemoon737's Avatar
Quoted: 2204 Post(s)
Liked: 2705
Is the input on your 940C that is being used for the K8500 set to "enhanced"?
-Jeff-
Man cave: Sony XBR75Z9D, Marantz SR8012, and OPPO UDP-203
Living room: Sony XBR75X950G, Denon x4500, and Sony UBP-X800M2
bluemoon737 is online now
post #6045 of 14194 Old 05-11-2016, 09:49 AM
3DMamper's Avatar
Quoted: 49 Post(s)
Liked: 36
Yup. Ive gollowed the guides and its on enhanced. Im using hdmi 2 port on the TV.
Another poster regarding using the bluray version... not to be rude by i bought A UHD disk to watch in higher res. ☺
andrewpana likes this.
3DMamper is offline
post #6046 of 14194 Old 05-11-2016, 09:50 AM
3DMamper's Avatar
Quoted: 49 Post(s)
Liked: 36
Hi there what tv are you watching HDR deadpool on?
Thankd
3DMamper is offline
post #6047 of 14194 Old 05-11-2016, 10:19 AM
CCsoftball7's Avatar
Quoted: 1692 Post(s)
Liked: 1286
Then you have something wrong. HDR on my set is amazing.
aaronwt, cmdrdredd, dkyork and 3 others like this.
Sony XBR75X940C & XBR65A1E Samsung UBD K8500
My Recommended Daytime Settings Apps(Video), My Recommended Daytime Settings Apps, My non-HDR and HDR Settings, Setting HDMI to show no overscan
Sony XBR75X940C, Samsung UBD K8500, Roku Ultra, DirecTV RVU and C61K, Chromecast Ultra
CCsoftball7 is offline
post #6048 of 14194 Old 05-11-2016, 10:23 AM
3DMamper's Avatar
Quoted: 49 Post(s)
Liked: 36
What tv do you have if you dont mind.
And is it a day and night difference between that and the bluray?
As i dont get that kind of a difference. It looks a little different... but nothing special.
3DMamper is offline
post #6049 of 14194 Old 05-11-2016, 10:27 AM
Liked: 1286
I have a 940C. It is night and day difference. Don't get me wrong, bluray is very good. However, UHD with HDR is in another league. Open the forum in a Web browser and look at my settings in my signature.
cmdrdredd likes this.
post #6050 of 14194 Old 05-11-2016, 10:57 AM
tomcrown1's Avatar
Quoted: 558 Post(s)
Liked: 263
Since their is posts about how bad HDR is or I wish I could turn off HDR
Joe Kane states SDR10 to be superior. This video may be of interest since it explains why some may not like HDR picture from. Our player
CCsoftball7 and x21inc like this.
Samsung un659000/SEK-3500
tomcrown1 is offline
post #6051 of 14194 Old 05-11-2016, 12:08 PM
voyager6868's Avatar
Quoted: 111 Post(s)
Liked: 56
Originally Posted by cmdrdredd View Post
Why would you use 24p from a computer? That's terrible for any type of usage except movies which aren't 12bit anyway.
I was using it in 12-bit mode simply to test out the capabilities of the set.
I do regularly use 24p mode for watching movies and some TV shows. MPC-HC + madVR provides a superior 4K upscaling versus any BluRay player.
voyager6868 is offline
post #6052 of 14194 Old 05-11-2016, 12:59 PM
cmdrdredd's Avatar
Quoted: 4227 Post(s)
Liked: 4521
https://m.youtube.com/watch?v=5ES03MkctjM
People just need to adjust to more shadow detail. That's all there is to it. Stop wishing everything was washed out crap with over saturated brightness.
LG 65" B7A OLED, Samsung 55" JS9000, Sony 43" x800e, Denon AVR-X2200w 5.1.2, PS4 Pro, Nintendo Switch, Gaming PC(GTX 1080ti + 4.7Ghz 8700k), Sony UBP-x800, Philips BDP-7501, Oppo BDP-203, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #6053 of 14194 Old 05-11-2016, 01:00 PM
cmdrdredd's Avatar
Liked: 4521
Right but isn't there an option to change the refresh rate upon playback so you don't have to set it manually?
post #6054 of 14194 Old 05-11-2016, 01:23 PM
UHD Addict
aaronwt's Avatar
Quoted: 8968 Post(s)
Liked: 5748
Something must not be set right if your 940C looks that way. Things should look superb with that set. Especially with the martian(The Exodus isn't a good one for HDR). The indoor scenes of the Martian are in 4K. Taken from a 5K camera. But the CGI shots are in 2k.
Even on my low end Sony 850C, with only some HDR capability, The Martian looks great from my K8500. On a 940C, with FALD, the MArtian should look superb from the K8500.
cmdrdredd, CCsoftball7 and galonzo like this.
49TB unRAID1a--53TB unRAID2--73TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #6055 of 14194 Old 05-11-2016, 01:49 PM
Quoted: 49 Post(s)
Liked: 47
First off if your blacks are suffering this is usually indicative of attempting to play HDR content on a non compatible display. Since the 940C seems to be HDR compatible based on my quick google search I would speculate that there is something wrong in your setup. Either settings on the player/display or a combination of both. I'm not familiar with your sets HDR related settings sorry. I'm sure someone else can help with that.
I will also say that if you feel THE SAME CONTENT viewed on a 4K streaming service is sharper than its Ultra HD Bluray counterpart I would have to say I find that very surprising. You have to compare apples to apples, by this I mean the same movie under the same conditions with the same picture settings (calibrated if possible). Any other comparison to other content is meaningless. Every film/video/documentary is created by different people who have varying degrees of skill and different views on how they want their content to look once released to consumers. Not all content is filmed and shot with the sole purpose of being very bright/high contrast/ultra sharp with everything in focus. Your right that there are a lot of high quality streaming videos and movies that can be almost demo worthy (I like time laps photography). Im sure if you could view this content on Ultra HD Bluray the difference would be significant.
The theory behind HDR and WCG is basic and when done properly through the whole signal train it will most definitely wow anyone who see's it.
My personal favorites right now are Life of Pi and Lego Movie and the revenant
Here are a couple of things to keep in mind about HDR (for comparison to SDR) if you would like to indulge me. Most of this is mentioned or covered in some way during the interview with Joe Kane.
1. HDR10 uses a new form of gamma or Electro Optical Transfer Function known as ST2084. This EOTF was designed for DARK ROOM viewing. Most of the video information within HDR10 exists from 0-100 NIT. Many people have become accustomed to viewing standard dynamic range material during the years past with a less than desirable gamma setting and higher than recommended light output in viewing conditions other than dark room. If HDR in its current form is viewed in a moderate to bright room the effect of the spectral highlights will not be able to overcome ambient light enough to have the impact intended. Some owners use the dynamic contrast settings to overcome this feeling. I believe this results in an inaccurate image but I have no tests or data to prove this at the moment so for now its to each their own.
2. The vast majority of colors created in nature exist within the Rec709 color space. Most of whats beyond that are man made. With the biggest exception being parts of green (color volume which relates to luminance is a separate thing). How much you notice the expanded color are going to be very content specific and may be subtle. Not to mention many people who prefer setting their display to a "preference" picture vs. a "reference" picture and are used to viewing over saturated and inaccurate colors may notice a smaller difference.
3. Luminance and Chromaticity (ST2086) - Right now luminance and tone mapping are done based on STATIC metadata. This means that the display takes into account the widest color gamut and the brightest scene within the content (the whole movie) and remaps based on that. The majority of the content will have a greater compression of dynamic range and color gamut than would be necessary based on the displays capabilities. HDR10 will one day be capable of scene by scene DYNAMIC metadata. Samsung recently showed a demo of a 2016 model display utilizing this feature. Dolby Visions system already does this. I don't know if this will require a hardware update, software update, or both. As always it will be at the manufactures discretion if and when certain products receive updates.
nathan_h, galonzo and Tomcup like this.
devon_djh is offline
post #6056 of 14194 Old 05-11-2016, 02:24 PM
jbelluccirx's Avatar
Quoted: 14 Post(s)
Liked: 5
I have the Samsung player and a new 75" Sony 940D. I was wondering if I could get some feedback on an issue I've been experiencing. While starting up a Ultra HD disc there is usually a pause on the part of the tv to recognize its an HDR signal and then the picture will display. Occasionally though the player seems to want and try and put the tv in 24hz mode, which will display no picture at all, only sound. If I then stop the disc and attempt to replay it then it throws it into HDR 4K and everything plays fine. I have everything running through a Denon X6200 and my hdmi input on my tv has been switched to enhanced. I was wondering if anyone had heard of this issue and if there were any suggestions on how to fix it. Also, should I expect to be getting 24hz playback with this setup?
jbelluccirx is offline
post #6057 of 14194 Old 05-11-2016, 02:48 PM
BeyondHD's Avatar
Quoted: 61 Post(s)
Liked: 47
Thankd
I have a Samsung 65JS9500 on my living room and a 55JS8500 on my bed room. Both are connected to the Samsung UBD-K8500 (I have 2 units). Obviously the HDR is better on the JS9500 but to my surprise the JS8500 handles HDR content very good. Probably I will make an upgrade to the UN65KS9500, Oled still out of my budget.
BeyondHD is offline
post #6058 of 14194 Old 05-11-2016, 02:59 PM
Quoted: 111 Post(s)
Liked: 56
Yes, there is.. but sometimes I don't want to go to the effort of adjusting my AVR's lipsync value (it's ~40ms for 2160/60 and ~140ms for 2160/24), so I don't want the video player to automatically switch resolutions.
I wish all of the devices had a way to save presets and auto-switch to them with one button. For instance, in 2160/24, I like to use LED Clear Motion on my TV, but at 60Hz it has obvious flickering.
post #6059 of 14194 Old 05-11-2016, 03:05 PM
cmdrdredd's Avatar
Liked: 4521
Wow that is unfortunate. Kodi changes refresh for me with no change to the audio delay.
post #6060 of 14194 Old 05-11-2016, 03:06 PM
cmdrdredd's Avatar
Liked: 4521
It could be an hdcp issue. I have had some trouble with my Denon x2200w. The easiest solution is for you to run two HDMI cables from the player to separate the audio from the video.
Reply Blu-ray Players
color calibration , hdr player , member , settings
