Official Samsung UBD-K8500 4K HDR Ultra HD Blu-Ray Player Owner's Thread - Page 341 - AVS Forum | Home Theater Discussions And Reviews
 40366Likes
post #10201 of 14221 Old 11-06-2016, 04:49 AM
rlb
rlb's Avatar
Quoted: 2255 Post(s)
Liked: 1904
Originally Posted by dubgreasemonkey View Post
I have a entry line Sony 4K UHD 65" 810C tv, I use a Sony BDP-BX650 4K Upscaling Streaming Blu-ray Player to watch Blu-Ray movies, will I noticed a big difference with the 4K up scaling and Blu-Ray player with this Samsung unit?
Big difference if you are playing 4K Ultra HD disks on the Samsung K8500 and your TV does HDR. Some difference if your TV doesn't do HDR and you are playing 4K Ultra HD disks on the Samsung (you still will have actual 4K instead of the upconverted 4K). Little if any difference when playing regular Blu Rays.
Sony XBR75Z9D, Samsung 65F9000 , Yamaha CX-A5200 & Outlaw 770
Samsung K8500, OPPO 103-D, Genie 2 and C61Ks, Roku Ultra, ATV4K, and Harmony Elite
rlb is offline
post #10202 of 14221 Old 11-06-2016, 06:10 AM
docrog's Avatar
Quoted: 1112 Post(s)
Liked: 382
I would prefer to send bitstream audio from my K8500 to my AVR via HDMI2 and directly connect HDMI1 to my projector, as there have been several posts which suggest that this would lessen the bandwidth requirements on my video feed HDMI cable. However, I'm unable to find any reference that the player will internally separate the audio and video paths if cables are plugged into both HDMI1 & HDMI2. Can anyone verify that the audio stream is removed from HDMI1 when a 2nd HDMI cable is attached to HDMI2? Thanks!
docrog is online now
post #10203 of 14221 Old 11-06-2016, 09:12 AM
Rudy1's Avatar
Quoted: 1960 Post(s)
Liked: 3260
Based on the generally accepted interpretation of the manual, if you connect cables to both HDMI jacks on the UHD BDP, you must select HDMI2 for audio output in order for the audio stream to be separated from the video stream.
Definition of "Stupid": Knowing the truth, seeing the truth, but still believing the lies.
Rudy1 is offline
post #10204 of 14221 Old 11-06-2016, 09:24 AM
docrog's Avatar
Liked: 382
Thank you for your response, but I'm unable to find any reference that indicates that this actually occurs; there doesn't seem to be any mechanism to identify HDMI2 as the sole audio stream. My interpretation of the instructions is that HDMI2 is to be used when an AVR does not support pass through, but this doesn't necessarily mean that this results in HDMI1 only carrying video. My set-up doesn't allow me to test this theory, as the projector doesn't have speakers. I guess the only way to verify the situation would be if someone who uses an AVR for audio distribution would connect HDMI2 to an active AVR audio input and connect HDMI1 to a television in order to see if the TV's speakers are still active when the TV's audio menu is set for the speakers being "ON".
post #10205 of 14221 Old 11-06-2016, 10:06 AM
Jon S's Avatar
Quoted: 1122 Post(s)
Liked: 403
It appears my Samsung player has some issues with Pacific Rim after the latest firmware update. It will not play the UHD or the Blu-ray disc, the disc icon just keeps spinning. I put the Blu-Ray in my Sony player and it works fine. Anyone else noticed this?
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #10206 of 14221 Old 11-06-2016, 02:01 PM
hammerdwn's Avatar
Quoted: 249 Post(s)
Liked: 91
Been playing with my new 4k equipment (see signature) for one week, updating, tweaking, testing, etc. Just finished enjoying Mad Max Fury Road 4k disc and it was awesome - flawless picture/sound! HDR kicked in fine, Atmos bit-streamed... No problems at all with hdcp or lip sync or blacking out or strange pixels. Everything in the player and avr is set to Auto/Passthrough, and using one hdmi cable from player to avr then one hdmi cable from avr to tv.
XBR-65Z9D | UBP-X700 | Xfinity 4k XG1v4 | JRMC HTPC w/9 cable tuners
AVR-X2200W | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #10207 of 14221 Old 11-06-2016, 02:59 PM
Musician's Avatar
Quoted: 2650 Post(s)
Liked: 5298
I tried it for you.
If I set the K8500's HDMI Audio Output setting to HDMI 1 and have my TV speakers setting turned ON, as expected the audio will be heard from the TV speakers since the player is hooked up directly to the TV.
However if I set set the K8500's HDMI Audio Output setting to HDMI2 (or Auto) with my TV's speakers setting turned ON, I hear nothing so I guess we can conclude that the audio stream is removed from HDMI1 when using Method 2 to hook it up and using the players HDMI2 (or Auto) setting but I am not convinced that is going to cure the issues you have been reporting regarding the menu being displayed at 4k 60Hz 4:4:4.
But hey, if you want to run another HDMI cable and give that a whirl no harm trying but since the Home menu doesn't have any audio associated with it, I can't see how this is going to help.
rlb likes this.
Samsung UN78HU9000 & SEK-3500U/ZA - Firmware 1540.3
Samsung UN40HU7000 & SEK-3500U/ZA - Firmware 1540.3
Samsung UBD-K8500 UHD Blu-ray Player; Apple TV 4K
Arris VIP5662W UHD Whole Home DVR; Chromecast Ultra
Marantz SR7005 Receiver; Magnepan Speakers; Martin Logan Subwoofer
Musician is online now
post #10208 of 14221 Old 11-06-2016, 03:59 PM
SkodaZek's Avatar
Quoted: 12 Post(s)
Originally Posted by cmdrdredd View Post
Hdcp issues. I had similar trouble but ended up having to run 2 cables from the player to fix it. One to the tv and one to the avr.
I had this issue as well, fixed it by buying expensive high bandwidth hdmi cables. Something I always thought was a waste of money and it worked..
SkodaZek is offline
post #10209 of 14221 Old 11-06-2016, 04:03 PM
jconjason's Avatar
Quoted: 1229 Post(s)
Liked: 2063
It is a waste of money. Just because it has a higher price tag doesn't mean it's better. But glad you got your issue fixed.
Samsung 65" KS8000
Denon AVR 6300H
Klipsch 5.1.2
HSU VTF-3 MK5 HP
jconjason is offline
post #10210 of 14221 Old 11-06-2016, 04:26 PM
cmdrdredd's Avatar
Quoted: 4251 Post(s)
Liked: 4545
I was using HDMI Premium Certified cables so I know it wasn't the cables. Magically when I hooked up a Philips UHD Player none of the issues the k8500 had existed even with just a single HDMI cable through my AVR.
LG 65" B7A OLED, Samsung 55" JS9000, Sony 43" x800e, Denon AVR-X2200w 5.1.2, PS4 Pro, Nintendo Switch, Gaming PC(GTX 1080ti + 4.7Ghz 8700k), Sony UBP-x800, Philips BDP-7501, Oppo BDP-203, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #10211 of 14221 Old 11-06-2016, 04:30 PM
SkodaZek's Avatar
Quoted: 12 Post(s)
Guess adding the word expensive was incorrect of me.
I switched out my 18gbps rated HDMI cable for a 27gbps rated HDMI cable and that fixed the problem. Now I can run my 4K HDR10 Image w/ Dolby Atmos & DTS:X without any black screen cut outs. Doesn't matter if the cable you buy is gold plated or what and what certified, I'm convinced it was the increased bandwidth that solved my issue.
SkodaZek is offline
post #10212 of 14221 Old 11-06-2016, 04:45 PM
cmdrdredd's Avatar
Liked: 4545
There is no such thing as a 27Gbps rated cable. The specification for HDMI 2.0b is 18Gbps. I'm glad the cable works, but they are selling cables with false marketing attached. HDMI Premium Certified cables are tested to function at full 18Gbps as per the latest spec at the listed length. There is nothing beyond that.
rlb and mrtickleuk like this.
post #10213 of 14221 Old 11-06-2016, 07:19 PM
DtroitPunk's Avatar
HDCP 2.2 has me worried..
I just got a Sony XBR65X850D and I own a Yamaha RX-V775 that apparently doesn't do HDCP 2.2. I have come to understand that every link in your av chain must do 2.2...
However, it does seem that I could use the two HDMI cables to split the image out to tv and audio out to receiver, correct?
Someone who truly loves others speaks the truth, not just what they want to hear.
DtroitPunk is offline
post #10214 of 14221 Old 11-06-2016, 07:52 PM
Geronimo.USMC's Avatar
Quoted: 311 Post(s)
Liked: 187
Originally Posted by dtroitpunk View Post
i just got a sony xbr65x850d and i own a yamaha rx-v775 that apparently doesn't do hdcp 2.2. I have come to understand that every link in your av chain must do 2.2...
However, it does seem that i could use the two hdmi cables to split the image out to tv and audio out to receiver, correct?
yes
- AUDIO: (7.2.4 Atmos) EMOTIVA RMC-1 | McIntosh MC-8207 + CROWN XLS 2502, 1502 | KEF LS50, SVS Prime Elevations, RYTHMIK G25HP + L22
- VIDEO: SONY OLED 65A9G | Panasonic UB820 | 44TB Synology DS1815+ | Dune Solo 4K | XBOX ONE X SCORPIO | PS4 PRO | Apple TV 4K | HTPC/Gaming Rig (Ryzen 3700X, GIGABYTE X570 I AORUS PRO WIFI, 16GB, STRIX OC 1080TI, Auzen HDMI XFi)
Geronimo.USMC is offline
post #10215 of 14221 Old 11-06-2016, 08:05 PM
docrog's Avatar
Liked: 382
FWIW, Monster Cable is promoting that certain of their cable lines have been tested to successfully pass a signal in excess of 27 Gbps. They don't claim certification, but do rate HDMI cable speed, probably on the basis of their own in-house testing.
post #10216 of 14221 Old 11-06-2016, 08:10 PM
docrog's Avatar
Liked: 382
Originally Posted by Musician View Post
I tried it for you.
However if I set set the K8500's HDMI Audio Output setting to HDMI2 (or Auto) with my TV's speakers setting turned ON, I hear nothing so I guess we can conclude that the audio stream is removed from HDMI1 when using Method 2 to hook it up and using the players HDMI2 (or Auto) setting but I am not convinced that is going to cure the issues you have been reporting regarding the menu being displayed at 4k 4:4:4.
Thanks, so much, for doing that leg work! I'll set the HDMI audio option to HDMI2 and see whether or not that will then be able to provide a "sparkle free" K8500 home menu screen over my (supposedly) certified 18Gbps cable with 4K60 4:4:4 (just as soon as my JVC PJ is returned from service at the end of this week). It sure would be nice not to have to resort to the "disc trick" every time that I power up the K8500.
post #10217 of 14221 Old 11-06-2016, 09:27 PM
Dave Vaughn's Avatar
Quoted: 1447 Post(s)
Liked: 2242
Their 27 Mbps cable didn't pass my testing earlier this year: http://www.soundandvision.com/conten...yqI1cs63uxW.97
Rudy1, aaronwt, rlb and 3 others like this.
David Vaughn Blu-ray Reviewer / Technical Writer Sound & Vision Magazine (Print & Online)
Dave Vaughn is offline
post #10218 of 14221 Old 11-07-2016, 03:48 AM
docrog's Avatar
Liked: 382
I very much appreciate your reply to my recent post; I had not been aware of your S&V article. "Sparkles" and intermittent loss of connectivity were present with my 25' run of the Monoprice Cabernet as well as the 35' Monster Cable Ultra HD Black Platinum HDMI cables, consistent with your findings. BTW, have you ever tested the 30' Sewell Silverback S6 active HDMI cable? Their customer support "guaranteed" that there would be no problem transmitting 4K60 4:4:4 at 30' with that cable.
post #10219 of 14221 Old 11-07-2016, 05:43 AM
UHD Addict
aaronwt's Avatar
Quoted: 9190 Post(s)
Liked: 5911
Audio takes up a fraction of the bandwidth used. The audio only accounts for a few megabits. While the video is over 12 Gigabits. Those few megabits should have little effect on bandwidth since it's literally only a fraction of the total bandwidth used.
galonzo and Toxic teletubby like this.
53TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #10220 of 14221 Old 11-07-2016, 05:45 AM
UHD Addict
aaronwt's Avatar
Liked: 5911
It does not send audio over HDMI 1 when HDMI 2 is set for audio. Well I should say the two K8500's I've owned has never done it.
post #10221 of 14221 Old 11-07-2016, 06:06 AM
Liked: 0
Hello,
Can this player be used to stream from Apple Store or Google Play rented movies?
Thanks a lot
kfp22 is offline
post #10222 of 14221 Old 11-07-2016, 08:14 AM
Liked: 2242
I have not. When I contacted them about sending in a sample for testing, I never heard back. I've read of others trying it with no success though.
post #10223 of 14221 Old 11-07-2016, 08:25 AM
Wiz33's Avatar
Quoted: 26 Post(s)
Originally Posted by Cam1977 View Post
Has anyone experienced slower load times with 4K blu rays, also for some reason the player is starting to act a little funky...for example I put in a 4K blu ray, but hdr was not activated on the tv. My chain is player-receiver-tv, I have the receiver on pass through only...(mode 1, yamaha)
It seems to vary disc to disc. Worst is my Pacific Rim which takes over 1 1/2 minutes to load while other loads in about 10 seconds. Have you tried plugging directly into the TV and does the problem persist?
Wiz33 is offline
post #10224 of 14221 Old 11-07-2016, 08:32 AM
Wiz33's Avatar
Quoted: 26 Post(s)
How long did you let the spinning disc icon run. I have the same problem with Pacific Rim. It take about 1 1/2 minutes to load but it will load eventually. It is strange as other disc loads in about 10 seconds.
Wiz33 is offline
post #10225 of 14221 Old 11-07-2016, 08:52 AM
cmdrdredd's Avatar
Liked: 4545
And I'm saying it's an 18Gbps cable they attach a number to and price it accordingly.
post #10226 of 14221 Old 11-07-2016, 08:53 AM
cmdrdredd's Avatar
Liked: 4545
4k60 4:4:4 with hdr and audio? I can do 4k60 4:4:4 with a 6 year old mono price bargain cable but it is marginal for hdr.
post #10227 of 14221 Old 11-07-2016, 08:56 AM
cmdrdredd's Avatar
Liked: 4545
Originally Posted by kfp22 View Post
Hello,
Thanks a lot
No, you need Apple TV or a device that runs android for either of those. The fandangoNow app does allow you to purchase movies to stream. It sure about rentals, I never looked into it.
post #10228 of 14221 Old 11-07-2016, 09:06 AM
jong1's Avatar
Quoted: 525 Post(s)
Liked: 522
4K60 4:4:4 isn't possible with HDR. 4K60 4:4:4 is already 17.8Gbps.
4K60 needs to drop down to 4:2:2 12-bits or 4:2:0 10-bit or 12-bit for HDR. The last 2 are actually a lower bit rate than 4K 4:4:4 8-bit.
But I'm sure you know this, so
jong1 is offline
post #10229 of 14221 Old 11-07-2016, 12:08 PM
mrtickleuk's Avatar
Quoted: 4696 Post(s)
Liked: 6971
I would have thought that the dynamic range of the colourspace is a separate thing and not related to which mode it's in. Ie just flag the data as "this is rec2020 colourspace and HDR" and the display does the mapping.
I agree that 4K60 HDR is possible in the 4:2:2 12-bits mode (17.8Gbps) or the 4:2:0 12-bit (13.4Gbps) or 10-bit (11.1Gbps) modes. I can't see how that means that that 4K60 HDR "isn't possible" in the 4:4:4 8-bit mode, though, which is also the same 17.8Gbps bitrate, and that's the mode that games are already using (AFAIK).
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is online now
post #10230 of 14221 Old 11-07-2016, 12:55 PM
jong1's Avatar
Quoted: 525 Post(s)
Liked: 522
HDR10 is always 10-bit. Dolby Vision 12-bit. Dolby say DV can be split across 2 video streams of lower bit depth, but, first, there aren't any DV HDMI sources, until Chromecast Ultra arrives and all of those, in practice will be using 12-bit video modes. Right now, all available HDR sources using HDMI are HDR10 and that's 10-bit.
Seems Xbox One S uses 4:2:0: http://support.xbox.com/en-GB/xbox-o...l-requirements
Harder to get a clear statement from Sony, but I'm sure they are doing the same: http://blog.us.playstation.com/2016/...-ultimate-faq/
jong1 is offline
Reply Blu-ray Players
color calibration , hdr player , member , settings
