Official Samsung UBD-K8500 4K HDR Ultra HD Blu-Ray Player Owner's Thread - Page 348 - AVS Forum | Home Theater Discussions And Reviews
 40368Likes
post #10411 of 14223 Old 11-19-2016, 02:45 PM
tor ove's Avatar
Quoted: 62 Post(s)
I'm sitting 2.5m (8 feet), from my Samsung 65" JS9505, and can barely spot the difference in resolution.
On Netflix, I find "House of Cards" and "Stranger things" to be quite equal if I stream them as 1080p and as 2160p.
I even find the blu-ray of movies like "Warcraft" and "Mad Max" to be somewhat "sharper" in standard 1080p.
But for the HDR-aspect there is a severe difference favouring the HDR on my part.
TimWelborn and Terminader like this.
tor ove is offline
post #10412 of 14223 Old 11-19-2016, 03:35 PM
BiggAW's Avatar
Quoted: 829 Post(s)
Liked: 245
I have found it depends on the content. With Orange is the new Black, I can't tell the difference. I probably wouldn't care if it was 720p, it's just not a highly detailed type of show that looks great in 2160p. I also watched Narcos, and it looks SPECTACULAR in 4K, and it doesn't have HDR. The pans over Medellin are absolutely spectacular, and everything looks sharp and crisp throughout the show.
rlb and boojitede like this.
BiggAW is offline
post #10413 of 14223 Old 11-19-2016, 04:02 PM
UHD Addict
aaronwt's Avatar
Quoted: 9320 Post(s)
Liked: 6003
You are eight feed away. You need to be half that distance to easily see the resolution difference. Although I can;t say that I've compared House of Cards to STranger things. But I've compared 1080P streamed HoC to 2160P steramed HoC to 1080P Blu-ray Disc HoC. The 2160P streamed version is easily better than the 1080P streamed version. But the 2160P streamed version is on par with the 1080P BD.
Dave Vaughn likes this.
53TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #10414 of 14223 Old 11-19-2016, 04:06 PM
Quoted: 43 Post(s)
Liked: 24
I have it on and it still shows that but on my pro everything shows it's good the 4K and hdr
Originally Posted by Maserdotcom View Post
Do you guys know why this comes out I got the hu9000 with the sek3500 and the k8500?
You will have to activate UHD Color in picture settings for the HDMI-port the player is connected to.
Example, lets say UBD-K8500 is connected to HDMI-3 on the SEK3500
On the tv, go to settings, picture, and a bit down there is the option for "UHD Color".
Activate UHD color for HDMI 3 in this case, the tv will reboot, and it should work fine.
Maserdotcom is offline
post #10415 of 14223 Old 11-19-2016, 04:40 PM
boojitede's Avatar
Quoted: 42 Post(s)
Liked: 31
Did you upgrade your netflix account to the 4k plan?
I watched 3 episodes of Narcos before I realized it was still 1080 and had to upgrade to the more expensive plan
boojitede is offline
post #10416 of 14223 Old 11-19-2016, 04:44 PM
Quoted: 43 Post(s)
Liked: 24
As you guys can see I have the hdmi Uhd color on and when I watch the 4K hdr movies on the k8500 this comes out
post #10417 of 14223 Old 11-19-2016, 05:19 PM
cmdrdredd's Avatar
Quoted: 4254 Post(s)
Liked: 4545
Is this connected through an AVR or sound bar? If so then plug it directly into the tv.
LG 65" B7A OLED, Samsung 55" JS9000, Sony 43" x800e, Denon AVR-X2200w 5.1.2, PS4 Pro, Nintendo Switch, Gaming PC(GTX 1080ti + 4.7Ghz 8700k), Sony UBP-x800, Philips BDP-7501, Oppo BDP-203, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #10418 of 14223 Old 11-19-2016, 06:22 PM
Dan Hitchman's Avatar
Quoted: 4636 Post(s)
Liked: 2704
Amazon's single season of Mad Dogs looks amazing in 4k and HDR. It really takes advantage of the detail and the nuances of both. Too bad it probably won't show up on UHD Blu-ray as it would, hopefully, have a greater bit rate. It was also a surprisingly enjoyable show too, though on the violent side.
And that's the problem with streaming... they compress the hell out of their content.
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is online now
post #10419 of 14223 Old 11-19-2016, 07:06 PM
Quoted: 43 Post(s)
Liked: 24
It's connected to a avr how can I use my receiver then ?
post #10420 of 14223 Old 11-19-2016, 07:19 PM
bobknavs's Avatar
Quoted: 2337 Post(s)
Liked: 1664
If you have a receiver that doesn't support 4k/HDR passthrough, you connect one HDMI output of the UBD-K8500 directly to the TV, and the second (for audio only) to the receiver. Choose the K8500 settings to match.
(I'll spare you a "search the thread" posting. With the number of posts, it gets ridiculous.)
bobknavs is offline
post #10421 of 14223 Old 11-19-2016, 08:07 PM
leedesert's Avatar
Quoted: 254 Post(s)
Liked: 132
So what does this new update do that just got pushed to my player?
leedesert is offline
post #10422 of 14223 Old 11-19-2016, 08:21 PM
Quoted: 43 Post(s)
Liked: 24
Thank you
post #10423 of 14223 Old 11-20-2016, 02:28 AM
etp
etp's Avatar
Quoted: 23 Post(s)
just set mine up last night. Any leads on a larger remote for bigger fingers?
ETP
etp is offline
post #10424 of 14223 Old 11-20-2016, 02:42 AM
tor ove's Avatar
Quoted: 62 Post(s)
Bigger and better remote.
TimWelborn likes this.
tor ove is offline
post #10425 of 14223 Old 11-20-2016, 02:53 AM
etp
etp's Avatar
Quoted: 23 Post(s)
Price is very good. Anyone use this on a 8500?
Many thanks.
ETP
etp is offline
post #10426 of 14223 Old 11-20-2016, 03:53 AM
tor ove's Avatar
Quoted: 62 Post(s)
Yes, several of us use it.
And it has more functions too.
Dedicated buttons for fast forward and rewind.
Dedicated buttons for sound track and subtitles. (These also work on Netflix, so no need to get into the language menu).
If you have a Samsung tv, in will also control channel + -, mute sound, as well as the volume up/down, source and power.
And if I remember correctly, the "[email protected]"-key on the remote, takes you to your app-screen.
tor ove is offline
post #10427 of 14223 Old 11-20-2016, 04:07 AM
etp
etp's Avatar
Quoted: 23 Post(s)
Ordered one.
Saw some talk that the Samsung TV remote may work also. Will check the buttons today.
ETP
etp is offline
post #10428 of 14223 Old 11-20-2016, 06:37 AM
Quoted: 43 Post(s)
Liked: 24
Anyone know any good settings for the k8500 on user settings with the hu9000?
post #10429 of 14223 Old 11-20-2016, 06:39 AM
Quoted: 99 Post(s)
Liked: 7
Is Netflix HDR available on this yet? I am waiting for it to be available on this player or my JS8500 TV.
Jumpem is online now
post #10430 of 14223 Old 11-20-2016, 06:56 AM
rlb
rlb's Avatar
Quoted: 2268 Post(s)
Liked: 1914
No, and no date has been announced. Per numerous posts, Samsung has announced that the JS Series displays will get the Netflix HDR app in December.
Sony XBR75Z9D, Samsung 65F9000 , Yamaha CX-A5200 & Outlaw 770
Samsung K8500, OPPO 103-D, Genie 2 and C61Ks, Roku Ultra, ATV4K, and Harmony Elite
rlb is offline
post #10431 of 14223 Old 11-20-2016, 07:06 AM
Liked: 5
The latest update fixed a Netflix issue for me. Every single time I tried watching it would crash out the moment an episode loaded. Then I would open it again and things were fine. After the update that no longer happens. Thank goodness as that was getting very old very quickly.
RestoredSparda is offline
post #10432 of 14223 Old 11-20-2016, 07:11 AM
Kage's Avatar
Quoted: 112 Post(s)
Yesterday I received my 4th Samsung UBD-K8500 and I updated it to the lasted firmware. This one has the same issues as the other three that I tried. The issue is that it it has HDCP handshake issues to my Yamaha RX-A860 receiver and also connecting the K8500 to my Sony 55BXR930 directly. Its not the HDMI cable or the HDMI ports. My Xbox One S does not have this kind of issue. I will be returning the K8500 and wait for the second gen Ultra 4k Bluray players. For the time being, I will use my Xbox One S for watching 4k blu-ray movies, 4k Netflix streaming, and use my Sony BDP-S6500 for watching blu-ray movies.
Kage is online now
post #10433 of 14223 Old 11-20-2016, 07:37 AM
tor ove's Avatar
Quoted: 62 Post(s)
Just for the kicks of it.
Try using the XBox One S HDMI-cable directly into your tv. Just to make sure.
tor ove is offline
post #10434 of 14223 Old 11-20-2016, 08:01 AM
cmdrdredd's Avatar
Liked: 4545
When going to the TV you have to turn on the enhanced mode for the input you are using. I had trouble with the K8500 through my AVR so I had to use the 2 HDMI cable method.
post #10435 of 14223 Old 11-20-2016, 08:46 AM
Musician's Avatar
Quoted: 2656 Post(s)
Liked: 5321
I guess you just wanted to let us all know you have extremely bad luck what with four K8500 UHD Blu-ray players since you have ruled out everything else.
Just for kicks, are those HDMI Premium Certified cables you are using to hook up the player to the TV? As you might have read in this thread (because it is discussed almost daily) the K8500's Home screen is displayed at 8bit 4:4:4 60hz which uses close to the full 18.0 Gbps bandwidth permissible under the HDMI 2.0 spec (almost double the bitrate under which conventional "high speed" cable testing tops out).
Rudy1, aaronwt, rlb and 7 others like this.
Samsung UN78HU9000 & SEK-3500U/ZA - Firmware 1540.3
Samsung UN40HU7000 & SEK-3500U/ZA - Firmware 1540.3
Samsung UBD-K8500 UHD Blu-ray Player; Apple TV 4K
Arris VIP5662W UHD Whole Home DVR; Chromecast Ultra
Marantz SR7005 Receiver; Magnepan Speakers; Martin Logan Subwoofer
Musician is offline
post #10436 of 14223 Old 11-20-2016, 09:13 AM
Quoted: 99 Post(s)
Liked: 7
Thank you for the information. I don't keep up with this and the JS8500 thread regularly.
post #10437 of 14223 Old 11-20-2016, 09:45 AM
CCsoftball7's Avatar
Quoted: 1695 Post(s)
Liked: 1287
Interesting some of us have had zero issues. It can't all be blind luck.
Sony XBR75X940C & XBR65A1E Samsung UBD K8500
My Recommended Daytime Settings Apps(Video), My Recommended Daytime Settings Apps, My non-HDR and HDR Settings, Setting HDMI to show no overscan
Sony XBR75X940C, Samsung UBD K8500, Roku Ultra, DirecTV RVU and C61K, Chromecast Ultra
CCsoftball7 is offline
post #10438 of 14223 Old 11-20-2016, 10:11 AM
jong1's Avatar
Quoted: 527 Post(s)
Liked: 522
Unfortunately, it's exactly that. Whatever some articles online will tell you, no high speed cables were designed to work @18Gbps, have not been tested to work with HDMI 2.0 sources and while, with short cables, they may work, often they will not, especially @>15ft, but even @3ft!
On the plus side, if they do work with the Samsung menu on a recent UHD TV, that supports 4K/60 4:4:4, the cable is good for anything! Make sure you are not using a Yamaha AVR though, as by default they use a 4K Mode that removes all video modes >9Gbps, so forcing the Samsung to use 4K/60 4:2:0 8-bit, although this can be changed in Advanced Setup. I know a few people with Yamaha AVRs that didn't discover this setting and didnt realise they were not getting the full UHD experience.
jong1 is offline
post #10439 of 14223 Old 11-20-2016, 01:01 PM
BiggAW's Avatar
Quoted: 829 Post(s)
Liked: 245
The problem I have is that while I am currently 7 or 8 feet away from my 65" JS850D, 4k and 1080p streaming look amazing, but Comcast is so bad that it's borderline unwatchable at that distance and screen size. I would argue that the difference between 1080p and 2160p is quite noticeable at that distance.
BiggAW is offline
post #10440 of 14223 Old 11-20-2016, 04:26 PM
Quoted: 43 Post(s)
Liked: 24
Is there a reason why every time I turn on the k8500 the backlight is always on 20?
Reply Blu-ray Players
color calibration , hdr player , member , settings
