Official Samsung UBD-K8500 4K HDR Ultra HD Blu-Ray Player Owner's Thread - Page 399 - AVS Forum | Home Theater Discussions And Reviews
 40557Likes
post #11941 of 14378 Old 02-18-2017, 10:22 AM
poppagene's Avatar
Quoted: 903 Post(s)
Liked: 836
Originally Posted by dicksop View Post
cAN YOU ADVISE HOW TO DO THAT?
http://www3.jvckenwood.com/english/d...rs400_uhd.html
UN48JS8500 UN55HU6950 w/SEK-3500U UN40HU6950 w/SEK-3500U UBD-K8500 UN37C5000
poppagene is online now
post #11942 of 14378 Old 02-18-2017, 10:22 AM - Thread Starter
Super Moderator
teachsac's Avatar
Quoted: 1436 Post(s)
Liked: 2518
Please refer to the JVC thread for that.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #11943 of 14378 Old 02-18-2017, 11:13 AM
galonzo's Avatar
Quoted: 1558 Post(s)
Liked: 2170
Originally Posted by DaMacFunkin View Post
On the Oppo 203 it has been found that THD/Atmos plays back from m2ts files on USB or Network fine, anybody tried it on the K8500?
Remuxing to m2ts can be a bit of a fiddle because tsMuxer does not recognize Atmos, but there are other ways to do it.
Tried it, still no go on the k8500
Main: XBR-85X950H | X4500H (5.1.4) | UDP-203 | TiVo Bolt | 2019 Shield Pro | PS4 Pro | CCU
2nd: XBR-65X950G | LG LAS855M | UBD-K8500 | TiVo Mini | ATV (4thGen)
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K | Roku P+ (4630)
FS - Dr. Strangelove (1964) and other UHD Digital codes (and some HD codes)
galonzo is offline
post #11944 of 14378 Old 02-18-2017, 11:18 AM
bobknavs's Avatar
Quoted: 2900 Post(s)
Liked: 2094
Originally Posted by shyyour View Post
I dont know if this is the right thread, if it isnt please direct me to the thread.
I have a non hdcp 2.2 receivers, a projector and im about to buy a 4K TV. I plan to plug the Samsung directly to the TV or use the dual hdmi cable method.
How do i connect the Samsung to the projector without having to swap HDMI cables? Is there a splitter that can handle 4k and 1080p concurrently (from the splitter one cable to 4K TV and other to Pre/pro). Is there anyone here that has a similar setup, i'll be grateful to know how you handled it.
I've never used one, but there are active HDMI switches available. I see some at Amazon for less than $50. The obvious down side is an additional remote, but it's better than swapping cables.
This isn't intended as a recommendation, but it might serve as a starting point for further research.
bobknavs is offline
post #11945 of 14378 Old 02-18-2017, 12:22 PM
Quoted: 400 Post(s)
Liked: 113
Thanks never heard of active HDMI switches, ill do some research.
Thanks again
Theater: JVC-RS440 & Elite 120". 7.2.4:T1, CS2, FXiA4, RTiA1, 620-RT & Dual 18" DIY Cyclops Subs. Marantz AV7704, Crown XLS(x5), UPA-700, UBP-X800, DP-UB424, ATV 4K & Shield.
Lounge: Benq HT1075, Elite 106" & Sony 75X900F. 7.2.4:RTiA3, CSi5, 65-RT(x4), MC60, RBH I-12 & SVS PB12-NSD. Denon X4300H, Crown XLS(x2), Amp 100v2(x2) & Shield.
shyyour is offline
post #11946 of 14378 Old 02-18-2017, 04:52 PM
dan webster's Avatar
Quoted: 304 Post(s)
Liked: 311
I just got the sammy player together with a fury integral to go to my jvc 4910 projector. Any tips on what settings to use on them. They come tomorrow. The way i believe it should work is sammy player to fury to marantz processor to projector. I tried the fury with a fire tv and could only get it to work with the fury between the fire tv and receiver.
Dolby Atmos 7.2.4 Yamaha CX-A5200 Gemstone 200x7 Emotiva upa-500 amps
Oppo 103 panasonic ub820 Ultra HD Blu-ray Jvc RS3000 projector
Eulenvusion 130 2.35 screen Golden Ear Triton 5 L&R
super center XXL triton 7's sides Emotiva T1 rears
4 RSL C34 in ceiling SVS PB2-plus sub SVS PC13 ultra sub
dan webster is offline
post #11947 of 14378 Old 02-18-2017, 05:00 PM
cyclones22's Avatar
Quoted: 141 Post(s)
Liked: 177
I'm considering buying the K8500 used from my sibling (they purchased an OPPO 203) for a good price for my new OLED UHD display. I likely would only play UHD discs on it only. For apps, I would use the streaming apps already installed on the OLED and for any other media files (HRA music, 1080P MKV/M2TS) I would continue to use my OPPO 103D. My question is would it be worth it for me to purchase the used K8500 considering my planned usage for it, or should I go with a different UHD disc player? Thanks!
Denon X4200W, Emotiva XPA-5
Klipsch RF-7II Front Cherry (x2), RC-64II Center Cherry, RP-280FA Surround/Atmos (x2), RP-140SA Atmos (x2)
SVS SB-2000 Subwoofer (x2)
OPPO BDP-103D, Sony UBP-X800, Synology NAS
LG OLED65C6P
cyclones22 is offline
post #11948 of 14378 Old 02-18-2017, 08:12 PM
Mark Dymek's Avatar
Quoted: 114 Post(s)
Liked: 47
The picture quality of this player is gorgeous. That being said I'd call it a low end device as it doesn't have some advanced features like SACD or dvd-a that your oppo does.
That said if you don't care about that get it.
Sent from my XR6P10 using Tapatalk
cyclones22 likes this.
Mark Dymek is offline
post #11949 of 14378 Old 02-18-2017, 08:22 PM
jpfe8851's Avatar
Quoted: 62 Post(s)
Liked: 38
Unless you're going to invest heavily in a 4K BD library the K8500 will suffice. For a 1st gen unit, it does a pretty good job. I would have waited for 2nd gen except I got a great price on one. I'll probably replace it with the Sony x800 or one of the new Panasonics when they are released. As I will mostly purchase Ultra 4K discs from now on, I think a better player would be advised. Too many little niggles with HDMI with the Sammy.
jpfe8851 is offline
post #11950 of 14378 Old 02-18-2017, 08:26 PM
BiggAW's Avatar
Quoted: 1046 Post(s)
Liked: 336
I'm having a weird audio problem. I have an older Onkyo AVR that does not have HDCP 2.2 or Atmos/DTS:X, but it can handle DTS-HD MA just fine. The problem is, with the UBD-K8500, the DTS-HD MA stops working after a few minutes, usually when it goes from the opening screen to the actual movie, and would have to "re lock" on the HDMI audio, the AVR goes to "No Signal" and stays that way until I reboot the UBD-K8500, and then it works again. If I output DTS from the UBD-K8500, it's fine, and the AVR is definitely decoding DTS-HD MA, as it shows up at "DTS-HD MSTR" on the AVR for a couple of scenes, and then stops working.
I'm trying to figure out if this is a player or AVR issue. My AVR just went in for an HDMI board recall, but it seems to work with other HDMI sources now, and it works fine with DTS or DD over optical from the UBD-K8500 through the TV or anything else (Roku, HTPC, TiVo, other TiVo, Nintendo, other Nintendo, etc).
BiggAW is offline
post #11951 of 14378 Old 02-18-2017, 08:28 PM
Mark Dymek's Avatar
Quoted: 114 Post(s)
Liked: 47
Haven't had and issues with mine. Granted only had it a day. Why do you say only if you don't invest in 4K? It's a 4K player. Are you referring to the fact that it doesn't do DV?
Larry Rosenberg likes this.
post #11952 of 14378 Old 02-18-2017, 09:09 PM
jpfe8851's Avatar
Quoted: 62 Post(s)
Liked: 38
Actually, what I said was "only if you're going to invest heavily in a 4K Library. If you're just going to buy a handful of 4K discs, it doesn't make much sense to buy an Oppo 203 or Pana 900, does it?
Like I also said, it's a pretty good player. I never said it's a bad player but they do have issues. You will find something that doesn't play right or HDMI handshaking problems sometime unless they fix it with firmware. Give it time...
It was not worth its original asking price IMO. But it was first and that counted for something at release.
Edit: PS. Nothing does DV yet. That's something that won't concern me as I am not replacing my TV, AVR or player just for DV.
jpfe8851 is offline
post #11953 of 14378 Old 02-18-2017, 09:24 PM
Adamd's Avatar
Quoted: 1298 Post(s)
Liked: 722
Do you guys know what setting is the best to use in the picture menu? I've read many different things, some say user is the best and others say standard.
Adamd is offline
post #11954 of 14378 Old 02-19-2017, 02:51 AM
mrtickleuk's Avatar
Quoted: 6240 Post(s)
Liked: 9069
Standard is marginally more accurate than "User mode with all zeros". This was discussed on this thread recently, do a search to find it.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #11955 of 14378 Old 02-19-2017, 02:53 AM
mrtickleuk's Avatar
Liked: 9069
Originally Posted by acefr View Post
Back to the K8500: HDMI Color Format setting in 4:4:4 or AUTO does not matter. When I played the Billy Lynn 60FPS UHD disc, K8500 automatically changed the chroma subsampling to 4:2:0. When I played Arrival 24FPS UHD disc, K8500 changed to 4:4:4. The only difference the HDMI Color Format setting makes is in the Menu screen. If set 4:4:4, the Menu is always in 4:4:4. If in AUTO, it could be in 4:2:2 or 4:2:0, so for those who have HDMI bandwidth issues on the Menu screen, it makes sense to leave it in AUTO.
I think it's worth editing the FIRST POST on this thread to make this very clear. At the moment it implies Auto or 4:4:4 are equivalent.
_______________
post #11956 of 14378 Old 02-19-2017, 06:39 AM
Adamd's Avatar
Liked: 722
Great found it, thanks!
Musician likes this.
Adamd is offline
post #11957 of 14378 Old 02-19-2017, 11:28 AM
Halichopter's Avatar
Quoted: 38 Post(s)
Originally Posted by Ted Brogan View Post
It's very simple, just hold the button down. After a second or so, you will notice a "x2" show up to the left of the progress bar (and this increases if you hold the button down). Now if you let go of the button, it will continue to fast forward (or rewind) at that speed and you must then tap Play to resume normal play.
I was thinking I was going to order an alternative remote for this, but after only a couple days using it, I'm perfectly fine with it. The only thing I miss is a single tap button for subtitle toggling - but none of the alt remotes I could find have that either.
Thanks Ted,
I was never holding the button down, I'm used to pushing once for 1x, twice for 2x etc.
Hal
Projector: Epson 5040UB
AVR: Marantz SR7010
Blu-Ray: Samsung UBD-K8500
Streaming: Roku Ultra
DVR: Tivo Roamio
Speakers: 5.1.2 System with five B&W M-1s, Subwoofer: B&W ASW 608
Halichopter is offline
post #11958 of 14378 Old 02-19-2017, 01:33 PM
ToddR's Avatar
Quoted: 112 Post(s)
Liked: 120
I've had mine over a week now. Trying to see if I can go indefinitely without ever using its remote.
ToddR is offline
post #11959 of 14378 Old 02-19-2017, 02:08 PM
Rudy1's Avatar
Quoted: 1975 Post(s)
Liked: 3284
I've had mine for a year now, and never even unwrapped the remote. ...I use my Harmony remote to control everything.
Definition of "Stupid": Knowing the truth, seeing the truth, but still believing the lies.
Rudy1 is offline
post #11960 of 14378 Old 02-19-2017, 07:59 PM
BiggAW's Avatar
Liked: 336
So I swapped the cable out from a Redmere cable to an AmazonBasics cable, restarted the UBD-K8500, and now it seems to be working OK, I've gotten through several minutes of The Revenant with DTS-HD MA 7.1 running. This is completely different from the behavior of the UBD-K8500 before swapping the cable out, where it wouldn't get 30 seconds of DTS-HD MA. The UBD-K8500 seems to be very picky about it's audio cable, as the Redmere cables have served me well for my entire setup when I had 1080p, and still serve me very well for the entirety of the 1080p side of my current setup (Nintendo, 2 TiVos, HTPC, DVDO EDGE).
BiggAW is offline
post #11961 of 14378 Old 02-20-2017, 07:17 AM
rlb
rlb's Avatar
Quoted: 2290 Post(s)
Liked: 1936
Any HDMI cable should work for the audio. Are you sure you have the Redmere cables running in the correct direction?
poppagene likes this.
Sony XBR75Z9D, Samsung 65F9000 , Yamaha CX-A5200 & Outlaw 770, Harmony Elite
Samsung K8500, OPPO 103-D, Genie 2 and C61Ks, Roku Ultra, ATV4K, FireTV Stick 4K, and Nvidia Shield TV Pro
rlb is online now
post #11962 of 14378 Old 02-20-2017, 09:45 AM
umenon's Avatar
Quoted: 989 Post(s)
Liked: 352
My 8500 is on the way ... quick question does it support Youtube HDR? I did a search and could not find anything on the topic. Thanks!
umenon is offline
post #11963 of 14378 Old 02-20-2017, 10:00 AM
NorthJersey's Avatar
Quoted: 576 Post(s)
Liked: 246
no it does NOT
mrtickleuk likes this.
NorthJersey is offline
post #11964 of 14378 Old 02-20-2017, 01:58 PM
BiggAW's Avatar
Liked: 336
Yup, they are running in the right direction. I have used Redmere cables successfully for several years with 1080p, my previous setup with a 60" 1080p TV was done entirely with Redmere. They only support HDMI 1.4 AFAIK, and I don't use them on the 4k side of my setup (just a Roku and the UDP-K8500's video connection) but nonetheless, it doesn't seem to like the cable for DTS-HD MA. It works fine for DTS or lower formats. Now that I know what the issue is, I'll treat the audio connection as part of the 4k side of my setup, even though it's technically only HDMI 1.4. I'll have to pick up some more Amazonbasics cables and just use those, as I've had good luck with them, but a lot of problems with off-brand/unmarked HDMI cables that I had laying around on the HDMI 2.0 side of my setup.
You do NOT want to use any of the apps on this thing- the UI and apps are a mess. It's a decent UHD-BD player, although if I were buying today, I'd probably buy the UDP-203 instead. This thing was the only one out when I got it.
BiggAW is offline
post #11965 of 14378 Old 02-20-2017, 02:45 PM
jpfe8851's Avatar
Quoted: 62 Post(s)
Liked: 38
No, but a Chromecast Ultra does.
Terminader likes this.
jpfe8851 is offline
post #11966 of 14378 Old 02-20-2017, 03:33 PM
MALICIOUS ONE's Avatar
Quoted: 57 Post(s)
Liked: 65
You sir rock! I have the premium monoprice certified cable, was using 4:4:4 instead of "Auto", & I was having to wait upwards of 5 minutes to have the menu show when booting up the TV at the same time. Now with "Auto", instead of 4:4:4 it shows the menu screen instantly I start the TV & Blu-ray player. Wish I knew & did this eight months ago. Thank you!
acefr likes this.
Samsung UN65JS8500/Samsung UBD-K8500/Outlaw 5000 amp/Onkyo TX-RX830 using 7.2.4/Xbox One X w/Kinect
XBL Gamertag: MALICIOUS ONE
MALICIOUS ONE is offline
post #11967 of 14378 Old 02-20-2017, 05:05 PM
Quoted: 386 Post(s)
Liked: 277
Update 1010.1 available here: http://www.samsung.com/us/support/ow...ayer-ubd-k8500
Anyone have it installed? If so, have you noticed any changes?
mr b, aaronwt, galonzo and 1 others like this.
TB4XSBC is offline
post #11968 of 14378 Old 02-20-2017, 05:09 PM
jedurocher's Avatar
Quoted: 110 Post(s)
Liked: 58
The Amazon app works just fine and does great HDR if you haven't invested in Roku or something else.
MALICIOUS ONE and galonzo like this.
JD
"Listen to advice and accept instruction, and in the end you will be wise." Proverbs 19:20
jedurocher is offline
post #11969 of 14378 Old 02-20-2017, 05:43 PM
poppagene's Avatar
Quoted: 903 Post(s)
Liked: 836
Apps are fine on this. I thought the Oppo doesn't have any apps at all
Have any of the Oppo blu rays had any streaming apps?
post #11970 of 14378 Old 02-20-2017, 06:06 PM
roque13's Avatar
Quoted: 139 Post(s)
Liked: 161
Curious if anyone has installed it yet also?
roque13 is offline
Reply Blu-ray Players
color calibration , hdr player , member , settings
