Official Samsung UBD-K8500 4K HDR Ultra HD Blu-Ray Player Owner's Thread - Page 416 - AVS Forum | Home Theater Discussions And Reviews
 40489Likes
post #12451 of 14321 Old 04-20-2017, 06:33 AM
Liked: 0
Thanks guys, I am gonna use the warranty and Samsung are picking it up tomorrow to give it a once over and repair any issues - would rather play it safe than have a faulty unit.
michaeldc is offline
post #12452 of 14321 Old 04-20-2017, 07:15 AM
galonzo's Avatar
Quoted: 1475 Post(s)
Liked: 2013
Originally Posted by jjone174 View Post
I just purchased this Blu-ray player to accompany my Samsung 55JS8500 (2015) and so far have been very pleased. I have thumbed through this thread, which is very long, but didn't get a clear answer to the below questions. Any insight or guidance would be greatly appreciated. Thanks to all!
1.) Can this Blu-ray player play 4K HDR videos from the YouTube app? My 2015 Samsung tv's app unfortunately will not play them.
No, only the 2016+ Sammy TVs and the Chromecast Ultra do this (only 4K is supported by this player's YT app).
2.) Should I set the resolution to 2160P and allow the Blu-ray player to handle all of the upscaling for non native 4K content? Other option would be to set the Blu-ray player to 1080P when watching standard Blu-rays and allow the tv to upscale to 4K.
You can use BDWise in the player to play disks at their native resolution automatically, although it is recommended to be sure to turn BDWise OFF in your TV (under MENU>>SYSTEM>>GENERAL)
3.) When watching standard Blu-rays (1080P), should I turn the HDMI UHD Color setting on my tv for my Blu-ray players source input back to off? The 2015 Samsung tvs don't automatically detect the source input and adjust.
This is the very reason I use my old BRP on a separate HDMI input for HD BRs; besides this setting, there are a few others that need to be changed for HDR (i.e. Gamma needs bumped up 2 ticks from your normal setting, I use SMART LED on High for HDR, and optionally Dynamic Range could be set differently)
Answered in red above
MALICIOUS ONE and Musician like this.
Main: UN78HU9000/SEK-3500 | X4500H (5.1.4) | UDP-203 | TiVo Bolt | 2019 Shield | PS4 Pro | Roku P+ (4630)
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | TiVo Mini | Roku P+
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - Heat (1995) and other UHD Digital codes (and some HD codes)
galonzo is offline
post #12453 of 14321 Old 04-20-2017, 08:31 AM
jjone174's Avatar
Quoted: 28 Post(s)
Liked: 32
Galonzo,
Thanks for your response and input!!
1.) Understood about the YouTube app.
2.) I didn't like the BD Wise settings and prefer to use a different mode. With that being said, what would you recommend in regards to the BR player vs. the tv doing the upscaling? I would assume the BR player would do better considering that is what it's designed for, right?
3.) I don't have an old standar BR player so I'll be using this for all types of BRs. Considering this, your comments tell me I would need to turn UHD HDMI Color off on my tv for the BR players source when watching a standard BR, correct?
Thanks again for all the help!
jjone174 is offline
post #12454 of 14321 Old 04-20-2017, 09:20 AM
Quoted: 41 Post(s)
HDMI Deep Color
Originally Posted by Agentbolt View Post
Awesome, that's the info I needed. Is Deep Color what's causing the crushed blacks issue? You've given me the correct settings to use (which I appreciate, thanks!) but I'm still curious why YCbCr 4:4:4 would register as a 0-255 signal to my projector. It's not just an EDID glitch, the picture looks awful (crushed blacks) unless I leave the projector set to "PC" or "Auto" mode.
Folks - It was great to see this. It exactly explains what happened with my set-up a few weeks back. I replaced my 2015 Samsung (65JU6500) with a new Sony 940E. The HDMI length to my Denon 4200W was 25 feet. To accommodate the Sony, we needed a 33 foot HDMI cable. UHD videos played fine on my 8500 ... but, after the installers left, I noticed 'snow'. Unfortunately with the Sammy, the only Y:CbCR option is 4:4:4, so I thought that was the cause. Then, the snow went away when I switched off Deep Color! Everything works fine now, but when I switch out my Epson 5030 PJ for a 4K projector, I will be sure to have a 18 gb 'pipe'.
Jim
mrtickleuk likes this.
jreash is offline
post #12455 of 14321 Old 04-20-2017, 10:02 AM
galonzo's Avatar
Liked: 2013
Galonzo,
This setting is the passthrough setting when available, and you are likely seeing the TV automatically switching picture modes for BD Wise, which needs to be defeated initially by turning it off in the TV (like I described) and making sure Movie is selected (or whichever mode you were using, Movie is the most accurate "out of the box"). Your more expensive TV was actually more so designed to upconvert any and every non-UHD video signal to fill all 3840x2160 pixels of its panel; that said, depending on your settings, it can be close, so test out a few HD BRs and see what you think.
This setting has less of an effect (if any at all) on HD BR than the other settings I mentioned that need adjusting for HDR.
Answered again in red above
galonzo is offline
post #12456 of 14321 Old 04-21-2017, 08:23 AM
Musician's Avatar
Quoted: 2716 Post(s)
Liked: 5615
Since you have a 2015 Samsung model you can turn BD Wise ON in the player settings and leave it OFF in the TV settings (where I have mine set to the Movie picture mode) and this will automatically output 1080p when it detects a standard blu-ray and 2160p when it detects a UHD disc and eliminate you having to remember to switch back and forth.
As you can see by the following post, the BD Wise setting on the K8500 provides the best setting when connected to a pre-2016 Samsung TV model following by Standard and then User set to all zeros...
https://www.avsforum.com/forum/149-bl...l#post43484850
For what it's worth somebody will disagree with this suggestion but ask them to show you their post with 11 Likes and charts prepared by @galonzo to back it up!
Samsung UN78HU9000 & SEK-3500U/ZA - Firmware 1550.0
Samsung UN40HU7000 & SEK-3500U/ZA - Firmware 1550.0
Samsung UBD-K8500 UHD Blu-ray Player; Apple TV 4K
Arris VIP5662W UHD Whole Home DVR; Chromecast Ultra
Marantz SR7005 Receiver; Magnepan Speakers; Martin Logan Subwoofer
Musician is offline
post #12457 of 14321 Old 04-21-2017, 10:36 AM
Ken Ross's Avatar
Quoted: 7433 Post(s)
Liked: 8325
For those that are interested, the K8500 is the only UHD BluRay player that can play 4K60p files from the USB input. I've tried the new Sony, Panasonic (I'm convinced this is the same player as the Philips) and the Philips, and only the Samsung plays these files without stutter.
umenon likes this.
Ken Ross is offline
post #12458 of 14321 Old 04-21-2017, 10:46 AM
UHD Addict
aaronwt's Avatar
Quoted: 9820 Post(s)
Liked: 6489
I had no issues playing 2160P60 files with my k8500 or my Sony x800. And actually my Sony played more of my 2160p files than the k8500 did. Although the k8500 played more audio formats from the files than the x800 did.
Sent from my Galaxy S6 using Tapatalk
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #12459 of 14321 Old 04-21-2017, 02:08 PM
Ken Ross's Avatar
Liked: 8325
I've had no luck with smooth 4K60p playback on any other player on both my B6 OLED & Sony 940c. The Sony player played 4K60p files created by my Panasonic GH5 via the USB input, but played them with the same stutter that the Philips & Panasonic did. In fact, even the new Samsung, although playing these files back better than the other non-Samsung players, had some stutter after playing 10 or so files consecutively. This was not true with the original Samsung UHD player. So even in the new Samsung, something has changed as it relates to USB playback.
BTW, these are .mov files recorded by the GH5 at 4K60p.
Ken Ross is offline
post #12460 of 14321 Old 04-21-2017, 02:21 PM
UHD Addict
aaronwt's Avatar
Liked: 6489
I was just using demonstration files I got off of the Internet. I only had a few that were 2160P60. Most of the ones I have are 2160P30 or 2160P24.
post #12461 of 14321 Old 04-21-2017, 07:26 PM
Quoted: 25 Post(s)
Liked: 3
So I just purchased this player to use on my 65" Samsung JU7100, and immediately, I noticed the colors are very washed and the screen is dim. I'm aware that there are settings that have to be set in order to get everything going properly, but I'd like to know if anyone has a sort of checklist of things to check for proper UHD and HDR display.
Seeko is offline
post #12462 of 14321 Old 04-22-2017, 06:12 AM
rlb
rlb's Avatar
Quoted: 2278 Post(s)
Liked: 1924
You don't say if you are playing a UHD HDR disk. If not, put one in the player and I suggest the following:
1) If your receiver is current and will handle hdmi 2.0a and HDCP 2.2, you can pass through the video to the JU7100. Otherwise send video to Samsung and audio to receiver.
2) Use following settings on the display: Use Movie mode and ensure HDMI UHD color for the applicable input port is "on". Set Smart LED to "high". Set Dynamic Contrast to "med" or "high". Color Space on "auto". Finally, adjust gamma upware "2 clicks" (i.e., if normally on 0, adjust to +2).
MALICIOUS ONE and galonzo like this.
Sony XBR75Z9D, Samsung 65F9000 , Yamaha CX-A5200 & Outlaw 770, Harmony Elite
Samsung K8500, OPPO 103-D, Genie 2 and C61Ks, Roku Ultra, ATV4K, and FireTV Stick 4K
rlb is offline
post #12463 of 14321 Old 04-22-2017, 08:20 AM
jjone174's Avatar
Quoted: 28 Post(s)
Liked: 32
For those of y'all with Samsung displays, what do you set the dynamic contrast to?
I love the way high makes the colors pop but medium seems to keep the flesh tones more accurate... What's y'alls thoughts? Thanks
jjone174 is offline
post #12464 of 14321 Old 04-22-2017, 09:27 AM
galonzo's Avatar
Liked: 2013
On my JS9500, Low to OFF (mostly OFF), on my HU9000, usually Medium to Low; so it really depends on which model you have. In my experience, High will clip details on both of my Sammy TVs.
Terminader likes this.
galonzo is offline
post #12465 of 14321 Old 04-22-2017, 12:23 PM
Quoted: 938 Post(s)
Liked: 424
Anyone having issues with amazon app? Playback issues. Freezes then play then studders. All functions lock up. Only amazon. Been using amazon tv instead but would prefer it on my player.
MarkMul1 is offline
post #12466 of 14321 Old 04-22-2017, 04:04 PM
thebignewt's Avatar
Quoted: 340 Post(s)
Liked: 94
Samsung UBD-K8500 vs UBD-KM85c?
The 85c costs a little more ($199 Amazon) but they both do 3D, which I need for my LG OLED65E6P TV. What's the difference between them, I can't tell from the website? Neither do DolbyVision I don't think. Thanks in advance.
[/B] LG OLED65E6P TV, Yamaha RX-V383 AVR with Paradigm speakers, Cableone STB, Samsung UHD BD player, AppleTV 4K[/B]
thebignewt is offline
post #12467 of 14321 Old 04-22-2017, 07:04 PM
aKa DaShiznit's Avatar
Quoted: 454 Post(s)
Liked: 284
Same player. The KM85c is the wholesale(Costco, BJ's) version and the K8500 is the retail(Best Buy,etc) version.
Sony XBR-65X930E (w/luminoodle)/Sony UBP-X800M2/Apple TV 4K/PS4 Pro/Xbox One X
Denon AVR-X6200W(Surround/Height)/Emotiva XPA-3(L/C/R)/AC Infinity Aircom T8 x2
DefTech SM 65 x3(L/C/R)/DefTech PM 1000 x4(Surround)/DefTech DI5.5R x4(Atmos/DTS X)
SVS PC-2000 x2(Subs)/Panamax M4300-PM(Main) & MD2(Subs)/Logitech Harmony Elite
aKa DaShiznit is offline
post #12468 of 14321 Old 04-23-2017, 05:23 AM
almost too old's Avatar
Quoted: 84 Post(s)
Liked: 122
Curious...
If anyone else has experienced this...go to play a UHD movie and the player reports that the TV (KS8000) is not UHD capable, and that the movie will play in 1080p. Has happened twice this week on the last 2 UHD movies I have watched (Patriots Day and Hidden Figures). Stopping the movie, ejecting the disk and restarting the movie solves the issue. I suspect it is a HDMI handshake thing. Any thoughts?
HDMI 1 > OCB HDMI 3, HDMI 2 > AVR and set to 2160p. HDMI and One Connect cables are firmly seated. HDMI cable is a Monster Black Platinum (got it for $28 @ BB before anyone shoots me, lol).
UN60HU8550FXZC / UHD w/ SEK-3500U, Arris VIP5662W Whole Home PVR, ONKYO TX-SR353, 4K Apple TV and UBD-K8500 /ZC
UN65KS8000FXZC /SUHD w/Arris VIP5662W Whole Home PVR, Denon AVR-S720W 5.1.2 and UBD-K8500 /ZC
almost too old is offline
post #12469 of 14321 Old 04-23-2017, 06:19 AM
Liked: 0
Hi all,
I'm trying to play mkv files (Dolby Atmos) on the UBD-k8500 via usb, however I can't get any audio.
its says the TrueHD isn't supported. Video works on some mkv files.
I was under the impression this player could handle DD+/TrueHD/Atmos 7.1 etc?
I want to try and listen to 'true' atmos clips.
http://thedigitaltheater.com/index.php/dolby-trailers/
Hybrid34 is offline
post #12470 of 14321 Old 04-23-2017, 06:37 AM
Liked: 0
I've done a bit of research and apparently this samsung player that can't support TrueHD/ 7.1 / DD+ etc? via the USB?
Is there anyway around this?
Hybrid34 is offline
post #12471 of 14321 Old 04-23-2017, 06:45 AM
poppagene's Avatar
Quoted: 885 Post(s)
Liked: 807
Take the HDMI cable back to best buy and get your money back. Get a certified premium cable from Monoprice.
https://www.monoprice.com/Product?p_id=15427
UN48JS8500 UN55HU6950 w/SEK-3500U UN40HU6950 w/SEK-3500U UBD-K8500 UN37C5000
poppagene is offline
post #12472 of 14321 Old 04-23-2017, 07:04 AM
galonzo's Avatar
Liked: 2013
... HDMI cable is a Monster Black Platinum (got it for $28 @ BB before anyone shoots me, lol).
Agreed; if you "Search This Thread" for "Monster", you'll find nothing but issues with those cables (even the $200, 35' Monster Cables UltraHD Black Platinum failed when tested by Sound & Vision)
Rudy1, umenon, mrtickleuk and 1 others like this.
galonzo is offline
post #12473 of 14321 Old 04-23-2017, 02:33 PM
bommai's Avatar
Quoted: 625 Post(s)
Liked: 204
I just bought the sams club version of this player. 4k disc works and is beautiful. Netflix and Amazon 4k work as well. I am using in with an Epson 5040ub projector. When I play a 3d bluray though it blanks out. I can hear the audio but no video. My projector supports 3d because I can use my older Sony bop-s6200 to play 3D using everything else the same. Is there a known issue. I am using hdmi to projector directly and second hdmi to connect to my receiver for audio.
bommai is offline
post #12474 of 14321 Old 04-23-2017, 05:16 PM
dubusduck's Avatar
Quoted: 158 Post(s)
Liked: 96
Try turning on your display first, then your player. It is an hdmi handshake issue. I have monoprice certified premium cables along with some other brands. Happens no matter what cable is installed.
almost too old likes this.
LG 65EF9500: Panasonic UB820; Sony UBP-X800; Yamaha CX-A5200; Polk LSI; Axiom Audio M5HP; SVS SB-13 Ultra; John 3:16;
dubusduck is online now
post #12475 of 14321 Old 04-24-2017, 08:46 AM
william06's Avatar
Quoted: 922 Post(s)
Liked: 511
Question. I have this uhd blu ray player. Attached to a samsung k950 soundbar. All. Attached to a non 4k pannasonic 65 zt60 tv its a great tv not wanting to part with yet. I reall like and look for atmos blu rays. When only available in uhd with atmos i have purcased them and the samsung down converts them to 1080 beautifullly. My question is are there any streaming servicees that has 4k with atmos that would do the same so i can play the atmos signal (down convert to 1080p) thanks for any help
william06 is offline
post #12476 of 14321 Old 04-24-2017, 08:59 AM
bobbino421's Avatar
Quoted: 1355 Post(s)
Liked: 874
I'm gonna say no for now. The only service is Vudu I believe and u need tv capable of of 4K to even access it. Plus it's only LG 4K only right now! Anyone on here correct me if I'm wrong?
bobbino421 is offline
post #12477 of 14321 Old 04-24-2017, 09:18 AM
william06's Avatar
Quoted: 922 Post(s)
Liked: 511
Thanks for the prompt reply
post #12478 of 14321 Old 04-24-2017, 09:20 AM
Stereojeff's Avatar
Quoted: 252 Post(s)
Liked: 162
3D Discs play perfectly on the Samsung on my Epson 6040 (same PJ as your 5040.)
Jeff
Stereojeff is offline
post #12479 of 14321 Old 04-24-2017, 10:33 AM
bommai's Avatar
Quoted: 625 Post(s)
Liked: 204
Jeff
I only tried one disk. May be I will try another one tonight and see.
bommai is offline
post #12480 of 14321 Old 04-24-2017, 07:07 PM
Howie411's Avatar
Quoted: 37 Post(s)
Weird issue with my UBD-K8500
So recently got Ice Age: 5 Movie Blu-Ray Collection. (1 of the 5 movies) Continental Drift, when I try to play it makes a really loud almost grinding noise when I put it in the drive. After about 20 seconds the player says it can't read the disc.
Now the interesting thing is, the disk works on my Samsung J7500 Blu-Ray, My Xbox One and my PC drive. So I don't think its a bad disc, though I don't have this issue with any other movies on the player. Any ideas?
Howie411 is offline
Reply Blu-ray Players
color calibration , hdr player , member , settings
