Official Samsung UBD-K8500 4K HDR Ultra HD Blu-Ray Player Owner's Thread - Page 423 - AVS Forum | Home Theater Discussions And Reviews
 40405Likes
post #12661 of 14253 Old 05-29-2017, 12:09 PM
Quoted: 12 Post(s)
Liked: 0
Originally Posted by Sal1950 View Post
It's a disc problem, I've seen it here and talked to a number of others on the forum with like issues. Without another player to test against I can't say if the 8500 is less tolerant of out of balance/center discs or not. But in every case I'm aware of, a different disc cured the issue.
I looked online and it says your 2300 if fully compatible.
"4K Ultra HD 60Hz video, 4:4:4 Pure Color sub-sampling, High Dynamic Range (HDR) and 21:9 video, 3D, and BT.2020 pass-through support on every input. "
So you should be good using one quality certified cable. If you have any issue get a Certified Premium HDMI cable from Monoprice, they will pass anything on today's market.
https://www.monoprice.com/product?c_...seq=1&format=2
Hi thanks for the help and taking the time to check. I bought another 4k disc and tried that plus different blu rays and no problems with any. Tried hacksaw ridge again and when the disc is first inserted it makes the noise but then subsides so isn't as bad as the first time.
Might see about returning it to Amazon.👍
Sent from my D6503 using Tapatalk
Mrtea_32 is offline
post #12662 of 14253 Old 05-29-2017, 01:30 PM
BuGsArEtAsTy's Avatar
Quoted: 715 Post(s)
Liked: 349
Does the Netflix app on this player work when video is output as 1080p to a display without HDCP 2.2?
On the Philips I just bought, the Netflix won't work at all, even though UHD Blu-ray will happily play at 1080p on such a display.
BuGsArEtAsTy is offline
post #12663 of 14253 Old 05-29-2017, 04:45 PM
p5browne's Avatar
Quoted: 4019 Post(s)
Liked: 3188
Samsung Canada: surprise, surprise, they're actually offering some free Fox 4K UHD Movies:
http://pages.samsung.com/ca/promotio...rc_20170209_EN
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is online now
post #12664 of 14253 Old 05-29-2017, 05:56 PM
Quoted: 715 Post(s)
Liked: 349
Not the K8500 though. M9500 required.
post #12665 of 14253 Old 05-29-2017, 08:16 PM
emilio1316's Avatar
Quoted: 38 Post(s)
Would it be worth picking one of these up for $99 with no remote? Used, but in good condition. And any recommendations on a cheap remote?
emilio1316 is offline
post #12666 of 14253 Old 05-29-2017, 10:28 PM
p5browne's Avatar
Liked: 3188
Just letting you know that Samsung actually has an offer out there. Usually Samsung freebies in Canada are few and far between!
UN65KS9800 - Mine
post #12667 of 14253 Old 05-29-2017, 10:37 PM
Quoted: 49 Post(s)
I have the K8500 connected into a sony 790 soundbar with the hdmi set to enhanced. Under the K8500 sound settings i have digital output set to pcm, pcm downsampling off, dynamic range control off, and downmixing mode at normal stereo. Is his correct to get the best sound quality out of blurays on my soundbar?
Kasfury is offline
post #12668 of 14253 Old 05-30-2017, 08:05 AM
Rudy1's Avatar
Quoted: 1966 Post(s)
Liked: 3270
I have the same setup in a bedroom. On the UBD-K8500, set DIGITAL OUTPUT to BITSTREAM UNPROCESSED, PCM DOWNSAMPLING to OFF, DYNAMIC RANGE CONTROL to OFF, and DOWNMIXING MODE to SURROUND COMPATIBLE. These settings will enable decoding of DTS, Dolby Digital, DTS-HD MA, Dolby TrueHD, Dolby Digital Plus, etc. by the Sony HT-CT790.
Definition of "Stupid": Knowing the truth, seeing the truth, but still believing the lies.
Rudy1 is offline
post #12669 of 14253 Old 05-30-2017, 08:25 AM
Quoted: 47 Post(s)
I have the Samsung attached to the "grown ups" TV upstairs, but am really debating about what to do with the "kids" TV in the playroom (Sony 850D). I'm leaning Xbox S because most of what they watch is streaming and I think they'd like to have Minecraft on it as well. The hesitation is that so many posts here and in other threads on AVS complain about the Xbox as a 4k Bluray device, which I'd definitely want to use it for sometimes. Am I just overthinking this?
Pupator is offline
post #12670 of 14253 Old 05-31-2017, 10:54 AM
Big Brad's Avatar
Quoted: 493 Post(s)
Liked: 628
Originally Posted by Mrtea_32 View Post
Thanks I'll check I have a denon 2300 so hopefully it will, if not would I then require 2 leads?
I also have a Denon 2300. Only one cable is needed for my K85C (Costco version of the K8500) to the Denon.
PSN ID/XBOX Live! Gamertag: BiffCo
Big Brad is online now
post #12671 of 14253 Old 05-31-2017, 12:08 PM
Sal1950's Avatar
Quoted: 543 Post(s)
Liked: 705
Absolutely if it works OK.
Just go to ebay and searh samsung blu-ray remote. They will all work and there are tons for under $10 like this
http://www.ebay.com/itm/Original-SAM...kAAOSwiONYQIlF
emilio1316 likes this.
Sony XBR75-X940D, Sony UBP-X800M2 UHD-BD, Xfinity X1 Voice DVR, Marantz AV-7703 Pre/Pro w/Auro, (3) Adcom GFA-545II amps, (2) Adcom GFA-535II amps for ATMOS speakers.
HSU Research 5.2 speaker system (4) HB-1 MK2, (1) HC-1 MK2, (2) STF-2,
Klipsch HT500 satellites (4) for ceiling mounted ATMOS playback
DIY Linux desktop w/Strawberry bit perfect media center. Emotiva Stealth DC-1 DAC
Sal1950 is offline
post #12672 of 14253 Old 06-02-2017, 03:41 PM
Axememan's Avatar
Quoted: 46 Post(s)
Liked: 40
used /refurbished harmony 650 remote off of Ebay.
Sony 65" 4K;Onkyo TX-NR838 Rx;Schiit Audio Freya Tube Preamp;Emotiva XPA-100 Monoblocks/Primaluna Prologue 5 Tube Amp-Front LR;Outlaw Audio M2200 Monoblock-Center ;Nvidia Shield TV 500Gb;Samsung UBD-K8500 4K Bluray;Sony BDP-S5100 Bluray;WD Media Player;Monoprice 15" Pa Speakers*Front LR;Klipsch RC62 Center;Epos Epic2-Heights;Bic PL200-Rear LR;SVS PC2000x2 & 20-39PCI.
Axememan is offline
post #12673 of 14253 Old 06-02-2017, 04:02 PM
cjmx2's Avatar
Looking for some Help and hoping someone can help me with the 4K handshaking problem I seem to be having between my ubd-k8500 and my 65ks8000 Samsungs. When I turn on the UHD color on the TV I get that bad message that seems all to common with the player:
The Content will be played in HD because the display or the HDMI input does not support HDCP 2.2...
I am under the impression that the ks8000 is HDCP compatible in all 4 inputs. I have tried several of the settings including turning off deep color and manually forcing the resolution and hdmi color to 4 4 4...I have the player directly connected to the one connect box and I tried several HDMI cables including a mono price certified for 18GBS...
Any one have a similar issue that they were able to fix....thanks!
cjmx2 is offline
post #12674 of 14253 Old 06-02-2017, 06:38 PM
Rudy1's Avatar
Liked: 3270
You will have to provide far more information than you have if you expect anyone to suggest a fix. Such as, how do you have the two units connected, and whether or not the error message occurs with all UHD disc titles you have tried. In the interim, I would recommend that you reset the BDP to factory settings, turn it off, disconnect the HDMI cable(s), and leave the unit alone for at least 30 minutes. Then reconnect the HDMI cable(s), then turn on the TV followed by the AVR. Set the input on the TV where you have the BDP connected to HDMI UHD COLOR ON before you turn the player on. Finally, turn on the BDP and begin the setup process all over again. If you are able to see the startup screen from the BDP, you know your HDMI cable is up to the task of passing the signal. Set the player as follows for use with your Samsung TV:
On the UBD-K8500:
Settings > Picture > TV Aspect Ratio: 16:9 Original
BD Wise: OFF
Resolution: Auto
Movie Frame (24Fs): Auto
DVD 24Fs Conversion: Auto
Fit Screen Size: Size 4 ( Your choice ) (Only applies to screen mirroring and Smarthub)
HDMI Color Format: Auto
HDMI Deep Color: Off
Preference setting:
Standard Mode, or while a movie is playing hit the Tools button and select user picture mode and set everything to mid point (zeroes).
Rudy1 is offline
post #12675 of 14253 Old 06-03-2017, 06:38 AM
DaGamePimp's Avatar
Quoted: 656 Post(s)
Liked: 674
I just picked up a K8500 and compared it to my Xbox One S (on a 65KS8000), the K8500 is superior regarding image quality and it's obvious even though it may not be considered a night & day difference (much like the UB900 vs K8500).
- Jason
jeep05 and Pupator like this.
HT = Epson HC4010 @133" / Marantz SR6013 7.3.4 Atmos / B&K 5000 II amp / Boston VR2/VR12/CR67 speakers / Rythmik 12" x2 / CV 15" / Panasonic UB820
Media Room = Sony 65x930e / Denon x3300 /Klipsch speakers /Velodyne subs /Sony x700 /PS4 Pro + PSVR/WiiU/PS3/360/Wii/ 2080 TI - 9900K PC / Multi-Arcade / Virtual Pinball TRE45ON
DaGamePimp is online now
post #12676 of 14253 Old 06-03-2017, 06:57 AM
Dreamliner's Avatar
Quoted: 1461 Post(s)
Liked: 773
- Jason
With default settings, I couldn't see a difference between the K8500, UB900 and X800. The UB900 does have an HDR slider than makes it look better, though.
Nice to see someone still rocking the Boston speakers though. I've got 2x VR3, 2x VR2, 6x CR77, 2x CR67 and a VR12. I shopped for tower replacements for the VR2s a few years ago and couldn't find anything I liked better for less than $1500 per speaker. Sometime after that, I found (and immediately bought) a pair of VR3s.
DaGamePimp likes this.
Dreamliner is offline
post #12677 of 14253 Old 06-03-2017, 08:03 AM
mrtickleuk's Avatar
Quoted: 5174 Post(s)
Liked: 7494
On the UBD-K8500:
BD Wise: ON if you have the BDP connected directly to the TV; the BDP will then output standard Blu-ray at 1080p.
No it won't he has a 2016 65ks8000 Samsung TV and Samsung dropped "BD Wise" for all their 2016 TVs onwards (if not before), so "BD Wise" won't be available.
(Samsung seems to to be doing their best to quietly airbrush "BD Wise" out of history!)
Rudy1, jeep05, galonzo and 1 others like this.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is online now
post #12678 of 14253 Old 06-03-2017, 08:10 AM
Rudy1's Avatar
Liked: 3270
Got it! Post corrected. I need to remember the features don't carry over if I'm going to swap TVs out every year.
jeep05, galonzo, Musician and 1 others like this.
Rudy1 is offline
post #12679 of 14253 Old 06-03-2017, 09:53 AM
william06's Avatar
Quoted: 902 Post(s)
Liked: 500
Are the 8500 netflix and amazon apps able to stream uhd 4k when using a 4k tv.
william06 is offline
post #12680 of 14253 Old 06-03-2017, 10:08 AM
joe221's Avatar
Quoted: 186 Post(s)
Liked: 60
Yes. Netflix need the 4x viewer choice and higher price.
Joe in West Los Angeles, CA
joe221 is offline
post #12681 of 14253 Old 06-03-2017, 10:11 AM
cjmx2's Avatar
resolved
Thanks Rudy1 that seemed to do the trick...no more HDCP problems!
On the UBD-K8500:
BD Wise: OFF
Resolution: Auto
Preference setting:
jeep05 and MALICIOUS ONE like this.
cjmx2 is offline
post #12682 of 14253 Old 06-03-2017, 10:14 AM
Rudy1's Avatar
Liked: 3270
Glad I could help. Enjoy the player.
Rudy1 is offline
post #12683 of 14253 Old 06-03-2017, 11:34 AM
william06's Avatar
Quoted: 902 Post(s)
Liked: 500
Thanks joe221
joe221 likes this.
post #12684 of 14253 Old 06-03-2017, 01:09 PM
kcgr's Avatar
Quoted: 77 Post(s)
Liked: 80
Anyone having problems with Deadpool 4K? I've gone through three discs. Two from Frys and one from BBuy. I even tried a second 8500 at Frys and it wouldn't play Dpool.
This is pissing me off. It just keeps spitting the disc out with the "specification" error.
kcgr is online now
post #12685 of 14253 Old 06-03-2017, 02:10 PM
mrtickleuk's Avatar
Liked: 7494
I have it and my copy works fine with this player.
_______________
post #12686 of 14253 Old 06-03-2017, 02:24 PM
kcgr's Avatar
Quoted: 77 Post(s)
Liked: 80
I guess I'll head back to BB and try another. They must have flooded the market with a batch of some bad discs. Either that or this production batch doesn't like Sammy players.
kcgr is online now
post #12687 of 14253 Old 06-03-2017, 03:05 PM
DaGamePimp's Avatar
Quoted: 656 Post(s)
Liked: 674
+1 (my K8500 was recently purchased from Fry's and my copy of Deadpool is from when it first released).
- Jason
post #12688 of 14253 Old 06-03-2017, 03:10 PM
Daryl L's Avatar
Quoted: 654 Post(s)
Liked: 450
Had Deadpool 4K for quite some time. Have watched it three times with the problem.
Sony XBR-55A9F OLED
Samsung SMT-H3272 HDC DVR Cable Box / Panasonic DP-UB820 4K BD Player
Roku Premium+ 4k / AppleTV 4K 4th Gen
Denon AVR-X4500H AV Receiver / Klipsch 5.1.2 Speakers
Daryl L is offline
post #12689 of 14253 Old 06-03-2017, 03:42 PM
mrtickleuk's Avatar
Liked: 7494
The player isn't that big. This sounds extreme but it might be easier to take the player there, if they'll let you test discs? Do other discs work ok for you?
_______________
post #12690 of 14253 Old 06-03-2017, 03:47 PM
kcgr's Avatar
Quoted: 77 Post(s)
Liked: 80
Well I wasn't leaving BBuy until I found a working copy. Fortunately disc #4 played. Bad Fox.... fix your QA/QC!
Daryl L, Robmidi and mrtickleuk like this.
kcgr is online now
Reply Blu-ray Players
color calibration , hdr player , member , settings
