Official Samsung UBD-K8500 4K HDR Ultra HD Blu-Ray Player Owner's Thread - Page 437 - AVS Forum | Home Theater Discussions And Reviews
 40519Likes
post #13081 of 14336 Old 09-14-2017, 11:38 AM
NorthJersey's Avatar
Quoted: 576 Post(s)
Liked: 246
Originally Posted by Stiler View Post
Posted a while back but never got an answer.
If I just want this player to output the source directly like you can do in other players what do I select? Like if I don't want it to mess with the picture (upscale, noise reduction, etc) and just want it to directly feed my a/v receiver the pure direct video/audio what do I put it on to do this?
I followed the setup that Bill Hunt provided (thedigitalbits.com), which is basically what you are looking for
look under the "setup" section
http://www.thedigitalbits.com/item/s...-uhd-bd-player
jackstar7 likes this.
NorthJersey is offline
post #13082 of 14336 Old 09-14-2017, 11:41 AM
galonzo's Avatar
Quoted: 1515 Post(s)
Liked: 2095
Originally Posted by tausifs View Post
Question , can this player output at 23.976 Hz for movies ? And specifically, 23.976 Hz for Amazon app movies ? Thanks.
Originally Posted by Quicksilv3r View Post
I gather you asking for FPS? Yes it does output 24 frames per second. As far as Amazon, I'm not 100% sure. I use my tv for Amazon, not my player.
Originally Posted by Dan Hitchman View Post
Yes, the player outputs 23.x for movies encoded that way (and, due to the newer BDA specs, 24 fps too). I'm not sure about the apps either.
Yes, 24p for Netflix and Prime confirmed.
Main: XBR-85X950H | X4500H (5.1.4) | UDP-203 | TiVo Bolt | 2019 Shield | PS4 Pro | Roku P+ (4630) | CCU
2nd: XBR-65X950G | LG LAS855M | UBD-K8500 | TiVo Mini | ATV (4thGen)
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - Star Wars Saga ('77 - '19) and other UHD Digital codes (and some HD codes)
galonzo is offline
post #13083 of 14336 Old 09-14-2017, 12:21 PM
jwestpfahl's Avatar
I have a same setup - K8500 and Denon X2000, but my TV also uses the SEK-3500 to handle the 4K video. I have no issues using two HDMI cables. One for video and one just for sound going to the X2000.
jwestpfahl is offline
post #13084 of 14336 Old 09-14-2017, 12:26 PM
tausifs's Avatar
Quoted: 12 Post(s)
Thanks Galonzo. Is it 24p or 23.976p ?
tausifs is offline
post #13085 of 14336 Old 09-14-2017, 12:27 PM
tausifs's Avatar
Quoted: 12 Post(s)
And does it auto select the frame rate or can you select manually ?
tausifs is offline
post #13086 of 14336 Old 09-14-2017, 12:48 PM
tausifs's Avatar
Quoted: 12 Post(s)
... and if so, can 23.976p frame rate be selected manually in the settings ?
tausifs is offline
post #13087 of 14336 Old 09-14-2017, 01:05 PM
Quicksilv3r's Avatar
Quoted: 524 Post(s)
Liked: 408
it automatically goes to 24p, and no you can't change it
tv: Samsung UN75MU800, Receiver: Denon AVR 730H, speakers: 4x M&K S-1B and M&K S85c for center, sub: MKsound V12 HTPC, Samsung UBP-K8500, Rogers Digital PVR, Chromecast Ultra
Quicksilv3r is online now
post #13088 of 14336 Old 09-14-2017, 01:06 PM
galonzo's Avatar
Liked: 2095
@tausifs , unfortunately, I do not currently have a way to get the exact framerate, as my display as well as my AVR only show 24Hz or 24p for the incoming signal. You can force 60Hz by setting Movie Frame (24Fs) = Off, or 24Hz when set to Auto for content that is 24Hz natively.
Edit: I just tested this with the Tick on Prime; Off I got 60p, and Auto I got 24p.
galonzo is offline
post #13089 of 14336 Old 09-14-2017, 01:22 PM
tausifs's Avatar
Quoted: 12 Post(s)
Thanks again Galonzo.
I also have a X box One S. I will try the Amazon app for streaming movies , this player has a 24fps setting too.
tausifs is offline
post #13090 of 14336 Old 09-15-2017, 02:14 AM
lizrussspike's Avatar
Quoted: 1507 Post(s)
Liked: 2288
Good Day,
I was wondering if anyone was using the RS420 with the Samsung K8500, and having a great viewing experience, or if I should get another 4K player? I am looking at ordering the RS420 possibly in the next day or two, but wanted to ask if the K8500 will be good for 4K discs.
I understand that streaming 4K and HDR all have some tweaking to get the best picture.
Russ
lizrussspike is offline
post #13091 of 14336 Old 09-15-2017, 08:53 AM
Dan Hitchman's Avatar
Quoted: 4971 Post(s)
Liked: 2993
Originally Posted by lizrussspike View Post
Good Day,
Russ
I would couple the JVC with the Oppo 203. This player has a number of extra nifty features for users of projectors. You could even do a scope ratio screen as it provides for moveable subtitles and a 21:9 mode (supposedly in 4k) if the JVC's scaler is limited in the latter regard. The subtitle feature is handy regardless.
Listen up, studios! Dolby Atmos Lite™ print-outs must stop!!
Dan Hitchman is online now
post #13092 of 14336 Old 09-16-2017, 04:52 AM
tausifs's Avatar
Quoted: 12 Post(s)
I tried the amazon app on my Xbox One. Used the Xbox advanced video setting of "allow 24 Hz" for games and apps.
Sadly, the TV is showing the input video signal as 60p , not 24p.
tausifs is offline
post #13093 of 14336 Old 09-18-2017, 04:36 PM
blee0120's Avatar
Quoted: 1081 Post(s)
Liked: 782
Can the k8500 stream Netflix with HDR?
blee0120 is online now
post #13094 of 14336 Old 09-18-2017, 05:22 PM
David Susilo's Avatar
Quoted: 798 Post(s)
Liked: 677
I don't think so
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #13095 of 14336 Old 09-18-2017, 05:45 PM
ilal2ielli's Avatar
Quoted: 29 Post(s)
Liked: 9
Yes it can as of update 1011.
galonzo and Musician like this.
ilal2ielli is offline
post #13096 of 14336 Old 09-18-2017, 05:50 PM
BrianNLS's Avatar
Quoted: 33 Post(s)
Liked: 35
It can stream 4K HDR on Amazon Prime. I am watching The Grand Tour thusly right now.
I have not paid to upgrade my Netflix account (yet) to 4K, as I am still very irritated by Netflix's reneging on their $7.99 per month for life deal - so I could not test it for 4K HDR via k8500 streaming.
joe221 and mrtickleuk like this.
Yamaha RX-A3060 AV receiver | Outlaw Model 5000 amp
LG 75UH8500 tv | Samsung UBD-K8500 4K BD player
Ascend Acoustics Sierra-2 (L & R), Horizon (C)
Rhythmik LVX12 sub | Atlantic Tech. IC-6 OBA (4x, in ceiling)
Paradigm Mini Monitor surrounds (4x)
BrianNLS is offline
post #13097 of 14336 Old 09-18-2017, 11:48 PM
IMWhizzle's Avatar
Quoted: 1094 Post(s)
Liked: 360
It does support Netflix content in HDR10, but as you already know the player doesn’t support Dolby Vision.
Klipsch Reference Premiere: 4 x RP-280's, 1 x RP 450C, 4x RP-500SA’s and dual R-115W's
Marantz 7011 AVR
LG OLED C9 65 inch
Apple TV 4K
PlayStation Pro
IMWhizzle is online now
post #13098 of 14336 Old 09-19-2017, 08:26 AM
tausifs's Avatar
Quoted: 12 Post(s)
Could it theoretically support Dolby Vision with a firmware update ?
tausifs is offline
post #13099 of 14336 Old 09-19-2017, 10:15 AM
Quoted: 524 Post(s)
Liked: 408
In theory yes, but actuality not going to happen. Samsung doesn't support DV. They are all in for HDR10+ which would be the "free" version of DV. Companies pay Dolby to use DV while HDR10+ is the competing metadata version of DV which Samsung is the leading company trying to push HDR10+
Both DV and HDR10+ are dynamic which right now HDR10 is not as it is static. Which means, DV applies it's coding per scene and it adapts where as HDR10 is just static and applied for the entire length of a movie. HDR10+ is dynamic, and depending on how it goes, will be DV's top competitor in about 2-6 months potentially.
Ricoflashback likes this.
post #13100 of 14336 Old 09-20-2017, 05:32 PM
Quoted: 24 Post(s)
Liked: 5
Send a message via Skype™ to bernievink
Once more having stuttering problems with two new movies, this time Minions and Despicable me 3.
now have 6 out of 60 UHD movies which cause my player problems.
Looks like I might be in the market for a better player.
the UBD-K8500 is just not good enough.
Samsung UA60KU6000WXXY TV, Sony STR#dh770 Receiver with wall, ceiling, and floor mounted 7.1 Sony Speaker system, Sony UBP-X800 Ultra HD Blu-ray™/DVD Player
bernievink is offline
post #13101 of 14336 Old 09-20-2017, 06:30 PM
Dreamliner's Avatar
Quoted: 1520 Post(s)
Liked: 805
If the disc stutters at the same point always, its probably the disc. Every time I have a disc stutter issue I exchange the disc and it works perfectly.
Dreamliner is offline
post #13102 of 14336 Old 09-20-2017, 07:16 PM
BAMABLUHD's Avatar
Quoted: 109 Post(s)
Liked: 163
[QUOTE=BrianNLS;54820840]It can stream 4K HDR on Amazon Prime. I am watching The Grand Tour thusly right now.
I have not paid to upgrade my Netflix account (yet) to 4K, as I am still very irritated by Netflix's reneging on their $7.99 per month for life deal - so I could not test it for 4K HDR via k8500 streaming.[/]That's a totally unfair criticism and shows a lack of business acumen.
It isn't Netflix that sets movie prices no more than it is AMC who does. The movie studios are who gouge us all, including Netflix and Theater chains.
There was no way possible for Netflix to not go bankrupt (still aren't very profitable) and continue to negotiate the ever rising contracts with the studios for the best content faster, the company wouldn't exist anymore should it have kept it's promise. Fact is, they had every intent to keep prices at the level they always did. However, the studios, I think it was 2 years ago, got together and said they didn't want Netflix to become the iTunes for movies, so they raised prices. Thats why Netflix moved to original content and shows. Remember, 5 years ago, Netflix was all movies; they're too expensive to keep, so the company wisely shifted. Luckily, the content is top notch.
Just look at the current contract dispute with Disney, yet the evil empire still decided to pull their movies within a year or so to develop their own streaming service for guess what price? $9.99 per month, or even higher for 4K is the rumor, which is why they don't want to do 4K discs for Star Wars etc.
Always think a layer deeper and remove emotions from such an analysis. I've been with Netflix for 14 years now and it's one of the most customer friendly companies I've ever known.
LG 65B6 OLED 4K HDR| Pioneer ELITE VSX-52 | Samsung K8500 4K Blu Ray | Polk Audio RTi and CS2 5.1 | Video cables by Monoprice! Audio cables by Audioquest
PS4 Pro| Apple TV | Sonos | Amazon Echo
BAMABLUHD is offline
post #13103 of 14336 Old 09-20-2017, 07:56 PM
Sal1950's Avatar
Quoted: 604 Post(s)
Liked: 925
In theory yes, but actuality not going to happen. Samsung doesn't support DV. They are all in for HDR10+ which would be the "free" version of DV. .
Beyond that the 8500 is a inexpensive player, they are considered disposable with a built-in planed obsolescence. You wanting the latest SOTA tech, pony up for a new player.
Sony XBR75-X940D, Samsung UBD-K8500, Xfinity X1 Voice DVR, Marantz AV-7703 Pre/Pro w/Auro, (3) Adcom GFA-545II amps, (2) Adcom GFA-535II amps for ATMOS speakers.
HSU Research 5.2 speaker system (4) HB-1 MK2, (1) HC-1 MK2, (2) STF-2,
Klipsch HT500 satellites (4) for ceiling mounted ATMOS playback
DIY Linux desktop w/Strawberry bit perfect media center. Emotiva Stealth DC-1 DAC
Sal1950 is offline
post #13104 of 14336 Old 09-20-2017, 08:46 PM
tausifs's Avatar
Quoted: 12 Post(s)
On a side note , Apple announced the ATV 4K recently , which will support Dolby Vision. There is no confirmation if it will support 24p but it's doubtful it will in my opinion.
I have learnt in this thread that Amazon movies on the Samsung UHD Blu ray player uhd-k8500 are output at 24p so it is on my shopping list. Thanks.
Quicksilv3r likes this.
tausifs is offline
post #13105 of 14336 Old 09-21-2017, 12:25 PM
bozer's Avatar
Quoted: 76 Post(s)
Any chance of this player having HDR support in the YouTube app?
bozer is offline
post #13106 of 14336 Old 09-21-2017, 12:33 PM
Quoted: 524 Post(s)
Liked: 408
As far as I know, it already does. I've looked at my Samsung tv info and it has said HDR when viewing YouTube.
Sent from my SM-G935W8 using Tapatalk
post #13107 of 14336 Old 09-21-2017, 01:27 PM
PaulGo's Avatar
Quoted: 269 Post(s)
Liked: 168
It should say it in the YouTube app. Also HDR in the app would show up in the codec used VP9.2. Unfortunately the YouTube app on the UBD-K8500 does not do this.
MALICIOUS ONE and Musician like this.
PaulGo is offline
post #13108 of 14336 Old 09-21-2017, 01:43 PM
mrtickleuk's Avatar
Quoted: 6026 Post(s)
Liked: 8726
No, this player does not have the hardware required to do VP9 profile 2. No YouTube HDR will be possible, for the same reason many other devices and TVs which can do HDR can't do YouTube HDR.
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #13109 of 14336 Old 09-21-2017, 06:25 PM
BrianNLS's Avatar
Quoted: 33 Post(s)
Liked: 35
[quote=BAMABLUHD;54832718]
Fact: Netflix committed to me (and millions of others) that my price for streaming services would be "$7.99 per for life."
Fact: Netflix unilaterally increased my monthly price, without my permission and despite my direct protests in 2016.
There was nothing equivocal about Netflix's promise.
The cost of Netflix's inputs does not impact their obligation to meet their advertised and sold commitments. Nor does Netflix's profitability. Nor does any or all of their changes in strategy, including content sourcing.
Zero emotion in the above. Just facts.
Note I am still a Netflix subscriber, but I do not subscribe to Netflix 4K streaming, which was germane to the poster's question. Your reponse to my posting was not.
I will choose to ignore the sanctimony and/or condescension in your reply above and assume it was not intentional. If you'd like to have a discussion on this topic, please start a new thread and I will engage.
mrtickleuk likes this.
BrianNLS is offline
post #13110 of 14336 Old 09-22-2017, 11:17 AM
Ricoflashback's Avatar
Quoted: 2005 Post(s)
Liked: 1461
[quote=BrianNLS;54838732]
I understand - - a deal is a deal. I'll say this, though - - the best streaming of 4K & HDR is via Netflix for me. I had a Netflix subscription many years ago for Bluray discs. I ended up going to my local Blockbuster and when that fizzled out, I began using Redbox. I still use Redbox but also subscribe to the cheapie, two discs a month from 3DBlurayrental.com for 4K/HDR content.
So while I understand your point, you are certainly missing a lot of great 4K/HDR content via Netflix. Only you can determine if it's worth it not to pay extra for the 4K/HDR streaming service.
I've finally been able to optimize my Samsung K8500 settings along with my TV (75" Sony 900E) and in general, I've been very happy with the player. Not so, at first, but then I did some reading into 4K/HDR Bluray Discs and all the fake/upscaled content from 2K sources that, quite frankly, doesn't look as good as HDR from Netflix. And I've also learned that you can't over generalize 2K source upscaling and the additional encoding of HDR. Just look at the reviews for 4K/HDR Bladerunner from bluray.com. I'm looking forward to renting that next month.
For grins, I went out and picked up a Sony UBPX800 player and found it to be far slower and inferior to the Sammy K8500. Just my experience. Load times were significantly higher on the Sony player.
Lastly - - no HDR with "YouTube" on the Samsung K8500? Confirmed? It still looks great on my set but my native Sony apps won't provide "YouTube" HDR content either.
galonzo and mrtickleuk like this.
Home Theater Setup
SONY 75X900F & 49X900E, Bluesound Node 2i, Denon X5200 & Emotiva XPA-3, AudioSource 100VS, OPPO 103 - 9.1.4 Setup - Speakers - Studio 60's-V.5 (FL/FR), CC-690-V.5 (C), ADP 590-V.5 (SS), MilleniaOne 2.0 (BS) - Velodyne 810 Sub, Cornered Audio (FH/RH), Definitive Technology (Front Wides)
Ricoflashback is offline
Reply Blu-ray Players
color calibration , hdr player , member , settings
