Official Samsung UBD-K8500 4K HDR Ultra HD Blu-Ray Player Owner's Thread - Page 448 - AVS Forum | Home Theater Discussions And Reviews
 40328Likes
post #13411 of 14191 Old 11-17-2017, 11:50 AM
mrtickleuk's Avatar
Quoted: 4369 Post(s)
Liked: 6623
Originally Posted by Quicksilv3r View Post
It might have to do with the HDMI handshake. It's nothing to do with any 1 company / brand or product. You can spend a billion dollars on the best system in the world and be plaqued by this issue.
Agreed!
Yes there is a sequence you should power you stuff up. It should always be your display or audio (AVR) first and then your bd player.
You could also try a HDMI reset, and then always used the recommended power on order:
Nicked from this post
HDMI HDCP reset
With all devices powered on, remove the two HDMI cables at both ends from the source device to the AVR and from the AVR to the TV.
Power off all devices and disconnect power cables to all devices.
Wait 10-15 minutes.
Reconnect HDMI and power cables to all devices.
Power on the devices in this order ... TV, wait a few secs, AVR, wait a few secs, and then source device (although this is the generally recommended order, in some instances, you may have better luck powering on the AVR first and then the TV, then the source last ... bottom line if it's still not working, try a different power on sequence).
_______________
Denon AVR-X4200W, Arcam Alpha 8P; 5.1.4 setup: Mission 702e, M7C1i, 77DS, 731. Rel T5 Sub. Monitor Audio CT165 4 Tops | LG OLED55C8PLA TV | Samsung UBD-K8500 UHD Blu-Ray
HDMI 2.0 4K modes | Dolby & DTS core+outer audio tracks on (UHD) Blu-Rays | Hello to Jason Isaacs
mrtickleuk is offline
post #13412 of 14191 Old 11-17-2017, 12:12 PM
emiller1181's Avatar
Quoted: 34 Post(s)
Liked: 52
Originally Posted by Alvin33 View Post
I seem to be the only one plagued by the following intermittent error message: "this content will only be displayed in hd as this is not hdcp 2.2 compliant. Switch screen".
The steps taken so far:
- Latest firmwares (Philips POS9002 and K8500)
- High-speed premium certified HDMI cables (tested 3 different cables)
- I am using HDMI port 1 on my TV but I have tried hdmi port 2 too, to no avail.
Samsung's technical support is telling me that is it the incompatibility of the TV (10-bit) and the player (8-bit). What does that even mean? Isn't K8500 able to detect this automatically?
Please help me!
Not sure if you've done this or if this is even a solution to your problem, but did you enable deep color/HDR on the HDMI port?
To get HDR you will often need to manually set up the TV from the on-screen menu. Typically you need to manually set the HDMI port (i.e. HDMI1), that PS4 Pro is connected to, to expect a HDR video signal. Depending on your TV brand look for:
Panasonic: Activate ”HDMI HDR Setting”
emiller1181 is offline
post #13413 of 14191 Old 11-18-2017, 07:06 AM
p5browne's Avatar
Quoted: 3983 Post(s)
Liked: 3140
Originally Posted by p5browne View Post
Addendum: Amazon took it back with full refund. (Must know I take good care of it!)
2nd Addendum:
Now finding my issue was NOT with the UBD-K8500, but with my TV system, having Amazon, through it's third party vendor, to return the unit, and recharge my CC. It was great of them to give me the full refund, but not fair when there was actually nothing wrong with the unit.
Note: UBD-M9500 does look better, but does NOT do 3D. So, I get the M9500, wife gets the K8500 since she's the one that mostly watches the 3D.
Addendum: Vendor says they may have re-sold it as an open box item.
Addendum 2: It helps if the HDMI Inputs are first calibrated with the HDR Patterns Blu-ray! Unfortunately on the HU9000 + SEK-3500U, we've run into a bug re the HDR calibrating.
Addendum 3: It appears the SEK-3500U and the JS Series OCBs have an issue with 2 settings for SDR and HDR. Work in progress.
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #13414 of 14191 Old 11-18-2017, 07:52 AM
tulsabrown's Avatar
Quoted: 77 Post(s)
Liked: 52
If you use the method 2 connections shown in the first post. HDMI 1 to the TV and HDMI 2 to the receiver, can this player not output Atmos over this connection? Although I’m playing an Atmos disk and have bitstream uncompressed selected, my receiver, an Onkyo RZ900, is only displaying it’s receiving a PCM track. Over optical it shows it’s receiving a 6.1 DTS track.
If I use the method 1 connection, HDMI 1 to my receiver I get the Atmos track.
tulsabrown is offline
post #13415 of 14191 Old 11-18-2017, 07:57 AM
p5browne's Avatar
Liked: 3140
# 1 Not knowing Onkyo, but my Yamaha, there were some settings that had to be changed in my unit.
# 2 It's my understanding, if the Dolby Atmos speakers are not detected being connected, it won't switch to Dolby Atmos ?
UN65KS9800 - Mine
p5browne is offline
post #13416 of 14191 Old 11-18-2017, 11:15 AM
mrtickleuk's Avatar
Liked: 6623
It all depends on what your TV is. We had a case recently with someone's TV which was messing up the HDMI handshake because the TV lied about which sound formats it could handle. In these circumstances, both HDMI outputs from this player drop down to the lowest common format that both TV and AVR can handle. (This is because inside this player it's like a HDMI splitter from a single HDMI output). Search/read up the thread a few weeks ago for more info.
edit: it's HERE .
tulsabrown and galonzo like this.
_______________
post #13417 of 14191 Old 11-18-2017, 01:44 PM
tulsabrown's Avatar
Quoted: 77 Post(s)
Liked: 52
You would think if they created an HDMI port just for audio, that when set, in the settings to use that port, it would only look to that port and ignore the video output port. So if that’s how it works it seems like that designer should be bagging groceries.
post #13418 of 14191 Old 11-18-2017, 04:50 PM
Quoted: 625 Post(s)
Liked: 364
Hi, new to this thread. Just got the unit at Sam's club. For some reason when I play content using an external drive, the audio and pic are out of sync and nothing I do with the lip sync option on the player, vizio t.v. or my Yamaha receiver helps as they all start from zero and it looks as I have to move the audio to negative below zero to get it sync. Is there a problem with the player or my settings are wrong? Movies from the bd discs are fine. Thanks in advanced.
meduzadg is online now
post #13419 of 14191 Old 11-18-2017, 04:53 PM
Quoted: 625 Post(s)
Liked: 364
Also, is HBO go available? Could not find it. Thanks
post #13420 of 14191 Old 11-19-2017, 04:48 AM
umenon's Avatar
Quoted: 981 Post(s)
Liked: 349
My unit's HDMI 1 is connected to the LG OLED B6 (cannot handle Atmos). HDMI 2 is connected to a Denon receiver (supports Atmos and DTS:X)
Watched several 4K BR discs. Receiver detected Atmos or DTS:X without any issues.
umenon is offline
post #13421 of 14191 Old 11-21-2017, 11:51 AM
Peja's Avatar
Quoted: 71 Post(s)
Liked: 51
Any Closed Captioning issues across disc formats with this player? BD Frozen works fine. Planet Earth and Jessie Stone DVD doesn't. Search hints? " UBD-K8500 closed captioning issues" and similar doesn't work
Peja is offline
post #13422 of 14191 Old 11-22-2017, 07:22 AM
galonzo's Avatar
Quoted: 1290 Post(s)
Liked: 1588
I've been following this thread since the beginning, and I can't recall anything about this; that said, we're going on 2 years now, so I could be wrong. It's usually best to only search by one, distinct word at a time to get any relevant posts, maybe try just "caption"?
Musician likes this.
Main: UN78HU9000/SEK-3500 | X4200W (Klipsch/HSU 5.1.2) | UDP-203 (fw 65-0131) | TiVo Bolt | Roku P+
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | AppleTV4K | TiVo Mini
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - UHD Digital codes (and some HD codes)
galonzo is offline
post #13423 of 14191 Old 11-22-2017, 07:52 AM
poppagene's Avatar
Quoted: 848 Post(s)
Liked: 715
I just tried disc one of the original BBC planet earth bluray and cc worked fine
UN48JS8500 UN55HU6950 w/SEK-3500U UN40HU6950 w/SEK-3500U UBD-K8500 UN37C5000
poppagene is offline
post #13424 of 14191 Old 11-22-2017, 10:59 AM
Peja's Avatar
Quoted: 71 Post(s)
Liked: 51
Thanks to both @galonzo and @papage ne. I tried a few single word searches but the threads are so long it would take hours to find anything. I'm researching for my BIL. He can't get CC on any DVD. I'll take a few DVD's to him I know work on mine and see what happens. I've got a feeling it's his player.
galonzo likes this.
Peja is offline
post #13425 of 14191 Old 11-24-2017, 07:14 AM
Liked: 0
HI all and one! At the risk of sounding techno illiterate, i am posting this question to clarify a couple of basics!
I have a Samsung ks7000. I would like to add a Samsung UBDK8500 so i can watch movies. I would also like to add something like a Yamaha ysp2500 for sound.
Is there anything i need to consider? will this combination work? I know the tv already gives You Tube and Amazon HDR, so that is covered. I don't need a receiver etc do I?
Any input on what i have not considered very much welcomed!
drongo2 is offline
post #13426 of 14191 Old 11-24-2017, 10:21 AM
blenky's Avatar
Quoted: 910 Post(s)
Liked: 835
The Samsung TV and UHD bluray will work great together - as both Samsung! You don't need a receiver but to enjoy HD sound such as DTS HD MA and Dolby TrueHD from the disks you would - plus appropriate speakers. The TV speakers are not great
Samsung UE55KS8000 | Pioneer SC-LX701 | Dune HD Pro 4K | Zidoo Z9S | Apple TV 4K | Samsung UBD-K8500 UHD Player
blenky is offline
post #13427 of 14191 Old 11-24-2017, 10:27 AM
Liked: 0
Thumbs up
HI there and thankyou for your reply! When you say the speakers are not that great, do you mean the Yamaha soundbar i quoted? Im aware this is no replacement for 5.1, but the room i am installing in is only 3.2m by 3 m area. Can you recommend a soundbar to me? im mainly interested in a clean hassle free install taht willl give me decent enough sound impact for the odd hdr 4k video i may watch in my downtime.
drongo2 is offline
post #13428 of 14191 Old 11-24-2017, 10:35 AM
blenky's Avatar
Quoted: 910 Post(s)
Liked: 835
Sorry thought the Yamaha you mentioned was a receiver! I have a Yamaha AVR and have no knowledge of soundbars as never owned one. Hopefully someone here may be able to help.
blenky is offline
post #13429 of 14191 Old 11-24-2017, 03:04 PM
Musician's Avatar
Quoted: 2631 Post(s)
Liked: 5171
Thanks to both @galonzo and @papagene . I tried a few single word searches but the threads are so long it would take hours to find anything. I'm researching for my BIL. He can't get CC on any DVD. I'll take a few DVD's to him I know work on mine and see what happens. I've got a feeling it's his player.
You are right, searching AVS Forum can get a little overwhelming at times so here is a trick I often use.
I use Google and include the word AVSForum in my search criteria coupled with the keywords of the topic I am looking for.
For example, in your case I searched for "closed captioning issue avsforum k8500" which returned the most popular results as shown below...
It also provides the option to view 'More results from www.avsforum.com' and when you click on that it provides a list of all the results and enough text that you can rule in those that are worth a further read.
Name:	Google Search.JPG
Terminader, madmas and Peja like this.
Samsung UN78HU9000 & SEK-3500U/ZA - Firmware 1540.3
Samsung UN40HU7000 & SEK-3500U/ZA - Firmware 1540.3
Samsung UBD-K8500 UHD Blu-ray Player; Apple TV 4K
Arris VIP5662W UHD Whole Home DVR; Chromecast Ultra
Marantz SR7005 Receiver; Magnepan Speakers; Martin Logan Subwoofer
Musician is online now
post #13430 of 14191 Old 11-24-2017, 03:42 PM
Peja's Avatar
Quoted: 71 Post(s)
Liked: 51
Beautiful. I would never have thought of that. Use the powerful Google search engine inserted into AVS Forums.
Peja is offline
post #13431 of 14191 Old 11-24-2017, 04:56 PM
galonzo's Avatar
Liked: 1588
Well @Musician and @Peja , some "tricks of the trade" are to use "AND" (all caps) in-between search terms to get pages that absolutely contain both terms; and to get right to the results, use "site:www.example.com" to search within a site. So try:
closed AND caption AND k8500 site:avsforum.com
and see what comes up
joe221, MALICIOUS ONE and Musician like this.
galonzo is offline
post #13432 of 14191 Old 11-25-2017, 08:36 PM
inspector's Avatar
Quoted: 227 Post(s)
Liked: 140
Well, here's my problem with my K8500. Sent it off (only player and power cord like they requested) to 220-Elecrtonics to make it REGION FREE. Just got it back, and tried my first 6 REGION B 3D BD discs...only two played.
When I call them on Monday, I hope there is an easy fix from my side and not a screw up on their side. A week to and a week back from them I don't want to go through again.
...finally retired and spending time in my dedicated HT!!!
SPARKSPLEX HT - Epson 6040 3D/4K UB Projector; 110" 16x9 Dalite HD Progressive Screen; Sammy 3D/4K K8500 region free; 7.2.4. w/Def Tech speakers, Earthquake P12v2 Subs; Auto Source 100vs Amp; Denon 4300H; MX990 Remote; 5 Bello chairs; Coaire Mini-split.
inspector is offline
post #13433 of 14191 Old 11-25-2017, 08:47 PM
Quicksilv3r's Avatar
Quoted: 453 Post(s)
Liked: 350
The player is already region free. You shouldn't have had to send it in. The only region locked players I know of are Sony's.
Sent from my SM-G935W8 using Tapatalk
tv: Samsung UN75MU800, Receiver: Denon AVR 730H, speakers: 4x M&K S-1B and M&K S85c for center, sub: MKsound V12 HTPC, Samsung UBP-K8500, Rogers Digital PVR, Chromecast Ultra
Quicksilv3r is online now
post #13434 of 14191 Old 11-25-2017, 09:00 PM
dwaleke's Avatar
Quoted: 1412 Post(s)
Liked: 719
Pretty sure this only applies to 4k discs. 1080p Blu-ray disks are still region locked.
galonzo and mrtickleuk like this.
dwaleke is offline
post #13435 of 14191 Old 11-25-2017, 09:03 PM
Quoted: 453 Post(s)
Liked: 350
Nope. I'm in Canada which is region 1, and I have Planet Earth on Bluray from the UK which is region 2 or whatever it is, wouldn't play in my PS3 but on my K8500, it plays no problem
post #13436 of 14191 Old 11-25-2017, 09:25 PM
Ph8te's Avatar
Quoted: 6264 Post(s)
Liked: 5891
BRs can be region free as well. The specific one you mention (Planet Earth series) is usually region free. You’d need a region locked BR to prove your case.
Ph8te is offline
post #13437 of 14191 Old 11-26-2017, 03:31 AM
mrtickleuk's Avatar
Liked: 6623
Yes.
  • For DVDs, they will only play if they match your region, or they are authored as "region free". Most DVDs are not.
  • For Blu-Rays, they will only play if they match your region, or they are authored as "region free". Most Blu-Rays are not.
  • For 4K Blu-Rays, they will only play if they match your region, or they are authored as "region free". All 4K Blu-Rays, so far, are.
NB: Because so many 4K discs are "bare bones" discs with all of the extras, documentaries, behind-the-scenes, storyboards, etc - all that great rich content - is on the accompanying region-locked Blu-ray, it means that in practice, it's a region-locked format regardless because you have to make sure you buy the right region-locked Blu-ray disc in the box with it, and you can't just import the cheapest 4K version you can find! Otherwise you can't play half the content!
So don't let anyone tell you that 4K Blu-Ray is a fully unlocked format. It is not, and it will not be so until all that extra content is also unlocked.
This is simply not a region-free player. None of my region 1 DVDs work. You have to have it modified.
_______________
post #13438 of 14191 Old 11-26-2017, 04:20 AM
Quoted: 453 Post(s)
Liked: 350
I can tell you, Planet Earth is NOT region free. It will not play in my PS3, but it will play in region free players.
joe221 likes this.
post #13439 of 14191 Old 11-26-2017, 04:25 PM
inspector's Avatar
Quoted: 227 Post(s)
Liked: 140
You are mistaken. The Sammy K8500 has to be modified to be REGION FREE and is only sold, that I'm aware of, by 200-Electronics in the USA.
Musician and mrtickleuk like this.
post #13440 of 14191 Old 11-26-2017, 06:24 PM
Rudy1's Avatar
Quoted: 1954 Post(s)
Liked: 3251
BHPHOTOVIDEO in NYC carries “reion-free” versions of both the UBD-K8500 and its successor, the UBD-M9500.
galonzo and Musician like this.
Definition of "Stupid": Knowing the truth, seeing the truth, but still believing the lies.
Rudy1 is offline
Reply Blu-ray Players
color calibration , hdr player , member , settings
