Sony S1700 / S3700 /S6700 Blu-ray players - Page 17 - AVS Forum | Home Theater Discussions And Reviews
 94Likes
post #481 of 568 Old 11-13-2018, 12:10 AM
zeuspaul's Avatar
Quoted: 253 Post(s)
Liked: 372
Originally Posted by aveatch View Post
Zeuspaul
I have a question that maybe you could answer. I have a BDP S3700 that I use to stream from an Emby server which works well. We watch a lot of DVD shows and while the 3700 upscales much better than my TV, I was wondering if there would be a significant difference with an Oppo.
I wish I could help. If you are already seeing a significant improvement my guess is you won't see another significant improvement. I didn't notice a difference between the images on my S1700 and the Oppo 93 but I am not up scaling and didn't do a side by side.
Spoiler!
zeuspaul is offline
post #482 of 568 Old 11-13-2018, 11:03 AM
aveatch's Avatar
Thanks for the reply.
Just thought you might have noticed a difference when watching DVDs.
I have been wondering lately if the cost of an Oppo would be worth the bump in video performance on DVDs. I know they will never look as good as they do on a CRT but always looking for a little improvement.
aveatch is offline
post #483 of 568 Old 11-13-2018, 01:11 PM
zeuspaul's Avatar
Quoted: 253 Post(s)
Liked: 372
I just tried a DVD. I have been watching the DVD NYPD Blue TV series on my Oppo 93. I didn't notice a difference with The Sony S1700, nothing jumped out at me. If I were to do a side to side comparison and do some pixel peeping perhaps I could see some differences.
aveatch likes this.
Spoiler!
zeuspaul is offline
post #484 of 568 Old 11-13-2018, 02:05 PM
aveatch's Avatar
aveatch is offline
post #485 of 568 Old 11-13-2018, 02:30 PM
aveatch's Avatar
Just thought I would mention, in case anyone is interested in this aspect. I had bought a S1700 to use for DLNA streaming which it will do with the Plex app in the Opera TV store, but my experience was that it wasn't that stable and it was slow.
I returned the S1700 and got the S3700 which does DLNA natively and it works quite well. You don't get all the eye candy as with the Plex app but if you just want to stream movies and tv shows it is great.
aveatch is offline
post #486 of 568 Old 11-16-2018, 01:41 PM
zeuspaul's Avatar
Quoted: 253 Post(s)
Liked: 372
I don't have the S1700 connected to a network so I can't comment on that. I am more concerned about it trying to connect to a network. My Western Digital media player tries to connect every time I turn it on which takes an inordinate amount of time. I can't find a way to tell it that I am not interested. The S1700 forced me to go through a few network screens during initial set up before letting me discard the network settings. It takes about thirty seconds to boot as it looks for a Blu-ray disc and a USB device. I haven't noticed it looking for a network.
Spoiler!
zeuspaul is offline
post #487 of 568 Old 11-18-2018, 10:02 AM
aveatch's Avatar
I have two S3700 connected with cat 5. I got tired of the 30 sec wait so I set them to quick start mode and when I turn them on they are up and ready in a couple seconds. (Obviously there is a wait to load if I insert a disk.) There is generally no lag connecting to the server unless there is a problem. Sometimes there is a couple second wait for the media to show up on the server because my media is on USB drives and they have to spin up.
I'm not to thrilled with the internet streaming performance. They work but they are slow and clunky.
zeuspaul likes this.
aveatch is offline
post #488 of 568 Old 11-18-2018, 04:24 PM
zeuspaul's Avatar
Quoted: 253 Post(s)
Liked: 372
Wow! Thanks! Boot is now almost instantaneous and reading the SSD connected to the USB port is also very quick.
Spoiler!
zeuspaul is offline
post #489 of 568 Old 11-18-2018, 04:49 PM
aveatch's Avatar
Cool
aveatch is offline
post #490 of 568 Old 11-29-2018, 07:55 AM
richard58's Avatar
Just my dos centavos here. I've had the S3700 for 2 years now and it's been a wonderful little BD player. A little slow to get started, but it works fine. Never froze once. I think the latest patches took care of that. If you don't need a 4K player, you can't do much better.
richard58 is offline
post #491 of 568 Old 01-17-2019, 10:28 PM
Quoted: 22 Post(s)
Liked: 3
Is there a way to reset the HDMI on the S3700? I get no video/audio signal. I may have accidentally fried it while fiddling with a Raspberry pi attached to my AVR. I had to unplug the AVR to reset it, and now it works, but the blu-ray player is still not working properly.
japanoise is offline
post #492 of 568 Old 01-19-2019, 10:15 AM
Selden Ball's Avatar
Quoted: 4823 Post(s)
Liked: 2874
Make sure the HDMI cable between the BDP and the AVR is plugged in all the way. Press firmly on both ends, perhaps wiggling them just a little.
If that doesn't help, try using a different HDMI input on the receiver. The connectors closest to the Monitor output often are more reliable.
Selden
Selden Ball is offline
post #493 of 568 Old 01-19-2019, 03:42 PM
Quoted: 1342 Post(s)
Liked: 4636
Try this...
https://www.ifixit.com/Wiki/Sony_BDP...roubleshooting
Panson is offline
post #494 of 568 Old 01-20-2019, 12:47 AM
Quoted: 22 Post(s)
Liked: 3
Thanks for the suggestions. I left the unit unplugged for two days and now it works ok. Maybe when I re-plugged the HDMI it wasn't in all the way, but I think I checked multiple times with different cables and even directly to the TV. At least it works now.
Panson likes this.
post #495 of 568 Old 01-28-2019, 06:37 AM
Bruce2019's Avatar
Quoted: 618 Post(s)
Liked: 339
My S3700 worked for only 4 months..
I had often freezes right at start where it would not go past the blu ray logo..
Since last week it wont play and eject my blu ray.. I did try everything and now it is sent to service..
Hope I get my blu ray back
2013 Panasonic TX-P42X60E PDP
2013 Panasonic TX-P42STW60 PDP
ST60 Settings: Custom Mode, Contrast 60 = 100nits peak brightness aka Filmmaker Mode, Panel Brightness Medium
Gamma 2.4, Gamma settings: 10% -30, 80% +3
Bruce2019 is online now
post #496 of 568 Old 01-28-2019, 01:16 PM
antennahead's Avatar
Quoted: 344 Post(s)
Liked: 253
Mine died a couple of months ago. I took it apart carefully, prior to sending it in, and removed my Blu ray. They sent me a new replacement player. Will be interesting to see how long this new one lasts. It's a secondary player in my bedroom and doesn't get a lot of action.
Equipment: Sony XBR-X940E, Marantz AV-7702, Wyred4sound mAMPS , Oppo 103
antennahead is offline
post #497 of 568 Old 01-28-2019, 04:45 PM
zeuspaul's Avatar
Quoted: 253 Post(s)
Liked: 372
Was it just the Blu-ray mechanism? If you hadn't used the disc option and only opted for USB do you think it would still be working?
Spoiler!
zeuspaul is offline
post #498 of 568 Old 01-28-2019, 05:20 PM
Quoted: 344 Post(s)
Liked: 253
The unit was totally dead, it would not power on under any circumstances. I read online that this was a fairly common trait on these players, many owners experiencing the same thing.......... played fine the day before, would not power on at all the next day ....... dead
Bruce2019 likes this.
post #499 of 568 Old 01-31-2019, 08:14 AM
Bruce2019's Avatar
Quoted: 618 Post(s)
Liked: 339
Same here.. It did power on, but froze at the blu ray logo.. And then you could not even turn it off.. dead as a dodo..
I now use the PS4 as replacement and like it really much because the Netflix and Amazon Prime video streaming is incredible fast.. I dont think I will go back to the BDP where it takes very long to load something.. I am surprised how well the ps4 does in that regard, and it is a good blu ray player too.. Also I get away with one less device..
antennahead likes this.
post #500 of 568 Old 01-31-2019, 02:24 PM
Quoted: 344 Post(s)
Liked: 253
I was literally two weeks away from my warranty expiring. Had Sony not sent me a new unit, I would have been looking for a replacement ......... by another manufacturer
post #501 of 568 Old 02-11-2019, 04:55 PM
Jim McC's Avatar
Quoted: 656 Post(s)
Liked: 183
Streaming Netflix with the 6700
Has anyone experienced audio problems while streaming Netflix with the 6700 ? Sometimes the volume goes very quiet and stutters. Not the dialog, the overall volume.
I'm trying to figure out if it's a Netflix problem or not.
The player works fine when playing Blu-rays, DVD's and CD's.
Jim McC is offline
post #502 of 568 Old 02-11-2019, 05:25 PM
Liked: 4636
FWIW last year's firmware update cleaned up a few Network Services issues on my 6500.
Sony help page -
https://www.sony-asia.com/electronic...icles/00013427
Panasonic TC65CX850U Yamaha RX-V1079 Technics SU-V650 Panasonic DMP-UB900 Sony UBP-X800 Polk Audio SDA-2B
"I watch a lot of movies, I know what I'm doing." - Daniel Lugo
Panson is offline
post #503 of 568 Old 02-25-2019, 03:54 AM
Bruce2019's Avatar
Quoted: 618 Post(s)
Liked: 339
Almost a month later.. I got a full refund.. It seems they dont even bother to repair these units..
Now I try to get back my blu ray that was in the drive.. But I think it is gone forever..
post #504 of 568 Old 02-27-2019, 06:55 AM
Bruce2019's Avatar
Quoted: 618 Post(s)
Liked: 339
After a call, I got my blu ray sent back..
antennahead and Panson like this.
post #505 of 568 Old 02-28-2019, 05:16 AM
mrpergo's Avatar
Quoted: 32 Post(s)
they still had the disk that was in the player....amazing
mrpergo is offline
post #506 of 568 Old 04-03-2019, 12:23 PM
Liked: 4636
For those interested, March 2019 firmware updates for these Sony Blu-ray players.
Sony BDP-S6500
https://www.sony.com/electronics/sup...loads/00015976
Sony BDP-S6700
https://www.sony.com/electronics/sup...loads/00015915
Panson is offline
post #507 of 568 Old 04-03-2019, 10:58 PM
Jim McC's Avatar
Quoted: 656 Post(s)
Liked: 183
Sony BDP-S6500
Sony BDP-S6700
Thanks. Does anyone know what the "Gracenote function" is ?
Jim McC is offline
post #508 of 568 Old 04-04-2019, 08:55 AM
Liked: 4636
"Termination of Gracenote Database"
https://www.sony.com/electronics/sup...icles/00203086
Panson is offline
post #509 of 568 Old 04-04-2019, 05:47 PM
Jim McC's Avatar
Quoted: 656 Post(s)
Liked: 183
Jim McC is offline
post #510 of 568 Old 05-05-2019, 12:58 PM
doni01's Avatar
Quoted: 175 Post(s)
Liked: 141
Sony Blu Ray Settings Help !
Hi guys,
I was wondering if I can get some help with the Audio Settings on my Sony BDP-S6700. I have a 7.2.2 system and the Blu Ray is connected to my receiver which is a Marantz SR6012. The pic below shows where the settings are at the moment from the factory. Does any of them need to be changed?? Thanks in advance!!
doni01 is offline
Reply Blu-ray Players
S1700
