Sony S1700 / S3700 /S6700 Blu-ray players - Page 18 - AVS Forum | Home Theater Discussions And Reviews
 94Likes
post #511 of 568 Old 05-06-2019, 05:58 AM
Quoted: 141 Post(s)
Liked: 145
I would turn all of those "on" listings off. You definitely need to turn the BD Auto Mix off if you want to get lossless audio from all discs that have it. As for that first "Auto" listing, make sure it's "bitstream."
doni01 likes this.
Flickpal is offline
post #512 of 568 Old 05-08-2019, 03:27 PM
doni01's Avatar
Quoted: 175 Post(s)
Liked: 141
Thank you!!
doni01 is offline
post #513 of 568 Old 06-01-2019, 05:43 PM
MistyBreeze's Avatar
My new Sony BluRay is not recognizing my External LaCie, please help?
I have a Sony KDL-32XBR4 LCD TV. Not sure how much life is left, but it's holding up pretty well.
I've had a WD Media Player hooked up to an External LaCie 300gb Firewire 800/400 so that I could view video files. My WD died.
I just bought the Sony BluRay BDP-S6700, which replaces the WD Media Player and upgrades my LCD to a Smart TV. Except, the Sony BluRay will not recognize my LaCie hard drive.
Outside of buying a new hard drive, is there anything I can do to get the Sony BluRay to recognize my current LaCie?
Thanks in advance!
Blowing my way to the top!
MistyBreeze is offline
post #514 of 568 Old 06-01-2019, 07:34 PM
CalJake's Avatar
Quoted: 97 Post(s)
Liked: 65
You're trying to connect the LaCie drive to the Sony BluRay with USB? Does any other USB device connect to the Sony BluRay player? Can any other device (computer, TV, etc.) connect to the LaCie drive?
CalJake is offline
post #515 of 568 Old 06-02-2019, 05:21 AM
@CalJake
Yes, we connected the LaCie to the Sony BluRay using the USB2 port.
We tested a different drive that belonged to my studio manager. Not sure which drive that was. I would have to ask later today. His drive was recognized.
The Firewire ports on the LaCie are not being used. We use the LaCie specifically for video files associated with viewing on the TV. We transfer files to the LaCie via a MacBook Pro, and we connect using Firewire when we do that.
UPDATE:
My studio manager tried two different hard drives from his personal collection; one WD, one LaCie, both bus powered and formatted for PC/Mac. The BluRay did not recognize his WD, but it did recognize his LaCie Rikiki 500gb.
Other details: My External LaCie 300gb is adaptor powered, and it is formatted for Mac only. I was once told it's better to run an adaptor powered external hard drive when playing videos.
I'm guessing I may need to purchase a compatible hard drive to replace my LaCie 300gb. How do I find out what drives are compatible with the S6700 BluRay?
UPDATE 2:
We decided to take the time to move all the video files off the LaCie 300gb drive and re-format the drive to MBR and FAT32, whatever those terms mean. The LaCie drive now works with the S6700. Problem solved. Thank you @CalJake for taking an interest.
post #516 of 568 Old 06-16-2019, 11:56 PM
See The Light's Avatar
Quoted: 125 Post(s)
Liked: 197
Latest Firmware update for the S3700 is M30R0527
Cable Channel Choice is the only choice I want to make !!
See The Light is offline
post #517 of 568 Old 07-24-2019, 02:47 PM
Liked: 0
guys, does this player have subtitle shift function?
I live in Brazil and would like to buy this player...
Stanley Garcia Pires is offline
post #518 of 568 Old 07-24-2019, 02:59 PM
Liked: 0
I mean, is it possible to change the position of the subtitle?
post #519 of 568 Old 08-03-2019, 07:49 AM
hodgjy's Avatar
Quoted: 225 Post(s)
Liked: 191
After recently purchasing the 6700, I thought I'd share a few impressions.
I purchased it mainly for the SACD playback and because I got it on sale for a very good price. I have no real interest in 4k UHD Blu rays at this point, and since my Samsung tv (UN50NU6900) has very good upscaling, the player's 4k upscaling was really inconsequential.
I've always thought Sony as a brand has done a good job at upcsaling 480i/60 DVDs to 1080p/60, so I thought I'd try out the upscaler vs. my tv and report back here for those looking at this player.
I found the 6700's 480i/24 to 4k/24 upscaling to be terrible (it will only upscale 24 hz videos to 4k). Horrendous artifacts of interlacing and pixelation ruined the picture. The tv's upscaling was clearly superior. However, if I set the 6700 to upscale 480i/60 to 1080p/60, and then let the tv upscale to 4k/60, the picture was slightly better than when I had the tv do the 480 to 4k upscaling.
Next, I found the 6700's 1080p/24 to 4k/24 upscaling to be basically indistinguishable from the tv's. I suppose if I was to nitpick certain complex scenes with some finer detail, the tv is a little better, but overall it's very difficult to tell them apart.
hodgjy is offline
post #520 of 568 Old 08-03-2019, 04:24 PM
hsinnott's Avatar
Quoted: 166 Post(s)
Liked: 131
Poor upscaling you say you are seeing may say more about your budget 4K Samsung display than the Sony to be fair.
SONY Bravia KD-65XE9005BU 4K UHD tv PANASONIC TX-40CX400B 4K UHD tv SONY UBP-X800 4K HDR Ultra HD player SONY BDP-S3700 Blu-ray player (U.S.)-*new 04/04/2019 SONY BDP-S760 Blu-ray player ES certified- Elevated Standard (UK) SAMSUNG BD-C6900 3D Blu-ray player (UK) SAMSUNG HW-MS650 Sound+ Soundbar
hsinnott is offline
post #521 of 568 Old 08-03-2019, 06:12 PM
hodgjy's Avatar
Quoted: 225 Post(s)
Liked: 191
What you're saying doesn't make sense. The tv upscales just fine. The 6700 upscales just fine except for the direct 480 to 4k.
Edited for clarification (a summary of my first post):
If I feed the tv a 480 signal, the tv upscales to 4k beautifully.
If I feed the tv a 1080 signal, the tv upscales to 4k beautifully.
The 6700 upscales a 1080 signal to 4k virtually identical to the tv.
The 6700 upscales a 480 signal to 4k very poorly. It's atrocious compared to the tv.
What I wrote in my first message gives absolutely no information you can use in any context to say the tv is poor at anything.
hsinnott likes this.
hodgjy is offline
post #522 of 568 Old 08-04-2019, 02:13 AM
hsinnott's Avatar
Quoted: 166 Post(s)
Liked: 131
480 on any 4K isn't going to look very good I imagine once your eyes are used to good quality 1080p blurays and 4K discs....no plans to buy a 4K player? Your tv will really shine with one. But I understand it is quite a challenge to make a DVD look anyway decent on a 4K display. Sold all my DVD's once Bluray came out except for those titles which may never see the light of day on the newer formats.
hsinnott is offline
post #523 of 568 Old 08-04-2019, 11:40 AM
hodgjy's Avatar
Quoted: 225 Post(s)
Liked: 191
No plans for a 4k Blu ray player for now. I have a large 480i DVD collection, I stream movies at 4k, and when I rent discs from Redbox, they don't have 4k Blu rays in my market. I rarely buy new discs anymore.
hodgjy is offline
post #524 of 568 Old 09-09-2019, 04:52 AM
box4m's Avatar
Quoted: 114 Post(s)
Liked: 32
On the s3700 can you manually change aspect ratio?
box4m is offline
post #525 of 568 Old 09-09-2019, 07:24 AM
hodgjy's Avatar
Quoted: 225 Post(s)
Liked: 191
Only stretching 4:3 to 16:9.
hodgjy is offline
post #526 of 568 Old 10-03-2019, 03:47 PM
Liked: 0
why would they take away chapters for mkvs? deal breaker for me
nightmareman81 is offline
post #527 of 568 Old 10-05-2019, 02:31 AM
Liked: 0
Question sony bluray player dolby atmos
Why does the player only play dolby atmos on some movies. It will play dolby atmos fine on Kong: skull island. It will not play dolby atmos on Godzilla: king of the monsters. The firmware has been updated on the player. BDPS-6700.
Frank Pultz is offline
post #528 of 568 Old 10-19-2019, 10:13 AM
tonybradley's Avatar
Quoted: 568 Post(s)
Liked: 236
High Pitch Sound- 6700
Was starting a movie the other night, and while on the menu screen, I heard some high pitch noise. Almost like the Emergency Broadcast sound, but not as loud. I thought it was my recessed lights. Turned lights off, sound still there. Thought maybe speakers. Muted audio and still present. Thought PJ fan, nope. I walked around and found it was my 6700. I stopped the disc and played again, high pitch sound present. Tried several discs. I will no longer be able to use this player as that sound is painful. A Google search found another model from 2010 purchased at Costco was plagued with this problem, but didn't see anything on the 6700.
Anyone here have this issue? It's 1 year and 2 months old. Two months past the warranty, of course.
tonybradley is offline
post #529 of 568 Old 12-10-2019, 11:06 PM
Jim McC's Avatar
Quoted: 657 Post(s)
Liked: 183
I'm looking for help with my 6700. I moved it from upstairs to downstairs, and now it will not hook up to the internet. I'm using a wired connection. I tried it a few times, and I also unplugged the player to re-boot it. No luck.
Does anyone have any advice ?
Jim McC is online now
post #530 of 568 Old 12-11-2019, 08:02 AM
hodgjy's Avatar
Quoted: 225 Post(s)
Liked: 191
Is there anyway to remove Hulu from the homepage? It's quite annoying that the app remains locked there despite it no longer working.
hodgjy is offline
post #531 of 568 Old 12-11-2019, 09:22 AM
venejo's Avatar
Quoted: 16 Post(s)
If the app is on the left side I'm afraid you can't. I wonder why they keep it if its obsolete and don't remove it like they did with Gracenote and e.t.c
hodgjy likes this.
Samsung QE49Q60R, Sony BDP-S480, Sony BDP-S6700, Pioneer VSX-521, DUAL 505-2, Yamaha YST-SW315, Various 5.1 speakers.
venejo is offline
post #532 of 568 Old 12-11-2019, 11:04 AM
hodgjy's Avatar
Quoted: 225 Post(s)
Liked: 191
That's what I figured. It's kind of annoying that Sony is ignoring their physical players.
hodgjy is offline
post #533 of 568 Old 01-22-2020, 01:56 PM
davidsco27's Avatar
BDP-S6700 Randomly Factory Resetting Now
Mine began a few weeks ago, I googled it and found others on the Sony forums with the same issue. Anyone else experiencing this? Worked fine for about 4 months, now when I go to use it I have found twice so far it all reset on its own to Factory. Have to go through the entire setup process again. It's bad enough the Sony clowns sunset their apps, but this is ridiculous
davidsco27 is offline
post #534 of 568 Old 02-07-2020, 09:37 PM
Paul.R.S's Avatar
Quoted: 63 Post(s)
Liked: 36
Does anyone with the S1700 use both it and an Amazon Fire Stick or Fire TV for Amazon streaming?
I've had some problems recently with the Prime Video app on the Sony: It loads, stutters in displaying my Wishlist, maybe pulls up the title-specific information screen of something I want to watch but then often generates one of three error messages when I press play/watch now to start the movie proper.
I've power cycled the player and my cable modem. Upload and download speeds are excellent. Other apps at least load (more) briskly, but I don't stream any other provider's content so I can't compare apples to apples in that regard.
I'm trying to suss whether this is an Amazon server side issue, the (dated) Amazon app in a now 4-year old entry level BD player or a combo of both. Player is on latest firmware.
Paul.R.S is offline
post #535 of 568 Old 03-15-2020, 12:58 AM
Paul.R.S's Avatar
Quoted: 63 Post(s)
Liked: 36
. . . annnnnd now the player drawer won't open.
Paul.R.S is offline
post #536 of 568 Old 04-27-2020, 12:34 PM
doni01's Avatar
Quoted: 175 Post(s)
Liked: 141
Hi guys, I just downloaded some Atmos Dolby files on a USB drive from TheDigitalTheater.com. I tried playing them from my Sony S6700 Blu-ray player via the USB drive but unfortunately all the ones that say "Lossless" do not have any audio. The other ones play just fine. Do you guys know what I can do to get them work?? Thanks in advance!
Home Theatre: Marantz SR7012 | Emotiva BassX A-300 | Ascend CMT-340 SE Front L/C/R | Klipsch R-14S Surround Side L/R | Klipsch R-41M Surround Rear L/R | Klipsch CDT-3650-C ii Atmos | Dual Monolith 12 Subwoofers | Sony BDP-S6700 | Minix NEO U9-H |
Music: Denon AVR-S910W | Klipsch RP8000F | Klipsch R-112SW Subwoofer |
doni01 is offline
post #537 of 568 Old 04-30-2020, 08:05 AM
Quoted: 195 Post(s)
Liked: 38
Using 2 Sony Blu-ray players - Help needed please
Experts,
Here is my issue & looking forward to your advise please....
-Have 2 Sony Blu-ray players placed one on the other. Basically one is Region-A 3D player (2014 model) & the other one is Region-Free Model Sony BDP-S6700. Both connected to same power source/switch.
Region-free model was bought only yesterday & found out that Ejecting button in either Remote opens up trays in both the players & also both Remotes look exactly alike
It is really annoying to see both trays opening and any advise how to control this?
Or, best solution is to split the Power for both, ON/OFF manually which ever not using?
thanks in advance
Newuser2018 is offline
post #538 of 568 Old 04-30-2020, 12:31 PM
Quoted: 195 Post(s)
Liked: 38
I had same issue with my Blu-ray player but then I attempted to play same USB hooked to my yamaha receiver and absolutely no issues.
doni01 likes this.
post #539 of 568 Old 04-30-2020, 06:38 PM
doni01's Avatar
Quoted: 175 Post(s)
Liked: 141
Thank you. I can try the usb straight to my receiver I guess but that way I will be using the video part of it ☹️
doni01 is offline
post #540 of 568 Old 04-30-2020, 07:08 PM
deano86's Avatar
Quoted: 724 Post(s)
Liked: 390
Sony's don't allow streaming and also USB playing of MKV format TrueHD audio files... but as you have found out, the regular Dolby Digital AC-3 or Dolby digital plus versions you can play. In some cases though, downloads will have both the TrueHD and the Digital Plus versions in them, so you may want to try and hit the Audio button on your Sony remote on those silent demo files to see if you can toggle to an alternate soundtrack.... if there is one included. For what it's worth, the Digital Plus versions of the Atmos demos will still sound pretty awesome. But, if you really want to play those lossless MKV files through the Sony, you will need to convert them to M2TS files..I believe they will play in that format.
doni01 likes this.
deano86 is online now
Reply Blu-ray Players
S1700
