Sony UHPH1 Premium Audio and Video Player (2016) - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 225Likes
post #451 of 467 Old 06-13-2018, 11:53 AM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 206
Yes that was an issue.
Sony has issues with this.
Only happened one time with heavy use on the new player.
The problem is a Network issue. I don't know how to setup IP adress, I've learned that it needs it's own individual adress.
The reason that I sent back the old is because it often reset itself to factory settings after an update...
IIDexII is offline
post #452 of 467 Old 06-13-2018, 01:24 PM
kutzon's Avatar
Quoted: 50 Post(s)
Originally Posted by IIDexII View Post
Yes that was an issue. // The problem is a Network issue. I don't know how to setup IP adress, I've learned that it needs it's own individual adress.
Okay, thanks a lot for the info. If it becomes a persostent problem I'll try to fix the network thing.
My Home Theater setup:
Picture:
Benq W2000 (HT3050) // 130" DIY AT-screen // Sony UHP-H1 // XBox One S & PS3
Sound: Yamaha RX-A820 (7.1) // Infinity Beta 50/C360/ES250, Mission 737R, Dynavoice Thunder T-12 // Sinus Live BassPump III
kutzon is offline
post #453 of 467 Old 10-17-2018, 09:03 AM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 206
I still have the uhp-H1, beside the 4k uhd bluray playback and powerchord and maybe a better Sony Dac it's the same as the 1000es. I've seen inside the players.. Very similar boards. I can't tell the difference between uhp-H1, x800 or 1000Es, I only don't understand why they put DV in their cheapest player x700???
I had a new player on warranty, but I think it's great, Sacd and bluray audio and spotify, netflix is great, and cd playback is great, it makes low sq CDs shine... But some music classical, jazz is better on a standalone cd player...
IIDexII is offline
post #454 of 467 Old 10-17-2018, 07:08 PM
UHD Addict
aaronwt's Avatar
Quoted: 9917 Post(s)
Liked: 6550
Because the X1000 and X800 players came out around 1.5 years ago. And could not be upgraded to Dolby Vision. The X700 came out this year. And they did not release a replacement for the X1000 and X800. If Sony had then the players would have DV.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #455 of 467 Old 10-20-2018, 01:48 PM
gbaby's Avatar
Quoted: 931 Post(s)
Liked: 512
Digital output from coaxial or optical outputs.
Does anyone know how to play music from USB using the UHP-H1 coaxial or optical digital outputs? I can only get the unit to play USB music from the unit's HDMI output.
gbaby is offline
post #456 of 467 Old 10-20-2018, 06:33 PM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 206
Yes i think you are right.
I only want to add mention that DV is frigging expensive.
That is a reason also.
Hopefully it will be available, or else Dolby is digging they're own grave.
IIDexII is offline
post #457 of 467 Old 10-20-2018, 06:35 PM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 206
I think it's the same here.. l will check when I have time.
I have avr and Power amp. I use coaxial only for cd, mostly I use the analogue Dac.
I know this, what I play back usb is Hi-Rez and Dsd files like 5.1 tracks...
This can't be played via coax.
I give it a try now, and let you know, tonight or tomorrow.
IIDexII is offline
post #458 of 467 Old 10-21-2018, 02:41 PM
gbaby's Avatar
Quoted: 931 Post(s)
Liked: 512
Please do. Thanks. I could not get sound from coaxial trying to play PCM (44.1/16) on my USB flashdrive.
gbaby is offline
post #459 of 467 Old 10-21-2018, 02:54 PM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 206
Analogue or hdmi only on high rez
I used a usb harddrive
I only guessing, I have the highest 192 khz on pcm.. I mean to remember that coaxial can not play this.
But I'm not sure...
aaronwt likes this.
IIDexII is offline
post #460 of 467 Old 05-02-2019, 06:37 PM
kzookid's Avatar
I have an opportunity to purchase a used Sony UHP-H1 and one question I would like to know is its use with DVD-Audio. Will this unit allow the hi-res 24/96-196 2.0/5.1 files on those disks to play back thru HDMI? I have an old Pioneer dv-563a dvd-a/v player that I have to put away due to upgrading my receiver (losing 5.1 analog inputs) and see this can playback dvd-a. Are there other used players besides this that can play hi-res dvd-a that is hdmi compatible for it and be had on ebay for under $100.
kzookid is offline
post #461 of 467 Old 05-04-2019, 08:21 AM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 206
I tried 24-96 5.1 success
But 24-192 I didn't get to work 5.1 but in stereo it plays 24-192. It may be my Avr is the issue, old or can't play it.
UHP-H1 is sertified Dvd audio ready, but I only own BD Audio and SACDs.
You must check the settings for dvd audio I think.
kzookid likes this.
IIDexII is offline
post #462 of 467 Old 05-05-2019, 03:39 AM
lebellium's Avatar
Quoted: 39 Post(s)
Liked: 30
DVD-Audio format doesn't support 24/192 in 5.1.
The UHP-H1 will obviously support the DVD-Audio specs, including up to 24/192 in 2.0 and up to 24/96 in 5.1
kzookid likes this.
lebellium is offline
post #463 of 467 Old 05-05-2019, 11:57 AM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 206
I dont know why I can't get BD audio work in DTS hd master 5.1 24-192
I use a Yamaha rxv 1900, it should support this. Meant I've played it before.
But I get Stereo 24-192 and 7.1/5.1 24-96
IIDexII is offline
post #464 of 467 Old 05-05-2019, 01:09 PM
lebellium's Avatar
Quoted: 39 Post(s)
Liked: 30
5.1 24/192 content is rare and your AV receiver is old.
Although it should theoretically support it as part of the Blu-ray disc specs and DTS HD MA specs, maybe there is some hardware limitation, don't know.
On the UHP-H1 you may want to set [Digital Audio Output] to [PCM] instead of [Auto] to check if it works this way.
IIDexII likes this.
post #465 of 467 Old 05-07-2019, 05:36 AM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 206
This is useful thanks! I will try that...
IIDexII is offline
post #466 of 467 Old 04-23-2020, 12:59 PM
kgveteran's Avatar
Quoted: 936 Post(s)
Liked: 264
Im looking to play dvda/sacd through hdmi, any reports on how well this performs
kgveteran is offline
post #467 of 467 Old 05-01-2020, 07:45 AM
kgveteran's Avatar
Quoted: 936 Post(s)
Liked: 264
Bump****** is the Sony capable of SACD/DVDA through hdmi and get the onscreen menus
Reply Blu-ray Players
sony uhp-h1 , usb-stick
