Xbox One S-UHD Blu-Ray Player Aug 2016 - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 3686Likes
post #901 of 2586 Old 10-16-2016, 09:52 AM
Quoted: 222 Post(s)
Liked: 55
Just a thought but wondering if has to do with HDCP 2.2 at all I wonder if the handshake of that is flaky or something with some TVs...... for those having issues are you sure you are in an HDCP 2.2 port on TV etc....
Oarneb is offline
post #902 of 2586 Old 10-16-2016, 06:36 PM
Liked: 3
Anyone here having issues getting 4K Blu Rays to play correctly on a Samsung KS8000 / KS8500? When I play a 4K disc, I'm getting a scrambled picture with a green tint to it. Just set everything up today so I'm wondering if I'm missing something in the settings...
GalacticMouse is offline
post #903 of 2586 Old 10-16-2016, 07:01 PM
Quoted: 1551 Post(s)
Liked: 811
No. I have that combo and no issues.
Some discs are not authored properly and need to be replaced.
I did need to update and reboot the xbox before discs would play.
dwaleke is offline
post #904 of 2586 Old 10-16-2016, 07:07 PM
Liked: 3
You know I don't think I actually did that after installing the Blu-Ray Player app. I'll give it a shot. Thanks!
EDIT: Yep, that did it. Thanks again!
post #905 of 2586 Old 10-17-2016, 03:34 PM
JayX's Avatar
Quoted: 44 Post(s)
Liked: 32
Haven't been able to get my copy of The Revenant working on my Gears of War bundle Xbox One S. A copy of Labyrinth and a few Blu-Rays I've tried have been fine, but it just doesn't go past the blue BD player screen until I eject it and it tells me to try a different disc.
I've noticed one other person mention this particular film recently, has anyone else got positive/negative feedback for it?
OS version 10.0.14393.1065 installed which it's telling me is the latest.
JayX is offline
post #906 of 2586 Old 10-18-2016, 08:28 AM
cchen326's Avatar
Quoted: 122 Post(s)
Liked: 35
Did you also update the Blu player app and then restart the console?
cchen326 is offline
post #907 of 2586 Old 10-18-2016, 08:51 AM
JayX's Avatar
Quoted: 44 Post(s)
Liked: 32
I downloaded the bluray app from the store so I presumed it pulled the latest version. I've not seen anything that indicates it can be updated further but I'll look deeper into this in case it's just hidden away. I've done full reboots/power cable pulls a bunch of times and I'll do another one if I can get the app updated.
JayX is offline
post #908 of 2586 Old 10-18-2016, 04:23 PM
Quoted: 222 Post(s)
Liked: 55
Are we talking 4k discs or blue rays?
Oarneb is offline
post #909 of 2586 Old 10-19-2016, 07:43 AM
bnculp's Avatar
There were a lot of reports in the XBox forums of unreadable 4k UHD Bluray discs for the new XBox One S. I had an issue with Star Trek into Darkness purchased at BestBuy. I replaced both the 4k UHD Bluray disc and the new XBox One S console but the problem wasnt fixed. The eventual solution was to get a replacement disc from Paramount Studios. The explanation from XBox support was the following :
" Microsoft has confirmed that certain 4K Ultra HD Blu-ray discs created at a manufacturing facility for multiple theatrical and home media titles were pressed in error. As a result of this disc manufacturing error, certain 4K Ultra HD Blu-ray movie discs released in North America and Europe may not play on the Xbox One S. Customers do not need to repair their console to resolve the issue, their affected disc needs to be replaced by the studio that published the title. It is important to note that not all discs for the specific titles are affected, only certain batches. This also does not apply to standard Blu-ray or DVDs. "
jlo8720 likes this.
bnculp is offline
post #910 of 2586 Old 10-19-2016, 08:30 AM
Quoted: 197 Post(s)
Liked: 86
Originally Posted by ack_bk View Post
I was going to buy a Samsung or Philips player but just did the math and it makes no sense since I can trade in my 500GB Xbox One for almost $150 towards a $299 S. This player is more causal 4K/HDR watching as I build out my dedicated theater room and I don't need to worry about Atmos, etc.
Why would you not want atmos? Seems like a waste to build out a new theater room without support for atmos/dts:x....
Sent from my STV100-2 using Tapatalk
dwaleke likes this.
Mrjmc99 is offline
post #911 of 2586 Old 10-19-2016, 08:56 AM
JayX's Avatar
Quoted: 44 Post(s)
Liked: 32
Yeah this is the UBD disc. I've had no issues with any normal BD discs I've tried, including the one that came with my copy of The Revenant.
I couldn't see any update for the BD player so I uninstalled, power cycled etc and still same problem. The spinning circle on the BD player just halts after a half turn and doesn't do anything until I eject.
I'll next look into trying to get another copy from manufacturer. This one is a Fox title, not Paramount, but they probably use the same process. Here's hoping they're aware of issues and don't give me a hard time.
Gutted as I've heard PQ on this disc is wonderful, I really want to put my OLED through its paces!
JayX is offline
post #912 of 2586 Old 10-19-2016, 09:04 AM
ack_bk's Avatar
Quoted: 1345 Post(s)
Liked: 1503
Sorry probably was not clear enough the Xbox S will be attached to my 65" Samsung KS8000 (4K/HDR) in the family room. No Atmos will ever be in that room (it's a 2.1 setup) and I am building out a dedicated home theater room over the next 6 months or so and will most likely be buying the upcoming Oppo player for that room and it will be Atmos enabled.
aaronwt and Mrjmc99 like this.
ack_bk is offline
post #913 of 2586 Old 10-19-2016, 10:24 AM
Quoted: 197 Post(s)
Liked: 86
Makes sense. Good luck.
Mrjmc99 is offline
post #914 of 2586 Old 10-19-2016, 06:57 PM
SubSolar's Avatar
Quoted: 119 Post(s)
Liked: 40
Where are you getting $150 for an origina xbox one tradein?
Samsung 85" 4K, Dolby Atmos 7.1.4 with MartinLogan Theos, Stage, Motion 15, EM-R, Seaton Submersive F2, Denon AVR-X5200W
SubSolar is offline
post #915 of 2586 Old 10-19-2016, 06:58 PM
SubSolar's Avatar
Quoted: 119 Post(s)
Liked: 40
Is Netflix still the only app that plays in 4k or have youtube and Amazon joined yet?
SubSolar is offline
post #916 of 2586 Old 10-19-2016, 07:15 PM
Dave Harper's Avatar
Quoted: 3159 Post(s)
Liked: 1723
Yes, Inquiring minds want to know!
Dave Harper is offline
post #917 of 2586 Old 10-20-2016, 05:10 AM
loverblue's Avatar
Is Microsoft ever going to bring an firmware update to bitstream audio?
I would also like to know what 4K apps xbox has besides Netflix?
loverblue is offline
post #918 of 2586 Old 10-20-2016, 09:07 AM
Quoted: 222 Post(s)
Liked: 55
They have officially said that they are looking into it. I am just very doubtful it will ever happen do to the nature of the beast. The mixing of all the different audio for the snap feature and such. Although Sony essentially does it through the app so maybe there is a way they could do it through their app and it will be an option like the video options that you can tick on and off.
Oarneb is offline
post #919 of 2586 Old 10-20-2016, 10:06 AM
ack_bk's Avatar
Liked: 1503
Amazon trade-in offered me $148.xx for my 500GB Xbox One. This also included one controller and one game that came with my console as part of the bundle. Best Buy and Gamestop only offered me $95 for the console and one controller. I jumped on that deal I suspect as the holidays approach the trade-in values will decrease. Amazon is easy too, they give you a pre-paid shipping label and, to clarify, you get your money in the form of an Amazon Gift Card, but that's like cash to me.
ack_bk is offline
post #920 of 2586 Old 10-20-2016, 10:15 AM
ack_bk's Avatar
Liked: 1503
Got my Xbox S yesterday and hooked it up to my Denon 510BT receiver (HDCP 2.2 compliant) which ultimately is connected to my 65" Samsung KS-80000. Really like the intuitive way the S auto detected my TV and it recognized 4K/HDR/10bit right out of the box. Popped in Angry Birds in HDR as we just finished watching this Sunday night as a family on regular Blu-Ray. In some scenes the color difference is night and day, and HDR really makes things pop. I was pretty impressed with just the limited viewing I did. Very excited to put in a true 4K filmed UHD disc.
I don't have Atmos in the living room and audio sounded great (this is running to a Klipsch RP-150M bookshelf speakers and just a simple 10" Klipsch sub).
I did read about some complaints of fan noise with the Xbox S but I did not notice anything. My S is in a well ventilated cabinet, but the fan noise was a concern for me and could have been a deal breaker. This was with about 30 minutes of watching in HDR but also after my son played Minecraft on the S for about an hour.
ack_bk is offline
post #921 of 2586 Old 10-20-2016, 10:38 AM
UHD Addict
aaronwt's Avatar
Quoted: 9437 Post(s)
Liked: 6118
That's almost as good as the trade in deal Gamestop had for the XBOne, toward the purchase of an XBOne S. Back in August.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #922 of 2586 Old 10-20-2016, 10:39 AM
Syed117's Avatar
Liked: 26
Weird.
Have the Gears of War Xbox and picked up the Samsung KS8000 and The Revenant last night.
No issues.
Syed117 is offline
post #923 of 2586 Old 10-20-2016, 10:53 AM
ack_bk's Avatar
Liked: 1503
Combined with the fact that I got an Xbox S 500GB Mincrast edition for $299 that (aside from Minecraft, the builders pack and some other DLC) I also got a $50 gift card and another game from a select list. Very happy. The Samsung and/Philips players just did not make sense at this price point for me vs the S.
aaronwt likes this.
ack_bk is offline
post #924 of 2586 Old 10-22-2016, 01:08 PM
p5browne's Avatar
Quoted: 4010 Post(s)
Liked: 3183
Only in Canada you say?
What kind of by-law would municipal counsels come up with to prevent trade ins? (Note the following from BB) And we elected these guys?
*October 21 - 27 2016 valid in-store only. Due to municipal by-laws, trade-in is not currently available in: Surrey & Kelowna (BC), Winnipeg (MB), Sudbury, Woodbridge, Richmond Hill (ON), Granby & Rosemere (QC). Trade-in hours may vary from store hours. Check BestBuy.ca/TradeIn to confirm participating stores or see in-store for details. Trade-in values can vary depending on condition and games must include boxes. No duplicate titles accepted, regardless of console. Some titles may be excluded. Stores not able to take consoles for trade-in can still give customers a $50 credit towards the purchase of an Xbox One when an old console is traded for recycling. No dealers. One trade-in credit per Xbox One console purchase.
Note where I live - Sudbury It figures!
UN65KS9800 - Mine
UN65HU9000 + SEK-3500U / UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN40J5200AF / HiSense 40H5507 - Wife's
UN55NU8000 X 2 - my 2 kids families (or should I say adults?)
p5browne is offline
post #925 of 2586 Old 10-22-2016, 03:05 PM
Quoted: 222 Post(s)
Liked: 55
Wondering if there is a loophole where you can still do it online like Amazon.....
Oarneb is offline
post #926 of 2586 Old 10-22-2016, 03:08 PM
p5browne's Avatar
Liked: 3183
Going over BB way next Tuesday for a dental appointment - will see what the deal is, and what they're doing to get around it.
UN65KS9800 - Mine
p5browne is offline
post #927 of 2586 Old 10-22-2016, 10:46 PM
Worf's Avatar
Quoted: 846 Post(s)
Liked: 574
Well, there can be at least two reasons. First, there may be some restriction on trading in stuff, blocking this period. Second, it may be a law preventing one from trading in for an item - either you trade in for anything the merchant has, or you trade for cash or gift certificate. The former is restraint of trade, the second one means you can trade for anything they sell.
Where I am, there are pawn shops and used game stores, so I'm guessing it's the latter - I should be able to trade in games or console for anything they sell, not just a specific console or a specific game. Given you get extra credit if you buy a specific item, that could go against the law - either offer the extra credit for all products, or not at all.
Funny since I'm covered by that, but it never really affected me. Perhaps because I shop near work, rather than home.
Worf is offline
post #928 of 2586 Old 10-23-2016, 08:50 AM
p5browne's Avatar
Liked: 3183
Pawn shops around town, you can trade in your vehicle for a new one, many places advertise bring in your old one and trade up. The above, didn't make sense. Will know more Tuesday. May even come home with one - excepting - all that work for a $50 Credit towards purchase, when I just have to wait till Black Friday. Now, will they allow the credit towards a Black Friday pricing? If not, then taking your old console in was for nought!
UN65KS9800 - Mine
p5browne is offline
post #929 of 2586 Old 10-23-2016, 10:52 PM
Worf's Avatar
Quoted: 846 Post(s)
Liked: 574
Yeah, but that's because you can trade for anything they sell. The best buy deal only applies to consoles and games. You can trade in a game and get credit towards more games, but not general merchandise. Or if you want the extra $50, you have to buy a console, and not say a tv.
The laws probably say you cannot offer a trade in for a specific item - either because used car dealers used to bait and switch for trade ins (trade in your car, get an extra $1000 off this model, but that's sold out so too bad, but you can get this more expensive model...) or many other scenarios which unscrupulous sellers used to get you in store. Or even worse, they take your item and give you a rain check that's never fulfilled, so you should be able to trade for anything in the store
Worf is offline
post #930 of 2586 Old 10-24-2016, 08:53 PM
Quoted: 21 Post(s)
Liked: 3
Just picked up the Xbox S and hooked it up to a 2014 Vizio P series TV through HDMI 5. When I play a Netflix movie, regardless of whether it is 4K or HD, the TV shows the input resolution as 2160p.
Does the Xbox S upconvert Netflix to 4K when the movie is only available in HD?
Is there any way to tell on the Xbox S whether you are actually receiving 4K for a 4K movie or a lower quality that the Xbox S is upconverting?
ChrisAZ02 is offline
Reply Blu-ray Players
blu-ray , epson 6040ub , upscaling 4k , xbox one s
