Xbox One S-UHD Blu-Ray Player Aug 2016 - Page 86 - AVS Forum | Home Theater Discussions And Reviews
 3686Likes
post #2551 of 2586 Old 03-20-2019, 11:25 PM
MattAAron's Avatar
Quoted: 14 Post(s)
Is the Xbox One X better then the Xbox One S, in regards to the UHD Player? I’m not talking about gaming, or apps… just the physical BluRay Disc Player part.
Example:
I thought I read the Xbox One X has HDMI 2.0b (S has 2.0), which means the X would be 18Gbps (S is 10Gbps?), which means X would show HDR, 4k, 60hz, 4:4:4 (S would just be HDR, 4k, 30hz, 4:2:0?)
I tried Googling this but it’s a bit difficult finding the right keywords to search (especially when I don't care about the gaming/app part), and I found lots of outdated info as MS has released firmware updates that might have addressed the above... hopefully someone can help me!
MattAAron is offline
post #2552 of 2586 Old 03-21-2019, 04:19 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 494
Example:
There is zero difference between the two as far as UHD goes.
Foxbat121 is online now
post #2553 of 2586 Old 03-25-2019, 05:34 AM
Quoted: 50 Post(s)
Liked: 26
Example:
The S could do HDR, 4k, 60Hz, 4:2:0 as well. The difference between 4:2:0 and 4:4:4 does not matter for BluRay, since all BluRays use 4:2:0 compression anyway.
mttpalmer likes this.
G4n0nD0rf is offline
post #2554 of 2586 Old 03-25-2019, 06:50 AM
MattAAron's Avatar
Quoted: 14 Post(s)
Thank you so much!! Especially getting technical, as it was hard finding details.
I am curious, does the X do 4:4:4 then? And if so, what it's use if it's not for BluRay (games?)?
post #2555 of 2586 Old 03-25-2019, 08:13 AM
Quoted: 50 Post(s)
Liked: 26
I suppose it could, but it wouldn't make much difference. You can only see the difference in very small details like with text from a computer. I doubt you would ever see the difference when using an xbox.
post #2556 of 2586 Old 03-27-2019, 05:41 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 494
Both console outputs exactly the same over HDMI. HDMI 2.0 already supports 4:4:4 and 18gbps. There is not much advantage there for HDMI 2.1 for Xbox.
The only difference between the two is one can play some games in 4K. The other one can't. If you are not interested in games, the only difference between the two is what's left in your wallet.
post #2557 of 2586 Old 05-07-2019, 07:03 AM
S_rangeBrew's Avatar
Quoted: 109 Post(s)
Liked: 123
I've had a Xbox One X for a long time, but I'd never played a UHD Bluray until now. The reason is, I upgraded my sound system to Atmos and it's mostly UHD discs that have the Atmos soundtrack.
Anyway, I pretty damn impressed with Atmos. As for the the Xbox One X as a playback device, it works just fine, just like it did for regular Blurays. I do like the fact it bitstreams the audio with the Bluray app now. I wish other apps had that option.
I'm still using 1080P devices, so I can't comment on the 4K image, but it looked fine to me downconverted.
S_rangeBrew is offline
post #2558 of 2586 Old 05-22-2019, 04:16 PM
eBalita's Avatar
Quoted: 21 Post(s)
I am struggling playing UHD, 4k, HDR discs on my Xbox One S. It either skips, pixelates or just does not load.
I have a 65 in KS800D hooked up to an Xbox One S.
I have been having problems playing UHD, HDR 4k even Bluray discs. They would play but not without stuttering, or color pixelation or will not load at all.
It probably has something to do with Xbox settings? or KS800D settings or maybe even Denon s740h settings.
Can somebody tell me what settings I should have so that I can enjoy a movie without it stopping or stuttering?
Thank you again.
eBalita is offline
post #2559 of 2586 Old 05-22-2019, 04:50 PM
Jrocker23's Avatar
Quoted: 727 Post(s)
Liked: 704
Thank you again.
You should first hook the Xbox up directly to the TV with nothing else in between and see if you have the issues. That would rule out the Xbox & tv if it plays well..
TV - LG C8 & LG C6, AVR - Pioneer SC-LX502, Xbox One X, PS4 Pro & Switch
Living Room: LG OLED65C9, AVR Pioneer SC-LX502, Xbox One X, PS4 Pro, Nintendo Switch
Bedrooms: LG OLED65C8, LG OLED55C6, LG Soundbar NB3530A, Xbox One X
LG C6PUA Firmware Link https://www.lg.com/us/support/product/lg-OLED55C6P.AUS
LG C8PUA Firmware Link https://www.lg.com/us/support-produc...5C8PUA#manuals
LG C9PUA/AUA Firmware Link https://www.lg.com/us/support/produc...LED65C9PUA.AUS
Jrocker23 is online now
post #2560 of 2586 Old 06-19-2019, 01:43 PM
eBalita's Avatar
Quoted: 21 Post(s)
I bought a couple of new bluray discs.. they freeze at certain points. This cannot be a cable issue right? I can hear the xbox is spinning.. but it is not advancing.
eBalita is offline
post #2561 of 2586 Old 06-19-2019, 01:46 PM
Jrocker23's Avatar
Quoted: 727 Post(s)
Liked: 704
I doubt its a cable issue but you can try a new cable to rule out a cable issue . Is the Xbox Blu-ray app up to date?
post #2562 of 2586 Old 06-19-2019, 01:53 PM
eBalita's Avatar
Quoted: 21 Post(s)
Yes it is. I am so close to buying a dedicated player. I had a PS3 before and for its price it was a good player. I was kinda hoping that the Xbox would be the same but so far I have been very disappointed.
eBalita is offline
post #2563 of 2586 Old 06-19-2019, 01:58 PM
Jrocker23's Avatar
Quoted: 727 Post(s)
Liked: 704
Sorry to hear that. I have never had an issue with the bluray player. I have the original x one, an x one s and an x and all work well.
Have you tried a hard reset? With the Xbox on, hold the power button till it turns off then pull the power cord and leave off for 1 minute then plug in and turn on.
Also try a new cable just for a chance the current cable is bad. Make sure it's a cable that can handle 4k uhd
eBalita likes this.
post #2564 of 2586 Old 06-19-2019, 02:29 PM
UHD Addict
aaronwt's Avatar
Quoted: 9295 Post(s)
Liked: 5980
What titles are they? I know the Xbox wont play the earlier UHD BD releases of Oblivion and Lucy.
And a BD drive in a windows computer won't read them either. But the stand alone UHD BD players have no problem playing them.
Sent from my Galaxy S10
53TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #2565 of 2586 Old 06-19-2019, 03:52 PM
Quoted: 12 Post(s)
Liked: 6
This is a bummer. I was hoping Microsoft would figure this out by now with various software updates. I'm reluctant to spend money on products like the Sony x800m2 because they haven't figured out how to auto detect dolby vision content and yet i'm paying somewhere between xbox one s or xbox one x.
TV: LG 55" OLED (OLED55C8PUA)
AVR = Denon AVR-1200W
Console: PS4 Pro
Other: nVidia Shield TV (2017)
domerdel81 is offline
post #2566 of 2586 Old 06-19-2019, 04:04 PM
Jrocker23's Avatar
Quoted: 727 Post(s)
Liked: 704
Xbox does Dolby vision for Netflix at this time. Dolby vision for games and uhd discs is being discussed internally but as of yet has not been announced to be coming.
post #2567 of 2586 Old 07-03-2019, 10:51 AM
eBalita's Avatar
Quoted: 21 Post(s)
Thank you again.
Ok I think I am getting somewhere. I adjusted my xBox settings. Maybe it is the limitations of my TV (Samsung KS800D).
Now it says "You TV supports 4k UHD (60Hz.)
It adds: Your TV setup doesn't support 4K 10-bit at 24hz. However, apps can use 4K 8bit if they support it.
Your TV setup doesn't support 4K 10-bit at 50hz. However, apps can use 4K 8bit if they support it.
Your TV setup doesn't support 4K 10-bit at 60hz. However, apps can use 4K 8bit if they support it.
HDR10 for games & apps is turned off. (my Samsung KS800D supposedly has HDR but not HDR10 (?)
Your thoughts?
Btw, I am connected to a Denon s740h AVR.
eBalita is offline
post #2568 of 2586 Old 07-03-2019, 11:00 AM
Jrocker23's Avatar
Quoted: 727 Post(s)
Liked: 704
Your thoughts?
Couple of questions
Have you enabled deep color mode (or possibly labled hdr) on the HDMI input your using?
Have you tried connecting the Xbox direct to the tv?
Are you sure the HDMI input your using supports hdr / deep color mode?
post #2569 of 2586 Old 07-03-2019, 11:52 AM
eBalita's Avatar
Quoted: 21 Post(s)
Couple of questions
Have you enabled deep color mode (or possibly labled hdr) on the HDMI input your using? YES.
Have you tried connecting the Xbox direct to the tv? No.
Are you sure the HDMI input your using supports hdr / deep color mode? It should. It is the Arc from the TV that says it is HDR.
Thank you for your attention.
eBalita is offline
post #2570 of 2586 Old 07-04-2019, 08:47 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 494
On Samsung TV, it is called UHD color and must be enabled per input.
Sent from my Pixel 3 using Tapatalk
jlo8720 likes this.
post #2571 of 2586 Old 07-04-2019, 09:00 AM
JChin's Avatar
Quoted: 454 Post(s)
Liked: 241
Your thoughts?
Hi eBalita, check the settings of each components.
Xbox Box S > HDMI > S740H receiver > HDMI > KS800D TV
Using 18Gbps Premium certified HDMI cables between Xbox, receiver and TV
KS800D - Settings > Pictures > Expert Settings > HDMI UHD Color > enable HDMI 1-4
(or Settings > General > External Device Manager > HDMI UHD Color > enable HDMI 1-4)
AVR-S740H - Setting > Vdeo > 4K Signal Format > Enhanced
Xbox One S - Settings > Display & Sound > Video Output > Display Resolution 4K UHD > Video Modes > check boxes for Allow 4K and Allow HDR10 > 4K TV Detail
JChin is offline
post #2572 of 2586 Old 07-05-2019, 04:06 PM
eBalita's Avatar
Quoted: 21 Post(s)
From AVR to TV it connects through ARC : Xbox Box S > HDMI > S740H receiver > HDMI > KS800D TV :
YES I AM USING Using 18Gbps Premium certified HDMI cables
KS800D - Settings > Pictures > Expert Settings > HDMI UHD Color > enable HDMI 1-4 : DONE
AVR-S740H - Setting > Vdeo > 4K Signal Format > Enhanced: DONE
Xbox One S - Settings > Display & Sound > Video Output > Display Resolution 4K UHD > Video Modes > check boxes for Allow 4K and Allow HDR10 > 4K TV Detail: DONE
Movie still hangs. Ordered new cables just in case... Plain Bluray plays with no problems. Just the HDR ones seem to have problems. Any
ideas? The only connection back to the KS8000 is through the ARC is that the problem? Thank you for the responses btw.
eBalita is offline
post #2573 of 2586 Old 07-15-2019, 07:55 AM
Quoted: 37 Post(s)
Liked: 3
Hey guys, im thinking about getting an xbox one s as an UHD player. Are there any considerable advantages on getting a dedicated UHD Bluray player instead of the xbox you might help me unsterstand?
Also i have a 2016 B6 oled and i understand it cant get dolby vision from the xbox via streaming apps or discs, would this change if i get any other UHD player different to the xbox?
LG B6, LG SJ8, H7, H4s & GTX 1060
posadajulian is offline
post #2574 of 2586 Old 07-20-2019, 10:43 AM
jlo8720's Avatar
Quoted: 40 Post(s)
Is there an official AVS thread for the Xbox One X BD player? I cannot find it.
Sony XBR-65X950G (2019) w/ Yamaha RX-677 w/ 3.1
Xbox One X
Apple TV 4K
YouTube TV
Sony XBR-43X830C (2015) w/ Xbox One S, LG 60PM6700 (2012)
jlo8720 is offline
post #2575 of 2586 Old 07-20-2019, 11:02 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 494
No big difference other than the fact you already noticed that Xbox UHD does not support DV on disc playback regardless of the display you connect to (only support stream app DV on a short list of TVs). You can get an LG UHD player with DV support for half the price of Xbox One S.
There is no difference when it comes to UHD playback between One S and One X. Why would they be a different thread. If you feel the need to have one, by all means start one.
post #2576 of 2586 Old 08-05-2019, 11:24 AM
nx_2000's Avatar
Can anyone comment on the Xbox's DVD upscaling performance?
nx_2000 is offline
post #2577 of 2586 Old 08-08-2019, 07:54 AM
mttpalmer's Avatar
Quoted: 454 Post(s)
Liked: 260
I let my TV do the upscaling. Really, you can't expect any device to output 4K gold when you're feeding it SD dirt.
OLED55E6P (609 build)
Denon X2400H
KEF Q100 L/R/C, SVS SB12-NSD
XB1S, Roku Ultra
mttpalmer is offline
post #2578 of 2586 Old 08-17-2019, 12:56 AM
Liked: 0
Red face
So I'm trying to figure out my options if I want media + streaming.
If I don't have a Dolby Vision compatible TV (one room), it seems that the XBOX One S does:
* 4K HDR Bluray playback
* Supports Bitstream (for Atmos)
* Supports Netflix in HDR + Atmos mode.
* Supports Prime video in 4K. A couple of articles suggest HDR + Atmos is also supported on Prime.
* All the historical (pre-2019 articles) that talked about playback bugs all seem to now be resolved (?)
re: Dolby Vision, it looks it supports Dolby Vision from streaming, but not on Bluray discs(?)
The best option for Dolby Vision TV (my other room) then seems to be:
- Apple TV 4K for anything stream
- Dedicated Bluray player (like the UBK90 or UB820) for discs
Is there anything I'm missing from anyone's knowledge?
yip7 is offline
post #2579 of 2586 Old 08-19-2019, 08:19 PM
sweetvar26's Avatar
Quoted: 16 Post(s)
Could you guys give me an insight to this?
I have the One X as my current UHD player. I am eyeing at the LG UBK90/UBKM9 UHD player. Will there be bump in the IQ compared to the One X or would you guys suggest to skip?
I have the LG 65C8 and a 7.1.4 set up running through a Marantz 8012 receiver.
sweetvar26 is offline
post #2580 of 2586 Old 08-20-2019, 02:04 AM
Quoted: 50 Post(s)
Liked: 26
You are correct about the Bluray part. No Dolby Vision for Bluray discs (yet). Besides that it works as you would expect.
Netflix does support HDR, Dolby Vision and Dolby Atmos, but has some disadvantages compared to Apple TV:
- Always 60 Hz. All 24 Hz content will be converted to 60 Hz. Some older TV's (like 2016 LG TV's) do not support Dolby Vision in 60 Hz mode.
- Always Dolby Atmos. 5.1 content will only use 5.1 speakers while others stay silent. No upmixing possible unless you switch to 5.1 uncompressed in Xbox settings manually.
I have no idea about Amazon Prime but I assume they have the same limitations as Netflix because these are true for all Xbox apps.
yip7 likes this.
Reply Blu-ray Players
blu-ray , epson 6040ub , upscaling 4k , xbox one s
