Official "Help Me Choose an UHD Player" Thread - Page 66 - AVS Forum | Home Theater Discussions And Reviews
 18347Likes
post #1951 of 2982 Old 11-19-2018, 10:22 AM
UHD Addict
aaronwt's Avatar
Quoted: 9817 Post(s)
Liked: 6485
Originally Posted by PlanetAVS View Post
The XB1X is the only gaming console with a UHD player but compared to other UHD players, most find the navigation to be painful. It also doesn't support Dolby Vision disc playback. The positives are that you get top notch gaming and Netflix Atmos support if that matters to you.
??? The XB1S also has a UHD BD player.
57TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is offline
post #1952 of 2982 Old 11-19-2018, 10:35 AM
PlanetAVS's Avatar
Quoted: 2346 Post(s)
Liked: 2253
Right, should have said Xbox.
PlanetAVS is offline
post #1953 of 2982 Old 11-19-2018, 10:58 PM
meli's Avatar
Quoted: 375 Post(s)
Liked: 131
This may be a good place to ask... Is there much difference between UHD players in their ability to upscale 1080p Blu-ray's to 4K? I don't remember seeing it mentioned in any UHD player reviews. Is there a particular model that upscales the best?
meli is offline
post #1954 of 2982 Old 11-21-2018, 05:17 AM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 206
Im not Shure but the rumours/reviews say that most blurays do a nice job at this.
IIDexII is offline
post #1955 of 2982 Old 11-21-2018, 06:47 AM
W2IRT's Avatar
Quoted: 163 Post(s)
Liked: 24
Hey all, I'm still looking for a decent 4K player that does DV, but also has good streaming apps built in. I'd say 10% of my viewing is physical discs, hence the need for a player, and the rest is Netflix, Amazon, and Vudu. I need to be able to stream 4K titles in DV when available, and with Atmos.
I currently have a fairly unreliable 2016 Roku Ultra, and native streaming apps in my Vizio P65-C1 drop audio several times an hour, so I'm basically after something that "just works." Any suggestions? Preferably ones that won't break the bank <g>. Anything to look for on Black Friday, perhaps?
W2IRT is offline
post #1956 of 2982 Old 11-21-2018, 09:03 AM
jerlane's Avatar
Quoted: 24 Post(s)
What's the consensus on the Xbox One S as a Bluray player? I'm about to get a new TV and am planning on getting an Xbox for casual gaming and would prefer to kill two birds with one stone.
Is it decent? I've read that the interface may not be the best, but I can deal with that. How is the picture and sound?
jerlane is offline
post #1957 of 2982 Old 11-21-2018, 09:18 AM
PlanetAVS's Avatar
Liked: 2253
Sony x700 but you'll have to manually flip Dolby Vision on/off. Alternatively you could go with the Philips BDP 7302/7502 or the LG UBK90 which have automatic DV switching, and then add a cheap streamer such as the new Amazon Firestick which has DV, ATMOS capability.
If you go up in budget, the Panasonic 820 or the Sony 1000 would also fit the bill.
post #1958 of 2982 Old 11-21-2018, 09:22 AM
PlanetAVS's Avatar
Liked: 2253
Interface is horrible but if you can live with it, it plays fine. It doesn't support Dolby Vision for disc play if that matters to you. The pros are Netflix Dolby Vision (if your TV supports the newer "low latency" Microsoft version of DV), Netflix ATMOS, gaming, price. Recommend getting a 3rd party remote for cheap, such as the PDP Talon remote if you decide to go with it.
post #1959 of 2982 Old 11-21-2018, 10:08 AM
UHD Addict
aaronwt's Avatar
Liked: 6485
I currently have a fairly unreliable 2016 Roku Ultra, and native streaming apps in my Vizio P65-C1 drop audio several times an hour, so I'm basically after something that "just works." Any suggestions? Preferably ones that won't break the bank . Anything to look for on Black Friday, perhaps?
Your best bet is to get the DV player on sale this week and then pick up a roku for half price this week. It will give you the best of both worlds. Or the FireTV 4K stick for on sale this week, if those apps work for you. Since external roku's only do hdr10. While the FireTV 4k stick can handle DV from the streaming apps.
Sent from my Galaxy S8 using Tapatalk
aaronwt is offline
post #1960 of 2982 Old 11-21-2018, 11:07 AM
W2IRT's Avatar
Quoted: 163 Post(s)
Liked: 24
Sounds like a plan. Does the Firestick 4k pass Atmos from Netflix or just from Amazon sources?
W2IRT is offline
post #1961 of 2982 Old 11-21-2018, 11:44 AM
PlanetAVS's Avatar
Liked: 2253
The firestick doesn't support Netflix Atmos, at least not yet. None of the current Dolby Vision UHD players also support Netflix ATMOS.
post #1962 of 2982 Old 11-21-2018, 03:45 PM
jerlane's Avatar
Quoted: 24 Post(s)
Would a Harmony remote do the trick? Any reason to pay up for the Xbox one X as far as movie playback goes?
jerlane is offline
post #1963 of 2982 Old 11-21-2018, 04:33 PM
PlanetAVS's Avatar
Liked: 2253
Not sure about Harmony but the main issue is the onscreen navigation is painful, no matter what physical remote is used. Using a 3rd party remote makes it easier than using the controller but its still not easy for disc use. As far as I know, the Xbox One X and Xbox One S both have the same disc player.
post #1964 of 2982 Old 11-21-2018, 05:58 PM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 206
The main issue with game console is start-up booting, must mention its been some time.. 360..
But suspect it's alot like starting a laptop.
Logitech started the 360, but it took time. Often I preferred to use the controller... And the Logitech isn't very point sensitive..
But the Xbox had very point sensitive issues with Logitech..
It's ok if you do alot of gaming, don't bother the upstart, or the background noise from the console.
IIDexII is offline
post #1965 of 2982 Old 11-21-2018, 08:54 PM
3Dhereicome's Avatar
Quoted: 356 Post(s)
Liked: 164
Dumb question...
Hey,
Im trying to find the info but going in circles. I’m looking for a new Blu-Ray player, leaning towards the X-700. Anyways, I’m doing so because I want Dolby vision support since Microsoft refuses to add it via disk. I’m finding a hard time finding a list of players that support that though. Also, Best Buy website has Dolby Atmos as a criteria. Are there really only 5 players that can decode the Atmos to send to my SJ9? That didn’t even cross my mind.
3Dhereicome is offline
post #1966 of 2982 Old 11-21-2018, 10:45 PM
bobknavs's Avatar
Quoted: 2671 Post(s)
Liked: 1900
Dolby Atmos isn't decoded by the player. It's passed as a "bitstream" signal. DTS:X is the same. I don't know of any stand-alone players that can't pass bitstream. (An Xbox One isn't a stand-alone player, but I believe that MS updated it to support bitstream.)
You'd think that Dolby Labs would publish a list of players that support Dolby Vision, as all must pay Dolby a licensing fee, but I am unaware of such a list.
I don't know what the best relatively low-cost player is that supports Dolby Vision, but the X700 may be it.
I liked the Sony X800, but it will never support DV.
bobknavs is offline
post #1967 of 2982 Old 11-22-2018, 10:12 AM
PlanetAVS's Avatar
Liked: 2253
Originally Posted by 3Dhereicome View Post
Hey,
LG UBK90, Philips 7302/7502
Panasonic 820, Sony 1000 at the higher end
post #1968 of 2982 Old 11-22-2018, 11:21 AM
bobknavs's Avatar
Liked: 1900
I was thinking of those. The first two are about the same price as the X700, and not obviously superior to it, so I didn't suggest them. The 7502 is already a fairly old model.
The latter two are much more expensive (around $500), so I didn't suggest them either.
bobknavs is offline
post #1969 of 2982 Old 11-22-2018, 11:24 AM
PlanetAVS's Avatar
Liked: 2253
He didn't mention any budget restrictions. Both the Philips and the LG have the advantage of automatic Dolby Vision switching.
post #1970 of 2982 Old 11-22-2018, 12:01 PM
Quoted: 356 Post(s)
Liked: 164
Hey,
Ok, that’s what I thought. I don’t know why Best Buy has boy-day players listed as “Dolby Atmos” that was confusing. I’ll check out the other ones, I saw a few of those, didn’t know if I missed anything. Budget isn’t really a big deal but I’m not going to buy the $500 Panasonic, not that hardcore. I did read the odd Sony manual DV switching so it looks like that’s out the window, that seems very annoying. I’ll either go with the UBK90/Phillips or see what comes out at CES. Thanks everyone.
post #1971 of 2982 Old 11-22-2018, 12:01 PM
UHD Addict
aaronwt's Avatar
Liked: 6485
Yes. The Phillips works and looks great. But it can be little loud sometimes. But I will take that any day over having to manually turn on DV like is needed on the x700.
I'm hoping Sony comes out with a proper DV player next year. One that properly switches between sdr, hdr10, and dv.
Because the current way of having to manually enable DV is just asinine.
PlanetAVS likes this.
aaronwt is offline
post #1972 of 2982 Old 11-22-2018, 09:08 PM
bobknavs's Avatar
Liked: 1900
Thanks for reminding me about that. The only DV players I've used are the Oppo UDP-203 and the Panasonic dp-UB820, both of which switch automatically. Having to do it manually with the X700 would be irritating at best.
Steve544 likes this.
bobknavs is offline
post #1973 of 2982 Old 11-23-2018, 10:42 AM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 206
LG also has function move down subtitles..
That is a nice feature...
IIDexII is offline
post #1974 of 2982 Old 11-23-2018, 12:38 PM
Steve544's Avatar
Quoted: 144 Post(s)
Liked: 122
Question UHD Blu Ray players
Now that the Oppo 203 is out of possibilities, what is the best player that comes as close as possible to the Oppo's quality and performance. I still have the Panasonic ZT 65 monitor and a Aerial Acoustics 7.1 sound system powered by a Macintosh amp. I own several hundred blu ray discs and only about 100 standard DVDs so upgrading both the monitor and player are coming soon. Just can't afford the $15,000 8K Samsung as yet....any recommendations on both monitor and player?
I do not stream anything or watch 3D so those features are not important to me.
Thanks all for your input.
Steve
Steve Douglas, McIntosh 8207 amp, Anthem AVM-60, Anthem MCA 50 amp, Aerial Acoustics 10T, CC3 center, 5s and SR3 dipole/bipole, 18"Velodyne Sub
Sony 85" 950G, 4 Paradigm Cinema 100 2.0 System and OPPO 203 Blu-ray deck
Steve544 is offline
post #1975 of 2982 Old 11-24-2018, 11:19 AM
jazztalker's Avatar
So, I'm getting an OLED (LG C8) and want to get a UHD player to go with it. I don't really want to spend the $500 for the Panasonic UB820, so I think it's either the LG UBK90 or the Sony UBPX700 as I'd like something with Dolby Vision capability. If I understand correctly - with the Sony I have to manually toggle Dolby Vision on and off depending on the disc, correct? And I believe you have to change between 60p and 24p on the LG - is that also correct?
Assuming these two players are relatively comparable overall - which of the aforementioned annoyances is going to be more annoying? I tend to be someone who likes to set and forget as much as I can. Is it going to be easier or less frequent to make one of these when needed as opposed to the other?
jazztalker is offline
post #1976 of 2982 Old 11-24-2018, 04:39 PM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 206
Sony has Sacd if you don't need this, only video etc maybe LG will do the job.
I'm going for the Sony.
IIDexII is offline
post #1977 of 2982 Old 11-25-2018, 02:19 AM
Quoted: 31 Post(s)
Liked: 2
I own a PS3 - should I buy a Blu-Ray player?
Hi,
I own the PS3 slim version and was wondering if I should consider buying a dedicated Blu-Ray player for my home cinema? I am fairly happy with the PS3 as a Blu Ray player except for the fan noise it produces. Will a new player pay off or would it be a waste of money?
I have the Denon AVR-X1400H and the LG OLED55C8 TV.
I see there is a quite large price variation on Blu-Ray players. What will I get from a high-end player that is not included in a low-end player? And where in this range is the PS3 located?
Thank you
Hoggorm is offline
post #1978 of 2982 Old 11-25-2018, 02:20 AM
markmon1's Avatar
Quoted: 6158 Post(s)
Liked: 4209
Originally Posted by Hoggorm View Post
Hi,
Thank you
no real benefit unless you're looking at something like a panasonic 820 to done map HDR. Otherwise, you should just stick with the PS3.
Video: JVC RS4500 135" ST130 G4 screen in batcave, htpc nvidia 1080ti madVR.
Audio: Anthem mrx720 running 7.1.4, McIntosh MC-303, MC-152, B&W 802d3 LR, B&W HTM1D3 center, B&W 805d3 surround, B&W 702S2 rear, B&W 706s2 x 4 shelf mounted for atmos, Infinite Baffle Subs 4x15 fi audio running on behringer ep4000 + 2x12 fi audio mounted in main chair firing into back.
markmon1 is offline
post #1979 of 2982 Old 11-25-2018, 02:25 AM
Quoted: 31 Post(s)
Liked: 2
Thank you!
How about the Sony UBP-X800?
Hoggorm is offline
post #1980 of 2982 Old 11-25-2018, 02:26 AM
markmon1's Avatar
Liked: 4209
Thank you!
Sorry, it should have said "tone map HDR" not "done map HDR". Unless you're looking for 4K Bluray playback, I'd stick with your PS3. And if you need HDR tone mapping, then only that panasonic is going to handle it. If you don't need that then stick with the PS3.
markmon1 is offline
Reply Blu-ray Players
4k player , blu ray , Blu Ray Players , dvd , hdcp upgrade compliance , hdr , hdr player , upscale 4k , upscaling , xbox one s
