Official "Help Me Choose an UHD Player" Thread - Page 75 - AVS Forum | Home Theater Discussions And Reviews
 18227Likes
post #2221 of 2556 Old 03-22-2019, 08:24 PM
Quoted: 82 Post(s)
Liked: 1
hello good people i am doing my theater room over and now i need to pick a good dvd player I am a movie nut! but I;m not doing 4k im runnung a sony 45es on a 110inch with maranbtz sr7012 what would be a good player to give the best picture?
quentinnw2 is offline
post #2222 of 2556 Old 03-23-2019, 05:15 PM
Quoted: 535 Post(s)
Liked: 1231
FWIW in this Sony 45ES review (linked) from 2017, the reviewer used a Samsung UBD-K8500 4K UHD player.
https://www.soundandvision.com/conte...ojector-review
Projectionists at this website often positively mention Panasonic UB820. You might check that owner's thread for compatibilty.
https://www.avsforum.com/forum/149-b...-talk-120.html
Panasonic TC65CX850U Yamaha RX-V1079 Technics SU-V650 Panasonic DMP-UB900 Sony UBP-X800 Polk Audio SDA-2B
Panson is offline
post #2223 of 2556 Old 03-24-2019, 03:44 PM
jollyguy23's Avatar
Quoted: 14 Post(s)
UHD player only for Dolby Atmos?
This group has helped me a great deal when I was putting together my home theater 4 years back. I am back with my upgrade questions.
I have a JVC 4910 and a Denon 4000 with a 7.2 setup on a 235 screen (133”) with an Oppo 103 and non 4K Apple TV. . After a long time I am finally taking the Atmos plunge and moving to a 7.2.4 confit with upgrading my receiver to support it.
I am a big Redbox guy since they work out cheaper for me. I am finding out that once I move to Atmos there are certain studios that give the Atmos option only when I go to the UHD blur ray.
This means for watching the UHD Blu-ray I believe I need a new player. Anything else that will need to be changed here? I am essentially moving to UHD only for the sounds than the real 4K.
Your help in anything I am missing here would be very much appreciated.
jollyguy23 is offline
post #2224 of 2556 Old 03-25-2019, 12:11 PM
UHD Addict
aaronwt's Avatar
Quoted: 9091 Post(s)
Liked: 5840
Originally Posted by tkundhi View Post
Yeah, that is what I've finding.Even the Cambridge Audio version doesn't have the same inputs. I'm kicking myself for not pulling the trigger on the Oppo.
Nor can I find a good DAC that does has HDMI, and multiple digital inputs.
t.
At least you never pulled the trigger. I bought one and then sold it in favor of the Sony x800 a couple of years ago.
The main reason I lament the mistake is because it is the only device to let you play back DOlby Vision rips. But at the time I only had an HDR10 set. And that was a major factor in my decision to sell the OPPO at the time.
Although even if I had kept it, I probably would have sold it by now anyway. Because of the sky high resale value.
53TB unRAID1a--49TB unRAID2--76TB unRAID3
TCL 6 Series--Sony UBP-X800--Philips BDP7502--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
post #2225 of 2556 Old 03-25-2019, 12:14 PM
UHD Addict
aaronwt's Avatar
Liked: 5840
It's just bitstreaming the audio to the receiver. Which every player should be able to do. My old BD players from a decade ago can bitstream Atmos audio.
post #2226 of 2556 Old 03-25-2019, 06:56 PM
Quoted: 82 Post(s)
Liked: 1
oppo ?
Is it worth sending a two week paycheck on a oppo players or should i just pick up the UB820 what you guys think plus im looking at mostly blu-ray very little 4K thanks.
post #2227 of 2556 Old 03-29-2019, 06:03 PM
Invader3's Avatar
Quoted: 98 Post(s)
Liked: 41
Hey guys. I'd like to get a 4k disc player to go with my Sony 900e 4k TV. What are the current recommendations? Will be paired with an Onkyo TX-RZ920 receiver running 7.1.2.
Invader3 is online now
post #2228 of 2556 Old 03-29-2019, 06:18 PM
PlanetAVS's Avatar
Quoted: 1871 Post(s)
Liked: 1516
Sony x800
Sent from my SM-G935P using Tapatalk
PlanetAVS is online now
post #2229 of 2556 Old 03-30-2019, 04:50 AM
Invader3's Avatar
Quoted: 98 Post(s)
Liked: 41
Originally Posted by PlanetAVS View Post
Sony x800
Thanks. Browsing around, it looks like that's the concensus for one of the best ones out there.
post #2230 of 2556 Old 03-31-2019, 10:54 AM
PlanetAVS's Avatar
Liked: 1516
Yep, it's excellent. The only thing missing is Dolby Vision support which your 900E doesn't support either.
post #2231 of 2556 Old 03-31-2019, 11:21 AM
Invader3's Avatar
Quoted: 98 Post(s)
Liked: 41
Yes, that is correct.
I ended up getting the 800 yesterday and hooking it up. I'm getting a stunning 4K picture. My copy of "The Avengers" on 4K looks amazing.
The only thing I'm not completely sure of is if I'm getting Atmos sound or not. I have the Sony player connected to my Onkyo receiver, and then sending the picture to my 900E display via HDMI Arc. Is there a setting on the 800 player I need to check? My Onkyo doesn't seem to be indicating an Atmos signal.
post #2232 of 2556 Old 03-31-2019, 11:34 AM
PlanetAVS's Avatar
Liked: 1516
I assume that you have already tested that ATMOS works properly from other sources?
For the 800, you should have the audio set to bitstream out.
Edit: BTW, the Avengers doesn't have an ATMOS soundtrack. Try a different disc that has ATMOS
post #2233 of 2556 Old 03-31-2019, 11:46 AM
Invader3's Avatar
Quoted: 98 Post(s)
Liked: 41
It actually does, or at least mine does. This is the version I have:
https://www.blu-ray.com/movies/The-A...lu-ray/207639/
post #2234 of 2556 Old 03-31-2019, 12:04 PM
PlanetAVS's Avatar
Liked: 1516
You're right, I misread the info. Did you try bitstream out and did that help?
post #2235 of 2556 Old 03-31-2019, 02:25 PM
Invader3's Avatar
Quoted: 98 Post(s)
Liked: 41
Yes, apparently I had to set "BD Audio Mix" to Off. That fixed the issue.
post #2236 of 2556 Old 04-01-2019, 09:47 AM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 205
That depends on your use.
.UB820 is a very good bluray player.
Oppo is better on CD, +sacd and DVDs.
IIDexII is offline
post #2237 of 2556 Old 04-01-2019, 12:38 PM
zeonstar's Avatar
Quoted: 485 Post(s)
Liked: 115
Hey all
Looking to possibly upgrade my the first 4K player I got, which was a UBK90, to something in a higher price range with hopefully a superior picture quality.
1. Looking in the $500 price range.
2. Must have Dolby Vision with auto detection
3. Ability to play MKV files off USB drive with Dolby Atmos/DTS:X Sound.
My front runner right now is the Panasonic 820. I think it does all I want, except maybe #3 . I actually need to check if I have another device than can play the files when I get home. Not being able to do #3 isn't the end of the world, I really just have some sound trailers on a usb drive I like to show people.
Player will be outputting to a LG C8 65 inch.
zeonstar is offline
post #2238 of 2556 Old 04-01-2019, 02:38 PM
Derek87's Avatar
Quoted: 97 Post(s)
Liked: 44
i've been tracking the x800 for a while now and was surprised to see it's price drop to $199 and recently go back up to $229. i had thought $199 was the new normal price with the imminent release of the X800mk2.
i'm hoping that the X800mk2 falls in under $300. i have a Sony 900e just like Invader3, but i wouldn't mind "future proofing" for Dolby Vision as i envision this will be the last disc player i buy. (at least that's what i'm hoping for with the better build quality of the x800 boxes)
still wishing i wasn't waffling about the Oppo203 when i first got our 900e. they closed shop right when i was grappling with spending $500 for a player. (i have loved my Oppo83 over all these years)
Derek87 is offline
post #2239 of 2556 Old 04-02-2019, 08:34 AM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 205
I don't know if DV or HDR10+ will win the war.
It depends if it will be available on all screens.
Today it's except of LG and expensive Oleds not available.
I remember a few standards, Laserdisk, HD dvd and Minidisc....
Does PlayStation and Xbox support DV?
IIDexII is offline
post #2240 of 2556 Old 04-05-2019, 05:30 PM
Quoted: 26 Post(s)
Liked: 51
In the market for a bluray player
Pairing it with a JVC RS66u e-shift. Looking at the sony x700 and x800 but saw the new x800m2 and 1100es coming out. Thoughts/opinions?
sfreiman is offline
post #2241 of 2556 Old 04-06-2019, 06:40 PM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 205
For Projector only I would look for one of the Panasonics, they are famous for pixel mapping.
Sony is good also, and I have Sony myself.
I choose this mainly for the Sacd, streaming and Dvd audio.
If Panasonic gets a BD player with Sacd I'm interested.
But check out the new Panasonics pixel mapping...
This is important specially on projectors.
IIDexII is offline
post #2242 of 2556 Old 04-07-2019, 05:54 AM
Liked: 0
I currently have a Sony 900e which I dont think will ever get DV. I really dont care too much about streaming capabilities because I just use the TV apps. That being said I am trying to decide between the LG UBK80 and the Sony Ubpx700. Since my TV wont ever have DV can I just turn it off on the X700 and be ok or should I just go with the UBK80 so I never have to worry about the DV. Or, should I just wait for the X800m2 to come out all though from my understanding the only real difference between 800 and 700 is DV (correct me if I'm wrong). Thanks in advance.
bigjakester is offline
post #2243 of 2556 Old 04-07-2019, 10:59 AM
Quoted: 535 Post(s)
Liked: 1231
You can turn off DV on the X700, and it's advised you do so if not using. X700 would help you for the future, if your circumstances change. It also has built-in WiFi.
FWIW currently at Best Buy US, X700 is only $30 more than LG UBK80.
X800M2 will be a better build than the X700, but it may be $200+ more. Prices to be announced.
Good luck. Enjoy.
Panson is offline
post #2244 of 2556 Old 04-07-2019, 11:07 AM
Quoted: 2328 Post(s)
Liked: 1131
Originally Posted by IIDexII View Post
Oppo is better on ... DVDs.
Shopping List:
TV: Samsung Q90R, or LG C9, or Sony ...
Blu-ray: Panasonic UB820, or Sony X800M, or Pioneer Elite LX500
Soundbar: Samsung Q90R, or Sennheiser Ambeo, or...
AVR and Speakers: Marantz 8012, or... and GE Triton Reference, or...
New24K is online now
post #2245 of 2556 Old 04-07-2019, 12:06 PM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 205
Originally Posted by New24K View Post
Upscaling..
IIDexII is offline
post #2246 of 2556 Old 04-07-2019, 12:25 PM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 205
I like 800 series most, but I also want the 700 because it fits my rack.
I don't like the build and disc play on Koreans.
Lg and Samsung make nice TV and phones. The rest I don't like. No offense.. Just my opinion and experience.
IIDexII is offline
post #2247 of 2556 Old 04-07-2019, 02:49 PM
Liked: 1131
Upscaling..
Vincent Teoh did a direct comparison between the Oppo 203 and Panasonic UB9000 (which is a UB820 with audiophile audio output - 7.1 analog audio out and balanced XLR connectors).
And states in his comparison video posted three weeks ago that the Panasonic is better at upscaling (including DVD) than the Oppo 203.
The Panasonic is also better at chroma upsampling, HDR to SDR conversion, etc.
"For DVD, Blu-ray, and 4K Blu-ray playback, no other player can beat the Panasonic... in terms of picture quality".
aaronwt likes this.
Shopping List:
post #2248 of 2556 Old 04-07-2019, 11:21 PM
IIDexII's Avatar
Quoted: 319 Post(s)
Liked: 205
https://www.youtube.com/watch?v=yvWEK0novkY
I agree Panasonic 9000 is best, but the member asked for Oppo...
Ok you say that it 820 has the same videoboard? I have heard that also but not confirmed.
Some say that the cheapest Panasonic also have the same videoboard.... But no DV.
The 9000 has the best build...
But don't have support for Sacd.
IIDexII is offline
post #2249 of 2556 Old 04-12-2019, 08:34 AM
Liked: 0
I just bought my first 4K OLED (LG C8 65 inch), and I need to start thinking about 4K content. I have a ROKU Ultra for streaming, but I also want the ability to play UHD 4K blu ray discs. My disc watching is somewhat limited. I only buy around 5 titles per year, and probably watch a disk from my library like once a month. Cost is not a huge deal for me, but I don't want to throw money away either. I want a player that is fast, and just works. I've read some stories of players randomly freezing... That sounds horrible, and it would drive me bananas. I don't do much audio, but I will obviously have a lot of standard DVDs and Blu-Rays in my library.
From the reading I have done, it sounds like my best options are to either wait for the Sony X800M2 (since it will have Dolby Vision), or buy the Panasonic UB820 right now. There is also a cheap LG player available (UBK80?), but I think I want something better that that. Any opinions from the experts would be greatly appreciated. Thanks!
wacky4alanis is offline
post #2250 of 2556 Old 04-12-2019, 01:54 PM
Quoted: 535 Post(s)
Liked: 1231
FWIW early indications are that the X800M2 will have the same manual DV choosing as the X700, not automatic. See X800M2 anticipation thread for reference to that.
Panasonic UB9000 (retailer Value Electronics) for your OLED, and for excellent upscaling of DVD and Blu-ray. Better build than UB820. Neither play SACD.
anwsmh likes this.
Panson is offline
Reply Blu-ray Players
4k player , blu ray , Blu Ray Players , dvd , hdcp upgrade compliance , hdr , hdr player , upscale 4k , upscaling , xbox one s
