Official "Help Me Choose an UHD Player" Thread - Page 91 - AVS Forum | Home Theater Discussions And Reviews
 18270Likes
post #2701 of 2706 Old 11-04-2019, 08:17 AM
Yankees24's Avatar
Quoted: 245 Post(s)
Liked: 93
Originally Posted by bobbino421 View Post
Thanks, I’d be pairing it with my 2019 Sony 75 inch xbr950G.
I may just bite the bullet and get the Panny.
I’m picking the Panasonic up today. Thanks for the advice[/QUOTE]
You won’t be disappointed. Ever since I got my 820 i feel like I won’t even need another disc spinner for a long while! The 9000 is nice if you can afford it and you need the extra audio support, but it’s basically the same PQ so if you need to spend the extra $500 on it the 820 is the perfect all around player. It’s not perfect as it don’t check all the boxes for every format but if you just doin discs you can’t go wrong.[/QUOTE]
Yup, its just for disc playing and so far I've been really enjoying it (especially the fine tuning of HDR and luminance on the the player.
Think before you speak....
Yankees24 is offline
post #2702 of 2706 Old 11-09-2019, 06:18 AM
Tiga's Avatar
Quoted: 12 Post(s)
Any good players for HDR to SDR Conversion?
I want to start enjoying Dolby Atmos tracks but I'm not planning on updating to a 4k projector for a while. Do most new UHD players do this conversion well enough? I thought I read Panasonic did a nice job - true? How's the Xbox S? Thank you!
Tiga is offline
post #2703 of 2706 Old 11-09-2019, 06:51 PM
MidnightWatcher's Avatar
Quoted: 190 Post(s)
Liked: 193
Best HDR to SDR conversion will be done by these Panasonic players imho. If you need Dolby Vision, go with the UB820. If you don't need Dolby Vision, go with the UB420.
Tiga and skylarlove1999 like this.
My Theater | Vero 4K | Epson 5030UB + Peerless PRG-UNV | 100" EluneVision Reference 4K Screen | Denon X3600H @ 5.2.4 | 4 x ADX Maximus w/ Dayton Audio SA230 | Polk Audio RTi A9 + CSi A6 + OWM3 + Micca M8C + SVS PC2000 + Monolith 15 | 40" HDTV w/ Z83V Mini PC + MoviePosterApp | Z83V + DietPi FTP Server + 3 x 8TB HDDs + 4 x DLink DHP-701AV
MidnightWatcher is offline
post #2704 of 2706 Old 11-09-2019, 07:14 PM
skylarlove1999's Avatar
Quoted: 1033 Post(s)
Liked: 720
I agree with this entire statement. Well said.
Sent from my SM-G965U using Tapatalk
skylarlove1999 is online now
post #2705 of 2706 Old 11-10-2019, 07:03 PM
pavelbarchuk's Avatar
Bluray player vs Media network players
I've been using network media players for about a decade now, Dune players for the most part. I'll play 4K UHD video with no issues.
Question is, am I missing out on audio and video quality? Let's say I get a Pioneer LX500 or similar high quality bluray player, would I even notice a difference?
pavelbarchuk is offline
post #2706 of 2706 Old 11-11-2019, 05:31 AM
smdelaney's Avatar
Quoted: 181 Post(s)
Liked: 148
It depends...
Are you using digital or analog outs on your media player and existing (or theoretical) disc player? If you are passing a digital signal to your AV system then it is doing the decoding/conversions and the differences should not be significant. If you are using analog outs then the player (media or 4k BD) is doing the converting and you have to compare the quality of those components against each other.
Assuming all links in your AV chain support it you would DEFINTELY see a difference between 4k UHD and 4k UHD HDR.
It boils down to which media formats are important to you, the quality of your media source and whether or not your chosen device supports what you need and want.
"You keep using that word...I do not think it means what you think it means."
-Steve-
TCL 55R617, Denon AVR-X2400H, Philips BDP-7502, Onkyo DX-C390, (2) HEOS 3HS2's,
Cambridge Soundworks Ensemble (FR/FL), MC150 (C), S100 (SR/SL), KLH E-12DB (SW)
smdelaney is offline
Reply Blu-ray Players
4k player , blu ray , Blu Ray Players , dvd , hdcp upgrade compliance , hdr , hdr player , upscale 4k , upscaling , xbox one s
