Official OPPO UDP-203 Owner's Thread - Page 1006 - AVS Forum | Home Theater Discussions And Reviews
 278828Likes
post #30151 of 36750 Unread 06-06-2018, 07:52 AM
BGLeduc's Avatar
Quoted: 2545 Post(s)
Liked: 2379
Originally Posted by Bob Pariseau View Post
I've just confirmed this failure in my test setup. I've reported the details to OPPO via Beta Tester channels.
CAUTION: If your display supports NEITHER HDR-10 nor Dolby Vision, you will not get good video from this Beta firmware when playing Dolby Vision discs!
There is no workaround I know of at this time. The fix will require updated firmware from OPPO.
There is no such problem when playing SD-DVD, regular Blu-ray, 3D Blu-ray, or UHD/HDR-10 discs.
--Bob
THANK YOU, Bob!!!!!!
I did report the issue to Oppo this morning via the normal support email address, but always great to know that I have not found some weird, obscure issue that only affects my specific set-up.
#JB17
BGLeduc is online now
post #30152 of 36750 Unread 06-06-2018, 07:53 AM
Quoted: 189 Post(s)
Liked: 204
Originally Posted by boe View Post
This may seem like a silly question but I see so many posts about DV and HDR I have to ask -
Does HDR or DV really matter if you have an OLED TV?
Yes
nusilver, galonzo and SinGA like this.
A1E OLED 4K Ultra HD
Oppo 203
Xbox One S
Denon AVR X6300W
Dolby Atmos 5.2.4
Origin Acoustics Theater 68
Nick Martelli is offline
post #30153 of 36750 Unread 06-06-2018, 07:54 AM
bodosom's Avatar
Quoted: 1876 Post(s)
Liked: 1419
Yes. [Ultra HD] benefits are independent of panel technology.
I might type 2K for 1080p.
UDP-203/ATV4K(6,2)/X3500/LG C8
bodosom is offline
post #30154 of 36750 Unread 06-06-2018, 07:56 AM
bluemoon737's Avatar
Quoted: 2204 Post(s)
Liked: 2704
Originally Posted by wmcclain View Post
Speaking only for myself: I don't know enough about DV to say.
Converting non-HDR or HDR10 content to DV seems like a goofy thing to do and I'm not bothering with it. If others like it, I don't mind, but I'm leaving that on Auto, meaning only DV sources produce DV for me.
-Bill
I wonder if it is Dolby's own version of on the fly dynamic tone mapping similar to what the LG and Sony TVs can do and their "reason" for not embracing HDR10+ (effectively does what HDR10+ does already). It could be Dolby's answer to HDR10+. Just speculating...
galonzo likes this.
-Jeff-
Man cave: Sony XBR75Z9D, Marantz SR8012, and OPPO UDP-203
Living room: Sony XBR75X950G, Denon x4500, and Sony UBP-X800M2
bluemoon737 is offline
post #30155 of 36750 Unread 06-06-2018, 07:56 AM
hernanu's Avatar
Quoted: 1194 Post(s)
Liked: 1995
Originally Posted by kristoffer77 View Post
So why would you the player do the conversion instead of the tv?
Added the “Dolby Vision” mode under the HDR Setting menu, which allows the player to convert the output to Dolby Vision when possible.
Added the “Dolby Vision Processing” setting under the HDR Setting menu. This setting allows customers to choose whether Dolby Vision processing is handled mainly by the TV or the UDP-20x player.
Originally Posted by Nick Martelli View Post
Trying to figure that out myself
The whole reason for this new firmware release is that:
  1. The original Dolby spec relied on the display doing all of the DV work.
  2. Sony TVs of a particular stripe for whatever reason couldn't handle the DV decoding in the agreed upon fashion
  3. Sony went to Dolby and whined about it.
  4. Dolby capitulated and created a "Sony DV" profile that requires any player feeding a Sony TV a DV signal to take on some of the decoding work.
  5. Sony was happy, the player / other input device manufacturers are now forced to take on more work.
  6. Oppo, to its credit put a lot of work in to put in this Sony required functionality in addition to the DV functions that it has for all other TVs.
Hence the new firmware. It enables a group of Sony TVs that have been updated to the "Sony DV" functionality to show DV content from Oppo players.
hernanu is offline
post #30156 of 36750 Unread 06-06-2018, 07:58 AM
Quoted: 189 Post(s)
Liked: 204
  6. Oppo, to its credit put a lot of work in to put in this Sony requierd functionality in addition to the DV functions that it has for all other TVs.
I know that. I'm just talking about that settings to have the TV process vs the player. Either setting sends DV correctly on my A1E. Is this a bug?
Oppo 203
Xbox One S
Denon AVR X6300W
Dolby Atmos 5.2.4
post #30157 of 36750 Unread 06-06-2018, 08:01 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4539 Post(s)
Liked: 4369
Is the device known to accept both profiles? Some do: the LGs after the "6" series, for example.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #30158 of 36750 Unread 06-06-2018, 08:02 AM
bodosom's Avatar
Liked: 1419
The LG E6 is evidently returning a handshake result saying it can not accept the low latency profile.
--Bob
Are you being model specific here? It works on a e.g. a B6 but not an E6? In any case, the posts I've read say the P5-only ATV4K sends DV to a 2016 LG OLED. Just with (reported) "elevated" blacks.
bodosom is offline
post #30159 of 36750 Unread 06-06-2018, 08:03 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5783 Post(s)
Liked: 8256
--Bob
It appears the Dolby certification tests still require /60 for that. It has to do with the processing bandwidth spec'd by the Dolby Vision engine during that conversion. I.e., not enough bandwidth at /24.
--Bob
OK, I've FOUND THE WORKAROUND!
The PROBLEM is that the OPPO is mistakenly using /24 output when attempting to do this Dolby Vision conversion for a display that accepts NEITHER HDR-10 nor Dolby Vision.
The WORKAROUND is to set the OPPO to Custom > 1080p 60Hz video output when you want to play a Dolby Vision disc into such a display.
Set that way Dolby Vision discs should play just fine into such displays. You will get proper 1080p SDR BT.709.
You can continue to use 1080p Auto output for other content, including conversion of UHD/HDR-10 discs for output to such a display.
And if your display accepts HDR-10 or Dolby Vision there is no such problem, so no Workaround needed.
--Bob
JFR0317, AVfile, BGLeduc and 6 others like this.
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #30160 of 36750 Unread 06-06-2018, 08:03 AM
Quoted: 189 Post(s)
Liked: 204
-Bill
That I'm not sure of. The way it's written in the firmware notes, it seems the TV led processing wouldn't work since that is what I thought this whole update was about.
Oppo 203
Xbox One S
Denon AVR X6300W
Dolby Atmos 5.2.4
post #30161 of 36750 Unread 06-06-2018, 08:05 AM
Read the FAQ!
Liked: 8256
I don't have a B6 to test, and I've not seen a handshake dump from OPPO for the B6. The handshake dump for the E6 shows it is reporting it can only accept the normal profile. When you set TV-led, the OPPO will send low latency profile despite that -- thus the video corruption.
--Bob
post #30162 of 36750 Unread 06-06-2018, 08:10 AM
Quoted: 189 Post(s)
Liked: 204
--Bob
Ah so even on the Sony a1e if I set to TV led it'll still send as Player led?
Oppo 203
Xbox One S
Denon AVR X6300W
Dolby Atmos 5.2.4
post #30163 of 36750 Unread 06-06-2018, 08:11 AM
bodosom's Avatar
Liked: 1419
This is not correct.
bodosom is offline
post #30164 of 36750 Unread 06-06-2018, 08:12 AM
Quoted: 60 Post(s)
It's extremely random that the Sony x700 can fix the elevated black issues with the 2016 LG oleds but the Oppo using what many assume is the same profile is unable to do the same.
I'm sitting on a unopened unit waiting for a fix from either Oppo or LG, otherwise I may just have to sell it and go with the Sony unit since all I really care about is playing Dolby Vision content properly on my B6
Display: LG OLED 65 B6
Receiver: Denon 4400 / UHD Player: Philips BDP 7501
Speakers: L/R Q Acoustics 3020, C Q Acoustics 3090C, SR/SL Q Acoustics 3010, Atmos Elac A4, Sub HSU VTF2 MK5
andresm1126 is offline
post #30165 of 36750 Unread 06-06-2018, 08:14 AM
bodosom's Avatar
Liked: 1419
Sorry, I posted before I finished typing. Are you saying the ATV4K can't send DV to an E6?
bodosom is offline
post #30166 of 36750 Unread 06-06-2018, 08:16 AM
Read the FAQ!
Liked: 8256
Nope. The ATV4K works just fine sending Dolby Vision to the E6. Go figur....
--Bob
post #30167 of 36750 Unread 06-06-2018, 08:17 AM
Read the FAQ!
Liked: 8256
Huh? That's not what I said, and as far as I know that is not correct.
--Bob
post #30168 of 36750 Unread 06-06-2018, 08:19 AM
weekendtoy's Avatar
Quoted: 540 Post(s)
Liked: 1290
Originally Posted by citsur86 View Post
I found and purchased a 203 today!
Question for the group. Is there any issue with me coming out of my Marantz SR-6011 into the 203 and then from there to the LG B7A in order to allow the Oppo to do all the 4K upscaling and tone mapping for all of my non-4K sources?
I have the SR-6011 and 203 as well. Why wouldn't you just pass the video (and audio) signal through the AVR and then to the TV?
I reject your reality and substitute my own.
weekendtoy is offline
post #30169 of 36750 Unread 06-06-2018, 08:22 AM
Read the FAQ!
Liked: 8256
I have not tried to confirm for myself what the Sony 700 is doing. It seems unlikely they have managed to find a workaround for a bug that LG and Dolby both admit is in the HDMI processing code in the LG panel.
The only thing I can think of is that the Sony is ACTUALLY sending HDR-10 (which doesn't have the problem), but doing so in such a way that it tricks the LG panel into displaying its Dolby Vision icon.
--Bob
galonzo and Madmax67 like this.
post #30170 of 36750 Unread 06-06-2018, 08:23 AM
bodosom's Avatar
Liked: 1419
If both end points support multiple profiles there must be a way to select one. Even if that means manual control.
It hard for me not to see it as bug-like* if the OPPO really sends an incompatible profile when it has a compatible profile or HDR10 if there are no compatible profiles. Unless they want to enable a certain kind of testing.
*Odd behavior like sending RGB to a YUV display is not unheard of.
bodosom is offline
post #30171 of 36750 Unread 06-06-2018, 08:26 AM
Quoted: 60 Post(s)
--Bob
I was actually wondering the same thing.
post #30172 of 36750 Unread 06-06-2018, 08:28 AM
Quoted: 189 Post(s)
Liked: 204
--Bob
Apologies. Treat this as a new question then. I have set my 203 to "TV led" to my A1E. Is the player recognising the A1E and converting to "Player led" even though I don't have that set in the Oppo? The TV should only be able to handle player led since it's a Sony, right?
Oppo 203
Xbox One S
Denon AVR X6300W
Dolby Atmos 5.2.4
post #30173 of 36750 Unread 06-06-2018, 08:30 AM
bodosom's Avatar
Liked: 1419
--Bob
--Bob
These statements appear contradictory.
bodosom is offline
post #30174 of 36750 Unread 06-06-2018, 08:32 AM
Read the FAQ!
Liked: 8256
That's my understanding. I don't have a Sony panel I can test on.
Get in touch with OPPO Tech Support and they can sort this out for you. You can use the Email Us link on their Support page for the player:
https://www.oppodigital.com/blu-ray-...3-Support.aspx
For your Sony, I would expect Dolby Vision Processing Auto and Player-led to work. I would expect TV-led to fail, but OPPO might have handled that specially.
Are you sure TV-led is getting Dolby Vision output to your A1E instead of HDR-10?
--Bob
galonzo likes this.
post #30175 of 36750 Unread 06-06-2018, 08:32 AM
Read the FAQ!
Liked: 8256
Yep!
--Bob
galonzo likes this.
post #30176 of 36750 Unread 06-06-2018, 08:37 AM
Quoted: 189 Post(s)
Liked: 204
--Bob
I'm getting the logo, and the extended info shows DV, but maybe it's HDR10 packaged in it or something. Thanks for the link
Oppo 203
Xbox One S
Denon AVR X6300W
Dolby Atmos 5.2.4
post #30177 of 36750 Unread 06-06-2018, 08:42 AM
boe
boe's Avatar
Quoted: 1207 Post(s)
Liked: 545
THanks - I didn't think it mattered much since OLEDs aren't very bright. I though DV and HDR were calibrated for TVs with up to 4000 nits.
boe is offline
post #30178 of 36750 Unread 06-06-2018, 08:45 AM
bodosom's Avatar
Liked: 1419
Apple did the same thing for the 2017 LG OLEDs so I don't think the profile has anything to do with it. The assertion that it can only be fixed in the display might be better read as it can only be fixed perfectly with some help from the display. For some value of perfectly.
When I saw undecoded DV on my display uneven blacks were obvious in the letter box. Perhaps that content specific noise breaks tone mapping and cleaning that noise resolves the issue. Being able to switch from P7 to P5 might provide some insight for LG x6 owners. Or not. In any case exposing a control makes the OPPO extra useful in some cases.
giomania likes this.
bodosom is offline
post #30179 of 36750 Unread 06-06-2018, 08:52 AM
Bass and Hi-Fi Enthusiast
citsur86's Avatar
Quoted: 1988 Post(s)
Liked: 973
Yeah I realized that if I did what I suggested, I wouldn’t have the audio from the 203 into the AVR! I was trying to have the 203 do my 4K upscaling but what I realized is that I really only need it for my xfinity box. So I’ll run the xfinity box through the 203 and then, like you said, go from the 203 to the AVR and then to the TV.
| 7.2.4 Photos (Updated Photos 1/5) | Frequency Response | Visual: LG 65” B7A OLED | Elite VMAX-2 Electric 120" | Optoma GT1080 Proj |
| AVR/Amps: Marantz SR-6011 9C | Audio Source AMP-100VS | iNuke 1000DSP; TTs: 4x AuraSound Pro |
| Center: B&W CM Center 2 S2 Ed | Fronts: 2x B&W 684 S1s | Side Surrounds: 2x B&W 685 S1 |
| Front/Rear Heights: 4x Polk T15 | In-Ceiling: 2x Micca M-8C | Subs: 2x Rythmik FV15HP |
citsur86 is offline
post #30180 of 36750 Unread 06-06-2018, 08:52 AM
jamisonia's Avatar
Quoted: 48 Post(s)
Liked: 31
Do you think its too late for them to put some other features into the firmware? 2 things I would like that I've emailed them about is the ability to use M3U playlists, and the ability to change the order of Oppo created playlists. If you can believe it you have to add songs to the Oppo playlist in the reverse order of how you want them to be played. Honestly the former is the bigger deal. I'd prefer to make them that way. Another thing would be nice is if I could gapless play from album sort. Right now you can only gapless play by going to through the folder menus. But if I sort by album, go to the album and play it won't be gapless, even though all the songs are in the same folder and play gapless via that way.
galonzo likes this.
jamisonia is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
