Official OPPO UDP-203 Owner's Thread - Page 1011 - AVS Forum | Home Theater Discussions And Reviews
 278838Likes
post #30301 of 36773 Old 06-07-2018, 05:39 AM
Liked: 6
Hi guys,
Would anyone know when the rest of the world will catch up in reference to the beta update? I'm in Australia
Craig Mecak likes this.
AndrewAmes is offline
post #30302 of 36773 Old 06-07-2018, 05:41 AM
StanGeek's Avatar
Quoted: 181 Post(s)
Liked: 67
Originally Posted by jb442386 View Post
Easy Fix! Simply set DV on the 203 to player DV!
Thanks. Unfortunately, this change did not make any difference for me. The same display information is showing for any UHD disc with DV information.
Video - UHD TV: Sony 940E, UHD BD:Panasonic UB900, Samsung K8500, Oppo 203 Apple TV 4K
Audio - Yamaha CX-A5100 PrePro, Outlaw Audio Amps x 3, Polk Rti-A7s x 2, Rti-A5s x 4, 70RTs x 4, SVS PB16 Ultra x2
StanGeek is offline
post #30303 of 36773 Old 06-07-2018, 06:07 AM
Quoted: 380 Post(s)
Liked: 652
Originally Posted by StanGeek View Post
Originally Posted by Bob Pariseau View Post
That’s likely a bug. If you can reproduce it, please email the details to OPPO.
(The bug is likely just in the formatting of that Info display. I.E., the DV is actually working. )
—Bob
I see the same thing on my 940E set. The 203 does trigger the Dolby Vision profile on the Sony TV, but the Oppo info shows SDR for the output.
Does anyone think that this is due to the player doing the processing of DV?
As Bob said, this is almost certainly just a display bug. I see it and I'm quite sure the output is actually DV and not SDR.
Sony XBR-65Z9D
Oppo UDP-203 4K BD Player
Panasonic DMP-UB900 4K BD Player
Denon AVR-X6400H
Larry Little is offline
post #30304 of 36773 Old 06-07-2018, 06:16 AM
StanGeek's Avatar
Quoted: 181 Post(s)
Liked: 67
Yes, I am almost there with you. It would just be great to get the visual confirmation from that extended info page.
galonzo likes this.
StanGeek is offline
post #30305 of 36773 Old 06-07-2018, 06:18 AM
Liked: 8
Same experience here too. TV showed DV profile, Oppo showed DV, but Info button was telling it was SDR.
boostedtv is offline
post #30306 of 36773 Old 06-07-2018, 06:25 AM
Quoted: 235 Post(s)
Liked: 60
Originally Posted by sddawson View Post
That’s very disappointing. Have you tested the new beta by any chance? The ability to use the Oppo tone mapping for Apple TV on a projector reliably would be great.
Yes. Disappointing for sure. I was one of those with the Apple TV sync issue FW that seemed to work but then didn’t. There is something random OR so specific that has to happen for the issue to happen that I went a full week with that test firmware with no stutter issues. Then bam. It hit.
I have installed this newest beta fw and sad to say within 10 min I had the dreaded stutter in Netflix (which is where is usually happens).
tswire is offline
post #30307 of 36773 Old 06-07-2018, 06:31 AM
Quoted: 12 Post(s)
Liked: 3
For those of you who have a Sony TV if you play a DV show or film on the internal Netflix app and than a DV Disc on the Oppo even if the info is BT2020 12Bit the peak brightness that you get with DV on the Oppo is not there but definitely is on Netflix. Something is wrong and I’ve been working with an engineer from Oppo and he stated this to be true and just to be clear this is only with Sony TV users.
StanGeek likes this.
BigBoyZigs is offline
post #30308 of 36773 Old 06-07-2018, 07:01 AM
cmdrdredd's Avatar
Quoted: 4227 Post(s)
Liked: 4521
Originally Posted by jwstegbauer View Post
You are correct that the default for Color Temperature for Dolby Vision on Sony's is Neutral.....Personally on my A1E in prefer the Neutral setting for Dolby Vision over Expert1.....White's do not have the yellow cast that is apparent in Expert1......both are usable and it becomes a matter of which setting is more accurate to what was the original intent of the director.....
The more yellow picture may actually be more accurate as all mastering monitors are calibrated to 6500k white point which is not paper white. It's closer to daylight which has more yellow than blue. Though if you prefer it the other way it's ok. I just like to point out the scientific standards.
Taxcheat, galonzo and Madmax67 like this.
LG 65" B7A OLED, Samsung 55" JS9000, Sony 43" x800e, Denon AVR-X2200w 5.1.2, PS4 Pro, Nintendo Switch, Gaming PC(GTX 1080ti + 4.7Ghz 8700k), Sony UBP-x800, Philips BDP-7501, Oppo BDP-203, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #30309 of 36773 Old 06-07-2018, 07:16 AM
cmdrdredd's Avatar
Liked: 4521
To be 100% clear is this when you set the player to handle the dolby vision data or the TV? There are two options for me and I'm not totally sure if they make a difference or whether the SOny TV only supports Player-led dolby vision or what.
post #30310 of 36773 Old 06-07-2018, 07:22 AM
Quoted: 103 Post(s)
Liked: 69
Can someone help reconcile OPPO stating Gladiatior is running in SDR, while Sony clearly has Dolby Vision enabled? Is that enough to assume the OPPO information is wrong, and the movie is displaying in HDR Dolby Vision?
isarafan is offline
post #30311 of 36773 Old 06-07-2018, 07:24 AM
JohnnytheSkin's Avatar
Quoted: 71 Post(s)
Liked: 48
Regarding the SDR extended info on Dolby Vision for my Sony 940E, after more testing and emails with Oppo support...it seems this is a labelling bug as discussed. Sorry to clutter the forum before fully checking things out more fully.
StanGeek, galonzo and jb442386 like this.
JohnnytheSkin is offline
post #30312 of 36773 Old 06-07-2018, 07:25 AM
Quoted: 12 Post(s)
Liked: 3
Either or the Oppo Engineer stated that SDR showing up is not a report error when DV was tested he stated HDR was present on the info and although the player is passing through the color gammat BT2020 the HDR Meta Data is not present.
isarafan likes this.
post #30313 of 36773 Old 06-07-2018, 07:26 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4545 Post(s)
Liked: 4377
That has been reported many times here already. It seems to be a bug in the Extended Info display with the new DV profile.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #30314 of 36773 Old 06-07-2018, 07:43 AM
bluemoon737's Avatar
Quoted: 2204 Post(s)
Liked: 2705
Pretty sure this is a case by case basis...I have a Z9D and am not seeing this issue.
galonzo likes this.
-Jeff-
Man cave: Sony XBR75Z9D, Marantz SR8012, and OPPO UDP-203
Living room: Sony XBR75X950G, Denon x4500, and Sony UBP-X800M2
bluemoon737 is offline
post #30315 of 36773 Old 06-07-2018, 07:44 AM
lujan's Avatar
Quoted: 4376 Post(s)
Liked: 2453
This bug seems to appear every time there is a beta firmware installed. You would think Oppo would have corrected this? I won't be installing the beta since I don't have the 203 connected to a Sony TV.
lujan
516 Ultra HD
724 HD
4 SD
lujan is offline
post #30316 of 36773 Old 06-07-2018, 07:57 AM
Quoted: 71 Post(s)
Liked: 48
Interesting...that never came up in my back and forth. Good to know they're looking at it. I had reported the output values for both TV-Led and Player-Led and they were identical which led us to think it was just a labeling bug.
galonzo likes this.
post #30317 of 36773 Old 06-07-2018, 08:00 AM
StanGeek's Avatar
Quoted: 181 Post(s)
Liked: 67
Sorry for not understanding this point. I had played several DV titles using the Sony X700 and saw a big difference in the brightness. Now, I played one of the same discs on the 203 and am not sure I see the same brightness. Is this the problem/point you are making? Does the 203 actually not send the correct gamma to the Sony 940E?
galonzo and isarafan like this.
StanGeek is offline
post #30318 of 36773 Old 06-07-2018, 08:13 AM
confinoj's Avatar
Quoted: 1206 Post(s)
Liked: 1012
Originally Posted by tezster View Post
Fairly certain that won't resolve the issue... if you're using a router, check if you're able to assign it as the role of master browser. If the existing firmware doesn't provide that option, you can check if there's a custom/3rd party firmware for your device.
I know I'm delving into Windows networking rather than Oppo issues here but still relevant to getting networking to work on the oppo. I think my Netgear router (R6400) which has readyshare may be able to be used as a master browser. Right now my SMB shares on Windows 10 are via a Homegroup. Do I need to turn this off and use a standard workgroup and give the Netgear Readyshare the same workgroup name as Windows?
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | Tivo Roamio OTA | Nvidia Shield | ATV 4K | Oppo UDP-203 | Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is offline
post #30319 of 36773 Old 06-07-2018, 09:01 AM
R8ders2K's Avatar
Quoted: 159 Post(s)
Liked: 151
Originally Posted by dcbii View Post
I wonder if this is a disc bug. Mine does this too (and I'm not running the beta FW yet), although the scenario is different from yours. My TV only supports HDR-10, not DV. However, setting HDR to "Forced" on the 203 should supposedly allow me to get the HDR instead of DV (or SDR). However, even with that setting, I see the output just like you do above -- SDR rather than HDR on Saving Private Ryan.
I wondering about that myself. As I see the same thing on my mine and I have the new firmware update installed.
Sony XBR-75X940E
Onkyo TX-NR777
DIRECTV HS17 + C61K
Oppo UDP-203
TV 4K
R8ders2K is offline
post #30320 of 36773 Old 06-07-2018, 09:01 AM
guitarguy316's Avatar
Quoted: 2055 Post(s)
Liked: 752
If you are asking about the new HDR setting options in the OPPO, yes, leave them at the default (Auto) values.
(You can experiment with having the OPPO convert content to Dolby Vision output if you'd like.)
--Bob
and with those settings, DV discs will always default to DV instead first of HDR?
guitarguy316 is offline
post #30321 of 36773 Old 06-07-2018, 09:07 AM
TrueDis's Avatar
Quoted: 93 Post(s)
Liked: 49
Originally Posted by wmcclain View Post
LG said it was a problem with their displays, requiring a firmware update not yet available for the older panels.
Now we have reports that the Sony player with the "Sony" DV profile fixes the problem without an update to the display, so I don't know what to think.
Waiting for more test results.
-Bill
Installed the Beta Firmware UDP20X-60-0601B on my UDP-203 last night to test the mother! UHD disc. Prior to the update the black bars around the scenes in the basement at ~12:40 had very prominent gray tones to them, but the update seems to have resolved, or at least mitigated that as far as my naked eye is concerned. There is a new setting for "Player-led" Dolby Vision on the 203, but that seems to cause the image to be totally screwed up on my B6 (weird neon colors, no indication on the TV that it's receiving DV signal). On either the "Auto" or "TV-led" settings, everything appears good. I didn't have much time to test, but I didn't notice any issues with the beta.
galonzo likes this.
LG OLED65B6P
Marantz SR7010 driving 5.1.4
Klipsch RP-280FA Atmos Towers (Front) | RP-250C (Center) | R-115SW (Sub)
Pioneer SP-EFS73 Atmos Towers (Rear)
TrueDis is offline
post #30322 of 36773 Old 06-07-2018, 09:26 AM
Quoted: 189 Post(s)
Liked: 204
I have noticed this too. I wonder if it's not sending the right gamma curve. Scenes seem darker and less glow to lights (thrusters in star wars etc.) I do think it's minor but it's there.
I have an A1E
A1E OLED 4K Ultra HD
Oppo 203
Xbox One S
Denon AVR X6300W
Dolby Atmos 5.2.4
Origin Acoustics Theater 68
Nick Martelli is offline
post #30323 of 36773 Old 06-07-2018, 09:49 AM
R8ders2K's Avatar
Quoted: 159 Post(s)
Liked: 151
I'll stand corrected, but the Player-led is REALLY for us Sony owners.
TrueDis likes this.
Sony XBR-75X940E
Onkyo TX-NR777
DIRECTV HS17 + C61K
Oppo UDP-203
TV 4K
R8ders2K is offline
post #30324 of 36773 Old 06-07-2018, 10:43 AM
jmschnur's Avatar
Quoted: 125 Post(s)
Liked: 61
I ran the diversified video HDR 10 disk with output set for Dolby Vision to my 8805 passed through to my Sony A1e.
The DV symbol came on on the set and the brightness and contrast setting were fairly close. The set is still un Ali rated as I am waited no for D-Nice to make his visit.
My Roku stick does not output as DV when set to the HDMI input viewing using Bosch second season. The Roku stick is not happy attached to the Oppo and needs to be reset each time. After reset it plays ok.
Sony A1E, Marantz 8805, Montis, Bryston,
jmschnur is offline
post #30325 of 36773 Old 06-07-2018, 10:54 AM
StanGeek's Avatar
Quoted: 181 Post(s)
Liked: 67
I have an A1E
Yes. I just put in the Escape Plan disc that I watched in the 203 last night. The scenes are much more realistic with better contrast (esp. for outside, sunny scenes) when I put that disc in the Sony X700 just now. The Oppo 203 is just not sending the right info to the Sony TVs.
galonzo and audiofan1 like this.
StanGeek is offline
post #30326 of 36773 Old 06-07-2018, 10:58 AM
Waboman's Avatar
Quoted: 6874 Post(s)
Liked: 15465
Originally Posted by markmanner View Post
Was it a McIntosh MX122? Mine got updated, and now passes my ATV 4K DV through great, which I needed to get the ATV 4K audio into my AVP. To keep this on point for this thread, the MX122 update doesn't pass my Oppo 203 DV signal through apparently. DV not triggered on my TV. However, when I connect the Oppo directly to my TV, the DV works and looks great. On my Oppo I have all the DV related settings set to Auto (didn't seem to matter whether auto or TV led, etc.). So, seems to me the Oppo DV update works well on my Sony A1E (but just not through my AVP). It is odd, I guess this means that the Oppo Sony DV implementation is in some way different than the ATV 4K implementation?
Mark
[edit: if anyone happens to have a setup like mine (Oppo, MX122, Sony A1E), let me know what you experience if you run the main Oppo hdmi into your AVP]
Similar. I have the Marantz AV8805. It's always passed DV from my ATV. Not sure what the new update covers. I haven't done the Oppo beta update yet.
galonzo likes this.
Waboman is offline
post #30327 of 36773 Old 06-07-2018, 11:01 AM
Quoted: 57 Post(s)
Hi all.
I recently got an OPPO 203. Please does anyone know how I can play BDMV files via usb. Thanks
chuckdy is offline
post #30328 of 36773 Old 06-07-2018, 11:04 AM
MackGuyver's Avatar
Quoted: 265 Post(s)
Liked: 230
Roku sticks and set top boxes don't support DV (only their TVs do), and the Oppo HDMI input doesn't support DV, so unless you're looking for the Oppo to convert it to DV, it's not going to work.
galonzo likes this.
Preamp/Amps: Anthem AVM60, Emotiva XPA-2, XPA-5, A-300
Speakers: (7.1.2): Klipsch Reference Premiere / Power Sound Audio S3000i sub
Video: LG OLED65B7A, Oppo UDP-203, Roku Premiere+, Nvidia Shield TV
Room: GIK Acoustics treatments
MackGuyver is offline
post #30329 of 36773 Old 06-07-2018, 11:08 AM
rdgrimes's Avatar
Quoted: 3777 Post(s)
Liked: 2977
Originally Posted by chuckdy View Post
Hi all.
You need to use a little modifier program which is incidentally attached here. It makes the player see the folder structure as "AVCHD".
For UHD disc rips, this is not required.
rdgrimes is offline
post #30330 of 36773 Old 06-07-2018, 11:45 AM
Quoted: 103 Post(s)
Liked: 69
OPPO responded to my inquiry, stating: "We can confirm that it is a labeling error with the output information screen. We’ll have the issue fixed when the public beta is promoted to an official release." So I guess HDR is working as it should!
R8ders2K, galonzo and grtuck like this.
isarafan is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
