Official OPPO UDP-203 Owner's Thread - Page 1012 - AVS Forum | Home Theater Discussions And Reviews
 279956Likes
post #30331 of 38231 Old 06-07-2018, 11:45 AM
bobbino421's Avatar
Quoted: 1355 Post(s)
Liked: 874
I don’t have a DV capable TV yet but I was wondering how do you get the beta update? I checked last night nothing? Also being that my Sony is just HDR 10 will it affect my viewing of discs? Or should I just wait till I get a DV TV?
Sony 55 A9F
Panasonic DP-UB820
Sony UBP-X700
Denon X4500H AVR
Klipsch 5.1.4 Dolby Atmos with Martin Logan 1000W SUB
bobbino421 is offline
post #30332 of 38231 Old 06-07-2018, 11:53 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4762 Post(s)
Liked: 4679
Betas cannot installed via network, you need to download a file for USB or burn a disc. The OPPO support page has links and instructions.
It will not affect your viewing of discs.
This is a beta; if you install it you should be prepared to look for anomalies and report them to OPPO.
-Bill
galonzo likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #30333 of 38231 Old 06-07-2018, 12:01 PM
Sound & Vision's Avatar
Quoted: 477 Post(s)
Liked: 288
Originally Posted by isarafan View Post
OPPO responded to my inquiry, stating: "We can confirm that it is a labeling error with the output information screen. We’ll have the issue fixed when the public beta is promoted to an official release." So I guess HDR is working as it should!
Ahhh.... Yet another great reason Oppo releases a beta software... A chance to catch any last minute bugs before the official release.. Oppo will surely be missed... They will be remembered for their Top notch support and great products. 😊
htwaits, JasonQG, galonzo and 3 others like this.
Sound & Vision is offline
post #30334 of 38231 Old 06-07-2018, 12:18 PM
jmschnur's Avatar
Quoted: 128 Post(s)
Liked: 62
Originally Posted by MackGuyver View Post
Roku sticks and set top boxes don't support DV (only their TVs do), and the Oppo HDMI input doesn't support DV, so unless you're looking for the Oppo to convert it to DV, it's not going to work.
I was hoping that the Oppo would convert the the Roku output to Dolby Vision. So far no luck.
Sony A1E, Marantz 8805, Montis, Bryston,
jmschnur is offline
post #30335 of 38231 Old 06-07-2018, 12:26 PM
wxman's Avatar
Quoted: 5743 Post(s)
Liked: 4112
I wrote OPPO about the differences I was observing with floating blacks letterbox bars between the Sony 700 and OPPO 203 on my E6. OPPO says the fix has to come from LG and that the black letterbox bars are not from the player but the tv.
"We are aware of certain issues with the "floating blacks" on LG panels and from what we understand, the fix will have to come from LG with a firmware update. That's very interesting that the letterbox appears different compared with the Sony. From our understanding the black bars aren't from the player, but from the panel itself."
giomania, galonzo and SinGA like this.
wxman is offline
post #30336 of 38231 Old 06-07-2018, 12:29 PM
jwstegbauer's Avatar
Quoted: 133 Post(s)
Liked: 122
Upgrade was simple.... no problems....put in a Dolby Vision UHD Blu-ray.....disc loaded....disc menu appeared....hit play.....Dolby Vision logo appeared on my XBR-65A1E.....didn't have to set anything.....and it works perfectly......
Taxcheat and galonzo like this.
Sony XBR-65A1E OLED | Harman Kardon PA-2200 Amp | Panamax MR4300 | Apple Tv 4K
Sony Receiver STR-ZA3100ES | Sony UBP-X700 | Oppo UDP -203 4K UHD Blu-ray Player
4 - Klipsch RP-250F Floorstanding Speaker | Klipsch RP-240S Surround Speaker (Pair) | Klipsch RP-440C Center Channel Speaker
Klipsch R-112SW Sub | Klipsch RP-140SA Dolby Atmos Speaker (Pair) | Playstation 4 Pro
jwstegbauer is offline
post #30337 of 38231 Old 06-07-2018, 12:34 PM
artur9's Avatar
Quoted: 1014 Post(s)
Liked: 396
Originally Posted by rdgrimes View Post
You need to use a little modifier program which is incidentally attached here. It makes the player see the folder structure as "AVCHD".
What does one do if the folder is hosted on Mac or Linux?
artur9 is offline
post #30338 of 38231 Old 06-07-2018, 12:38 PM
wmcclain's Avatar
Liked: 4679
On Linux you'd use the Wine emulator.
-Bill
wmcclain is offline
post #30339 of 38231 Old 06-07-2018, 12:48 PM
bongobob's Avatar
Quoted: 30 Post(s)
Liked: 25
New firmware on LG C7 shows Oppo output as DV, Color Space DV. LG shows DV as well.
Dark Knight, DV setting to Auto. No floating blacks on my panel.
Cheers!
galonzo likes this.
bongobob is offline
post #30340 of 38231 Old 06-07-2018, 12:55 PM
audiofan1's Avatar
Quoted: 2409 Post(s)
Liked: 3086
Did the update and from what I can tell with my Sony 940e using a gamma of +1 (even +2 didn't hurt) has more brightness and looks great vs that of a value 0f 0 which is what I used with HDR10 using Transformers Dark of the Moon , not sure if it matters but i'm sure once a test disc or someone with the right equipment measures, I'd like to know what the correct values are
jb442386 likes this.
audiofan1 is online now
post #30341 of 38231 Old 06-07-2018, 01:14 PM
jb442386's Avatar
Quoted: 387 Post(s)
Liked: 296
Bill; Do you recommend full reset of the player after the DV update? Thanks!
galonzo likes this.
Sony55A1E|Oppo 203|Sony Z9F Soundbar|ATV4K
jb442386 is offline
post #30342 of 38231 Old 06-07-2018, 01:17 PM
StanGeek's Avatar
Quoted: 181 Post(s)
Liked: 67
So, Oppo support is confirming that the output/picture we get is as good as it gets with their player (on Sony X1 Extreme TVs)? If yes, the little Sony X700 seems to beat the Oppo picture when it comes to DV material.
Video - UHD TV: Sony 940E, UHD BD:Panasonic UB900, Samsung K8500, Oppo 203 Apple TV 4K
Audio - Yamaha CX-A5100 PrePro, Outlaw Audio Amps x 3, Polk Rti-A7s x 2, Rti-A5s x 4, 70RTs x 4, SVS PB16 Ultra x2
StanGeek is offline
post #30343 of 38231 Old 06-07-2018, 01:17 PM
bongobob's Avatar
Quoted: 30 Post(s)
Liked: 25
I always do on any piece of gear. You might to back up your settings first via usb.
The whole process is quick and painless.
bongobob is offline
post #30344 of 38231 Old 06-07-2018, 01:46 PM
Liked: 8
That's disheartening to hear. Are there any comparisons of DV content on the two? For $200 I'd pick one up but I know as soon as I do Oppo will release another update eh.
StanGeek likes this.
boostedtv is offline
post #30345 of 38231 Old 06-07-2018, 01:49 PM
markmanner's Avatar
Quoted: 346 Post(s)
Liked: 295
Originally Posted by markmanner View Post
Was it a McIntosh MX122? Mine got updated, and now passes my ATV 4K DV through great, which I needed to get the ATV 4K audio into my AVP. To keep this on point for this thread, the MX122 update doesn't pass my Oppo 203 DV signal through apparently. DV not triggered on my TV. However, when I connect the Oppo directly to my TV, the DV works and looks great. On my Oppo I have all the DV related settings set to Auto (didn't seem to matter whether auto or TV led, etc.). So, seems to me the Oppo DV update works well on my Sony A1E (but just not through my AVP). It is odd, I guess this means that the Oppo Sony DV implementation is in some way different than the ATV 4K implementation?
Mark
[edit: if anyone happens to have a setup like mine (Oppo, MX122, Sony A1E), let me know what you experience if you run the main Oppo hdmi into your AVP]
Hi, further testing indicates that my AVP will pass DV perfectly from an ATV 4k and from a Sony UBP X700 blu ray player. However, when connecting the OPPO HDMI into the AVP, it will not pass DV. Not only does it show SDR as the output resolution, the TV does not indicate that it is receiving DV (and it doesn't look like DV or HDR either visually). So, it appears that the Oppo Sony DV implementation is still not working through an AVP that otherwise will accept the Sony DV implementation from an ATV 4K and Sony UBP X700. Perhaps the incorrect information display bug that others are noticing is causing my AVP to not pass DV at all, not just show SDR as it is doing with other devices. [Edit, someone on the MX122 forum seems to be getting DV into a Sony ZD9 TV, so it may just be a quirk of the A1E (or some gremlin in my system. I will continue to test).
Mark
System
Spoiler!
markmanner is offline
post #30346 of 38231 Old 06-07-2018, 01:51 PM
wmcclain's Avatar
Liked: 4679
Yes. It is good luck.
-Bill
galonzo likes this.
wmcclain is offline
post #30347 of 38231 Old 06-07-2018, 01:54 PM
wmcclain's Avatar
Liked: 4679
What? Where do they say that in the quote? The conversation was about an error in the Extended Info popup, not anything to do with picture quality.
It is beta firmware that has been out two days; too early for categorical judgements.
-Bill
bongobob, galonzo and bluemoon737 like this.
wmcclain is offline
post #30348 of 38231 Old 06-07-2018, 02:10 PM
Dave-T's Avatar
Quoted: 1225 Post(s)
Liked: 597
Cansomebody please help me out? I read through the last 6 pages of this thread to bring myself up to date. I own a Oppo 203, a Marantz 8802a and a LG E6, should I update my Oppo to the latest Beta? I read somewhere that Bob had commented that there is a Bug with the E6 and the 203 combination, is this correct? Sorry for my ignorance but I am so confused and not sure what to do.
Thanks in advance,
Dave
Dave-T is offline
post #30349 of 38231 Old 06-07-2018, 02:15 PM
Patsfan123's Avatar
Quoted: 552 Post(s)
Liked: 359
I think the bug is that if you force player led processing on a DV disc with a x6 OLED, you get video corruption. If you leave it on default, it's the works the same as a prior FW.
Thanks in advance,
Dave
Sent from my Moto G (5) Plus using Tapatalk
Madmax67 likes this.
LG 65C6P FW: 05.30.85 | Onkyo TX-RZ730 5.1.4 | Oppo UDP-203 | Sony UBP-X700 | Xbox One X | Chromecast Ultra | Apple TV 4K
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501 | Panasonic DMP-BDT110
Patsfan123 is offline
post #30350 of 38231 Old 06-07-2018, 02:17 PM
lujan's Avatar
Quoted: 5042 Post(s)
Liked: 3056
Thanks in advance,
Dave
Cansomebody?
lujan
643 Ultra HD
729 HD
4 SD
lujan is offline
post #30351 of 38231 Old 06-07-2018, 02:21 PM
wmcclain's Avatar
Liked: 4679
Thanks in advance,
Dave
There is no problem. Dolby Vision has worked on the E6 since it was introduced on the OPPO.
You really don't need the beta; it is of interest to those with Sony displays.
-Bill
galonzo likes this.
wmcclain is offline
post #30352 of 38231 Old 06-07-2018, 02:29 PM
Dave-T's Avatar
Liked: 597
-Bill
Thank you for the reply. I was thinking the same but them I saw #6 which probably pertains to me because I buy a lot of the new releases on day one.
dave
Dave-T is offline
post #30353 of 38231 Old 06-07-2018, 02:49 PM
wmcclain's Avatar
Liked: 4679
dave
Sure, that might avoid problems with new releases. If there are such problems the production firmware will be coming along soon.
-Bill
galonzo likes this.
wmcclain is offline
post #30354 of 38231 Old 06-07-2018, 03:11 PM
Madmax67's Avatar
Quoted: 2410 Post(s)
Liked: 2675
And how exactly is the Sony player accessing and changing/improving a closed source end to end DV workflow to improve the picture? The answer is it can't. It has to decode the same metadata the same way just as the TV would have to. It's all layed out in the DV patent and is part of the DV licensing standard for players and TV's. The only major difference between the 2 profiles is the Sony implemented version doesn't contain the backwards compatible enhanced layer and uses the DV iptpqc2/ipt color space instead of the UHD blu ray standard.
https://en.m.wikipedia.org/wiki/ICtCp
giomania, cmdrdredd and galonzo like this.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #30355 of 38231 Old 06-07-2018, 03:30 PM
jb442386's Avatar
Quoted: 387 Post(s)
Liked: 296
-Bill
Thanks Bill for the response! BTW, DV update is working perfectly!
galonzo likes this.
jb442386 is offline
post #30356 of 38231 Old 06-07-2018, 03:32 PM
confinoj's Avatar
Quoted: 1367 Post(s)
Liked: 1241
As an alternative to SMB given Microsoft removing the master browser function needed for Oppo 203 can we set up an nfs server on windows to share bmdv folders?
LG OLED65C7P (Chad B Calibrated) | Denon X4300H | HDHomeRun Quatro | Nvidia Shield Pro 2019 | ATV 4K | Oppo UDP-203 | 40TB Plex server
5.2.4 | Front Klipsch RP-160M x2 | Center Klipsch RP-450C | Surrounds Klipsch RP-150M x2 | Atmos Klipsch RP-140SA x 4 | Subs SVS PC-4000 x 2
confinoj is offline
post #30357 of 38231 Old 06-07-2018, 03:34 PM
wmcclain's Avatar
Liked: 4679
It will work. Setting it up is beyond the scope of this thread.
-Bill
galonzo likes this.
wmcclain is offline
post #30358 of 38231 Old 06-07-2018, 03:43 PM
Crazytrekker's Avatar
Quoted: 118 Post(s)
Liked: 58
Originally Posted by Bob Pariseau View Post
It should. There's a fix in the firmware for the data display, although I don't believe that issue was related to whether Pure Audio mode was used or not.
--Bob
You do mean during CD playback, yes? If so, cool!
Crazytrekker is offline
post #30359 of 38231 Old 06-07-2018, 04:44 PM
nusilver's Avatar
Quoted: 22 Post(s)
For anyone who's curious, got this email from OPPO when inquiring about which DV profile they're using in the player:
"With LG panels, it is recommended for Dolby Vision content to not use Player-led processing as that can cause flickering and display the wrong color profile. The Player-led processing is meant for Sony televisions that requires a different process."
giomania, wxman, StanGeek and 1 others like this.
nusilver is offline
post #30360 of 38231 Old 06-07-2018, 04:59 PM
bluemoon737's Avatar
Quoted: 2204 Post(s)
Liked: 2707
Suspect you can leave it in auto and it will do the "right" thing.
-Jeff-
Man cave: Sony XBR75Z9D, Marantz SR8012, and OPPO UDP-203
Living room: Sony XBR75X950G, Denon x4500, and Sony UBP-X800M2
bluemoon737 is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
