Official OPPO UDP-203 Owner's Thread - Page 1074 - AVS Forum | Home Theater Discussions And Reviews
 278962Likes
post #32191 of 36921 Old 07-27-2018, 11:47 AM
DSperber's Avatar
Quoted: 340 Post(s)
Liked: 276
Originally Posted by studiozut View Post
Thanks everyone for jumping in to help with this. Sounds like I'm all set, I'll try a more flexible set of cables first. I'm going to wall mount a TV (LG 65" C8) and want to make sure the cables don't get kinked (or are visible when using the side ports). Should have asked in the LG thread I guess, but this thread has been so much more helpful
Can't wait to hook up my 203 to an actual 4k TV...
I have my 203 connected to a stand-mounted 55" C7 sitting on an equipment credenza rack, using one of those 8ft ultraslim Monoprice cables going to HDMI2 input (ARC) which is completely invisible from the front of the TV as it is "indented" somewhat on the rear of the set.
There is a plastic cable guide clip on the back of the TV, and I have the cable in the HDMI2 port making a 180 degree U-turn (totally invisible from the front of the TV) and then going through the cable guide and then down to the 203 on the rack below. Similar with the ethernet cable also connected on the back of the set and down through the cable guide to my nearby switch.
I also have a Panny 65VT50 wall-mounted, which will likely some day be replaced by a new OLED. It's about 12 feet away from the AVR (fed by a 103) and I previously had used a very thick 15ft HDMI cable that had to be threaded from the AVR through a wall plate and then through the wall opening behind the TV, and then out an opening and through the cable guide of the large flexible extendable wall mount and then make a right turn and then a U-turn in order to plug into HDMI2 (ARC) of the TV. Very bad idea, and I actually did some minor (and thankfully non-fatal) damage to the HDMI1 input port I was originally using because of stress coming from curving the cable. And because the 15ft cable was really too short I ended up never occasionally extending the TV off the wall and rotating it to face my easy chair, as I'd originally intended. Thankfully, the HDMI2 input port was never damaged. But the TV itself was simply always used "compressed" back against the wall and facing straight ahead, all because I really was using the wrong cable.
I had long planned to someday replace the thick 15ft passive cable with a thinner 20ft Redmere cable, but never got around to it. Just recently I actually took the time to buy a new 20ft super-slim and flexible optical HDMI cable from RUIPRO and perform the cable replacement surgery. Wow! The new super-slim cable was actually now able to run up through the cable guide of the wall mount along with the TV's power cable and an ethernet cable, and now finally also close the metal top cover over the cables in the guide, and velcro-strap it snapped closed securely! Also, the extra 5 feet of super-slim and flexible length is what was needed all along in order to make the U-turn connection into HDMI2 without any stress and also without being visible out the side edge of the TV from the front of the set. And most importantly, I can now actually pull out the 65" TV from the wall to the full extended length of the mount, and then rotate both the mount and the TV on the head at the end of the mount properly so that it correctly faces me in my easy chair about 45 degrees off of perpendicular, as I'd been wanting to do for 6 years.
Plus, the new 20ft super-slim and flexible optical HDMI cable future-proofs me if/when I replace the Panny with a 4K OLED, and require exactly such a cable anyway. Well worth the price to me, for all of these benefits, and no extra right-angle connectors needed.
studiozut likes this.
DSperber is offline
post #32192 of 36921 Old 07-27-2018, 11:49 AM
jb442386's Avatar
Quoted: 383 Post(s)
Liked: 295
Originally Posted by Bob Pariseau View Post
How far did it get when you tried to play it? If the player did not even recognize the disc as a Blu-ray/UHD disc when it tried to load it, and if the same thing happens with your replacement disc, get in touch with OPPO Tech Support as your 203 may need Warranty service.
By the way, for folks interested, I've added a Blog post discussing how to distinguish different types of disc playback failures, and how to Clean The Disc:
Quick Tip: Suffering Individual Disc Playback Freezes? Clean The Disc!
--Bob
The 4K version of the disc Bob simply rendered an “unknown disc” response. Interestingly, the Blu-Ray played just fine. Go figure.
Sony55A1E|Oppo 203|Sony Z9F Soundbar|ATV4K
jb442386 is online now
post #32193 of 36921 Old 07-27-2018, 12:13 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5796 Post(s)
Liked: 8269
If an exchange disc produces the same result, get in touch with OPPO. The player has to do “different stuff” when it is trying to recognize the disc type. Usually a failure like this would indicate a flaw in that copy of the disc. But if it happens on a replacement disc, you should ask OPPO for help.
—Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is online now
post #32194 of 36921 Old 07-27-2018, 01:56 PM
Clark Burk's Avatar
Quoted: 693 Post(s)
Liked: 644
—Bob
Just curious Bob, when a fault like this occurs and if the second copy is unrecognized by the 203 is it usually a drive issue or something else? I know OPPO has been great about fixing issues like this in the past (had a 83 they replaced the drive in 5 years after warranty expired) but was wondering if this out of warranty service is still happening now that the company is closing it’s doors?
How long will they still have replacement drives or units to swap out?
Clark
Clark Burk is offline
post #32195 of 36921 Old 07-27-2018, 02:06 PM
Read the FAQ!
Liked: 8269
^ OPPO is still there for service, and that isn’t going to change anytime soon. They sold new 203 players just recently that have 2 year Warranty (3 if you buy the extender).
—Bob
post #32196 of 36921 Old 07-27-2018, 02:17 PM
Clark Burk's Avatar
Quoted: 693 Post(s)
Liked: 644
—Bob
So they are saving enough replacements to cover themselves for the next 3 years? If so good to hear and totally what I would expect from OPPO.
Clark
post #32197 of 36921 Old 07-27-2018, 02:55 PM
Carbon Ft Print's Avatar
Quoted: 362 Post(s)
Liked: 302
Just lost audio (not video) for 203 HDR and SDR blu ray. That's for both the main and audio hdmi outputs. The audio through the optical link still works (headphones). My 95 plays video/audio fine through the avr. I've had quite a few OPPO players and this has never happened before. Any cockpit suggestion before I try contacting OPPO service? Thx!
Carbon Ft Print is offline
post #32198 of 36921 Old 07-27-2018, 03:09 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4582 Post(s)
Liked: 4419
Have done the standard diagnostics like powering everything down and up and again? Reseating all the cables? Bypassing the receiver and trying a direct connection? Reset Factory Defaults? Reinstall firmware?
-Bill
galonzo and Carbon Ft Print like this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #32199 of 36921 Old 07-27-2018, 03:20 PM
Quoted: 362 Post(s)
Liked: 302
Thx! Tried all suggestions. Audio still does not work. I'll try redownloading the firmware tomorrow and do a power off/on.
EDIT: MUTE was not on the denon 4810ci. Swapped OPPO with 8500. No sound. Looks like a receiver issue, like you said. I have not touched the denon 4810ci for many years, but I do have a pioneer back up receiver.
Maybe it's time for a new denon w. ATMOS. Thx!
pjm877 and pappaduke like this.
post #32200 of 36921 Old 07-27-2018, 03:23 PM
wmcclain's Avatar
Liked: 4419
Also check that you don't have MUTE on, or have VOLUME set to 0.
Failing all that, without knowing anything about it, I would like to blame the receiver.
-Bill
post #32201 of 36921 Old 07-27-2018, 04:51 PM
retro124's Avatar
Quoted: 1427 Post(s)
Liked: 1154
I did today new Oppo update so I'm hoping to finally get DV on 930E Sony TV but still no luck. I don't know if anything else needs to be set up with Oppo or if AVR do not pass it , any ideas?
I already figure all out problem is AVR do not pass it. Not sure what to set up in AVR but if I'm not wrong it shoud pass DV as well.
Denon X6200W
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's
SVS 2x PC12-Pluses, Emotiva XPA-200
Sony XBR65X930E , Oppo 203
Apple 4K TV, Mac mini, Sony UBP-X800, PS3
retro124 is offline
post #32202 of 36921 Old 07-27-2018, 04:59 PM
Read the FAQ!
Liked: 8269
First do a Reset Factory Defaults on the OPPO, then turn it Off and back On again to complete that. Do NOT restore your normal settings yet.
Also turn the TV and AVR off, and disconnect both of them from wall power for a few seconds before turning them back on again. This is to force them to fully reboot and forget whatever they think they know about the HDMI output capabilities of the OPPO.
Next, try connecting Main HDMI out of the OPPO directly to your Sony TV. If that works for Dolby Vision -- still using the default settings in the OPPO -- then try through the AVR again.
--Bob
retro124 likes this.
post #32203 of 36921 Old 07-27-2018, 05:07 PM
kokishin's Avatar
Quoted: 1239 Post(s)
Liked: 1250
Denon 6200 will have a firmware update in August to allow DV to pass thru. Until then, you need to run separate HDMI cables from the 203 HDMI outputs to the TV for video and to the 6200 for audio.
galonzo, stikle and retro124 like this.
Denon AVR-X6200W, Outlaw Audio 7125 Amp, Oppo UDP-203, Oppo BDP-103, Amazon Fire TV Stick, Tivo Roamio Pro, Pioneer Elite Andrew Jones Dolby Atmos Enabled EFS-73 Fronts/EBS-73 Surrounds, Chane A2.4 Center, SVS SB-2000 Sub, Panasonic Plasma TH-58PX600
avsforum Members Atmos & Auro Configuration Spreadsheet
I'm just a caveman. Your modern world frightens and confuses me. RIP Phil Hartman
kokishin is offline
post #32204 of 36921 Old 07-27-2018, 05:08 PM
galonzo's Avatar
Quoted: 1342 Post(s)
Liked: 1723
--Bob
DV passthrough update hasn't come for 2015 Denons yet (only X7200W), supposedly coming before the end of summer
Crazytrekker, stikle and retro124 like this.
Main: UN78HU9000/SEK-3500 | X4200W (Klipsch/HSU 5.1.2) | UDP-203 (fw 65-0131) | TiVo Bolt | Roku P+
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | AppleTV4K | TiVo Mini
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - UHD Digital codes (and some HD codes)
galonzo is offline
post #32205 of 36921 Old 07-27-2018, 05:20 PM
retro124's Avatar
Liked: 1154
--Bob
Thank you Bob, I did all like you said and all works as well except when I plug it back to AVR all switch back to HDR. So I guess Denon still don't pass DV yet or no update for my model yet.
Denon X6200W
retro124 is offline
post #32206 of 36921 Old 07-27-2018, 05:24 PM
retro124's Avatar
Liked: 1154
@kokishin , @galonzo , @Bob Pariseau Thank you guys I got it.
I will make it work temporary and wait for update. It is also why I can't get DV from ATV 4K.
Thanks for help and fast responses.
galonzo likes this.
Denon X6200W
retro124 is offline
post #32207 of 36921 Old 07-28-2018, 09:05 AM
muzz's Avatar
Quoted: 930 Post(s)
Liked: 641
Thankfully that's finally done....
Maybe now they can fix the Tone-Mapping, but Dolby screwed around for so long I'm not confident... unfortunately.
Originally Posted by seggers View Post
Either leave the Oppo on 'auto' and let the HDMI handshake work it out, or set it to 'player led' as that makes the player do the work. The latest Oppo firmware was, mostly, for the Sony DV profile.
Seggers
stevenjw likes this.
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is online now
post #32208 of 36921 Old 07-28-2018, 10:20 AM
Wireless Hd's Avatar
Quoted: 126 Post(s)
Liked: 31
Originally Posted by NorthBayAVphile View Post
In my setup using a Roku Premier+ fed into the HDMI Input of an Oppo 203, via a Rotel RAP-1580 (processor/amp) to a Sony XBR75X940E display, the Roku P+ does output HDR/60.
How do you do this ??? I cant use my ROKU ULTRA in HDR no matter what settings I am telling to the ROKU or the OPPO. Worse, After I use the ROKU ULTRA with the HDMI input of the OPPO, the OPPO
stop sending HDR signal at all ! I made some test with DLNA and SMB and all my titles in HDR10 or Dolby Vision have lost HDR signals...
I have to power off the ROKU ULTRA, restart the OPPO and things are back to normal after that.
So, does the OPPO can send HDR signal through the HDMI input with other machines or it wont work with any devices ?
Wireless Hd is offline
post #32209 of 36921 Old 07-28-2018, 10:27 AM
cmdrdredd's Avatar
Quoted: 4241 Post(s)
Liked: 4534
The hdmi in can transmit hdr10. As to why it does not work for you, I don’t know.
edfowler and galonzo like this.
LG 65" B7A OLED, Samsung 55" JS9000, Sony 43" x800e, Denon AVR-X2200w 5.1.2, PS4 Pro, Nintendo Switch, Gaming PC(GTX 1080ti + 4.7Ghz 8700k), Sony UBP-x800, Philips BDP-7501, Oppo BDP-203, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #32210 of 36921 Old 07-28-2018, 11:34 AM
Quoted: 131 Post(s)
Originally Posted by ncabw View Post
Hi All
I’m a real newbie to all this home theatre stuff and after reading a lot of these post I’m not sure if I’m setup right
Oppo 203
JVC 570r
Not sure if it matters but the projector was calibrated the day after I bought the oppo and from my understanding they didn’t change anything with the player settings.
So here are my output for 4k disk
And same movie but Blue ray disk
For colour spacing I did change to 4:2:2 after I took the pictures. Again since I was calibrated with unchanged settings on the oppo do I leave that as shown in the pictures??
I don’t know if that SDR is right.
I do understand I don’t get DV with my projector
Oh movie was the new blade runner if that matters.
Sorry guys but a quick question and probably a dumb one.
My output says HDR should it ever say HDR10?
Does it go
DV>HDR10>HDR ?
ncabw is online now
post #32211 of 36921 Old 07-28-2018, 11:39 AM
Read the FAQ!
Liked: 8269
Does it go
DV>HDR10>HDR ?
"HDR" in the Info displays means HDR-10.
--Bob
galonzo likes this.
post #32212 of 36921 Old 07-28-2018, 11:55 AM
Quoted: 131 Post(s)
--Bob
Ok so all HDR is HDR-10 then?
ncabw is online now
post #32213 of 36921 Old 07-28-2018, 12:06 PM
cmdrdredd's Avatar
Liked: 4534
Dolby vision is also HDR. It’s different than HDR10 though and it will specifically say Dolby vision.
galonzo likes this.
post #32214 of 36921 Old 07-28-2018, 12:33 PM
Quoted: 587 Post(s)
Liked: 310
Hi Bob.. Let me see if im understanding this.. If i set the Oppo on hdr off and I use the HLG that comes with my JVC projector will the oppo block it from coming through or will I be able to use my HLG that comes with the projector.. In other words I don't want OPPO to do the tone mapping...
I'm asking because Directv has sports in HLG now and I want to run my directv through the oppo..
Thank you
jorgebetancourt is offline
post #32215 of 36921 Old 07-28-2018, 12:51 PM
Read the FAQ!
Liked: 8269
Thank you
The OPPO 205 does not yet support pass through of HLG. It appears to work in some cases, but you can't depend on it. So if you want to use HLG from DirecTV, don't pass the video through the OPPO.
As for future support, OPPO has said they are still looking at it, but no promises yet.
--Bob
galonzo and codyrocco like this.
post #32216 of 36921 Old 07-28-2018, 12:54 PM
Read the FAQ!
Liked: 8269
If you see the three letters "H", "D", and "R" -- reading "HDR" -- in the Info displays then the OPPO is telling you that the HDR-10 flavor of HDR is in use.
The Dolby Vision flavor of HDR will be shown in the Info displays as "Dolby Vision".
--Bob
galonzo likes this.
post #32217 of 36921 Old 07-28-2018, 12:56 PM
Quoted: 131 Post(s)
--Bob
Perfect thanks for the reply
ncabw is online now
post #32218 of 36921 Old 07-28-2018, 12:57 PM
Quoted: 587 Post(s)
Liked: 310
--Bob
Thank you so much.. Works and it does't work sometimes, sound tempting to keep trying but I'll probably end up pissed off..
post #32219 of 36921 Old 07-28-2018, 01:03 PM
Quoted: 587 Post(s)
Liked: 310
--Bob
This is what I get when I run DirecTV and use the HLG on the projector..
Sent from my SM-G930T using Tapatalk
post #32220 of 36921 Old 07-28-2018, 01:42 PM
grey9hound's Avatar
Originally Posted by LKeene View Post
Thanks for that. I've sent an email to NAD. It'll be interesting to hear what they have to say.
Something just occurred to me, though. The problem when I connect the Oppo video directly to the TV and then the Oppo audio to the NAD (both via HDMI) is that the audio is mysteriously corrupted but the Dolby Vision suddenly works. Considering that I'm only running a 2-channel audio setup anyway, can I not connect the Oppo to the NAD using an optical connection and then in the Oppo's "Audio Output Setup -> S/PDIF Output" set it to "192k LPCM" for high-resolution 2-channel output? The NAD is equipped with such a DAC and therefore should be able to accept that signal. That way I'll get the Dolby Vision and (presumably) restore the audio since I'm no longer using the HDMI input on the NAD (I can't imagine something going wrong with the optical input...that should be bulletproof). I seriously doubt I would be able to hear the difference in 2-channel audio quality between optical vs. HDMI, if a difference even exists.
Thoughts?
Have you set your HDMI (Audio only) output to BITSTREAM ?
It needs to be set to bitstream, that way the NAD can decode it .
That should work great into your NAD.
I assume you are using the (Main)HDMI to the TV... Right ?
Also. Depending on your system you could hear a difference between the HDMI vs the Optical.
I would be willing to bet that they will sound a little different .
Now, as to which one you might prefer, you would have to decide that.
grey9hound is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
