Official OPPO UDP-203 Owner's Thread - Page 1105 - AVS Forum | Home Theater Discussions And Reviews
 279354Likes
post #33121 of 37533 Old 09-12-2018, 04:28 AM
wl1
wl1's Avatar
Quoted: 446 Post(s)
Liked: 402
Originally Posted by thecaptain2000 View Post
.... playing CDs is becoming a pain because, at random, during playing a song, the reproduction stops for a few seconds. Did anybody else experience this? any idea how to fix it?
How are your HDMI Outputs on the Oppo configured?
This thread mentions an issue with Sony TV's in standby still triggering HDMI handshakes - which cause momentary losses of sound. Is a Sony TV involved? If so, try unplugging the HDMI on it and see if the problem goes away.
This could also be any other equipment using CEC control too - so start with switching it OFF on all devices.
galonzo likes this.
Ken Kreisel Twin DXD808, Q125 LCR, x4 Q125 TriFX, x4 QFH - for Atmos 7.2.4/Auro 9.2/DTS:X 11.2
Oppo 93 & 203 & Sony VPLHW55ES PJ with Lumagen 2020, 2.35:1 Seymour AT XD screen. Logitech Ultimate One & Hub, SqBox Touch & Philips Hue. Nakamichi AVP1 with Denon X7200WA. With MiniDSP 2x4.
wl1 is offline
post #33122 of 37533 Old 09-12-2018, 04:49 AM
thecaptain2000's Avatar
Wow, this is one of the things that one would be unable to troubleshoot by himself. There is indeed a Sony TV involved (a Z9) albeit indirectly, The OPPO output goes into a Yamaha cx-a5100 and the Sony is connected to the Yamaha rather than to the OPPO itself. Will try to unplug the Sony and see if it improves things.
Craig Mecak likes this.
thecaptain2000 is offline
post #33123 of 37533 Old 09-12-2018, 05:47 AM
Craig Mecak's Avatar
Quoted: 337 Post(s)
Liked: 270
Yes, I'm sure it will.
Sometimes I will just turn my Sony Z9D on, but mute the screen to black (there's a display OFF function), and PRESTO, no audio interruptions!
galonzo and ad5wb like this.
Yamaha RX-A3060 7.1.4 Receiver [+Sony Power Amp for Rear Height] / Sony KD-65Z9D / JVC HD1 DILA Projector / 90" screen / OPPO UDP-203 UHD blu-ray / Apple TV 4K
Ascension Summoner 3-way Front Speakers / Ascension 3-way Centre Speaker / Peachtree D5 Surrounds / Yamaha NS-555 3-Way Rear Speakers / ERA D4 x 4 Height Speakers / Rythmik Audio F15HP Sub
Craig Mecak is offline
post #33124 of 37533 Old 09-12-2018, 07:29 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5838 Post(s)
Liked: 8329
Can somebody give me any clue troubleshooting a problem? I use the 203 for CD / SACD playback and playing movie, mostly UHD blu rays disks. Movie playback works fine but lately playing CDs is becoing a pain because, at random, during playing a song, the reproduction stops for a few seconds. I tried to clean the laser lens but it did not help. Movie playback works regularly which would let me believe it is not a reader problem as I believe the data density is much higher on an UHD blu ray CD. Did anybody else experience this? any idea how to fix it?
Cheers
Do you have a newer Sony TV, and do you have the TV Off while playing these CDs? If so test by leaving the TV On and see if the problem goes away. This is a known issue with these Sonys generating bogus HDMI traffic while “off”. The workaround is to leave the Sony On, and use the button on its remote to black out its screen.
—Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #33125 of 37533 Old 09-12-2018, 09:05 AM
Cibo's Avatar
Quoted: 50 Post(s)
Bob is correct. Most of the 2017 Sony TV's do have that problem. I have been working with Sony for at least 6 months on this with no luck. Further, it's documented that the power usage spikes each time the HDMI ports on the TV's looks for attached devices.
Since you have a Yamaha receiver, check your remote. My Yamaha TSR-7810 remote has a button called "HDMI OUT." That button turns off the HDMI outputs 1 or 2 or 1 and 2 if you have more than one on your unit. By turning off the HDMI outputs, the handshakes will not occur. It saves having to turn on the TV to use power.
Best of luck.
oldsteve and galonzo like this.
Cibo is offline
post #33126 of 37533 Old 09-12-2018, 01:47 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 673 Post(s)
Liked: 422
Originally Posted by giomania View Post
Spoiler!
I just wanted to post an interim update on my situation. I learned my existing 45-foot HDMI cable had an apparent maximum capability of 4K/30, as that was the maximum I could see when testing the various resolutions using the Apple TV 4K. I know the Apple TV 4K has an automatic cable test option, but when I tried using it, I saw some brief flashing, then the screen went blank. I had to power-cycle the Apple TV to get a picture back. I have ordered a 50-foot Ruipro hybrid HDMI cable, and will test it before installing in the conduit. I just didn't see the point in continuing until I know I have a solid cable run that works in excess of 4K/30.
I took the advice to simplify, but there has not yet been conclusive evidence of any particular device at fault. Frankly, it is very frustrating, but I also created a spreadsheet to track my testing, as it was getting too confusing. Once the new cable is installed, I will continue with the testing.
Mark
Update #2
Executive Summary
I thought my matrix switch was defective due to its inability to pass through [email protected] Hz, but it turns out it was just incapable of providing enough power (5 VDC, 50 mA) for my Ruipro 50-foot hybrid fiber cable. I purchased an HDMI voltage inserter at the source end of the Ruipro 50-foot cable, and the Apple TV 4K works fine through the matrix switch, and prompts to "Enable Dolby Vision". This device was simply the easiest to test, because it automatically tests the HDMI video path capabilities when it is restarted.
Background
After Monoprice ignoring my support ticket for two weeks, I called them. They said they switched to a new computer tracking system and were behind on emails. I explained the situation in detail, and they are clearly knowledgeable techhies. They had me perform some troubleshooting, including various EDID settings and connecting only one source and one display. They stated that sources can sometimes cause feedback that prevents the switch from working properly. There was no change in the behavior of the switch, so I called them back and set up the RMA, but they were out of stock until late September.
While waiting, I started thinking about what I could do to try and force EDID, in case the switch was not at fault. I started following along in the HDFury Vertex thread, as that device can force EDID. One of the users there has the same Ruipro 50-foot hybrid fiber HDMI cable, and a Vertex, and he posted about issues he was having. One of the troubleshooting steps recommended by Vertex support was to use an HDMI voltage inserter, because he said those types of cables have a chip inside that usually requires external power, but the manufacturers don't provide those to keep costs down.
I looked them up, and they were $10, comes only with the cable, no power supply, so I figured that is cheap enough to try it out. It came yesterday, and I used one of my extra Amazon Fire HD tablet power supplies (5 VDC, 1.0A), and boom, it worked right away with the Apple TV 4K. I still need to finish testing with OPPO UDP-203 and the Nvidia Shield, but at least I know the switch works and those sources may just require more settings, EDID tweaks, or yes...cable changes. Note that I had set the switch back to the default EDID (passthrough video and audio) during the final testing, so I just might need to play around to coax the other sources to send 4K through the switch.
Mark
Lumagen Radiance Pro HDR Tone Mapping Guide: Click Here
Lumagen Radiance Pro Setup & Calibration Tips: Click Here
UHD-BD Backup & Playback Guidance Link
giomania is offline
post #33127 of 37533 Old 09-12-2018, 11:05 PM
ray0414's Avatar
Quoted: 12752 Post(s)
Liked: 12071
for anyone interested, looks like oppo will be bringing HDR10+ support if possible.
G-Rex, tbass2k, meli and 13 others like this.
82Q90R*75Q9FN(RIP)*55C8OLED*Galaxy Note10+*Ub820 fed into Oppo 203*XB1X*4k DenonX4200
MASTER LIST OF HDR CONTENT THREAD HERE, UPDATED OFTEN
ray0414 is online now
post #33128 of 37533 Old 09-12-2018, 11:44 PM
Bytehoven's Avatar
Quoted: 1502 Post(s)
Liked: 1173
FlatpanelsHD
https://twitter.com/Flatpanels?s=17
JVC DLA-X990 - 128" 2.35 1.3 Gain Screen - X800M2 - UB820 - ATV4K64 - ROKU Ultra - PS4 - XBone
7.1.4 Atmos - Denon X4300H + Denon 3806(LCR) - JBL Control 5 - BIC Sub - Dayton
Bytehoven is offline
post #33129 of 37533 Old 09-13-2018, 12:41 AM
wesslan1's Avatar
Quoted: 105 Post(s)
Liked: 42
Interesting to implement new features now when customers can't buy one. And they usually never talk about it....
Say you just bought a HDR10+ tv and never had Oppo in your sight before.
Wish they focus on perfect media playback instead over network, SMB, DNLA and such now that disc playback is pretty much perfect. I once in a while get that the Oppo freezes when playing files over SMB. Need to hard reboot the whole thing.
There is also that subtitles dimming function we long for that panasonic have. Can't be harder than HDR10+ to implement.
wesslan1 is offline
post #33130 of 37533 Old 09-13-2018, 12:46 AM
Coyote Waits
htwaits's Avatar
Quoted: 1333 Post(s)
Liked: 2364
The part I like is the reference to "the next few firmware updates."
My Components:
Denon X3400H, OPPO UDP-203 & BDP-93, Xfinity XG1-P, Vizio PQ, Roku 3 & Ultra 2018
Calibration Resources:
Customer's Reports -- Professional Calibrations
Calibrator's locations and tour areas.
htwaits is offline
post #33131 of 37533 Old 09-13-2018, 02:07 AM
woofer's Avatar
Quoted: 1490 Post(s)
Liked: 2330
OPPO.........Tone MAPPING....... FIX..........PLEEEEEASE!
woofer is offline
post #33132 of 37533 Old 09-13-2018, 05:50 AM
hernanu's Avatar
Quoted: 1321 Post(s)
Liked: 2178
I think we all have our favorites to be implemented. One of the most impressive things I saw was after having bought an 83 in the wayback time, they kept implementing new features (DVD-A, DLNA, etc... ) and keeping it current long after I had bought it. Without charging extra.
Now that they've stopped selling the players, to plan ANY new features never mind very complex ones is amazing. Most companies would have run out of Dodge.
Anyways, my next desired feature is DV through the HDMI input. There... I said it.
bguzman, galonzo, Greg TB and 3 others like this.
hernanu is offline
post #33133 of 37533 Old 09-13-2018, 06:52 AM
hlindstr's Avatar
Quoted: 69 Post(s)
Liked: 96
I guess we will see multiple FW updates this and next year before they cease the 20x support for good. I have a feeling they will fix the tone mapping eventually. People must be going crazy when we some day see the "final" FW with all fixes and they also close the BDMW folder playback etc. loopholes .
Oppo UDP-203 and Oppo BDP-83 both hw region modded, M9702 v3 "Chinoppo" (65-0131), Apple TV 4K 32GB, LG OLED55E6V 55", Asustor 2-Bay NAS currently 8TB
hlindstr is offline
post #33134 of 37533 Old 09-13-2018, 09:06 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1957 Post(s)
Liked: 2370
Keep in mind that some features and bug fixes are fully within Oppo's control, while others require partners (most often MediaTek) to take action before Oppo can implement their piece. It's quite likely that fixing tone mapping requires some involvement from MediaTek and that could easily be what is delaying a fix. While waiting for them, it's perfectly reasonable to get other stuff done. Hopefully Oppo will be able to make most of us happy in the end. DV support on the HDMI input may not be possible - IIRC, they haven't said absolutely not, but have said that it doesn't seem likely.
galonzo and Spidacat like this.
gsr is offline
post #33135 of 37533 Old 09-13-2018, 09:40 AM
Quoted: 23 Post(s)
Liked: 8
Originally Posted by Jameshtx View Post
Thanks for this info. I've taken Bytehoven advice and mirrored the settings on the Oppo. However I can't on the projector b/c I've got the Epson 5040. Can anyone with the Oppo 203/Epson 5040 PJ share your 5040 image setup? Thx
Just sent you a PM!
HTD Versa HTSI LRC, HTD HD-W80 S/R surrounds, HTD HD-R80 x4 Heights, SVS PB-2000 sub x2, Pioneer Elite SC-97 in 7.1.4, Emotiva A-300, Oppo 203, Sony BDP-S6500, VAPEX 120" fixed, Epson 5040UB, Harmony Elite, Phillips Hue, HT Design Somerset Seating
Drmdvl is offline
post #33136 of 37533 Old 09-13-2018, 11:10 AM
Jameshtx's Avatar
Quoted: 202 Post(s)
Originally Posted by Drmdvl View Post
Just sent you a PM!
Thx n much appreciated
7.2.4 l Epson 5040ub Projector l Oppo 203 Blu Ray player l Denon AVR-X4300h l Def Tec BP9080 LR/Front Atmos l Def Tec CS9080 C l Def Tec SR9080 SL/SR/SBL/SBR l Monoprice 6.5 Rear Atmos l SVS PB-2000 dual setup l Panamax M5400
Jameshtx is offline
post #33137 of 37533 Old 09-13-2018, 11:38 AM
Iamjcl's Avatar
Quoted: 501 Post(s)
Liked: 106
Encouraging to hear FW updates may materialize.
So with the 203 in high demand on the resale market, what are everyone's main reasons for hanging onto them?
So far I feel like the DVD / 480i (esp. non film based material) playback, from disc or file, is about as good as it gets with the 203. I've got quite a few DVD concert rips in this format.
I don't see much difference - if any - with 1080 or 4K playback of MKVs however (-vs- a Shield, for example).
The fact that it will play Dolby Atmos / Tru HD via MKV / network is a huge plus also - though the Shield will do that also, but not many (any?) other BR players.
The HDMI input is nice, but not sure it does a lot for me until the tone mapping is rectified through a FW fix.
The android app is nice, as you can navigate network shares etc... and change video settings w/out interrupting playback in many cases.
Just curious what others' reasons are for not turning loose of their 203.
Iamjcl is offline
post #33138 of 37533 Old 09-13-2018, 11:41 AM
Matt2026's Avatar
Quoted: 915 Post(s)
Liked: 26460
I'm not dead yet
Iamjcl, giomania, htwaits and 16 others like this.
Regards, Ken (Retired)
7.1.2) Denon 4520CI; Aircom T-8, Samsung 55H8000; OPPO 203; 6x SVS Ultra BS,
Ultra Center; FH 2xPolk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nak RE-1, CR7A, BD F7500, Denon 300F/Ortofon 2M Bronze;
Matt2026 is online now
post #33139 of 37533 Old 09-13-2018, 11:42 AM
hernanu's Avatar
Liked: 2178
Say it ain't so, gsr !!!
hernanu is offline
post #33140 of 37533 Old 09-13-2018, 01:03 PM
Ishniknork's Avatar
Quoted: 67 Post(s)
Liked: 71
For me it's because there isn't another player that can play just about everything like the 203 can. I want my TrueHD off MKV files to play. The Sony X800 I have won't do it and I'm not sure if any newer players are going to support it either.
I'm not into streaming much either so the 203 fits the bill perfectly.
galonzo likes this.
Ishniknork is offline
post #33141 of 37533 Old 09-13-2018, 01:28 PM
Iamjcl's Avatar
Quoted: 501 Post(s)
Liked: 106
I agree - playing MKVs properly over network is very nice, as is SACD / DVD-A playback (which the x800 i also have will do though, and it was fairly inexpensive).
As mentioned though, my Shield will also do MKVs, but my older concert DVDs aren't de-interlaced with the precision that the Oppo delivers. That is the major thing to me the 203 can do that nothing else seems to be able to match. The Apple TV 4K is really quite bad at this - worse than the Shield, which is not too bad if you don't compare it right away to the Oppo...
SACDs and DVD-As can also be ripped, possibly eliminating the need for an optical drive (I've done my DVD-As, but you need an older Oppo to do the SACDs, or there are people online who will rip them for you), but I'm not sure the Shield can play those files properly - may still need the Oppo to play those audio files over the net. I'll need to check this on Shield...
Iamjcl is offline
post #33142 of 37533 Old 09-13-2018, 02:32 PM
golden78's Avatar
Quoted: 409 Post(s)
Liked: 135
I asked tech support some questions about tone mapping and hdr and color space issues and their response was only about hdr to sdr conversion but he said they basically used alot resources trying to make improvements but engineers couldn't "achieve their goal"
golden78 is offline
post #33143 of 37533 Old 09-13-2018, 04:33 PM
rmilewsk's Avatar
Quoted: 132 Post(s)
3D streaming via HDMI input
Does anyone know if the 203 supports 3D streaming via the HDMI input?
rmilewsk is offline
post #33144 of 37533 Old 09-13-2018, 04:38 PM
Jameshtx's Avatar
Quoted: 202 Post(s)
Just curious what is MKV files?
Jameshtx is offline
post #33145 of 37533 Old 09-13-2018, 04:46 PM
SeeMoreDigital's Avatar
Quoted: 1032 Post(s)
Liked: 814
The term "MKV" refers to the container format type that audio and video streams are placed within.
Other popular containers are: mp4, mov, avi, mpg and m2ts. But there are many more containers. Each one having their limitations and their strengths
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 1No Audiolab 6000A, 3No Audiolab M-PWR | SPEAKERS: 2No KEF 103.2, 6No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: Synology DS212+
SeeMoreDigital is offline
post #33146 of 37533 Old 09-13-2018, 04:46 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4673 Post(s)
Liked: 4548
https://en.wikipedia.org/wiki/Matroska
-Bill
galonzo likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #33147 of 37533 Old 09-13-2018, 04:51 PM
vld
vld's Avatar
Quoted: 114 Post(s)
Liked: 87
Point me to something that does more or does better than the 203, (besides the 205), and I may sell mine.
RockinRay and rightintel like this.
vld is offline
post #33148 of 37533 Old 09-13-2018, 05:19 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6062
Yep. I have a shield, appletv 4k and Roku, as well as the 205 now. For wifi streaming MKV and playing BDMV from a drive, it is the best overall for a videophile type, plus it spins discs. I use my 820 right now for streaming.
XBR65A9G / XBR65A8F / 55R615
ATV4K / Uverse / Sony X800M2
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is offline
post #33149 of 37533 Old 09-13-2018, 05:20 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 673 Post(s)
Liked: 422
Wouldn’t that require them to pay the license fee to Dolby?
Sent from my iPhone using Tapatalk Pro
giomania is offline
post #33150 of 37533 Old 09-13-2018, 07:13 PM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 2370
The reason for no DV support on the HDMI input haven't been shared, AFAIK. So no idea if it's a licensing fee issue, hardware limitation, chipset vendor issue, or something else. But Oppo never promised the HDMI input would ever support DV. If it gets added at some point, then great - consider it a nice bonus if it happens.
giomania, Tom C and hernanu like this.
gsr is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
