Official OPPO UDP-203 Owner's Thread - Page 1111 - AVS Forum | Home Theater Discussions And Reviews
 279069Likes
post #33301 of 37079 Old 09-22-2018, 08:10 AM
Airsculpture's Avatar
Location: English but in Fredericton, New Brunswick, Canada
Quoted: 500 Post(s)
Liked: 617
Currently have output resolution set to custom. What difference does setting this to custom rather than auto, I can’t see what other setting custom determines?
Sony XBR65X900E, Oppo UDP-203 Universal Player
Front L&R - Polk TSx550t, Centre - Polk CSiA6 all in Cherry
Surrounds & Rears - Mission 77DS & Mission 780s
Subwoofer - Polk PSW125 in Cherry
Receiver - Marantz SR6012
Airsculpture is offline
post #33302 of 37079 Old 09-22-2018, 08:19 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4610 Post(s)
Liked: 4445
Output Resolution = Custom enables Custom Resolution.
The results may be the same, depending on what you have for Custom Resolution, and how the display responds to Auto. You can use the Extended Info popup to compare; scroll down to the HDMI Output section.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #33303 of 37079 Old 09-22-2018, 08:27 AM
Quoted: 500 Post(s)
Liked: 617
Thanks Bill
post #33304 of 37079 Old 09-22-2018, 04:23 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 625 Post(s)
Liked: 382
Originally Posted by bobknavs View Post
UHD BDs are supposed to be 4:2:0 natively. I believe that includes SDR, HDR10, and DV (12 bit).
A repeat of HDMI data rates:
Originally Posted by cmdrdredd View Post
Dolby vision is 12 but 4:2:2 isn’t it?
Beats me.
I see that 12 bit 4:2:2 would be supported by HDMI 2 at both 24 and 60 fps. (The latter would be about the same as 4:4:4, 8 bit, 60 fps.)
I have captured some notes from my travels around AVS that explain this:
Dolby Vision RGB Tunneling
The method Dolby Vision (DV) uses to transport the signal over HDMI is referred to as “RGB Tunneling”. The 12-bit ICtCp DV signal + Metadata is encapsulated inside the regular RGB 8-bit video signal. The DV “tunneling” carries 12-bit YCbCr 4:2:2 data in an RGB 4:4:4 8-bit transport. This is possible because both signal formats have the same 8.9 Gbps data rate requirements.
https://www.dolby.com/us/en/technolo...hite-paper.pdf
DV requires dynamic luminance data which cannot be explicitly carried in an HDMI 2.0 (18 Gbps max) data stream, so it is designed to transport over HDMI 1.4 (8.9 Gbps max); at least up to [email protected] DV base content and DV luminance (meta) data is encapsulated in an HDMI 1.4 compatible (except HDCP 2.2) RGB 4:4:4 8-bit video stream. That's why Dolby claims that DV can be sent via HDMI v 1.4, but in reality, HDMI v2.0 is needed due to the HDCP v2.2 encryption.
The DV metadata is encoded into the least significant bits of the chroma channels. Upon the HDMI EDID exchange (handshake), the sink (AVR, Display, or HDMI switch) signals the source that it supports Dolby Vision "tunneling". The source then signals the sink that it's transmitting Dolby Vision through an AVI Infoframe, which therefore triggers the Dolby Vision mode in the sink. The display DV engine extracts the components and produces a tone mapped image.
As a result, video pass-through components must be DV 'aware' to not alter the signal, which is in effect 'hidden' inside the 8 bit RGB 'container'.
AVR’s may report DV signals in one of two ways, but both are correct:
Resolution: 4k:24Hz ->4k:24Hz
HDR: Dolby Vision
Color Space: RGB 4:4:4 -> RGB 4:4:4 -OR- YCbCr 4:2:2 -> YCbCr 4:2:2
Color Depth: 8 bits -> 8 bits -OR- 12 bits -> 12 bits
giomania is offline
post #33305 of 37079 Old 09-22-2018, 04:49 PM
cmdrdredd's Avatar
Quoted: 4253 Post(s)
Liked: 4545
According to my reading Dolby vision from PC games can be done over hdmi 1.4 because there is no hdcp there.
giomania and galonzo like this.
LG 65" B7A OLED, Samsung 55" JS9000, Sony 43" x800e, Denon AVR-X2200w 5.1.2, PS4 Pro, Nintendo Switch, Gaming PC(GTX 1080ti + 4.7Ghz 8700k), Sony UBP-x800, Philips BDP-7501, Oppo BDP-203, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #33306 of 37079 Old 09-23-2018, 09:09 AM
veggav's Avatar
Quoted: 29 Post(s)
How you guys show that OSD on the left top corner with the output settings showing bitdepth, Hz, resolution, etc?
veggav is offline
post #33307 of 37079 Old 09-23-2018, 09:14 AM
Postmoderndesign's Avatar
Quoted: 495 Post(s)
Liked: 288
Hold down the i key on the Oppo remote then release and scroll
galonzo likes this.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Display: LG OLED 65e6p, Player: OPPO UDP-203, AVR:Yamaha TSR 7810, Streaming: Comcast 60Mbps RG6 to Cat6a, Speakers: Mains Vandersteen IIC, Center, Surrounds, Rears Klipsch
Postmoderndesign is offline
post #33308 of 37079 Old 09-24-2018, 12:55 AM
VoodooDoctor's Avatar
Anyone using their Oppo 203 in a AV rack? The official rack mount is double the price in the UK to the US and I was wondering whether it is OK just to have it on a well ventilated shelf rather than with the official kit.
VoodooDoctor is offline
post #33309 of 37079 Old 09-24-2018, 04:26 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 625 Post(s)
Liked: 382
I have mine on a rack shelf. I prefer having HDMI devices on shelves, as it provides a place to support (provide strain relief for) HDMI cables.
Sent from my iPhone using Tapatalk Pro
giomania is offline
post #33310 of 37079 Old 09-24-2018, 06:35 AM
artur9's Avatar
Quoted: 1002 Post(s)
Liked: 390
Any way to add an NFS mount as a favorite?
studiozut likes this.
artur9 is offline
post #33311 of 37079 Old 09-24-2018, 08:08 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1914 Post(s)
Liked: 2301
Yes, that's definitely OK.
I prefer to use lacing bars mounted to the rear of the rack for that, bu anything that allows for appropriate ventilation should be fine.
Unfortunately no. When I first started testing the player, that was one of the first things I asked for, but it has never been added.
gsr is offline
post #33312 of 37079 Old 09-24-2018, 09:31 AM
artur9's Avatar
Liked: 390
Any mechanism to get an NFS server to show up quicker and more reliably?
artur9 is offline
post #33313 of 37079 Old 09-24-2018, 10:53 AM
dcbii's Avatar
Quoted: 203 Post(s)
Liked: 124
Oppo 203 conversion of DV to HDR-10
Hello, I don't think I've seen much about this in this thread (I've been on it since the 203 was released), and I didn't immediately see anything doing a thread search. I have an LG55EF9500 OLED which supports HDR-10 but not DV. Discs in HDR-10 look great on my set, which was "calibrated" by me using HDR test patterns. (I'm not trying to compare to a real calibration, but I don't generally like using the TV defaults or presets). My receiver is a Denon 4200, which supports HDR passthrough, but not DV passthrough (yet, although an update is supposedly coming).
However, when I put in a DV disc, the DV to HDR-10 conversion looks terrible (very obvious heavy red cast, oversaturated) with the same settings. If I set the Oppo so for DV discs, it outputs SDR, then the picture is way too dark. I can use one of the TV presets (like "Cinema") with these discs, and that looks pretty good, though not as good as native HDR-10 material. Still, I like it better than putting in the Blu-ray instead. This problem is super obvious with the recent 4K Jack Ryan disc set.
Is this common, and should I be trying to adjust/calibrate one of my other user settings for DV-converted HDR-10, or is this another question that relates to the "tone mapping" people want for use with projectors? Is anyone else out there watching DV discs with an older HDR-only TV set?
Dave Barnhart
Oppo UDP-203, Oppo BDP-83, Denon X4200W, Denon X8500H, LG 55EF9500, NVidia Shield TV, Apple TV 4K, Roku Ultra, RSL speakers, all Monoprice Premium Certified HDMI cables
dcbii is offline
post #33314 of 37079 Old 09-24-2018, 11:06 AM
rdgrimes's Avatar
Quoted: 3826 Post(s)
Liked: 3052
There is no "conversion" taking place in the player. DolbyVision is based on metadata that's added to the HDR10 data. Its magic sprinkles. If the display does not support DV then the magic sprinkles are stripped off. This is all required for compatibility.
If you have issues with the HDR10 signal, look at your display calibration for HDR10. There are several decent places to get calibration images for HDR10.
gwsat and galonzo like this.
rdgrimes is offline
post #33315 of 37079 Old 09-24-2018, 11:15 AM
Sailor08's Avatar
Quoted: 17 Post(s)
There should not be a DV to HDR10 conversion unless you try to force it. And by that i mean force DV on everything. I have a Sony X900E which does not have DV capability. When I play discs with DV on my Oppo 203, the player uses the HDR10 data which is mandatory on all UHD discs and that's it. Check your player settings to see if you put Dolby Vision output for everything. If you put everything on Auto, you will get HDR10.
galonzo likes this.
Sailor08 is offline
post #33316 of 37079 Old 09-24-2018, 11:16 AM
dcbii's Avatar
Quoted: 203 Post(s)
Liked: 124
That's interesting, but then that doesn't explain why HDR-10 native discs look so good.
Dave Barnhart
dcbii is offline
post #33317 of 37079 Old 09-24-2018, 11:18 AM
dcbii's Avatar
Quoted: 203 Post(s)
Liked: 124
Obviously I can't force DV to on, since I can't play DV on my TV. If I set HDR to "Forced" instead of "Auto," does that do anything different from just stripping the DV "sprinkles?"
Dave Barnhart
dcbii is offline
post #33318 of 37079 Old 09-24-2018, 11:19 AM
rdgrimes's Avatar
Liked: 3052
There's no accounting for choices made by authoring engineers. But the player isn't causing what you see.
rdgrimes is offline
post #33319 of 37079 Old 09-24-2018, 11:28 AM
Sailor08's Avatar
Quoted: 17 Post(s)
Have you checked the extended info screen on the Oppo when you play one of those DV discs? If you have not, try it. It will tell you what the player is getting from the disc and what it is sending to the TV. Might give you some insight.
Sailor08 is offline
post #33320 of 37079 Old 09-24-2018, 11:30 AM
dcbii's Avatar
Quoted: 203 Post(s)
Liked: 124
Thanks for the suggestion. Yes, I used that feature after I saw the horrible color. Input is DV, output is HDR. If I set the 203 to output SDR instead, then it shows that in the info screen under the output section.
Dave Barnhart
dcbii is offline
post #33321 of 37079 Old 09-24-2018, 11:35 AM
dcbii's Avatar
Quoted: 203 Post(s)
Liked: 124
So what you are saying is that whatever HDR authoring the disc has underneath the DV sprinkles could be something my LG TV doesn't really like and isn't able to display well, correct? That's why I was asking if anyone else is watching DV discs (or maybe specifically the Jack Ryan discs) on an HDR-but-no-DV television. Maybe this is an LG-only thing. As I said earlier, my adjustments for HDR look pretty good on HDR-10 discs. Planet Earth II and Blue Planet II look stunning, so I don't think my HDR "calibration" is that far off.
Dave Barnhart
dcbii is offline
post #33322 of 37079 Old 09-24-2018, 01:15 PM
Sailor08's Avatar
Quoted: 17 Post(s)
And that is super weird. I just put Atomic Blonde on my Oppo. This disc has DV but the extended info screen tells me the player is pulling HDR (input) from the disc and output is also HDR. So it might be a peculiarity of those particular discs you have. the Oppo should not be pulling the DV data from the disc if the target is not DV-capable.
These days it seems like you have to go to the UN General Assembly and get a treaty so all your HDMI devices work as they should..a simple good handshake...
galonzo and CrazyEddie like this.
Sailor08 is offline
post #33323 of 37079 Old 09-24-2018, 01:47 PM
Bytehoven's Avatar
Quoted: 1284 Post(s)
Liked: 1007
They make rack mount steel shelves. Some designed for tilting rack face and also for vertical rack face.
JVC X990 - 128" 2.35 1.3 Gain Screen (Flexi-White) - ub820 - ROKU Ultra - PS4 - Xbone
7.1.4 Atmos - Denon X4300H + AVR-3806(LCR) - JBL Control 5 - Dayton - BIC Sub
Bytehoven is offline
post #33324 of 37079 Old 09-24-2018, 02:07 PM
dcbii's Avatar
Quoted: 203 Post(s)
Liked: 124
I'll re-examine the extended info screen. Maybe I need to read it more carefully. I know it reported DV, but I will look at the heading for each section again.
galonzo likes this.
Dave Barnhart
dcbii is offline
post #33325 of 37079 Old 09-25-2018, 12:31 AM
Liked: 5
Does anyone have issues with streaming large mkv files over the network, i saw a review on YouTube that said it struggles with large mkv files.
Loading times are slow and the video sometimes freezes, is this the case if it is played directly via the USB.
Still trying to decide between the oppo and the cambridge.
Lazzar is offline
post #33326 of 37079 Old 09-25-2018, 12:48 AM
codyrocco's Avatar
Quoted: 80 Post(s)
Liked: 35
well, a gigabit network is required for big files/ big bitrates; for example, i hadn't any problems playing a 80GB MKV UHD rip from a NAS, with all-gigabit connections (well, no gigabit on TV and AVR, but doesn't matter here)
codyrocco is offline
post #33327 of 37079 Old 09-25-2018, 01:11 AM
Liked: 5
Exclamation
thanks, i have just checked and my network is a gigabit network so i should be good to go. just need to decide between oppo and cambridge now
Lazzar is offline
post #33328 of 37079 Old 09-25-2018, 01:18 AM
SeeMoreDigital's Avatar
Quoted: 992 Post(s)
Liked: 757
What is considered 'large'? And is the review referring to file size or bit-rate size?
Either-way, when streaming high bit-rate (BRD and UHD) files over a home network a stable 'hard-wired' ethernet set-up is vital...
galonzo likes this.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 2No Audiolab 8000A, 2No Audiolab M-PWR | SPEAKERS: 4No KEF 103.2, 3No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: DS212+
SeeMoreDigital is offline
post #33329 of 37079 Old 09-25-2018, 01:23 AM
codyrocco's Avatar
Quoted: 80 Post(s)
Liked: 35
same chipset, but some says that cambridge has a better sound, because of digital-only transport (i'd like to know, from a fellow engineer, if a DAC operation can insert noise into a separate digital stream), but oppo has a better video ( https://www.stereophile.com/content/...ambridge-cxuhd , https://www.avforums.com/review/camb...r-review.14103 ). i don't know what to say, it feels like it's about those >1000$ hdmi cables with silver ions
again, probably here already did a comparison.
post #33330 of 37079 Old 09-25-2018, 01:48 AM
Liked: 5
I only have one file at the moment and it is 2160p.BluRay.x265.10bit.HDR.DTS-HD.MA.TrueHD.7.1.Atmos 20gb
Will the oppo play a x265 file ? or should they be X264 or H264.
Lazzar is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
