Official OPPO UDP-203 Owner's Thread - Page 1112 - AVS Forum | Home Theater Discussions And Reviews
 279158Likes
post #33331 of 37235 Old 09-25-2018, 03:03 AM
codyrocco's Avatar
Quoted: 80 Post(s)
Liked: 35
Originally Posted by Lazzar View Post
I only have one file at the moment and it is 2160p.BluRay.x265.10bit.HDR.DTS-HD.MA.TrueHD.7.1.Atmos 20gb
Will the oppo play a x265 file ? or should they be X264 or H264.
you'll find rarely a UHD video in H264 compression (X264 is the software used to compress); H265 is used for this kind of files, and oppo will happily play them
actually, you'll rarely find files unplayable by oppo, most of them being encoded with very old/rare codecs; these files could be played from a PC, anyway.
an exception here is AV1 codec (but it's in its infancy) - maybe on 4-5 years you'll need a dedicated player for this kind of codec.
galonzo likes this.
codyrocco is offline
post #33332 of 37235 Old 09-25-2018, 03:10 AM
Liked: 5
Cheers, i pulled the plug and decided to go the Oppo. Should get it by the end of the week, looking forward to setting it up and see how it performs.
Thanks for your help.
I managed to get the very last one in Australia
Craig Mecak, pjm877 and galonzo like this.
Lazzar is offline
post #33333 of 37235 Old 09-25-2018, 03:34 AM
bob brennan's Avatar
Quoted: 354 Post(s)
Liked: 341
Very Lucky!!! In the USA they are going for $ 1,000 to $1,500 on Amazon - this list price was $549!
ad5wb likes this.
LG OLED 77G7P - Panasonic TC-P65ZT60 – OPPO UDP-203/103D - Toshiba HD-DVD-3A – Harmony ONE
Marantz SR7011 - Definitive Technology - Studio Monitor 65 (2) - CS8040HD - Studio Monitor 55 (2) - Super Cube 6000
bob brennan is offline
post #33334 of 37235 Old 09-25-2018, 04:10 AM
Liked: 5
Picked it up for $949 AUD
687.806USD
aguy and pjm877 like this.
Lazzar is offline
post #33335 of 37235 Old 09-25-2018, 04:11 AM
lizrussspike's Avatar
Quoted: 1216 Post(s)
Liked: 1826
^WOW That is just amazing. I will keep my 203, as the Oppo is solid!
galonzo likes this.
lizrussspike is offline
post #33336 of 37235 Old 09-25-2018, 04:14 AM
jqmn's Avatar
Quoted: 432 Post(s)
Liked: 155
My question is how do I force DV to OFF? I get what appears to be a chroma mismatch and can't get out of it for a DV disc (HDR10 only discs play fine). I know I am in DV because when trying to adjust the video output it is not selectable ("DV does not allow change in ...."). I have to eject the disc, try changes (HDR Auto), reload the disc...nothing works. The only device in the chain that is DV capable is the Oppo yet it is trying to put it out. I gave up and watched something else without any issues.
Originally Posted by Sailor08 View Post
There should not be a DV to HDR10 conversion unless you try to force it. And by that i mean force DV on everything. I have a Sony X900E which does not have DV capability. When I play discs with DV on my Oppo 203, the player uses the HDR10 data which is mandatory on all UHD discs and that's it. Check your player settings to see if you put Dolby Vision output for everything. If you put everything on Auto, you will get HDR10.
jqmn is online now
post #33337 of 37235 Old 09-25-2018, 04:54 AM
wesslan1's Avatar
Quoted: 103 Post(s)
Liked: 42
Only thing I found that applies to older Oppos as well is that they stumble sometimes on mkv/subs. This is only over network/SMB and hard wired. No problem on discs and BDMV folders but mkv with subs can sometimes stop/hang the Oppo so a hard reboot is needed. More than often subtitles is involved/showing.
Always wondered if it's something in the mkv specifications on how things are ripped and how subtitles are handled in the container and in what format but very hard to narrow down and specify more :/
And since the network features is "beta" still I guess I'm just happy it works as good it does.
galonzo likes this.
wesslan1 is offline
post #33338 of 37235 Old 09-25-2018, 05:01 AM
shoeboo's Avatar
Quoted: 95 Post(s)
Liked: 92
Follow Bill’s feedback below:
Originally Posted by wmcclain View Post
You want HDR10 from Dolby Vision discs? See the FAQ: How do I force HDR10 from a Dolby Vision disc?
galonzo likes this.
JVC RS-440 | SI Slate 1.2 120" Zero Edge 16x9 screen | Fusion Lagoon Seating
Denon x4300H | Revel 5.1.4 F206/C205/W893/C763 | Dayton
Sealed 18-HO | Behringer EP4000
Tivo Bolt | Oppo 203 | Apple TV 4K | PS4 Pro | Nvidia Shield TV
shoeboo is offline
post #33339 of 37235 Old 09-25-2018, 05:06 AM
jqmn's Avatar
Quoted: 432 Post(s)
Liked: 155
Thanks for the redirect; will give it a go.
jqmn is online now
post #33340 of 37235 Old 09-25-2018, 05:35 AM
archer75's Avatar
Quoted: 699 Post(s)
Liked: 342
Does anyone have issues with streaming large mkv files over the network, i saw a review on YouTube that said it struggles with large mkv files.
Loading times are slow and the video sometimes freezes, is this the case if it is played directly via the USB.
Still trying to decide between the oppo and the cambridge.
No problems here.
Streaming Devices: Nvidia Shield, 2x Roku 3's, 1st/2nd gen chromecast, ATV4k, Apple TV 4, xbox 360/one
Displays: Vizio M602i-B3, LG OLED65B6, panasonic ax100u on a 145" S-I-L-V-E-R painted screen, 40" Samsung
Receivers: Denon X3300, Yamaha RX-V663. Bluray/UHD player: Oppo UDP-203
archer75 is online now
post #33341 of 37235 Old 09-25-2018, 05:36 AM
artur9's Avatar
Quoted: 1011 Post(s)
Liked: 392
I have streamed Atomic Blonde and Bladerunner UHD movies over my network which has the NAS wired directly to an Orbi satellite which then goes wireless backhaul to the Orbi router where the Oppo is also wired.
Works a treat!
artur9 is offline
post #33342 of 37235 Old 09-25-2018, 07:44 AM
StevenC56's Avatar
Quoted: 583 Post(s)
Liked: 206
same chipset, but some says that cambridge has a better sound, because of digital-only transport (i'd like to know, from a fellow engineer, if a DAC operation can insert noise into a separate digital stream), but oppo has a better video ( https://www.stereophile.com/content/...ambridge-cxuhd , https://www.avforums.com/review/camb...r-review.14103 ). i don't know what to say, it feels like it's about those >1000$ hdmi cables with silver ions
again, probably here already did a comparison.
After reading this review on the Cambridge CXUHD it seems the first sample they tested had flawed firmware. After the firmware was updated, the video was on par with the Oppo 203. I think at this point if you can get the Oppo 203 at it's MSRP price, that is the better choice. But given that there doesn't appear to be any left to buy except on the inflated secondary market, the Cambridge may be the smarter buy as long as you don't need analog outputs. Now in a month or 2 when new Cambridge units have all been sold, (They are discontinued as well) then you will see their value go up on the secondary market just like the Oppos have.
galonzo likes this.
JVC X750R Projector,Yamaha CX-A5200 Pre-Pro, Yamaha RX-Z11 Receiver, (Amps Only) Yamaha MX-D1 Power Amps x 2, Yamaha RX-Z1 (L&R Surround Channel Amp), Oppo BDP-103D BR, Panasonic DP-UB820 UHD, Pioneer Elite CLD-99 LD, Definitive Tech BP7000SC Mains, CLR3000 Center, BPVX Surround Sides&Backs, BPX F&R Presence, Martin Logan Abyss Front L&R Subs/Dynamo L&R Rear Surround Channel Subs, Infinity SSW-210 Center Channel Sub.
StevenC56 is offline
post #33343 of 37235 Old 09-25-2018, 09:15 AM
hernanu's Avatar
Quoted: 1279 Post(s)
Liked: 2121
No problem here. Use it frequently.
hernanu is online now
post #33344 of 37235 Old 09-25-2018, 10:10 AM
Taxcheat's Avatar
Quoted: 465 Post(s)
Liked: 352
well, a gigabit network is required for big files/ big bitrates; for example, i hadn't any problems playing a 80GB MKV UHD rip from a NAS, with all-gigabit connections (well, no gigabit on TV and AVR, but doesn't matter here)
Exactly right. I'd also add that your NAS needs to be up to par as well. I have Oppo glitching when (a) I'm playing from a drive array that's writing lots of data for another task; or (b) drive maintenance is going on in the background. Since the Oppo will either freeze or stutter when this happens, it's easy to mistakenly blame the player.
galonzo and codyrocco like this.
XBR-75Z9D fed by Oppo 203. Decrapifying the X1 Extreme
Taxcheat is online now
post #33345 of 37235 Old 09-25-2018, 10:58 AM
siuengr's Avatar
Quoted: 241 Post(s)
Liked: 264
That review sounded like it was written by CA to justify the CXUHD. There is no way the analog output is affect the digital outputs. The problem is always digital noise affecting analog circuits. That is the reason behind seperate power supplies for the analog stage on the 205 is because you don't want digital noise getting to that board. You can see of the attached image the digital boards are identical. The analog board is a completely seperate board connected by a single ribbon cable, with the DAC on the analog board. Nothing is going back from the analog board to the digital board to cause interference.
My Theater Build: The Underground Apolkalypse Theater
Marantz SR7010, Monolith 7 Amplifier, Pro-Ject - Debut Carbon Esprit SB
Epson 5040ub, Oppo UHD-203 Player, Xbox One, nVidia Shield
Atmos 7.3.4 - Polk 2x RTiA9, CSiA6, 2x FXiA6, 2x RTIA3, 4x 70-RT
PowerSoundAudio XS30, Sunfire 2x - HRS-12 12" Subwoofers
siuengr is offline
post #33346 of 37235 Old 09-25-2018, 11:31 AM
SeeMoreDigital's Avatar
Quoted: 1004 Post(s)
Liked: 770
You're on you're own. I can't and wont help anyone who obtains copyrighted content illegitimately!
galonzo and stikle like this.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 2No Audiolab 8000A, 2No Audiolab M-PWR | SPEAKERS: 4No KEF 103.2, 3No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: DS212+
SeeMoreDigital is online now
post #33347 of 37235 Old 09-25-2018, 03:34 PM
jb442386's Avatar
Quoted: 383 Post(s)
Liked: 295
Watched “Solo “ this afternoon & can’t emphasize enough how much I enjoy the Zoom feature on the 203. Really enjoyed the movie on my display. Take Care All!
Sony55A1E|Oppo 203|Sony Z9F Soundbar|ATV4K
jb442386 is offline
post #33348 of 37235 Old 09-25-2018, 10:53 PM
codyrocco's Avatar
Quoted: 80 Post(s)
Liked: 35
oook... so CA physics works in the same way as in AudioQuest Diamond HDMI cables...(comments on Amazon are magnificent )
siuengr likes this.
post #33349 of 37235 Old 09-26-2018, 01:46 AM
Clark Burk's Avatar
Quoted: 712 Post(s)
Liked: 661
The 203 has great features. Icing on the cake would be a well functioning tone mapping. I’m hoping the 203 has enough processing power to pull it off and enough engineers left to make it happen.
Clark
Clark Burk is offline
post #33350 of 37235 Old 09-26-2018, 04:15 AM
Old A/V Addict's Avatar
Quoted: 35 Post(s)
Liked: 62
A lot of us 203 owners with projectors are with you on this, Clark.
Oppo 203>Marantz 7704>JVC RS520
Old A/V Addict is offline
post #33351 of 37235 Old 09-26-2018, 07:14 AM
Quoted: 50 Post(s)
Liked: 38
If the Cambridge CXUHD had 2 channel analog audio output I would buy one but.............. :-(
ad5wb is offline
post #33352 of 37235 Old 09-26-2018, 07:37 AM
Sound & Vision's Avatar
Quoted: 473 Post(s)
Liked: 286
No surprise there.... When you think about it... No matter what Panasonic, or any other manufacturer may release.. The Oppp 203 is still the only player currently available that supports 21:9 displays and offers a Zoom option.
I bet the next firmeware release for the 203 will be one of the best.
galonzo likes this.
Sound & Vision is offline
post #33353 of 37235 Old 09-26-2018, 08:02 AM
StevenC56's Avatar
Quoted: 583 Post(s)
Liked: 206
The Cambridge CXUHD will get the 21:9 zoom options added at the next firmware update soon to be released.
post #33354 of 37235 Old 09-26-2018, 08:10 AM
Quoted: 473 Post(s)
Liked: 286
Oh good.... So did they strike a deal with Oppo to continue the legacy?
post #33355 of 37235 Old 09-26-2018, 08:21 AM
StevenC56's Avatar
Quoted: 583 Post(s)
Liked: 206
No-The Cambridge CXUHD is built on the Oppo 203 chassis design, so they are discontinued too although there is still limited stock available at a few retailers and dealers. That being said, they are going fast.
post #33356 of 37235 Old 09-26-2018, 09:40 AM
claw's Avatar
Quoted: 2316 Post(s)
Liked: 2171
I don't know that you have ever posted what the Oppo Information popup reports for output format. That would help a lot.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is offline
post #33357 of 37235 Old 09-26-2018, 10:33 AM
jqmn's Avatar
Quoted: 432 Post(s)
Liked: 155
Thanks for asking. I think I posted that the Oppo msg was that video setting (settings...video...) can't be changed when in DV mode...so I was in DV mode. The reference to Bill's tips/faq provided by @shoeboo was the right pointer for what I needed and solved my question/issue on how to force DV Off and pass only HDR10.
jqmn is online now
post #33358 of 37235 Old 09-26-2018, 11:37 AM
Quoted: 473 Post(s)
Liked: 286
Oh... Thanks, that explains it. 😊
post #33359 of 37235 Old 09-26-2018, 11:57 AM
StevenC56's Avatar
Quoted: 583 Post(s)
Liked: 206
But-If you absolutely need analog outputs, the Cambridge is not the unit for you. (It has no analog outputs) It does have a beefier power supply and a couple other tweaks the Oppo doesn't have. Check out the internal pictures. It actually weighs 1.5 pounds more than the Oppo 203, even with the omission of analog circuits and connections.
ID:	2460468   Click image for larger version
post #33360 of 37235 Old 09-26-2018, 12:01 PM
claw's Avatar
Liked: 2171
What I was asking was to press and hold the Info key on the Oppo remote control. It will bring up a popup screen that reports the input format and you can scroll down to see the output format. Then we could see what the Oppo was sending as output instead of guessing.
CJ
claw is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
