Official OPPO UDP-203 Owner's Thread - Page 1114 - AVS Forum | Home Theater Discussions And Reviews
 279158Likes
post #33391 of 37235 Old 09-27-2018, 07:25 PM
rdgrimes's Avatar
Quoted: 3850 Post(s)
Liked: 3086
Originally Posted by CrazyEddie View Post
The Oppo remote is very nice. And could still be purchased as recently as a about a month ago from Oppo for not much cost. Perhaps still.
Y'all with that 'other' player might want to consider buying an Oppo remote, if they are still available.
You are asked to provide an Oppo serial number in order to buy a replacement remote. Supplies are limited.
rdgrimes is offline
post #33392 of 37235 Old 09-27-2018, 08:25 PM
StevenC56's Avatar
Quoted: 583 Post(s)
Liked: 206
So, will the Oppo remote work on the Cambridge CXUHD?
JVC X750R Projector,Yamaha CX-A5200 Pre-Pro, Yamaha RX-Z11 Receiver, (Amps Only) Yamaha MX-D1 Power Amps x 2, Yamaha RX-Z1 (L&R Surround Channel Amp), Oppo BDP-103D BR, Panasonic DP-UB820 UHD, Pioneer Elite CLD-99 LD, Definitive Tech BP7000SC Mains, CLR3000 Center, BPVX Surround Sides&Backs, BPX F&R Presence, Martin Logan Abyss Front L&R Subs/Dynamo L&R Rear Surround Channel Subs, Infinity SSW-210 Center Channel Sub.
StevenC56 is offline
post #33393 of 37235 Old 09-27-2018, 09:23 PM
codyrocco's Avatar
Quoted: 80 Post(s)
Liked: 35
Originally Posted by ray0414 View Post
Anybody using the Oppomod power supply for video quality improvement?
Why not using ALL mods and doubling the unit price?
codyrocco is offline
post #33394 of 37235 Old 09-28-2018, 02:36 AM
Kazz063's Avatar
Quoted: 105 Post(s)
Liked: 102
Has anyone had issues since the last FW update?
When I out in a UHD disc I now get the message that I need to connect to a display that supports HDR and when I click on OK and play the disc the picture is completely over saturated.
Running Oppo -> Marantz 7010 -> HD Fury Vertex -> JVC X5000, the only change I've made is updating the Oppo FW.
Edit : Ok this doesn't seem to be an Oppo issue I've taken the Vertex (and therefore the AVR) out of the loop and the issue is resolved.
Kazz063 is offline
post #33395 of 37235 Old 09-28-2018, 04:24 AM
rdgrimes's Avatar
Liked: 3086
This is all pretty consistent with a dodgy cable in the chain.
galonzo likes this.
rdgrimes is offline
post #33396 of 37235 Old 09-28-2018, 04:28 AM
Kazz063's Avatar
Quoted: 105 Post(s)
Liked: 102
I'm guessing it would have to be the short one then as it's running fine trough the Ruipro straight to the PJ, I'll swap out the short one tomorrow and see if that helps.
Kazz063 is offline
post #33397 of 37235 Old 09-28-2018, 06:28 AM
I-SIBI's Avatar
Quoted: 84 Post(s)
Liked: 121
Send a message via Skype™ to I-SIBI
Originally Posted by jjwinterberg View Post
I would be interested if I-Sibi could actually weigh them. Sometimes manufactures are not accurate to a pound.
Is not possible due to the way my Home Theatre room is assembled... sorry...
What I can tell you is that the wight difference is minimal... just a feeling...
Pioneer UDP-LX500 - Oppo 203EU - Panasonic DP-UB9000 - SONY X-800 UHD BLU-RAY -Apple TV 4K - Marantz SR6013 in 5:1:2 Dolby ATMOS/DTS:X Config - KLIPSH REFERENCE (Towers + Central + 2 surrounds + 2 Atmos Enabled) - KLIPSH R-120SW SUBWOOFER- LG OLED 65C8 - LG OLED 55B7 - OPTOMA UHD60 4K/HDR Projector on 110' SCREEN- Toshiba HD-EP30 HDDVD PLAYER - NAIM ND5 XS 2 streamer - NAIM NAIT XS 2 stereo amplifier - Roon Core on the network
I-SIBI is offline
post #33398 of 37235 Old 09-28-2018, 06:32 AM
I-SIBI's Avatar
Quoted: 84 Post(s)
Liked: 121
Originally Posted by SeeMoreDigital View Post
Bigger heavier feet maybe... [an old turntable feature]
hmmm... no big feets under mu CXUHD...
I-SIBI is offline
post #33399 of 37235 Old 09-28-2018, 07:20 AM
claw's Avatar
Quoted: 2318 Post(s)
Liked: 2173
Originally Posted by dcbii View Post
So I re-examined the Extended Info output, and although I thought there might be a 3 sections (Disc, Input, Output), all I found was Disc and Output. They definitely reported DV on the disc, and HDR output, when used normally. Strip metadata shows non-HDR 2020 output, and SDR shows 709 output, as expected. All from DV reported on the media.
I've attached 3 files showing what I see with different Oppo output on my TV. The pictures aren't great, but they give an idea of the color differences. The first shows HDR set to strip meta data, the 2nd shows HDR from the DV, and the third shows SDR. Again, I have this issue with all of the Jack Ryan discs I've tried, but I don't see it with standard HDR discs. My TV must really not like the HDR from these!
I would check what picture mode the TV is in when it gets the HDR from the DV disc. It appears to me that the TV might not have switched to an HDR picture mode which could explain the color issue.
galonzo likes this.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is offline
post #33400 of 37235 Old 09-28-2018, 10:59 AM
dcbii's Avatar
Quoted: 203 Post(s)
Liked: 124
Well...I get the indicator in the top corner saying HDR is on (when the 203 is outputting HDR, not in strip-metadata or SDR mode), but it's certainly possible that the TV is doing something wrong. I need to get some other DV discs to try, as I don't have that many. Maybe it's just this disc set that looks so weird. I don't think it's really the 203, since noone else seems to have the same issue, but it certainly is hard to explain.
Thanks for the response.
galonzo likes this.
Dave Barnhart
Oppo UDP-203, Oppo BDP-83, Denon X4200W, Denon X8500H, LG 55EF9500, NVidia Shield TV, Apple TV 4K, Roku Ultra, RSL speakers, all Monoprice Premium Certified HDMI cables
dcbii is offline
post #33401 of 37235 Old 09-28-2018, 03:52 PM
ti-triodes's Avatar
Quoted: 531 Post(s)
Liked: 1208
No, but there is a slight bit of overlap. Depending on what code you are using, the OPPO remote can activate some functions on the CXU you didn’t expect.
ti-triodes is offline
post #33402 of 37235 Old 09-28-2018, 04:09 PM
ianfretwell's Avatar
Quoted: 29 Post(s)
Liked: 32
Check out the reviews of the first three Jack Ryan films on the UK avforums website - you'll find that they also state that the colour grading on them is 'monochromatic' - effectively your using three really bad examples to test your viewing experience.
dcbii, galonzo and Madmax67 like this.
ianfretwell is offline
post #33403 of 37235 Old 09-28-2018, 07:00 PM
rrebello's Avatar
Quoted: 43 Post(s)
Liked: 48
iPad App update
I see my iPad app updated or it is the new IOS 12. The font changed on the app. It seams to be faster also.
galonzo likes this.
rrebello is offline
post #33404 of 37235 Old 09-28-2018, 08:36 PM
Liked: 5
Should i be using the SPDIF output on the oppo to my Reciever or is HDMI all i need.
Lazzar is offline
post #33405 of 37235 Old 09-28-2018, 09:04 PM
cmdrdredd's Avatar
Quoted: 4254 Post(s)
Liked: 4545
HDMI does it all and is the only way to get lossless audio including Dolby Atmos and DTS:X
roland6465, galonzo and CrazyEddie like this.
LG 65" B7A OLED, Samsung 55" JS9000, Sony 43" x800e, Denon AVR-X2200w 5.1.2, PS4 Pro, Nintendo Switch, Gaming PC(GTX 1080ti + 4.7Ghz 8700k), Sony UBP-x800, Philips BDP-7501, Oppo BDP-203, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #33406 of 37235 Old 09-29-2018, 04:26 AM
Lesmor's Avatar
Quoted: 765 Post(s)
Liked: 335
For those who might have considered modifying the power supply and have a spare €5000 to go beyond doing that you might find this of interest
In any case I found it worth a watch enjoy
Andy
G-Rex, galonzo, snpanago and 4 others like this.
Lesmor is offline
post #33407 of 37235 Old 09-29-2018, 11:36 AM
zombie10k's Avatar
Quoted: 5373 Post(s)
Liked: 5710
Andy
Thanks for posting the video. I think Vincent was having a spiritual moment there
galonzo and Matt2026 like this.
zombie10k is online now
post #33408 of 37235 Old 09-29-2018, 12:47 PM
shadowspawn's Avatar
Quoted: 197 Post(s)
Liked: 171
Has anyone seen their 203 go into slow stutter mode on the HDMI input?
We run the signal out of a 2014-era Samsung cable-card enabled cable TV box into the HDMI input of the 203, then out to an LG 65C8 OLED. (This is because the 203 upscales to 4K better than the TV).
At least once a day, the 203 goes into slow stutter mode on this input. It will freeze for a couple of seconds, then resume for a couple of second, then freeze for a couple of seconds.... over and over. Power-cycling the 203 fixes it.
Anyone else ever see this, or have any insight into it?
shadowspawn is online now
post #33409 of 37235 Old 09-29-2018, 12:56 PM
rdgrimes's Avatar
Liked: 3086
Its not unheard of, and cable boxes are notorious for such issues. Make sure you have the 203 set for the appropriate type input image, such as 1080/SDR.
rdgrimes is offline
post #33410 of 37235 Old 09-29-2018, 03:25 PM
kitzi's Avatar
I have this issue with an AppleTV 4k on the HDMI input. I have to force an HDMI handshake to get it back to normal.
galonzo likes this.
kitzi is offline
post #33411 of 37235 Old 09-29-2018, 06:02 PM
DSperber's Avatar
Quoted: 340 Post(s)
Liked: 277
This seems to be a symptom unique to the 203,and it's buffering and processing for upconverting/deinterlacing HDMI input. I've never seen it on my 103 which I've used with 720p/1080i HDTV input via HDMI for six years. Could be due to the extra work needed to upconvert to 4K (2160p) which is at the heart of this.
When I feed the same 720p/1080i HDTV input (i.e. my DVR output) to the 203, and repeatedly use the "skip forward 30-seconds" or "skip backward 12-seconds" control to navigate past commercials, or put the DVR into "fast-foward" mode to play past a TV program segment I'm not interested in, what gets delivered to the Oppo in rapid sequence are frames which are "discontinuous" as far as the onscreen image. This is very different from normal 30i or 60p frame delivery where each consecutive frame really is just a tiny bit different from the previous frame, making it "easy" to interpolate between video image data on consecutive frames. When this smooth progression of frames is radically disturbed by "skipping" through discontinuous image data on consecutive frames I believe the Oppo's buffering and processing logic is very much bothered (seemingly moreso than the same logic on the 103).
Eventually, what appears on the display screen is this "stuttering" artifact as you describe it, kind of like "pulsing" of "every so often" images rather than the true rapid-fire sequence of discontinuous (or even continuous, when normal speed playback on the DVR is supposedly restored) frames we know are coming from the source device feeding fast-forward or frame-skip to the Oppo. In fact, even after stopping the fast-forward or commercial-skip breaks source stream, ordinary regular motion program data is also presented in the "pulsing" defective way.
Similar to the other methods mentioned above as the "solution" to get things back to normal, my own technique is to:
(a) STOP the source DVR momentarily to stop feeding program data to the Oppo,
(b) use the INPUT button on the 203 to navigate from "HDMI IN" to "BLU-RAY PLAYER" and press ENTER, so as to force the "buffer flushing" of whatever damaged frame information is currently being absorbed and processed from the external HDMI input,
(c) wait a few seconds with the Oppo's home screen main menu displayed, for things to stabilize on the 203 NOT processing external input
(d) again use the INPUT button on the 203 to navigate back to "HDMI IN" and press ENTER, to effect a totally empty brand new buffering/processing handling for the HDMI input
(e) resume PLAY on the source DVR, and everything is once again normal with no "stutter"
I feed both Roku Ultra and DVR through my StarTech 4-to-1 HDMI switch feeding the single HDMI input of the 203, but haven't seen the "stutter" symptom from the Roku. But then I pretty much never am doing the kind of "commercial skip" or "fast-forward" I regularly do when viewing my DVR. However I suspect that if I did actually control the Roku the way I controlled the DVR that I probably would see the same symptom, since based on my theory its really kind of an "eventual overrun" of the buffering and inter-frame interpolation done by the Oppo as pertains to its upconvert/deinterlace of external input to 2160p output when "overwhelmed and confused" due to a rapid-fire arrival of completely discontinuous image frames from the source device.
galonzo likes this.
DSperber is online now
post #33412 of 37235 Old 09-29-2018, 07:22 PM
Madmax67's Avatar
Quoted: 2224 Post(s)
Liked: 2516
"Aural not oral"(along with hand motions describing the 2), LMAO! Classic Vincent.
galonzo likes this.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #33413 of 37235 Old 09-29-2018, 07:25 PM
rrebello's Avatar
Quoted: 43 Post(s)
Liked: 48
I have the stutter on the Apple TV 4k (every time I try it). I never have a problem with stutter on the Roku Ultra. I have to go back to the Roku every time as the Apple TV will not work consistently on the HDMI input.
rrebello is offline
post #33414 of 37235 Old 09-29-2018, 08:58 PM
Marc Drake's Avatar
Quoted: 29 Post(s)
Liked: 41
Really? Better than to an LG C8?.... I'd like to see that
Yamaha RX-A3060 / 5.2.2 + Zone 2 | LG OLED65C6T | Oppo UDP-203 | VAF Platform Sub | VAF DC-3 G4MkII x 7
Canton Sub 12.2 | Samsung UA65KS9500 | Samsung C34F791 21:9 Ultrawide | Ruipro 15m HDMI Optic Fiber
Sonos ZP90 / Play5 G2 | VAF MPD SW4 Sub | Canton InWall 465 x 2 | Corsair HTPC / XFX RX Vega 64 | RTI T2-Cs+ RP1
Marc Drake is offline
post #33415 of 37235 Old 09-29-2018, 09:15 PM
ray0414's Avatar
Quoted: 12678 Post(s)
Liked: 11913
Yep.
This is EXTREMELY annoying. It happens over and over with my Apple tv. I usually have to turn my Oppo off and back on which takes forever.
ray0414 is offline
post #33416 of 37235 Old 09-29-2018, 11:38 PM
Keenan's Avatar
Quoted: 3945 Post(s)
Liked: 3652
Yep.
Same here, I usually just restart the ATV4K and it fixes it.
Keenan is online now
post #33417 of 37235 Old 09-30-2018, 05:03 AM
Russ_64's Avatar
Quoted: 37 Post(s)
Liked: 26
Why use the HDMI Input for the Apple TV 4K - it is already 4K (and DV which the Oppo cannot pass)? I just go straight into my AVR. I thought this was only good for non-4K sources that you want to upscale?
Panasonic TX-65GZ950B, Oppo UDP-203, Musical Fidelity M3i, Marantz SR7013, 5.1.2 - Dali Oberon 5, Oberon Vokal, Oberon 1, Alteco C-1, BK P12-300SB-PR, Apple TV 4K, Sky Q (UHD/Atmos), Sky Fiber Max (80/20).
Russ_64 is offline
post #33418 of 37235 Old 09-30-2018, 08:08 AM
kitzi's Avatar
My receiver isn't 4k capable...I go directly from the Oppo to my projector.
galonzo likes this.
kitzi is offline
post #33419 of 37235 Old 09-30-2018, 09:12 AM
Quoted: 197 Post(s)
Liked: 171
Yes, that is indeed the case.
It's subtle. I subjectively felt that the picture upscaled through the 203 looked more "real", had more "depth". But it was subtle enough that I thought it might just be placebo effect / confirmation bias.
When I got things setup so that both devices were getting the lower resolution HDMI signal at the same time (making it easy to quickly A-B between the two) I spotted that the subjective impression of "better and more satisfying" had an underlying reality. For example, watching the news at 720p, with the LG C8 upscaling there were suggestions of lines across Neil Cavuto's forehead. Coming out of the 203, you could very clearly see the lines.
Little things like that spread across the whole picture makes for a subjective difference.
edfowler, galonzo and Madmax67 like this.
post #33420 of 37235 Old 09-30-2018, 11:27 AM
chrisdack's Avatar
Quoted: 240 Post(s)
Liked: 81
Hi
Does anyone know if Oppp are aware of a bug with NFS network browsing. If you browse folder that the Oppo doesn't have permissions for the device hangs with a busy symbol.
Reboot fixes it.
Cheers
Chris
P.s.
I remember Bill asking if anyone spotted the mistake on the home screen images. Looking back at some old holiday photos I've finally spotted it, well the lake anyway.
chrisdack is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
