Official OPPO UDP-203 Owner's Thread - Page 1115 - AVS Forum | Home Theater Discussions And Reviews
 279966Likes
post #33421 of 38237 Old 09-30-2018, 11:56 AM
Quoted: 12 Post(s)
Liked: 0
Hi everyone, I've got a few UHD discs now but I'm looking to buy the Asus BW16D1H and an Oppo 203 player. My understanding is that I will be able to make UHD rips with Dolby Vision using DVDfab. Will I be able to play these on the Oppo (over the network) even on rips that contain Cinavia?
avs_rio is offline
post #33422 of 38237 Old 09-30-2018, 12:03 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4763 Post(s)
Liked: 4681
With current OPPO firmware Cinavia is ignored except for optical disc copies (including MKV versions).
This surprises me. Earlier firmware was more strict.
-Bill
galonzo likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #33423 of 38237 Old 09-30-2018, 12:05 PM
giomania's Avatar
Quoted: 830 Post(s)
Liked: 632
Read this before you buy the BD drive, as the “UHD Friendly” drives are not really in stock anywhere:
https://docs.google.com/file/d/1EvYk...iletype=msword
Sent from my iPhone using Tapatalk Pro
galonzo, Madmax67 and avs_rio like this.
Lumagen Radiance Pro HDR Tone Mapping Guide: Click Here
Lumagen Radiance Pro Setup & Calibration Tips: Click Here
UHD-BD Backup & Playback Guidance Link
giomania is online now
post #33424 of 38237 Old 09-30-2018, 12:21 PM
Quoted: 12 Post(s)
Liked: 0
-Bill
Sorry what do you mean by optical disc copies? It looks as though DVDfab creates a BDMV Folder Structure or ISO file without the Cinavia Watermark.
avs_rio is offline
post #33425 of 38237 Old 09-30-2018, 12:38 PM
wmcclain's Avatar
Liked: 4681
A copy on a optical disc.
If Cinavia is not present then it won't be a problem.
-Bill
galonzo and avs_rio like this.
post #33426 of 38237 Old 09-30-2018, 04:24 PM
limbery's Avatar
Quoted: 78 Post(s)
So if I'm running an appleTV 4K through my Opportunity 203 and then to my JVC DLA-X570R projector should I have my ATV set for UHD SDR but allow full resolution, and then my Opponent set at HDR Auto? with HDR off on the projector? I'm trying to let the Oppo manage my HDR
limbery is offline
post #33427 of 38237 Old 09-30-2018, 06:38 PM
claw's Avatar
Quoted: 2745 Post(s)
Liked: 2588
I would suggest
- In the ATV4K: 4K SDR with Match Dynamic Range and Match Frame Rate.
- In the Oppo: HDR OFF BT.2020 to let the Oppo tone map the HDR received from the ATV to SDR BT.2020.
- In the JVC: BT.2020 color profile and Gamma 2.4.
You will need to disable Atmos in the ATV4K if you play any content with Atmos. The Oppo does not support the Atmos format sent from the ATV4K.
galonzo likes this.
CJ
JVC RS500 | LG B7A OLED | Denon X6400H/X4200W | Panasonic UB820 | Two Oppo 203 | Samsung K8500 | Apple TV 4K | HDfury Diva/Vertex/Linker/Integral | MadVR with EVGA RTX-2080 Ti
claw is offline
post #33428 of 38237 Old 09-30-2018, 08:10 PM
zombie10k's Avatar
Quoted: 5620 Post(s)
Liked: 6095
-Bill
That would be a nice parting gift.. I haven't see it yet and hoping it stays that way
stevenjw and galonzo like this.
zombie10k is online now
post #33429 of 38237 Old 09-30-2018, 08:24 PM
limbery's Avatar
Quoted: 78 Post(s)
Originally Posted by claw View Post
I would suggest
Does that mean any content that has Atmos won't play through and just give me 5.1 after it's gone through the Oppo?
limbery is offline
post #33430 of 38237 Old 09-30-2018, 11:32 PM
ray0414's Avatar
Quoted: 12878 Post(s)
Liked: 12248
Originally Posted by Russ_64 View Post
Why use the HDMI Input for the Apple TV 4K - it is already 4K (and DV which the Oppo cannot pass)? I just go straight into my AVR. I thought this was only good for non-4K sources that you want to upscale?
Apps on the Apple tv are a little soft compared to the built in apps. With the oppo you can use their advanced sharpener to sharpen in back up by just bumping up the sharpness a tiny bit on the Oppo. The Oppo 203 input can accept 4k with DV or HDR10.
ray0414 is offline
post #33431 of 38237 Old 10-01-2018, 01:25 AM
G-Rex's Avatar
Quoted: 1230 Post(s)
Liked: 870
I would suggest
That’s good advice. Would love if someone who uses the Nvidia Shield to come up with a similar recommendation for ideal settings (color bandwidth seeting, frame rate, and HDR on/off) for both the Shield and the Oppo. It’s a bit different as the Shield does not have a match Dynamic Color Range or match Frame Rate setting. The Shield goes through the Oppo input, to a processor (MX160) with a 10.2 gbps hdmi chipset, then to a Sony 4k projector. Would like, if possible, the best seting that is widely applicable to all scenarios, without the need to adjust everything for each movie. I have experimented with the options, but curious what others are using.
G-Rex is offline
post #33432 of 38237 Old 10-01-2018, 02:49 AM
smoore's Avatar
Quoted: 173 Post(s)
Liked: 99
It was my understanding that the Oppo 203 input could not pass DV just HDR 10.
smoore is offline
post #33433 of 38237 Old 10-01-2018, 04:33 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 2075 Post(s)
Liked: 2577
Your understanding is correct.
gsr is offline
post #33434 of 38237 Old 10-01-2018, 04:55 AM
claw's Avatar
Liked: 2588
If you have Atmos turned on in the ATV4K and play Atmos content, the Oppo will not output any audio at all. In the same way it can't pass Dolby Vision, it can't pass the ATV4K flavor of Atmos.
You would need to turn off Atmos in the ATV4K so it never outputs Atmos.
galonzo and limbery like this.
CJ
claw is offline
post #33435 of 38237 Old 10-01-2018, 06:17 AM
MBullen's Avatar
Quoted: 105 Post(s)
Liked: 54
You are right but nevertheless I am crossing fingers it will come to us one day, tomorrow is fine Not sure whether it is technically possible with the current MediaTek SoC though.
Mike
Sony XBR-75X940E (75XE9405) | Sony XBR-55X9305E (55XE9305) | Sony VPL-HW55ES | Optoma UHD51 | OPPO UDP 203 + 103D | Denon X4200W + PMA-520AE (Atmos Front) | 2 x Apple TV 4K | 2 x JBL Northridge E80 - JBL Northridge E150P/230 - 2 x ELAC B5 - 4 x ELAC A4 - ELAC Uni-Fi UC5
MBullen is offline
post #33436 of 38237 Old 10-01-2018, 07:44 AM
Ccondo1's Avatar
Quoted: 236 Post(s)
Liked: 50
I would suggest
So in this scenario, is the AppleTV in SDR mode until HDR movie plays and then it automatically switches to HDR? I tried something similar over the weekend where I forced HDR to Oppo and then did HDR->SDR conversion and kept having HDMI handshake issues but maybe that was because I didn't disable Atmos...?
Ccondo1 is online now
post #33437 of 38237 Old 10-01-2018, 08:14 AM
claw's Avatar
Liked: 2588
Yes, that is how it should work and it did when I had my ATV connected to my Oppo. I no longer connect it to my Oppo as Atmos is too important for me.
galonzo likes this.
CJ
claw is offline
post #33438 of 38237 Old 10-01-2018, 08:16 AM
bob brennan's Avatar
Quoted: 358 Post(s)
Liked: 342
Passes DV on this side of the pond - watch Star Wars - Last Jedi.
LG OLED 77G7P - Panasonic TC-P65ZT60 – OPPO UDP-203/103D - Toshiba HD-DVD-3A – Harmony ONE
Marantz SR7011 - Definitive Technology - Studio Monitor 65 (2) - CS8040HD - Studio Monitor 55 (2) - Super Cube 6000
bob brennan is offline
post #33439 of 38237 Old 10-01-2018, 09:11 AM
limbery's Avatar
Quoted: 78 Post(s)
I have to go through my Oppo because the only HDMI cable that will work for me only reaches physically to where the disc player is located ....I can't place the ATV where the Oppo is since I need to go through the Oppo to get my feed for the audio....grrrr
limbery is offline
post #33440 of 38237 Old 10-01-2018, 12:51 PM
Quoted: 296 Post(s)
Liked: 71
Can you go ATV direct to receiver then receiver out to OPPO then OPPO to TV? you should be able to get Atmos audio AND still get the video through OPPO.
tswire is online now
post #33441 of 38237 Old 10-01-2018, 12:55 PM
naustin's Avatar
Quoted: 1973 Post(s)
Liked: 1307
Originally Posted by bob brennan View Post
Paase DV on this side of the pond - watch Star Wars - Last Jedi.
Did you verify it in the AppleTV settings? FYI, the ATV4K will switch down to HDR10 if it is connected to a non Dolby Vision device.
naustin is online now
post #33442 of 38237 Old 10-01-2018, 01:38 PM
Liked: 0
Hello,
About the possible future new firmware...if there'll ever be a future new firmware
1.FWD, REV buttons won't work on audio files (flac, wav, mp3)
2.Zoom is having too large increments ... would be nice if it may incrementally increase and decrease horizontally and vertically and also re-position the image up and down incrementally (in order to view the subtitles below a 16:9 image instead over it). Zoom is not working while picture is set to any other selection other than "Auto"... (there are custom UHD Auto, and Source Direct - on these zoom is not working)
3.Font size needs more increments for getting shrinker (I have a very large screen)
4.Subtitles should have a seeting for allowing direct external subtitles adding instead of implicit internal selection... which always made me select and search until the end of the list, and on the last position of the list, the external subtitle can be added. Please make THIS subtitle as first to be selected automatically and let the user choose otherwise.
5.Volume is not operating on HDMI output ... but other players don't have this problem... so, for volume I must switch the remote controls and use alwasy the TV remote for volume and the Oppo remote for playing functions.
6.Sharp, Contrast, Luminosity seems to have no effect from the button...no matter the settings of the picture (auto, custom UHD, or Source Direct)
I am not sure if the software might fix all these issues or the hardware has limits... but it would be nice
ChristianMM is offline
post #33443 of 38237 Old 10-01-2018, 02:04 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5893 Post(s)
Liked: 8430
Originally Posted by StevenC56 View Post
Any idea why the Cambridge weighs 1.5 lbs more than the Oppo?
Those are probably metric pounds. Or perhaps Pounds Sterling.
--Bob
htwaits, galonzo, Greg TB and 1 others like this.
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #33444 of 38237 Old 10-01-2018, 02:36 PM
Liked: 0
Hello,
I think I wrongly added this post somewhere else ... I hope here is the correct place...
post #33445 of 38237 Old 10-01-2018, 03:04 PM
Quoted: 12 Post(s)
Liked: 0
-Bill
That would be a nice parting gift.. [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG] I haven't see it yet and hoping it stays that way
So just to confirm sorry on the latest oppo firmware UHD rips not on optical disc, i.e. external usb and network will play both the HDR and Dolby vision metadata as outlined in the unofficial FAQs. Cinavia obviously being the exception.
avs_rio is offline
post #33446 of 38237 Old 10-01-2018, 03:35 PM
Taxcheat's Avatar
Quoted: 503 Post(s)
Liked: 390
Yup. DV works great over the network with full-disc backup. Only one title is a problem: Cinavia is triggered on Fate of the Furious full-disc backup over the network (no optical disc involved).
galonzo likes this.
XBR-75Z9D fed by Oppo 203. Decrapifying the X1 Extreme
Taxcheat is online now
post #33447 of 38237 Old 10-01-2018, 03:51 PM
dcbii's Avatar
Quoted: 206 Post(s)
Liked: 126
Originally Posted by ianfretwell View Post
Check out the reviews of the first three Jack Ryan films on the UK avforums website - you'll find that they also state that the colour grading on them is 'monochromatic' - effectively your using three really bad examples to test your viewing experience.
That's a fair criticism -- these were the first DV films where I noticed the color being so off. I don't have all that many 4K discs with DV, but I do have a few others. I'll compare some of them to see where they land, though I don't remember seeing this red tint before. Thanks.
Dave Barnhart
Oppo UDP-203, Oppo BDP-83, Denon X4200W, Denon X8500H, LG 55EF9500, NVidia Shield TV, Apple TV 4K, Roku Ultra, RSL speakers, all Monoprice Premium Certified HDMI cables
dcbii is offline
post #33448 of 38237 Old 10-01-2018, 03:58 PM
iserum's Avatar
Quoted: 318 Post(s)
Liked: 132
does Oppo send bitstream from input to /avr, I am getting AVR display say Dolby Atmos, but display on Oppo says 5.2 48K, what is correct ?
SONY XBR75X900F: Oppo UDP-203: DirecTv 4K: ATV4K
Marantz SR6013: Parasound 2250 V2: Aircom T8: Dolby Atmos 5.2.4
Definitive Tech. BP9060, CS 9060 HD: Mythos GEMS
Subwoofer Paradigm X12: Belkin PF30: Panamax
Harmony Elite Remote: Philips Hue Ambient Lights
iserum is online now
post #33449 of 38237 Old 10-01-2018, 05:14 PM
limbery's Avatar
Quoted: 78 Post(s)
I'm going to try that...I think I've got it hooked up the way I have is because I'd just got the third HDMI cable that I'd tried (which now works but is limited due to it's length) and I wanted to rule out as much as possible in my chain from the ATV to the projector....hopefully I won't lose any signal going through my AV processor as it's rated as being supposed to pass 4K. In either setup though, I'm going through the Oppo so I guess I'll just turn off the Atmos on the ATV
limbery is offline
post #33450 of 38237 Old 10-01-2018, 05:15 PM
bluechunks's Avatar
Quoted: 217 Post(s)
Liked: 268
Both are correct, and yes, you are getting Atmos.
In this scenerio the Oppo is bitstreaming and the Oppo is displaying the characteristic of the audio track and not the “contents.”
When the audio track is processed by the AVR it detects the Atmos encoding and displays accordingly. The AVR won’t display Atmos unless it’s receiving an Atmos track.
galonzo likes this.
__________
Visio P65-C1 / Oppo UDP-203 / Apple TV 4K / TiVo Bolt
Yamaha RX-A2060 5.1.4 / KEF iQ / Speakercraft (Ceiling) / Hsu sub / Ruipro 15 Meter Fiber HDMI
bluechunks is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
