Official OPPO UDP-203 Owner's Thread - Page 1125 - AVS Forum | Home Theater Discussions And Reviews
 280294Likes
post #33721 of 38638 Old 10-25-2018, 10:47 AM
Keenan's Avatar
Quoted: 4495 Post(s)
Liked: 4141
Originally Posted by Bob Pariseau View Post
^ I've seen the reported issue with DV media files clips, and I'm not using a Sony.
--Bob
I wondered if it might be the quality of the files themselves as I have no idea how and where they came from other than that site I linked to that I found in the LG display thread.
Keenan is offline
post #33722 of 38638 Old 10-25-2018, 11:45 AM
sage's Avatar
Quoted: 13 Post(s)
The problem folks have been talking about is specific to the HDR Off(BT.2020) choice. You are not using that, so you are not affected.
--Bob
Thanks tswire & Bob for confirming.
sage is offline
post #33723 of 38638 Old 10-25-2018, 04:07 PM
chrisdack's Avatar
Quoted: 242 Post(s)
Liked: 83
Originally Posted by artur9 View Post
Headless Linux but yeah.
No way to get the thing to not open a window?
It only changes a byte or two. Run it once. Diff the files and the hex edit whenever you need to do this
chrisdack is offline
post #33724 of 38638 Old 10-25-2018, 04:22 PM
Vader424242's Avatar
Quoted: 162 Post(s)
Liked: 117
--Bob
Bob,
I thought the issue is present for all of the tone mapping options, not just the BT.2020 one. An earlier post said that the blacks are still being clipped below 2.5% on all of the options for any type of display (both PJ and direct view). Given that my display is an older 1080p plasma (Panasonic P65V10 - MLL corrected), I am primarily concerned that the BT.709 TM options are also problematic...?
Disclaimer: All of this is new to me (as of a month ego), so I am still learning...
Peace... Vader
"Ya see, we plan ahead. That way we don't do anything right now. Earl explained it to me." - Valentine McKee
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
Vader424242 is offline
post #33725 of 38638 Old 10-25-2018, 08:02 PM
galonzo's Avatar
Quoted: 1526 Post(s)
Liked: 2110
@Vader424242 , I'm not Bob, but I posted the video evidence of the black clipping; Bob was referring to another issue that happens when trying to preserve the BT.2020 colorspace with HDR content when the HDR Off(BT.2020), HDR to SDR conversion is selected (the BT.2020 colors will only show as far as the REC.709 colorspace allows).
Vader424242 likes this.
Main: XBR-85X950H | X4500H (5.1.4) | UDP-203 | TiVo Bolt | 2019 Shield | PS4 Pro | Roku P+ (4630) | CCU
2nd: XBR-65X950G | LG LAS855M | UBD-K8500 | TiVo Mini | ATV (4thGen)
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - Star Wars Saga ('77 - '19) and other UHD Digital codes (and some HD codes)
galonzo is offline
post #33726 of 38638 Old 10-25-2018, 08:46 PM
Quoted: 162 Post(s)
Liked: 117
Thanks for the reply, galonzo!
I was afraid of something like that. I do believe that a FW fix is coming eventually, but exactly when is the question. With my luck, I will have upgraded to a 4k set by then (I'm shooting for next summer)...
galonzo likes this.
Peace... Vader
post #33727 of 38638 Old 10-25-2018, 08:46 PM
StevenC56's Avatar
Quoted: 682 Post(s)
Liked: 267
So-Just how bad is the HDR to SDR conversion picture with this issue?
JVC X750R Projector,Yamaha CX-A5200 Pre-Pro,Yamaha MX-A5000 Amps x2,Yamaha MX-D1 Power Amps x2,Yamaha RX-Z1 (L&R Surround Channel Amp), Oppo BDP-103D BR, Panasonic DP-UB820 UHD, Pioneer Elite CLD-99 LD, Definitive Tech BP7000SC Mains, CLR3000 Center, BPVX Surround Sides&Backs, BPX F&R Presence, DT UIW94/A x4, (Atmos) Martin Logan Abyss Front L&R Subs/Dynamo L&R Rear Surround Channel Subs, Infinity SSW-210 Center Channel Sub.
StevenC56 is offline
post #33728 of 38638 Old 10-25-2018, 09:07 PM
galonzo's Avatar
Liked: 2110
^^^^^^^ @StevenC56 , it depends on who you ask; to some, the difference is indiscernible (unless you know what you're looking for), and to others ( @claw ), the difference is quite obvious
I'm not in a position to comment, as I currently don't own a projector and am able to use HDR without any conversion needed.
galonzo is offline
post #33729 of 38638 Old 10-26-2018, 04:18 AM
aguy's Avatar
Quoted: 124 Post(s)
Liked: 99
For me I have a Sony 550es projector. I use the rec 709 setting as I find it has overall more pop than either sdr 2020 or HDR to the projector. That means for me I prefer the tone mapping to 706 that the oppo does to the tone mapping that is built in to the Sony projector. No projector really is able to display enough brightness for proper HDR so it has to be mapped somewhere.
AVfile likes this.
Living Room NAD M17 / NAD M27 / Martin Logan 60XT (LR) 50XT (C) / Def Tech LCR 6.5 (Surrounds) / SVS SBUltra 13+ / Sony A1 OLED
aguy is online now
post #33730 of 38638 Old 10-26-2018, 05:20 AM
HiRez24's Avatar
Quoted: 107 Post(s)
Liked: 58
Hi All, I posted this in the 205 owners thread but I fear it was shadowed by a later post.
I recently bought a Sony 900f 85" coming from a Vizio p series. My issue is that the oppo is sending Dolby Vision to the Sony regardless of Media format and or settings.
I have tried resetting the oppo, and because someone will ask I have the oppo connected to a marantz 8802a and then yo the Sony 900f. All units have latest firmware.
Is this a known bug and is there a fix?
Sent from my Pixel 2 XL using Tapatalk
Mains: Swan diva 6.1 Center: Swan diva C3 Surrounds: Swan Diva 4.1 Sourround Back: Polk TSi200 Sub: SVS SB-2000 x 2 Front And Rear Top Speakers: SpeakerCraft AIM 8 TWO Series 2PreAmp : AV-8802a Amps: Outlaw 7200\Onkyo M-5010 Transport :Oppo 205 UHD Display:Sony XBR85X900F Turntable:project audio debut carbon esprit sb beatles 1964
HiRez24 is offline
post #33731 of 38638 Old 10-26-2018, 06:15 AM
Clark Burk's Avatar
Quoted: 761 Post(s)
Liked: 697
Is DV on the OPPO set to Auto or On? You should be using Auto.
bluemoon737 likes this.
Clark
Clark Burk is offline
post #33732 of 38638 Old 10-26-2018, 06:28 AM
HiRez24's Avatar
Quoted: 107 Post(s)
Liked: 58
DV is set to auto, I tried to toggle the setting from auto to on and back again but it did not work. This is what prompted me to do the factory reset although it was the one that didn't erase acounts. I will try again tonight to do a full factory reset in case that will help. I will also take the Pre pro out of the equation to see if that makes a difference. Thanks for the suggestion though, keep em coming. If I have time I will email oppo support.
HiRez24 is offline
post #33733 of 38638 Old 10-26-2018, 12:48 PM
grendelrt's Avatar
Quoted: 590 Post(s)
Liked: 318
Question for people running a 3D MVS M2TS files. I can play the file fine and I can fast forward fine, but when I stop fast forwarding the movie becomes unresponsive. I can stop the movie and restart it at that point and it picks up from where I stopped fast forwarding. Just curious if everyone experiences this, I have tried over network and via USB 3.0 with around 60MB/s transfer rate, the USB fairs a little better.
grendelrt is offline
post #33734 of 38638 Old 10-26-2018, 03:35 PM
Quoted: 162 Post(s)
Liked: 117
One last question (until I have another...). On the HDR settings menu, is it safe to assume that the default setting of 300 nits is ideal for direct view (remember, my display is a Panny 1080p plasma), and only really is applicable to projectors?
I realize it would be simpler to just use the included BD until I get a full 4k display, but I am looking primarily at titles where a newer transfer is only on UHD, and the included BD is the older, flawed transfer (ie. Predator, The Dark Knight). Also, there are those titles that have better audio (Atmos, DTS-X) only on the UHD...
Peace... Vader
post #33735 of 38638 Old 10-26-2018, 04:40 PM
barryc46's Avatar
Liked: 26
I use a plasma with my 203, and I use the 100 nit setting. I also use the Mode 4 Tone Mapping. Looks great to me!
Sent from my SM-G920V using Tapatalk
Vader424242, StevenC56 and galonzo like this.
barryc46 is offline
post #33736 of 38638 Old 10-26-2018, 06:47 PM
Ezra Goldman's Avatar
Question from the "still figuring it out" gallery :
Honestly, I've read most of this thread over the last few weeks ... but between the messages from months ago that reference "pre-update FW" and German curves, and the expert settings in the PJ menu (not the right thread, I realize), .... I'm still a bit lost.
What are the settings that force tone mapping to take place in the Oppo and not in the projector when either streaming (Apple TV 4k) or UHD disks that have HDR? I've got the Oppo (203) driving a Sony PJ (VPL-VW385es).
Thanks in advance!
Ezra Goldman is offline
post #33737 of 38638 Old 10-26-2018, 09:09 PM
AVfile's Avatar
Quoted: 362 Post(s)
Liked: 181
Originally Posted by xlc210 View Post
Bob, I followed your recommendation for video settings at 4:2:2 and get some serious banding. If I leave on auto the player defaults to 4:4:4 12 bit and looks great. What is the reasoning for your settings recommendation?
Are you running at 1080p or 2160p?
I have several older 1080p displays and they work much better with 4:4:4.
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
post #33738 of 38638 Old 10-26-2018, 09:44 PM
Daniel Cheung's Avatar
Oppo 203 cannot connect to Shield TV SMB server
I got my Oppo 203 last week and have been trying to connect it to my Shield TV's external USB 3.0 hard drive via Network. The problem is I can find "Shield" with a SMB signed computer icon in Oppo's Network menu. However, when I entered Shield TV's share folder credentials, it said they were incorrect.
FYI, Shield TV's shared folders option is ON and I am using the Shield TV's given credentials to access the external hard drive without problem from my MacBook Pro.
I remember somewhere in this forum said Oppo 203 is still using some basic network protocol which is outdated. Is it the cause of my problem?
Thanks in advance.
Daniel Cheung is offline
post #33739 of 38638 Old 10-26-2018, 11:19 PM
SkyCyberguy's Avatar
Quoted: 129 Post(s)
Liked: 74
Seems to be normal behaviour, I have lots of 3D m2ts movies (I guess you mean MVC?) on my NAS and they all behave as you describe.
Had been the same on the BDP-103 already.
I can live with it, also since you can use the cursor-left/-right buttons to skip a certain amount of time (might take a little while though).
http://www.av-insider.de - Bild und Ton mit Sachverstand (Sound And Vision Expertized)
SkyCyberguy is offline
post #33740 of 38638 Old 10-27-2018, 01:05 AM
wl1
wl1's Avatar
Quoted: 473 Post(s)
Liked: 428
I find FF is more reliable if I stick to a couple of clicks....the faster it goes, the slower to come back to Play. Same applies with RW, but it seems to fail more often. I rarely need this feature, and just accept it too. My preferred way is to use Goto function.
The above is much the same on 93 and 103 so I don’t expect it to change.
galonzo likes this.
Ken Kreisel Twin DXD808, Q125 LCR, x4 Q125 TriFX, x4 QFH - for Atmos 7.2.4/Auro 9.2/DTS:X 11.2
Oppo 93 & 203 & Sony VPLHW55ES PJ with Lumagen 2020, 2.35:1 Seymour AT XD screen. Logitech Ultimate One & Hub, SqBox Touch & Philips Hue. Nakamichi AVP1 with Denon X7200WA. With MiniDSP 2x4.
wl1 is online now
post #33741 of 38638 Old 10-27-2018, 02:07 AM
zombie10k's Avatar
Quoted: 5674 Post(s)
Liked: 6250
Same experience, try hitting pause first after ff or rew... then play. This consistently works with that method
galonzo likes this.
zombie10k is offline
post #33742 of 38638 Old 10-27-2018, 06:21 AM
grendelrt's Avatar
Quoted: 590 Post(s)
Liked: 318
Awesome, thanks for the replies, I will stop tinkering with it now that I know its normal haha.
post #33743 of 38638 Old 10-27-2018, 08:58 AM
artur9's Avatar
Quoted: 1023 Post(s)
Liked: 399
I did that. The change isn't just a simple bit flip. It may not be much more than a simple bit flip but I have not determined what it is yet. Moved to a better thread.
artur9 is offline
post #33744 of 38638 Old 10-27-2018, 10:49 PM
Quoted: 106 Post(s)
Liked: 61
If your TV handles 4:2:2 input poorly then you should definitely not use that. TVs have their quirks, and it's no use trying to fight them.
I've posted the logic on 4:2:2 multiple times in this thread. I prefer to minimize the change in format sent to the TV when playing different types of content. The HDMI specs prohibit 12-bit for 4K/60 4:4:4. If you try, you'll get 8-bit instead. But if you set 4:2:2 output you can get 12-bit for both 4K/24 and 4K/60 video going to the TV.
--Bob
I've always been curious as to how you know that even if you set it to 4:4:4 or Auto it gets converted eventually to 4:2:2 seeing the Oppo always tells me that is outputting at 4:4:4 12 bit?
I can't seem to find out what the Sony A1 TV is displaying the picture as unless it's HDR or Dolby Vision and even then the Sony doesn't say how many bits it is so I presume it's just what the Oppo tells me it is.
Cheers
yobbo is offline
post #33745 of 38638 Old 10-28-2018, 01:15 AM
wl1
wl1's Avatar
Quoted: 473 Post(s)
Liked: 428
Cheers
The Oppo extended info shows what is being Output. If it says 4:4:4: 12 bit, that’s what it is doing. Bob mentions the rare occasion of 4K/60Hz (eg Billy Lynn) when if you play that disc with it fixed to 4:4:4 it will output as 8bit.. Have you tried it ?
So Bob prefers to ALWAYS know what will be Output, so he sticks with 4:2:2 12bit which is allowed for ALL content.
The 203 FAQ has more background info to describe Chroma subsampling here
http://watershade.net/wmcclain/UDP-2...or-spaces-mean
It might help you get your head round it.
giomania, galonzo, Lesmor and 1 others like this.
wl1 is online now
post #33746 of 38638 Old 10-28-2018, 01:28 AM
Quoted: 106 Post(s)
Liked: 61
I don't have that movie.
yobbo is offline
post #33747 of 38638 Old 10-28-2018, 04:17 AM
Craig Mecak's Avatar
Quoted: 379 Post(s)
Liked: 306
Cambridge UHD blu-ray player is promising the following..
I wonder if the Oppo which it is based upon will also get these updates, like 1 & 4?
https://www.avsforum.com/forum/465-h...l#post57021114
1. HDR10+ support
2. Supports Sony TV Dolby Vision
3. Bug fixes
4. HDMI IN supports Dolby Vision
5. Add 3 Aspect Ratio modes "21:9 Movable, 21:9 Fixed and 21:9 Cropped"
Yamaha RX-A3060 7.1.4 Receiver [+Sony Power Amp for Rear Height] / Sony KD-65Z9D / JVC HD1 DILA Projector / 90" screen / OPPO UDP-203 UHD blu-ray / Apple TV 4K
Ascension Summoner 3-way Front Speakers / Ascension 3-way Centre Speaker / Peachtree D5 Surrounds / Yamaha NS-555 3-Way Rear Speakers / ERA D4 x 4 Height Speakers / Rythmik Audio F15HP Sub
Craig Mecak is online now
post #33748 of 38638 Old 10-28-2018, 05:18 AM
Quoted: 815 Post(s)
Liked: 423
Originally Posted by sheridd22 View Post
Got a prompt response from Oppo customer service on my Tone Mapping firmware update request :-
We are investigating tone mapping issues related to converting BT.2020 to REC.709, but we do not have any additional firmware at the moment that will enhance the current performance of this conversion.
Well, it looks like it's currently being worked on so I'll need to wait a while longer.
I'm glad you god a respond but her tone doesn't tell us much.. investigatigating to me sounds more like looking over the issue.. If she had replied we are working on it then we know they are working on it..
Maybe u can reply back and ask her if they are actually working on it or looking over it from above..
I'm with some of the guys here.. As soon as another brand comes out with an hdmi in I'm moving on and I love my oppo..
Sent from my SM-G930T using Tapatalk
jorgebetancourt is offline
post #33749 of 38638 Old 10-28-2018, 05:59 AM
sheridd22's Avatar
Quoted: 47 Post(s)
Liked: 27
I did go back to Oppo and pressed them for more definite info on whether the Tone Mapping can be fixed and their response is in post 33689.
From the reply it looks like they have put a lot of resource into this - unsuccessfully, and is unlikely to be resolved, that's my reading of their response.
Mike_WI and jorgebetancourt like this.
sheridd22 is offline
post #33750 of 38638 Old 10-28-2018, 11:38 AM
riddle's Avatar
Quoted: 205 Post(s)
Liked: 107
I got this reply from OPPO:
Hi, Riddle. Yes, we are exploring the feasibility of adding HDR10+ to the UDP series with the next firmware update. It is still too early to tell if it is 100% possible.
riddle is online now
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
