Official OPPO UDP-203 Owner's Thread - Page 1135 - AVS Forum | Home Theater Discussions And Reviews
 279920Likes
post #34021 of 38184 Old 11-23-2018, 11:44 AM
Aquarian09's Avatar
Quoted: 98 Post(s)
Liked: 32
Originally Posted by imobilizer View Post
Run AppleTV to Marantz to Oppo to TV/ Projector. You will get Atmos sound, and Oppo tone mapping or video processing. Just remember to Ron an hdmi cable from Oppo Audio output to receiver, to get audio when playing discs.
Thanks alot
will try tomorrow and update here
Aquarian09 is offline
post #34022 of 38184 Old 11-23-2018, 12:47 PM
aguy's Avatar
Quoted: 116 Post(s)
Liked: 93
Originally Posted by jevansoh View Post
I actually own the 205, but this thread is more active, so I'm asking my question here.
The "Info" button on the remote will display extra content if held down. First, are there any other buttons on the remote that require being held down to do some/any other function, besides the info button?
My problem is, I use a program for my remote control, IRCommand2, which is a Windows program and it doesn't allow holding buttons down. I can only send one button press.
So is there an IR Hex code/Discrete code for the extended info function I can program into my remote control program?
Any other work-arounds would be greatly appreciated as I don't want to have to use the original Oppo remote and as of now, can't use the extended info feature.
--J
I actually control my 203 via it’s IP protocol from a crestron remote.
I know it’s not IR but there is a discrete IP / RS232 command for the extended info page which I have utilised with good effect.
For anyone who is interested OPPO publishes their rs232 / IP protocol for the 203 on their website.
Living Room NAD M17 / NAD M27 / Martin Logan 60XT (LR) 50XT (C) / Def Tech LCR 6.5 (Surrounds) / SVS SBUltra 13+ / Sony A1 OLED
aguy is online now
post #34023 of 38184 Old 11-23-2018, 03:26 PM
rocky1's Avatar
Quoted: 596 Post(s)
Liked: 196
I run everything thru my receiver (oppo/ATV/DTV) and 1 out to the display.So don't think it can pertain to me but,Out of curiosity using this suggestion wouldn't the TV inputs need to be switched back and forth going from regular tv broadcasts (unless cord has been cut)back to apple tv ? Just asking
Sony XBR65A1E,(Pioneer 500m relocated), AppleTv 4K,Marantz sr7012, System Audio Loudspeakers( sa1750 mains), ML Grotto.
Eastern Electric Minimax cd, Oppo UDP-203, Toshiba HD, Pro Ject 1expression Carbon TT.
rocky1 is offline
post #34024 of 38184 Old 11-24-2018, 07:19 AM
normandia's Avatar
Quoted: 345 Post(s)
Liked: 138
This is the logical way, as I and most probably do.
However, do you get Dolby Atmos from ATV?
The suggested alternative was to get DA from ATV and the ability to use Oppo's Tone Mapping feature.
Still trying to determine which output from processor/receiver to go into Oppo. Is it the main video out?
Theater: Lyngdorf MP-50 7.3.4, Sony VW675ES, Revel Ultima Salon2/Voice2/Gem2(4)/Paradigm Be Atmos (4), Mark Levinson amps (53 L/R, 532 Center biamped, 531H side/surrounds), Atmos amp: Sherbourn, Oppo 203, Roku Ultra Premier+, DTV 4k, Velodyne 1812 Signature (LFE), Velodyne DD-15.
FR: Marantz 8802A (and/or 7703), Sony XBR 4k TV, Meridian A350 LCR onwall, Dali in-wall surrounds, Atmos Martin Logan in-ceiling, REL sub, Oppo 105 (and/or 103), DTV, AppleTV, Sony 4k Media Server.
normandia is offline
post #34025 of 38184 Old 11-24-2018, 09:17 AM
BlueDude's Avatar
Originally Posted by Tom Riddle View Post
I’m not 100% sure, but from what I was told it has an issue tone mapping and I believe it affects the gamma curves of UHD HDR content. I’m hoping someone in the thread can better explain and provide a possible workaround. It was definitely a bummer when I found that out. I’m a long time Panasonic guy and went to the Oppo when I went to 4k as I’ve always heard how superior they are to other players.
It sure would be nice to know if the Oppo is usable or not. What's wrong with simply passing the original signal (4k, HDR, BT2020) and letting the projector take care of tone mapping? If I don't want the Oppo to tone map HDR, only do the resolution upscaling that it's so good at, can it do so?
BlueDude is offline
post #34026 of 38184 Old 11-24-2018, 09:41 AM
limbery's Avatar
Quoted: 78 Post(s)
I've got a JVC dal-X570R projector and have been told it's best to let the Oppo do the HDR stuff and have mine setup like threads on the JVC owners forum. I know when I had the JVC detecting and switching to HDR, I couldn't get a decent picture....always weird greenish tint and washed out look with way too much contrasts....It looks ok now but I don't think the projector can put out high enough nits to make HDR really pop like I've seen on OLED and QLED screens
limbery is offline
post #34027 of 38184 Old 11-24-2018, 09:59 AM
BlueDude's Avatar
The projector will only put out 100 nits at best, so no matter what, I'll never get HDR highlights. The better black detail is very desirable, along with preserving the wide color gamut.
BlueDude is offline
post #34028 of 38184 Old 11-24-2018, 10:02 AM
limbery's Avatar
Quoted: 78 Post(s)
Yes the JVC had amazing blacks for a projector and I'm happy the way the Oppo manages the color gamut (not the way the projector does). Overall happy with the picture, just never going to be able to do HDR as good as a panel display I guess
limbery is offline
post #34029 of 38184 Old 11-24-2018, 10:15 AM
BlueDude's Avatar
I'd just like some information on why the Oppo output should be set to rec709, which would appear to destroy any wide color gamut information.
limbery likes this.
BlueDude is offline
post #34030 of 38184 Old 11-24-2018, 10:29 AM
Theheadsn's Avatar
Quoted: 118 Post(s)
Liked: 55
Ok, dumb question time.
What would be the reason the 203 would take 2+ mins for a 4k UHD file to load up over my local network. All lines and connections are cat6e.
I'm curious where the bottleneck is happening. I figured its the Oppo because when playing the files directly from my LG C7 it plays right away but lacks the ability to play HiDef sound over ARC.
Theheadsn is offline
post #34031 of 38184 Old 11-24-2018, 11:57 AM
artur9's Avatar
Quoted: 1014 Post(s)
Liked: 396
We had a discussion about this a few pages back. Just to get it going again: what do you mean by "local network"? DLNA, SMB, NFS, from a what?
A.Bell and boe like this.
artur9 is offline
post #34032 of 38184 Old 11-24-2018, 12:06 PM
imobilizer's Avatar
Liked: 6
I cut the cord.
imobilizer is offline
post #34033 of 38184 Old 11-24-2018, 12:06 PM
imobilizer's Avatar
Liked: 6
Yes I get Dolby Atmos from the ATV.
DaveC56 likes this.
post #34034 of 38184 Old 11-25-2018, 11:32 AM
perzon57's Avatar
Quoted: 25 Post(s)
Liked: 24
Originally Posted by perzon57 View Post
I got a link to a fixed firmware from an other European member.Will try it out when I get the time.
Regards
Got around to load this firmware tonight,and it fixed the green line problem! Big thanks to the member that provided the link.
galonzo, SkyCyberguy and azz7686 like this.
perzon57 is offline
post #34035 of 38184 Old 11-25-2018, 06:26 PM
Theheadsn's Avatar
Quoted: 118 Post(s)
Liked: 55
From my PC over to my Oppo 203. Technically I think its handled through Plex, but its not being transcoded
post #34036 of 38184 Old 11-25-2018, 07:52 PM
redsandvb's Avatar
Quoted: 91 Post(s)
Liked: 63
For me Plex via DLNA takes a lot longer than SMB, at least it seems that way. I don't use Plex often.
redsandvb is offline
post #34037 of 38184 Old 11-25-2018, 08:45 PM
boe
boe's Avatar
Quoted: 1236 Post(s)
Liked: 561
Disable plex or any other dlna programs for now. Try it with SMB or NFS (winnfsd is great) - should load up a 4K mkv in about 5 seconds.
galonzo likes this.
boe is offline
post #34038 of 38184 Old 11-25-2018, 11:38 PM
barryww's Avatar
Hi I have the same issue any chance of giving me the link - I’ve tried OPO UK support but no luck! Thanks.
barryww is offline
post #34039 of 38184 Old 11-26-2018, 06:29 AM
wl1
wl1's Avatar
Quoted: 453 Post(s)
Liked: 412
Check you messages here.
galonzo likes this.
Ken Kreisel Twin DXD808, Q125 LCR, x4 Q125 TriFX, x4 QFH - for Atmos 7.2.4/Auro 9.2/DTS:X 11.2
Oppo 93 & 203 & Sony VPLHW55ES PJ with Lumagen 2020, 2.35:1 Seymour AT XD screen. Logitech Ultimate One & Hub, SqBox Touch & Philips Hue. Nakamichi AVP1 with Denon X7200WA. With MiniDSP 2x4.
wl1 is offline
post #34040 of 38184 Old 11-26-2018, 03:40 PM
BlueDude's Avatar
I went back and read several hundred posts from back in March about the SDR/BT2020 processing bug and it seems the problem was on the display side with some Sony projectors and even some LG OLEDs. At that time, JVC projectors accepted and displayed the tone mapped wide color gamut signal correctly. Apparently, the Oppo was never at fault and the HDR Off/BT2020 mode works correctly. Is this still the case, or do I have more reading to do?
BlueDude is offline
post #34041 of 38184 Old 11-26-2018, 05:56 PM
claw's Avatar
Quoted: 2731 Post(s)
Liked: 2571
Read more. That was surmised but later proved to be a failure to cover the BT2020 wide color gamut.
CJ
JVC RS500 | LG B7A OLED | Denon X6400H/X4200W | Panasonic UB820 | Two Oppo 203 | Samsung K8500 | Apple TV 4K | HDfury Diva/Vertex/Linker/Integral | MadVR with EVGA RTX-2080 Ti
claw is offline
post #34042 of 38184 Old 11-26-2018, 06:12 PM
filmnut's Avatar
Quoted: 185 Post(s)
Liked: 173
The HDMI input doesn't support MHL, correct?
filmnut
filmnut is offline
post #34043 of 38184 Old 11-26-2018, 07:22 PM
rdgrimes's Avatar
Quoted: 4017 Post(s)
Liked: 3306
Correct. Only the 103/105 players do that.
rdgrimes is offline
post #34044 of 38184 Old 11-27-2018, 08:51 AM
Bytehoven's Avatar
Quoted: 1608 Post(s)
Liked: 1272
It is easy to demonstrate the saturation issue with the oppo in sdr2020 versus sdr709/hdr2020.
Another words, while you might think sdr2020 tracking might be better than sdr709, it is not.
A scene to try is in the opening production titles for Ready Player One. On the Amblin entertainment logo, look at the red bars and compared. The red bars are slightly orange and washed out in sdr2020.
galonzo likes this.
JVC DLA-X990 - 128" 2.35 1.3 Gain Screen - Vertex2 - X800M2 - UB820 - ATV4K64 - ROKU Ultra - PS4 - XBone
7.1.4 Atmos - Denon X4300H + Denon 3806(LCR) - JBL Control 5 - BIC Sub - Dayton
Bytehoven is offline
post #34045 of 38184 Old 11-27-2018, 10:35 AM
perzon57's Avatar
Quoted: 25 Post(s)
Liked: 24
I got the link from a member who had received it from Oppo Germany,I think.I will not forward that link,that must be up to him
if he will do so.It do not seem like the different Oppo country departments talk to each other,it should be them who gave out links,as this has been a known problem for some while.
perzon57 is offline
post #34046 of 38184 Old 11-27-2018, 11:51 AM
BlueDude's Avatar
Hm. So is this something Oppo is definitely going to fix or should we give up on it?
BlueDude is offline
post #34047 of 38184 Old 11-27-2018, 11:54 AM
wl1
wl1's Avatar
Quoted: 453 Post(s)
Liked: 412
The “green line” link is expired.
Optimist says it’s because a beta will be about to release...
Pessimist says it’s because they have given up...
I have provided a Dropbox link for the FW to @barryww , but I wouldn’t blame him for not trying it...not the official source and all that.
galonzo likes this.
wl1 is offline
post #34048 of 38184 Old 11-27-2018, 12:51 PM
barryww's Avatar
Hi the Dropbox link has expired too unfortunately. I'm going to give UK support another try - I'll let you know if I get a response.
EDIT - sorry missed your PM with the second link - downloading now. I'll try the update when I've got it - Thanks!
barryww is offline
post #34049 of 38184 Old 11-27-2018, 01:05 PM
C.-P.'s Avatar
Is this fixed firmware for all versions of the OPPO 203 (EU, US)? Thank you!
C.-P. is offline
post #34050 of 38184 Old 11-27-2018, 02:18 PM
wl1
wl1's Avatar
Quoted: 453 Post(s)
Liked: 412
The green line issue only affects Non-US FW, and the beta I was sent only address the green line issue, nothing else.
The fault occurs occasionally, when playing UHD to 1080p displays only....so pretty minor really.
galonzo likes this.
wl1 is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
