Official OPPO UDP-203 Owner's Thread - Page 1141 - AVS Forum | Home Theater Discussions And Reviews
 279444Likes
post #34201 of 37614 Old 12-08-2018, 01:01 PM
GGA
GGA's Avatar
Quoted: 304 Post(s)
Liked: 69
I installed a Fire Stick 4K into the HDMI IN of my 203. It plays 1080p without issue from Prime, Netflix and Hulu. Unfortunately it also plays 4K Bosch and 4k Jack Ryan as 1080p. Amazon tech support was of no help. The Oppo is connected to a JVC RS600 projector.
Anyone having success with a Fire Stick 4K and the Oppo?
GGA is offline
post #34202 of 37614 Old 12-08-2018, 01:21 PM
Keenan's Avatar
Quoted: 4071 Post(s)
Liked: 3799
It works here. It's even going through a Kinivo 4K HDMI switch. AFT4K>HDMI Switch>OPPO HDMI In>Denon X4500H>Sony A9F.
Name:	Jack Ryan 4K.JPG
galonzo and Broxxx like this.
Keenan is online now
post #34203 of 37614 Old 12-08-2018, 01:40 PM
Matt2026's Avatar
Quoted: 941 Post(s)
Liked: 26857
Are you using the HDMI port on the rear panel and not the front input? I believe the front input is limited to 1080.
Regards, Ken (Retired)
7.1.2) Denon 4520CI; Aircom T-8, Samsung 55H8000; OPPO 203; 6x SVS Ultra BS,
Ultra Center; FH 2xPolk; Rythmik F12; CyberPower CP1500PFCLCD (x2)
2.1 Ch.) Nak RE-1, CR7A, BD F7500, Denon 300F/Ortofon 2M Bronze;
Matt2026 is offline
post #34204 of 37614 Old 12-08-2018, 01:52 PM
Keenan's Avatar
Liked: 3799
There is no HDMI In port on the front of the 203, just a single HDMI In on the back panel. The front has a USB port.
galonzo likes this.
post #34205 of 37614 Old 12-08-2018, 01:53 PM
GGA
GGA's Avatar
Quoted: 304 Post(s)
Liked: 69
Thanks, so there is hope. I also plan on trying a switch, so good to hear the Kinivo works.
Curious why you use RGB and 12bit instead of YCbCr and 10bit for 4k.
I read that Jack Ryan uses Atmos. Does your receiver not use Atmos?
GGA is offline
post #34206 of 37614 Old 12-08-2018, 02:01 PM
Matt2026's Avatar
Quoted: 941 Post(s)
Liked: 26857
Oops
Keenan likes this.
Matt2026 is offline
post #34207 of 37614 Old 12-08-2018, 02:29 PM
Clark Burk's Avatar
Quoted: 726 Post(s)
Liked: 664
Oops
Relax, we have all made mistakes like that. Important to know too is that the front USB is only USB2 and the back USB's are 3.0. Regardless I've plugged in USB sticks in the front that are high speed and have played UHD folders that I've dumped from my UHD discs and they play great!!
One of the best features of the 203 is it's media streaming capability.
galonzo likes this.
Clark
Clark Burk is offline
post #34208 of 37614 Old 12-08-2018, 02:35 PM
Keenan's Avatar
Liked: 3799
That RGB setting may have been an artifact of me re-setting the Stick back to factory settings in an attempt to resolve the audio dropout problem the Stick has.
And yes, it does Atmos.
As you can see, that HDMI switch and utilizing the HDMI In port on the OPPO 203 is not a perfect solution, not yet anyway.
<deleted incorrect info>
GGA likes this.
post #34209 of 37614 Old 12-08-2018, 02:35 PM
Quoted: 46 Post(s)
Liked: 30
Oops[IMG class=inlineimg]/forum/images/smilies/redface.gif[/IMG]
This is the exact reason that I bought a used 203 a few weeks ago. Playing UHD folders off of an external hard drive with Dolby Vision is amazing. I also have played them through the front USB port with no issues at all even through its only USB 2.
Streaming Devices: Nvidia Shield TV, Roku Streaming Stick+ 4K, Xbox One X, PlayStation 4 Pro
Displays: LG OLED55C6,
Bluray/UHD player: Oppo UDP-203
Sold Off: Apple TV 4K, TCL P605 55", Amazon Fire TV 4k
Got the Shakes is offline
post #34210 of 37614 Old 12-08-2018, 02:50 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4690 Post(s)
Liked: 4563
What do have for Setup -> Device Setup -> HDMI IN Specs ? Does varying the setting have any effect?
Are you on current firmware?
-Bill
galonzo likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #34211 of 37614 Old 12-08-2018, 03:31 PM
GGA
GGA's Avatar
Quoted: 304 Post(s)
Liked: 69
-Bill
All Picture Adjustments at AUTO. I tried Custom UHD 24Hz, it didn't help. Celerity Fiber Optic cable. Latest firmware. No trouble playing 4k discs.
The Fire TV stick is plugged directly into the HDMI IN. May be it needs to go through a switch (wonky EDID?).
When I choose FORCE in the HDR setting in the OPPO I still get only SDR at the projector. That seems strange.
GGA is offline
post #34212 of 37614 Old 12-08-2018, 03:39 PM
Clark Burk's Avatar
Quoted: 726 Post(s)
Liked: 664
Yes!! Didn’t think the front USB would do UHD folders on thumb drives but it does! Amazing player!
edfowler and galonzo like this.
Clark
post #34213 of 37614 Old 12-08-2018, 03:42 PM
wmcclain's Avatar
Liked: 4563
I was asking about a different setting.
-Bill
GGA likes this.
post #34214 of 37614 Old 12-08-2018, 03:45 PM
GGA
GGA's Avatar
Quoted: 304 Post(s)
Liked: 69
And yes, it does Atmos, but if my information is correct the 203 does not pass the type of Atmos that is used by the streaming services, that being Dolby MAT. I'm still playing around with the different streaming services, the devices they play best on and then determining the best way to connect them to get the most of their capabilities, such as Atmos for example. I'm hoping that with the rumored 203 update that Dolby MAT via the HDMI In port will become a reality.
Thanks for the good info. The other problem with the Stick is that if you choose native resolution in Settings it only works with Amazon Prime. It does not work with Netflix or Hulu. From an article I read it is because the Apps have to be updated.
If you have a chance could you please insert the Stick directly into the Oppo HDMI IN and see if it works? I am wondering if your switch is "correcting" the Stick's EDID, or I could always have a defective Stick.
GGA is offline
post #34215 of 37614 Old 12-08-2018, 03:47 PM
GGA
GGA's Avatar
Quoted: 304 Post(s)
Liked: 69
-Bill
Sorry for the confusion. I will check tonight. Thanks.
GGA is offline
post #34216 of 37614 Old 12-08-2018, 04:08 PM
Keenan's Avatar
Liked: 3799
Yes, it works. I've been switching things around so much lately I've ended up confusing myself as to what's what.
With the Fire Stick plugged into either the 203 directly or through the Kinivo switch it will pass Atmos audio and UHD HDR at 24fps. I guess it's Dolby Vision that the HDMI In port does not pass?
Keep in mind that it can take a minute maybe more for the video stream to ramp up to UHD. It will initially show just 1080p.
GGA, thomasphoenix and galonzo like this.
post #34217 of 37614 Old 12-09-2018, 01:59 AM
SkyCyberguy's Avatar
Quoted: 123 Post(s)
Liked: 74
Is there a way to create video playlists (apart from placing videos in folders and naming them in the desired order, e.g. 1. THX trailer, 2. Dolby Atmos trailer, etc.) and make the Oppo play them back?
Might it be even possible to include AVCHD folders in them?
http://www.av-insider.de - Bild und Ton mit Sachverstand (Sound And Vision Expertized)
SkyCyberguy is offline
post #34218 of 37614 Old 12-09-2018, 05:24 AM
shamus's Avatar
Quoted: 30 Post(s)
new owner here... paid a hefty price on ebay. 😂
anyone know best color space to send a jvc rs-2? I remember it had to do with whatever the jvc processed stuff in. Avoided an extra conversion or something.
thanks
shamus is offline
post #34219 of 37614 Old 12-09-2018, 05:26 AM
Greg TB's Avatar
Quoted: 47 Post(s)
Liked: 53
Yes, the HDMI In will not pass Dolby Vision.
Keenan and galonzo like this.
OLED65C7P - Denon AVR S920W - Oppo 205 - Apple TV 4K - Bowers & Wilkins 804, HTM2, 805 - SVS PB2000
Greg TB is offline
post #34220 of 37614 Old 12-09-2018, 06:07 AM
wmcclain's Avatar
Liked: 4563
I've used symbolic links for this purpose; you can name them whatever you like to get the desired ordering, or even create alternative views of your collection in terms of the directory layout.
The BDP-103 FAQ has details on doing this with NTFS for use with USB, but the same technique works over SMB. Unix filesystems support the same sort of link: Are hard links supported on NTFS volumes?
I don't recall testing links to folders like AVCHD.
-Bill
hlindstr likes this.
post #34221 of 37614 Old 12-09-2018, 06:11 AM
Quoted: 123 Post(s)
Liked: 74
-Bill
Good to hear that there seems to be a way, but what you're writing about it is all greek to me.
Can't really find anything about it in the FAQ either (maybe because I have no idea of what to look for).
Is there another resource about this, maybe one with one or two practical examples?
post #34222 of 37614 Old 12-09-2018, 06:20 AM
wmcclain's Avatar
Liked: 4563
Where are your files and how are you accessing them? How did they get where they are now and how did you name them?
-Bill
post #34223 of 37614 Old 12-09-2018, 06:22 AM
Quoted: 123 Post(s)
Liked: 74
-Bill
They are on a NAS and I access them via SMB.
Some are .m2ts or .mkv files, others are "bdmv_modified" AVCHD folders.
post #34224 of 37614 Old 12-09-2018, 06:33 AM
wmcclain's Avatar
Liked: 4563
My SMB servers are on linux systems I login to directly to do file maintenance and organization.
Can you do that with your NAS? Or it might be possible to make the links from another system on the mounted remote file systems.
I presume you have a computer on the same network? MS Windows?
-Bill
post #34225 of 37614 Old 12-09-2018, 06:38 AM
Quoted: 123 Post(s)
Liked: 74
-Bill
Yes, it's a Windows PC and I'm doing all the file transfers to the NAS with it.
I do not plan to go that deep into the system though, altering internal system or file links.
I had hopes I could simply put an additional file (.txt or .html or similar) into the video files folder that contains a playlist the player can recognize and interpret.
post #34226 of 37614 Old 12-09-2018, 07:24 AM
Vader424242's Avatar
Quoted: 144 Post(s)
Liked: 115
Originally Posted by davehale View Post
I have lost the reasoning for the tone mapping bug. Is this just for the projector crowd or does this effect the rest of us lcd/Oled owners also?
Projectors.
-Bill
Forgive me, I'm not trying to be dense (it just comes naturally). I know this has been covered multiple times, but an earlier post suggested that the black crush problem affected projectors and direct displays alike. Or is the black crush different from the tone mapping problem, and I am confusing the two (which wouldn't surprise me). Thanks!
Peace... Vader
"Ya see, we plan ahead. That way we don't do anything right now. Earl explained it to me." - Valentine McKee
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
Vader424242 is offline
post #34227 of 37614 Old 12-09-2018, 07:30 AM
wmcclain's Avatar
Liked: 4563
I'm not recalling any issue with direct display devices that have HDR, like my LG OLED. (Apart from fixes only the display manufacturers can make).
Maybe I've just blocked it out of my mind; if so I'm sure I'll be corrected here.
-Bill
Vader424242 likes this.
post #34228 of 37614 Old 12-09-2018, 07:32 AM
Quoted: 144 Post(s)
Liked: 115
^^^ Sorry. I didn't specify that my display is a 1080p plasma, and I am using HDR --> SDR conversion (the upgrade to 4k is targeted for next year)...
Peace... Vader
post #34229 of 37614 Old 12-09-2018, 07:41 AM
kepstein123's Avatar
Quoted: 20 Post(s)
I am finding that the MediaControl app crashes in my iPad, but works on my iPhone, when I am trying to access music stored on an attached USB drive. Any solutions?
Ken
kepstein123 is offline
post #34230 of 37614 Old 12-09-2018, 08:14 AM
psuKinger's Avatar
Quoted: 1632 Post(s)
Liked: 716
I've just recently begun tinkering with the "networking" capabilities of my OPPO UPD-203, and I have BubbleuPnP installed on my phone. I'm really enjoying the sound quality of what I'm hearing when I cast via uPnP and/or access directly on my Oppo.
File navigation (particularly locally right on the Oppo) isn't as awesome as I think it could be (or at least figured out it could be). I have multiple folders (categorized by source/quality level, from vbr MP3s to EAC bit-for-bit CD rips to HDTracks purchases), and if I browse by folder there is no option (that I'm seeing) to sort by any option other than whatever this default is (with all my files named by Artist-Album-Track-Song, being able to sort that way would be OK, but that's not the default)... Sorting by artist piles all sources from all folders (and therefore quality types) on the screen. So finding what I want to play hasn't been as easy/quick as I'd like.
Point to all this:
I have a few music playlists set up in Plex Media Server. I can't seem to get the OPPO (or the BubbleuPnP app on my phone) to show me those. I can see my Music and Music folders, just not the playlists... my question is, is there a way to make that happen, or do I have to recreate from scratch playlists that I want to play back this way.
Living Room: Sony x940E; Denon x4400h; Ascend Sierra RAAL Tower L/R's and 2EX center, Ascend HTM-200SE Rears, Rythmik F25 sub. NVidia Shield, ATV4k, OPPO UDP-203, CCA.
Basement: Samsung PN58B650 LN-T4065F (x2); Onkyo TX-NR809; Polk Monitor 70 Series II L/R's, SVS PB-1000 sub. NVidia Shield (x2), Windows Desktop, CCA.
psuKinger is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
