Official OPPO UDP-203 Owner's Thread - Page 1144 - AVS Forum | Home Theater Discussions And Reviews
 279371Likes
post #34291 of 37549 Old 12-12-2018, 10:23 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4676 Post(s)
Liked: 4550
Originally Posted by nxs450 View Post
I have a Oppo 203 I purchased about a year ago for my theater room. It have been using it for Blu-Ray movies only until last night. I purchased a new CD and when trying to play it I get a no disc in bottom left of screen and unknown disc in top right, and it does not play. I tried two other CD's and the same thing. I don't know if there is a problem or if I am not doing something right. Anyone have any ideas?
There are two lasers: one for CD/DVD and another Blu-ray/UHD.
Try a DVD. If it does not work and CDs don't work then I suspect a problem with that laser.
Contact OPPO support. They may recommend a cleaning procedure or ask that you return it for warranty service.
-Bill
galonzo likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #34292 of 37549 Old 12-12-2018, 10:24 AM
gable74's Avatar
Quoted: 63 Post(s)
Originally Posted by wmcclain View Post
(1) Test one of the files with a direct connection on a USB device. Just want to make sure the player is happy with the files themselves.
(2) Are you using a wireless connection? As a diagnostic, try a wired connection and see if there is a difference.
(3) Are you using DLNA or SMB from your server? Try the other.
-Bill
Well my tests came back a little confusing (big surprise). I do not have a lot of knowledge on file structures or server architecture so I apologize in advance. I figured it would be a much simpler test to switch from a DLNA to SMB type file sharing but I just do not know enough about how to do that exactly.
However, I was able to run some tests with some success.
I have all my media files segregated in the following folders.
UHD Movies
HD Movies
TV Shows
Music
Pictures
All these folders are associated with my PLEX server. When testing with the built in Windows 10 server, I simply redirected those folders to the preset folders that the Windows 10 server uses as outlined HERE
I did some research about file sharing prior to my tests and did the following prior to running those tests.
1. Turned on media streaming from within my Network Options as outlined HERE
2. Turned on SMB file sharing options as outlined HERE
So either of these may have helped me over the hump.
Anyway, here is what I got....
Using the PLEX server library and associated folders these were my results:
1. Using the media control (Oppo) App, I was able to cast everything to the Oppo except for UHD and HD movies. They would buffer for about 5sec and error out.
2. Using a Windows 10 PC I was able to cast all files to the Oppo without issue.
3. Browsing to the files via the Oppo itself (Oppo remote control) I was able to cast everything to the Oppo except for UHD and HD movies. They would buffer for about 5sec and error out.
Using the Built in Windows 10 DLNA server library and associated folders these were my results:
1. Using the media control (Oppo) App, I was able to cast all files to the Oppo without issue.
3. Browsing to the files via the Oppo itself (oppo remote control) I was able to cast all files to the Oppo without issue.
Test conclusion:
- Using the media control app as well as directly from the Oppo remote itself, I am unable to play any movies from the PLEX server library.
- Using the built in DLNA Windows 10 server allowed me to play everything without issue.
Sorry for the long post and if anyone would care to link me to a resource that better explains the differences between DLNA and SMB sharing that would be great!
gable74 is offline
post #34293 of 37549 Old 12-12-2018, 01:40 PM
Rebellion's Avatar
Originally Posted by SkyCyberguy View Post
I tried ripping "The Walk 3D", "The Adventures of Tintin 3D" and "Django Unchained" to my NAS and during playback after a few minutes audio was muted.
I am on current firmware.
So it still detects Cinavia and (sadly) does what it's supposed to do...
Are these UHD movies or just standard Blu-ray?
Is Cinavia detected on standard blu-ray backups or just on UHD's?
Rebellion is offline
post #34294 of 37549 Old 12-12-2018, 02:31 PM
shivaji's Avatar
Quoted: 1228 Post(s)
Liked: 1202
Was watching the last episode of the Bravo show, "Below Deck". Near the end of it, the captain was about to show a vid to the crew on a big screen tv on board. I saw something on the screen so familiar that it at first, didn't register. Then I look again and see the Oppo screen saver logo, bouncing around the tv. But of course, Quality ship, quality blue-ray player.
bluer101, galonzo, artur9 and 1 others like this.
shivaji is online now
post #34295 of 37549 Old 12-13-2018, 02:19 AM
Liked: 0
Originally Posted by Got the Shakes View Post
I have the U.S. version, but I’m on the latest firmware and I’ve had no problems playing UHD folders off of a USB hard drive. Menus and everything have worked for me just like if I were playing off of UHD discs.
Thanks a lot.
AudioSlave2018 is offline
post #34296 of 37549 Old 12-13-2018, 05:42 AM
Quoted: 130 Post(s)
Can someone explain how a bluray player can be so expensive?
I'm used to playing everything from my PC. I have lots of storage so I usually buy a movie, rip it to my HD, store my disc so it doesn't get damaged and play all movies from a Windows based PC.
What am I missing with a player that retails for $1700?
RichardPryor is offline
post #34297 of 37549 Old 12-13-2018, 05:45 AM
seggers's Avatar
Quoted: 191 Post(s)
Liked: 146
When it was being sold by the manufacturer, it was in the 550 region IIRC.
Now that they have exited, people are offloading their players for whatever they think the market can bear. And in this case, someone thinks it can bear $1700...
Seggers
Sony XBR-85X900F, Oppo 203 UHD, Denon X6300H, Emotiva UPA5 (triggered), Wharfedale Pacific Evo 40s, CS, 10s, PC DX12 sub, Def Tech A60 Atmos tops, the internet and a Nvidia Shield. There's also a Wii, but we don't talk about that...
seggers is offline
post #34298 of 37549 Old 12-13-2018, 06:56 AM
chi_guy50's Avatar
Quoted: 2275 Post(s)
Liked: 2345
Seggers
That's right on the money (pun intended).
OTOH, Oppo's original MSRP for the audiophile UDP-205 which, just like its brother UDP-203, is designed just to "spin discs," was $1,300. And I don't think Oppo had any problem selling out those units.
You don't even want to know what new UDP-205's are going for now (hint: double to triple the MSRP).
Operon and Matt2026 like this.
Living Room: Sony XBR-65Z9D; Oppo UDP-203; Nvidia Shield TV; Roku Ultra; Denon AVR-X8500H (9.1.4/13.1); Polk Audio RTiA7 (Fl/r), CSiA6 (C), RTiA5 (Sl/r & FW), OWM5 (SB), 80F/X-RT (FH, RH); SVS SB-2000 (SW)
Bedroom: Sony XBR-55HX929, DarbeeVision DVP 5000S, Amazon Fire TV 4K, Yamaha R-N402 Network Receiver, Polk Audio LSiM703
chi_guy50 is online now
post #34299 of 37549 Old 12-13-2018, 07:36 AM
Super Moderator
teachsac's Avatar
Quoted: 1283 Post(s)
Liked: 2115
This is an owner's thread. It is not the place to discuss pricing or current street prices. Please stick to technical discussions.
No street price talk or retail links please.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #34300 of 37549 Old 12-13-2018, 07:38 AM
Quoted: 130 Post(s)
So I'm good using a computer running windows and a cheap(ish) BluRay player to "spin discs", right? Cause I can probably build a pretty decent computer with a bunch of storage for $1700.
post #34301 of 37549 Old 12-13-2018, 08:20 AM
Quoted: 235 Post(s)
Liked: 60
Anyone with ATV4k tried using the OPPO to upscale from 1080p to 4K instead of the ATV? was curious to see if the upscale difference was enough for me to hold on to the OPPO seeing that the tone mapping fix is likely dead.
Currently I have 4K SDR as the video for ATV4k then have range match on. So essentially that is taking EVERYTHING I watch from HD (1080p) like Netflix shows to 4K. Then it will keep SDR. If something was 4K then no upscaling is done on ATV but the match range will switch to HDR if that show is HDR or DV. thoughts about using OPPO to do the upscaling? Will it work on HDMI IN?
tswire is offline
post #34302 of 37549 Old 12-13-2018, 08:27 AM
galonzo's Avatar
Quoted: 1401 Post(s)
Liked: 1845
@tswire , the HDMI input on the 203 currently doesn't support DV, or the type of Atmos the ATV uses, FYI
Main: UN78HU9000/SEK-3500 | X4500H (Klipsch/HSU 5.1.4) | UDP-203 (fw 65-0131) | TiVo Bolt | Shield
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | TiVo Mini | Roku P+
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - Hot Fuzz and other UHD Digital codes (and some HD codes)
galonzo is offline
post #34303 of 37549 Old 12-13-2018, 08:35 AM
Quoted: 235 Post(s)
Liked: 60
Yes I know that. But ATV has HDR10 out even when it says DV on the title description. I also have it going to my receiver first to play atmos then to OPPO then to projector.
galonzo likes this.
tswire is offline
post #34304 of 37549 Old 12-13-2018, 08:47 AM
artur9's Avatar
Quoted: 1014 Post(s)
Liked: 395
Probably. The OPPO is better in that it does all of that and does not require me to train the rest of the family EVERY FREAKING DAY on how to use the home theater.
Only slightly jk'ing. And, don't say Harmony, have one already.
artur9 is offline
post #34305 of 37549 Old 12-13-2018, 09:03 AM
galonzo's Avatar
Liked: 1845
Which is fine, except the ATV4k still doesn't correctly convert DV to HDR correctly (as discussed in the ATV thread).
For example, if you watch Netflix in HDR-10 from another device and compare (through the 203's HDMI input, of course), you'll see that the DV to HDR conversion from the ATV for the same content is obviously amiss (or, if you haven't done so and believe what you're getting from the ATV is fine, maybe don't do this; you know, ignorance is bliss and all that jazz )
galonzo is offline
post #34306 of 37549 Old 12-13-2018, 09:40 AM
rdgrimes's Avatar
Quoted: 3895 Post(s)
Liked: 3148
I just tested an MKV file I keep around, its UHD with Cinavia. As it always has, the 203 ignores the Cinavia.
As it always has, the 203 will trigger Cinavia in full disc (BDMV folder) rips or anything on an optical disc.
Doesn't make any difference if its BD or UHD, detection is the same.
Taxcheat and galonzo like this.
rdgrimes is online now
post #34307 of 37549 Old 12-13-2018, 10:40 AM
Sittler27's Avatar
Quoted: 1357 Post(s)
Liked: 122
Oppo 203 Owner - Switch?
Currently have a 203 setup with my JVC X970R projector and have an Atmos speaker setup (Marantz SR7010 AVR + 9.2.2 Paradigm speakers). I use it mainly for local streaming of mkv files from my NAS.
I'm using the the custom gamma curves in the projector for HDR.
Am I better off going with the Panasonic UB900?
Also, I recently purchased an Apple TV 4K because I wanted to pair it with the Oppo 203 to get some of the Netflix & Amazon Prime streaming options. Would the Panasonic UB900 provide this all in one box + advantages for HDR?
Finally, in my setup, what would be the advantages of going with the new UB9000 over the Oppo 203 or even the UB900?
Sittler27 is offline
post #34308 of 37549 Old 12-13-2018, 10:48 AM
Cal1981's Avatar
Quoted: 684 Post(s)
Liked: 1086
Originally Posted by jorgebetancourt View Post
I would get the panasonic for tone mapping much better because it works.. I only hold on to my oppo because it has a 3D enhancer and zoom option that I love to use with my 3d.. I looked to buy the panasonic the other day but it doesnt have these options so I kept the oppo..lol I have to pick my battles..
Agreed. That's why, even with my owning an Oppo-203, I added the Panny UB820 to the inventory. Its HDR Optimizer isn't effective in every single case but when it works it tends to even out many HDR10s on my LG C7 OLED. For playing video files from a hard drive or my PC via DLNA, it's the Oppo all the way. Nothing matches its abilities in this arena.
Cal1981 is offline
post #34309 of 37549 Old 12-13-2018, 11:02 AM
stikle's Avatar
Quoted: 957 Post(s)
Liked: 1133
Sounds like it's time to upgrade your technology with a SmartFamily.
Oh, and Harmony. My 73 year old mother can control my entire theater.
The Seth-o-Plex 2.0 Build Thread - featuring Dolby Atmos/DTS:X 9.4.4 & 4K Dolby Vision!
Vizio | Dual Denon Atmos AVRs | Oppo | SVS | Mirage | Onkyo | Monoprice
stikle is offline
post #34310 of 37549 Old 12-13-2018, 12:42 PM
Quoted: 235 Post(s)
Liked: 60
Wow. Maybe I will pretend I never saw this post!! Lmao.
Ok so regardless of the OPPO you are saying ATV to my receiver to my projector (non DV) will still be crap? Basically ATV is not converting DV to HDR10 that well?
tswire is offline
post #34311 of 37549 Old 12-13-2018, 01:41 PM
galonzo's Avatar
Liked: 1845
That is correct, however, the thing that is amiss is that any tone mapping might be thrown off (due to the incorrect metadata that results from the conversion), so it may or may not be very noticeable (depending on your setup), and maybe only noticeable in a side-by-side.
I only noticed something was amiss because I almost exclusively watch stuff in true HDR-10 (not into sports), and so when I was watching some Netflix HDR shows via the ATV, I could tell something was amiss; which is why I now watch Netflix and Amazon Prime HDR shows via a Roku that passes through the 203.
galonzo is offline
post #34312 of 37549 Old 12-13-2018, 02:57 PM
Quoted: 661 Post(s)
Liked: 365
For me to be honest this oppo thing is truly an amazing machine it has everything you need and more.. I wish the tone mapping had been fixed. The hdmi in is a home-run all the way.. The day another player comes out with this feature and correct tone mapping then I would do the switch..
Oh and another reason why I held off on the Panasonic is because it does't have zoom control or 3D enhancement which I use a lot.. Had the panasonic had zoom and 3D enhanment then I would had given up on the oppo..
galonzo likes this.
jorgebetancourt is online now
post #34313 of 37549 Old 12-13-2018, 05:42 PM
CatBus's Avatar
Quoted: 33 Post(s)
Liked: 59
This guy who printed out a Harmony cheat sheet featuring such guidance as: To listen to music, press "Listen to music", and to watch a movie, press "Watch a movie", I am openly envious. And yes, the cheat sheet is used frequently, and when it's misplaced, panic ensues.
davehale likes this.
CatBus is offline
post #34314 of 37549 Old 12-13-2018, 06:02 PM
Sittler27's Avatar
Liked: 122
Tell me how the zoom control works...is this for films like Dunkirk that switch aspect ratios? How does this feature assist with that?
post #34315 of 37549 Old 12-13-2018, 06:53 PM
bodosom's Avatar
Quoted: 2172 Post(s)
Liked: 1706
TL;DR how it turns out is depends on your system.
My C7 used mastering metadata so the content (the movie CLL/FALL) metadata is ignored. Apple used fixed mastering metadata so you don't have to buy an outboard device to do the same. I watch various things and have no issues Apple's mastering data or with non-static content metadata.
At least one Sony projector is reported to do an HDMI handshake whenever the HDR10 metadata changes. This is inconvenient but can be fixed with an HDFury Vertex, friend of PJ owners everywhere.
It can be argued that Apple shouldn't do this but until 2017/2018 the vast overwhelming majority of display makers responded to the preponderance of bad HDR10 metadata by ignoring it and doing scene analysis based tone mapping in the display. Strictly speaking they have to be able to manage in the face of missing data because 0 is valid for both CLL and FALL. It means the data is unknown.
galonzo likes this.
I might type 2K for 1080p.
UDP-203/ATV4K(6,2)/X3500H/LG C8
bodosom is offline
post #34316 of 37549 Old 12-13-2018, 07:03 PM
Quoted: 235 Post(s)
Liked: 60
Ya I have x770 JVC and REALLY wanted the tone mapping fix from OPPO. In light of this maybe not happening I was trying to figure out if it will still be useful as a media input video processor. I do currently use somewhat custom curve and HDR looks good. So maybe given I am using static TM the ATV output of HDR is working ok for me (it does look pretty damn good). Based and what you said above I think the metadata “quirk” is not affecting me. Now, if OPPO does end up fixing the tone mapping which is highly reliant on the metadata maybe that won’t work well for me??
tswire is offline
post #34317 of 37549 Old 12-13-2018, 07:24 PM
Bytehoven's Avatar
Quoted: 1505 Post(s)
Liked: 1180
My 203 just sold and shipped, so expect tone mapping update to follow shortly.
You're welcome.
giomania, aguy, galonzo and 2 others like this.
JVC DLA-X990 - 128" 2.35 1.3 Gain Screen - X800M2 - UB820 - ATV4K64 - ROKU Ultra - PS4 - XBone
7.1.4 Atmos - Denon X4300H + Denon 3806(LCR) - JBL Control 5 - BIC Sub - Dayton
Bytehoven is offline
post #34318 of 37549 Old 12-13-2018, 07:31 PM
bodosom's Avatar
Liked: 1706
If the OPPO solution does depend on metadata rather than analysis then yes. Lumagen also reveals the problem when used to perform some level of curve selection based on metadata that is assumed to be static.
galonzo likes this.
bodosom is offline
post #34319 of 37549 Old 12-13-2018, 07:33 PM
bluer101's Avatar
Quoted: 638 Post(s)
Liked: 744
I noticed the same thing watching the other night. I pointed it out to the wife.
shivaji likes this.
bluer101 is offline
post #34320 of 37549 Old 12-13-2018, 07:36 PM
RevolutioN64's Avatar
Quoted: 37 Post(s)
Liked: 41
So does anybody know if Oppo will be releasing a firmware to support the new IMAX Enhanced (HDR10+) format? I have read rumors that one was incoming, but haven't heard anything about it for awhile. Thanks!
Samsung UN78JS9500, Sony VPL-VW295es + 100" Elite Screens Aeon Cinegrey 3D
Pioneer Elite SC-95 w/ 5.1.4 Dolby Atmos Speakers, 4 SVS Prime Elevations
OPPO UDP-203 Ultra HD Blu-Ray Player
Pioneer CLD-HF9G LaserDisc Player
XBOX One X, PS 3/4, Wii U, Octane Seating Turbo XL700 3 Seat Curved w/ Power Recline
RevolutioN64 is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
