Official OPPO UDP-203 Owner's Thread - Page 1151 - AVS Forum | Home Theater Discussions And Reviews
 280290Likes
post #34501 of 38625 Old 12-28-2018, 02:34 PM
archer75's Avatar
Quoted: 837 Post(s)
Liked: 445
I’m not sure why I would need to use the HDMI input on the oppo? What advantage wouldn’t it offer?
I have both a atv4k and a shield. Those and the oppo into my denon. Tv is a LG OLED.
Mainly watch Netflix, amazon and my own collection of rips.
Streaming Devices: Nvidia Shield, 2x Roku 3's, 1st/2nd gen chromecast, ATV4k, Apple TV 4, xbox 360/one, FireTV Stick 4k
Displays: Vizio M602i-B3, LG OLED65B6, panasonic ax100u on a 145" S-I-L-V-E-R painted screen, 40" Samsung
Receivers: Denon x3300w, Yamaha RX-V663. Bluray/UHD player: Oppo UDP-203
archer75 is online now
post #34502 of 38625 Old 12-28-2018, 02:41 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5911 Post(s)
Liked: 8467
Originally Posted by wxman View Post
Thanks! Got it to work. DV from ATV passes through when selecting HDMI bypass. I did some testing on ATV and OPPO. OPPO set to force DV, and ATV setup only to HDR10. OPPO does not convert HDR10 to DV with HDMI In. When in bypass mode, can't use many buttons on OPPO remote. INFO button does not work, neither does setup. Have to power down OPPO and power back on.
To process the HDR10 Input you must not use HDMI In Bypass. The Bypass choice disables all processing, and is just for pass through of the unprocessed input signal.
You should be able to use Input-1 to get back to Blu-ray Player mode while in Bypass. (I.e., to select the first line item in the Input selector list.)
--Bob
galonzo and naustin like this.
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #34503 of 38625 Old 12-28-2018, 02:50 PM
wxman's Avatar
Quoted: 5787 Post(s)
Liked: 4145
--Bob
When not selecting HDR bypass, but HDMI In instead, the 203 set to force DV, the OPPO will still not convert HDR10 to DV for HDR10 coming into the OPPO from the ATV. It will only display HDR10. So the only way to get DV is to set OPPO to HDMI Bypass. HDR10 will display as HDR10 and DV as DV. Can not get the 203 to force everything to DV when ATV connected via the HDMI in port.
wxman is online now
post #34504 of 38625 Old 12-28-2018, 02:58 PM
Quoted: 77 Post(s)
Liked: 69
Would anybody be kind enough to check that DV playback from AVCHD folders on a NAS is still possible on the latest beta firmware? Don't want to update and find the 'feature' has been removed.
galonzo likes this.
FredsElbow is online now
post #34505 of 38625 Old 12-28-2018, 02:58 PM
wxman's Avatar
Liked: 4145
If you don't have an AVR capable of passing DV or HDR, this frees up sending a separate HDMI cable to the tv from the device.
galonzo and bluemoon737 like this.
wxman is online now
post #34506 of 38625 Old 12-28-2018, 03:02 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4806 Post(s)
Liked: 4729
Media file support is as before. However, pay attention to the release notes:
This release is still a beta test version, not an official release. Use it only if you would like to experiment with the new features and improvements. There is a very small chance of the new features and improvements not working properly. If that happens, please report any issue to us.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #34507 of 38625 Old 12-28-2018, 03:22 PM
Quoted: 77 Post(s)
Liked: 69
Thanks, so you've tried playback yourself?
post #34508 of 38625 Old 12-28-2018, 03:25 PM
wmcclain's Avatar
Liked: 4729
I heard it through the grapevine.
-Bill
galonzo and FredsElbow like this.
post #34509 of 38625 Old 12-28-2018, 03:49 PM
guitarguy316's Avatar
Quoted: 2137 Post(s)
Liked: 822
Can you bypass HLG HDR yet through hdmi in?
guitarguy316 is offline
post #34510 of 38625 Old 12-28-2018, 03:50 PM
wxman's Avatar
Liked: 4145
When forcing the player to convert everything to DV, it apparently does not convert HDR10+ layer to DV, but instead the base HDR10 layer to DV. I tried that with A Beautiful Planet disc. Only shows BDMV HDR, 10 bit as the layer being converted to DV.
multiformous likes this.
wxman is online now
post #34511 of 38625 Old 12-28-2018, 05:08 PM
tezster's Avatar
Quoted: 660 Post(s)
Liked: 554
My Buttkicker is connected via the OPPO's analog LFE output - meaning I can now use it for anything that's fed through the OPPO's HDMI input
Tom C and galonzo like this.
tezster is offline
post #34512 of 38625 Old 12-28-2018, 05:34 PM
galonzo's Avatar
Quoted: 1525 Post(s)
Liked: 2108
No. HDR Off (BT.2020) mode still clips the most saturated BT.2020 colors.
--Bob
Confirmed; blacks are still clipped below 2.5% when converting HDR to SDR in all modes (BT.2020, REC709, and Strip Metadata).
Main: XBR-85X950H | X4500H (5.1.4) | UDP-203 | TiVo Bolt | 2019 Shield | PS4 Pro | Roku P+ (4630) | CCU
2nd: XBR-65X950G | LG LAS855M | UBD-K8500 | TiVo Mini | ATV (4thGen)
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - Star Wars Saga ('77 - '19) and other UHD Digital codes (and some HD codes)
galonzo is offline
post #34513 of 38625 Old 12-28-2018, 06:18 PM
Quoted: 303 Post(s)
Liked: 74
Seriously pissed right now. Oh well. Bye OPPO.
tswire is offline
post #34514 of 38625 Old 12-28-2018, 06:40 PM
Ezra's Avatar
Quoted: 60 Post(s)
Liked: 49
Beta change anything with passing ATV or XBox Atmos through the HDMI in?
Ezra is offline
post #34515 of 38625 Old 12-28-2018, 07:11 PM
Coyote Waits
htwaits's Avatar
Quoted: 1333 Post(s)
Liked: 2365
For a programmable remote, you can select it directly by sending Input button followed by the digit button corresponding to that line.
--Bob
Is this a part of the new firmware or something that's always been available? I tried a version of what I thought you were indicating and I was still not getting HDMI IN selected.
I'm using a Harmony Elite.
My Components:
Denon X3400H, OPPO UDP-203 & BDP-93, Xfinity XG1-P, Vizio PQ, Roku 3 & Ultra 2018
Calibration Resources:
Customer's Reports -- Professional Calibrations
Calibrator's locations and tour areas.
htwaits is offline
post #34516 of 38625 Old 12-28-2018, 08:17 PM
goodsonr's Avatar
I had asked earlier .. but now that there is a HDMI-PASSTHRU .. I'll ask again (there was no answer at the time)
Could I use this to route a tone-mapped output from the panasonic ub820 through the HDMI-IN and then to projector (picture) and amplifier (sound).
I do like the HDMI-IN acting as a switch and the streaming play-back capability. But really want to be able to use the full capabilities of the projector.
Tks
goodsonr is offline
post #34517 of 38625 Old 12-28-2018, 08:56 PM
Vader424242's Avatar
Quoted: 162 Post(s)
Liked: 117
A disappointment to be sure, but not near enough to tip the balance of pros to cons of this incredible player. IMO, nothing else, available now or on the horizon, even comes close to the overall functionality and build quality of this thing... but, as with everything, needs differ, so YMMV. Once I upgrade to a true 4k display (currently slated for next Black Friday), even this inconvenience becomes a non-issue...
Peace... Vader
"Ya see, we plan ahead. That way we don't do anything right now. Earl explained it to me." - Valentine McKee
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
Vader424242 is offline
post #34518 of 38625 Old 12-28-2018, 09:55 PM
Neil S. Bulk's Avatar
Quoted: 78 Post(s)
Liked: 55
Wonderful news about the public beta. Nice to see the player can support HDR10, Dolby Vision and HDR10+. That's the great thing about standards: there are so many of them!
Neil S. Bulk is online now
post #34519 of 38625 Old 12-28-2018, 10:48 PM
xlc210's Avatar
Quoted: 33 Post(s)
What is the advantage to force DV?
ppasteur likes this.
xlc210 is offline
post #34520 of 38625 Old 12-28-2018, 11:32 PM
Keenan's Avatar
Quoted: 4492 Post(s)
Liked: 4135
I haven't had to play with this for a while so Harmony may have added an "Input" command by now. What I did was learn the Input command from the OPPO remote and named it "Port", and as I recall it wouldn't accept the name "Input" for some reason and that's why I named it "Port". I then went to the Activity, selected "Customize This Activity" and added in 2 OPPO commands so that the last thing to happen when starting the Activity was having the OPPO select the HDMI-In port/input. The "2" command coincides with the HDMI-In port number. A screenshot of this is below. It's worked fine ever since I added those commands.
BTW, if you input the following in the Google search bar you'll get the link below with posts concerning the Harmony remote/OPPO input problem.
site:avsforum.com oppo 203 harmony input setting
https://www.google.com/search?q=site...hrome&ie=UTF-8
The AVS Forum search engine is garbage so I usually go with the Google "site:" command as it drills down right to where I want to be.
Name:	2018-12-28 23_21_49-AsPowerBar.jpg
Keenan is online now
post #34521 of 38625 Old 12-28-2018, 11:59 PM
Coyote Waits
htwaits's Avatar
Liked: 2365
Thanks very much for your reply. It looks like you nailed it. I'll get a chance to try it Sunday at the latest.
Thanks also for showing me the "site:" command. Where can I find other such search commands?
My Components:
htwaits is offline
post #34522 of 38625 Old 12-29-2018, 02:17 AM
MBullen's Avatar
Quoted: 105 Post(s)
Liked: 54
HDMI IN Pass-through for DV is very good news!
The major advantage for me is the ability to use the 21:9 zoom functionality that the Oppo offers for people having 2.35:1 projection screens like me. So the HDMI IN is where my ATV 4K will now be connected instead of going through my Denon AVR.
Seems that Europeans will have to wait a little longer to get the beta, I don't see it on the Oppo UK site yet. I'll have to wait a little longer
Mike
galonzo likes this.
Sony XBR-75X940E (75XE9405) | Sony XBR-55X9305E (55XE9305) | Sony VPL-HW55ES | Optoma UHD51 | OPPO UDP 203 + 103D | Denon X4200W + PMA-520AE (Atmos Front) | 2 x Apple TV 4K | 2 x JBL Northridge E80 - JBL Northridge E150P/230 - 2 x ELAC B5 - 4 x ELAC A4 - ELAC Uni-Fi UC5
MBullen is offline
post #34523 of 38625 Old 12-29-2018, 03:13 AM
Boofster's Avatar
Confirming AVCHD 4K DV playback still works the same as usual.
I could not get the the bypass option to do DV with the ATV4K.
It tried, TV flipped to DV, but then the screen was black for a few seconds and reset back to HDR.
It feels like there is some odd sync issue. It also triggers the TV volume bar on and off a few times (why?)
The PS4 nor the nVidia Shield work through the bypass option either.
robo24 likes this.
Boofster is offline
post #34524 of 38625 Old 12-29-2018, 03:50 AM
Read the FAQ!
Liked: 8467
It's always been there. Try it with the regular OPPO remote and you'll see it works. For your Harmony, odds are there's something wrong in the setup -- perhaps in the delay between buttons sent during the selector request, perhaps in the repeat count.
--Bob
thomasphoenix likes this.
post #34525 of 38625 Old 12-29-2018, 04:23 AM
naustin's Avatar
Quoted: 2006 Post(s)
Liked: 1355
I am glad the new beta firmware offers an HDMI In bypass that works for Dolby Vision on the AppleTV4K. Does the beta firmware support Apple's weird Atmos audio format as well?
naustin is online now
post #34526 of 38625 Old 12-29-2018, 04:37 AM
Read the FAQ!
Liked: 8467
Power cycle the display, OPPO, and ATV4K so that the HDMI info gets updated.
--Bob
post #34527 of 38625 Old 12-29-2018, 04:55 AM
wmcclain's Avatar
Liked: 4729
Some people like the results.
It is a personal choice. I don't use it, but neither have I had time or interest to do much experimentation.
-Bill
post #34528 of 38625 Old 12-29-2018, 05:48 AM
Quoted: 26 Post(s)
As expected. Now we need another firmware.
blackie333 likes this.
Sausage is offline
post #34529 of 38625 Old 12-29-2018, 09:36 AM
stikle's Avatar
Quoted: 963 Post(s)
Liked: 1145
I'll try and shake loose some time to test it.
And FYI- it's not Apple's format, it's Dolby MAT (Metadata-enhanced Audio Transmission).
giomania, galonzo, naustin and 1 others like this.
The Seth-o-Plex 2.0 Build Thread - featuring Dolby Atmos/DTS:X 9.4.4 & 4K Dolby Vision!
Vizio | Dual Denon Atmos AVRs | Oppo | SVS | Mirage | Onkyo | Monoprice
stikle is offline
post #34530 of 38625 Old 12-29-2018, 10:00 AM
wxman's Avatar
Liked: 4145
If you have an older Oled that has a peak brightness around 700 nits, you have significantly less clipping on the high end when you convert HDR10 to DV. The dynamic tone mapping of DV will produce a better image. In my case, I own an E6, the difference is pretty significant. I convert all my HDR10 discs to DV. It doesnt look good converting SDR to DV though.
wxman is online now
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
