Official OPPO UDP-203 Owner's Thread - Page 1156 - AVS Forum | Home Theater Discussions And Reviews
 279180Likes
post #34651 of 37254 Old 01-04-2019, 04:57 PM
rdgrimes's Avatar
Quoted: 3860 Post(s)
Liked: 3087
Originally Posted by skads_187 View Post
wondering if anyone can help me out, I have the hardware external add-on in the back for the all region access. I havent tested all, but I have quite a few region b blu rays that work fine. However, when I tried playing State of Grace (UK BD Region B) I get the screen that says it must be a region b player in order to play. I take it out then put another region b locked blu ray and it works.
I have version: UDP20X-60-0625
thanks
Not all discs claiming to be locked to R-B are actually locked.
Anyway, did you do the magic dance to make the player R-B? If its the same device as mine:
1) Go to playback setup and turn "auto resume" to off.
2) For R-B, press Dimmer - Dimmer - Dimmer - Mute - 2. (This must be completed in 20 sec.)
oldsteve and skads_187 like this.
rdgrimes is offline
post #34652 of 37254 Old 01-04-2019, 05:08 PM
Boofster's Avatar
Originally Posted by met_fan View Post
Have you had any luck fixing this? I contacted Oppo and the first thing they suggested was to reboot the Apple TV after I got the black screen. That didn’t change anything for me, so I’m waiting to hear back from them again.
Seems like there are a few of us with this issue. I am still not sure if anyone has this working and if so, what are they doing different.
My emails with support ended at "we're working it".
Someone also mentioned the ATV4K is using something called DOLBY-MAT transport (?) which I'm guessing was not accounted for by Oppo. I asked what device they used to make the update as I thought the ATV4K was the only one using DV. Apparently the Amazon Fire TV 4K dongle does it as well. I ordered one to play with so we'll see.
There was also an issue uncovered with the HDMI-CEC option which keeps turning off the bypass device so you should turn that off for now.
Boofster is offline
post #34653 of 37254 Old 01-04-2019, 05:26 PM
Quoted: 95 Post(s)
Liked: 49
Why doesn't HDR10+ show up in the video output options or does it only show up in the Oppo setup menu if you have a TV that will output HDR10+ ?
yobbo is offline
post #34654 of 37254 Old 01-04-2019, 06:41 PM
wxman's Avatar
Quoted: 5405 Post(s)
Liked: 3827
The tv has to be HDR10+ capable.
yobbo likes this.
LG 65E6P OLED - LG 65EF9500 OLED - OPPO 203 - OPPO 103D
wxman is offline
post #34655 of 37254 Old 01-04-2019, 07:09 PM
mutelight's Avatar
Quoted: 2245 Post(s)
Liked: 2534
It is Dolby Atmos that is sent via PCM MAT 2.0 and the Xbox uses this method as well for Atmos. Most devices use a bitstream of DD+ or TrueHD with the Atmos layer but the method Apple and Microsoft use is a PCM container with the object layer metadata on top.
galonzo likes this.
mutelight is offline
post #34656 of 37254 Old 01-04-2019, 07:36 PM
Boofster's Avatar
I couldn't find info on the Fire TV 4K transport method and it's not in the specs.
https://developer.amazon.com/docs/fi...fications.html
But I'm still confused why would they base it on the exception device. I mean the ATV4K and XBOX no doubt represent a much larger market share than the Fire TV 4K. Unless it was much easier to implement it that way...
Boofster is offline
post #34657 of 37254 Old 01-04-2019, 07:53 PM
rdgrimes's Avatar
Liked: 3087
The Apple and Xbox are using the same stream for Atmos as anything else, but they do not support bitstreaming and must decode to LPCM. The MAT PCM format accommodates that restriction and passes the Atmos sprinkles. The other devices are simply bitstreaming the DD+ that the content owner has provided without decoding.
galonzo likes this.
rdgrimes is offline
post #34658 of 37254 Old 01-04-2019, 08:18 PM
mutelight's Avatar
Liked: 2534
I will admit I didn't dig around too long but it looks like the Fire TV 4K may be decoding the stream internally and passing PCM as well.
https://forum.kodi.tv/showthread.php...661#pid2675661
So that would make three devices that use that method.
That developer site you linked just indicates the formats it is capable of decoding.
post #34659 of 37254 Old 01-04-2019, 08:58 PM
skads_187's Avatar
Quoted: 179 Post(s)
Liked: 37
Originally Posted by Bob Pariseau View Post
Erase Persistent Storage in the OPPO and try that disc again. If the disc ever produced that error (perhaps because you had the mod set to a different region), then Resume Play on the disc may cause it to restart showing that same error message. I.e., it isn't even doing the check, but just going straight to the error message since that was where it was playing when you last stopped it. This is a programming error found on a number of discs, but you can't really blame the studio programmers since players aren't SUPPOSED to be able to change Regions. So what you need to do is get rid of the Resume Point so the disc plays from the beginning again.
--Bob
Yup! that was it, thanks for both of you help! once I turned auto resume off, it worked! thanks
Bob Pariseau likes this.
skads_187 is offline
post #34660 of 37254 Old 01-04-2019, 10:37 PM
claw's Avatar
Quoted: 2323 Post(s)
Liked: 2175
The Oppo 203 was released at the end of 2016. Its HDMI input supported bitstreamed Atmos at release. I was able to pass bitstreamed TrueHD Atmos from my Samsung K8500 through the Oppo HDMI input to my AVR when I purchased my first Oppo in January 2017.
The XBox added Atmos in April 2017. The ATV4K added Atmos in 2018. How was Oppo supposed to know in 2016 that Microsoft and Apple would choose to send Atmos in a format that no other player used?
Even some Pioneer and Yamaha AVRs were unable to process the Atmos format from the ATV, with Apple telling owners that their AVRs might need a firmware update.
Oppo announced the end of production in April 2018. Apple did not provide a beta firmware with Atmos until August, months after Oppo announced the end.
If Apple had included Atmos when the ATV4K was first released, when Oppo was still making players, Oppo might have been open to determining if support for Dolby MAT Atmos could be added.
gsr, htwaits, Bittermidget and 7 others like this.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is offline
post #34661 of 37254 Old 01-05-2019, 06:09 AM
rdgrimes's Avatar
Liked: 3087
No, it does not.
rdgrimes is offline
post #34662 of 37254 Old 01-05-2019, 07:27 AM
mutelight's Avatar
Liked: 2534
No, it does not.
Guess it just does for the people in that thread using that app but I’m definitely no expert and have no desire for one so I’ll leave it to you. 🙂
post #34663 of 37254 Old 01-05-2019, 09:28 AM
Quoted: 22 Post(s)
Liked: 8
Originally Posted by gankum View Post
Any help ?
thanks
Bootcamp is your friend. I gave up searching for a modifier tool recently and just ran the tool in Windows.
Bytehoven likes this.
FredsElbow is offline
post #34664 of 37254 Old 01-05-2019, 10:01 AM
Bytehoven's Avatar
Quoted: 1383 Post(s)
Liked: 1093
Also check out Bootchamp whi h provides for very quick switching in and of osx and windows.
Bytehoven is offline
post #34665 of 37254 Old 01-05-2019, 12:52 PM
bguzman's Avatar
Quoted: 145 Post(s)
Liked: 866
Dolby Vision works in my setup via the HDMI after the update. Nothing special needed to be done. ATV4K plus Oppo 203 plus TCL 55P605 and tested cables.
robo24 likes this.
HT TCL 55P605, Mitsubishi HC6500, Pioneer UDP LX500, Panasonic LX1000, Firestick 4K, ATV4K, Onkyo TX-NR787, DefTech, Klipsch, Martin Logan, SVS @ 5.2.4 Atmos
Stereo Sansui SR-4050, Dual 1219, Pioneer UDP LX500, Emotiva PT-100, Be One Audio MA100, Polk Monitor 10, SVS SB1000
bguzman is offline
post #34666 of 37254 Old 01-05-2019, 01:35 PM
claw's Avatar
Liked: 2175
Dolby MAT is only output from the ATV if the Atmos setting is turned on. Turn off Atmos in the ATV menu and Dolby MAT is not used for audio output, and the Oppo is able to process the audio. Dolby MAT has nothing to do with with the Dolby Vision issue you are experiencing.
RichB, bguzman, galonzo and 1 others like this.
CJ
claw is offline
post #34667 of 37254 Old 01-05-2019, 02:03 PM
Crazytrekker's Avatar
Quoted: 115 Post(s)
Liked: 58
Does this update help with the occasional Dolby Vision hiccups that occur during menu navigation? My LG periodically loses video signal, even though sound is present. Most recent example, Venom (when the movie finishes). Worst offender The Last Jedi.
Sent from my SM-G920F using Tapatalk
Crazytrekker is offline
post #34668 of 37254 Old 01-05-2019, 02:26 PM
Dave-T's Avatar
Quoted: 1172 Post(s)
Liked: 566
I get that all the time with any Dolby Vision Movies on my LG E6 which is connected to a Marantz 8805 and then from the 8805 to the Oppo 203. I was wondering also if that is ever going to get fixed. I do not think anything is effected by it and it is more of just an annoyance.
Crazytrekker likes this.
Dave-T is online now
post #34669 of 37254 Old 01-05-2019, 03:04 PM
claw's Avatar
Liked: 2175
I have not seen this issue with my B7A. I will watch Last Jedi again when I get a chance. Oppo > Denon x4200w updated for Dolby Vision support > B7A
CJ
claw is offline
post #34670 of 37254 Old 01-05-2019, 03:45 PM
Quoted: 115 Post(s)
Liked: 58
Mine is via a Denon 4200 as well (using the twin HDMI outs from the Oppo even though mu Denon is also updated)
post #34671 of 37254 Old 01-05-2019, 05:47 PM
Quoted: 128 Post(s)
Liked: 85
Originally Posted by galonzo View Post
FWIW so far, the passthrough isn't allowing Atmos via Dolby MAT with the ATV4K (the same type of Atmos the XBONE uses for Netflix, not sure about how it handles Atmos from disks).
This is too bad. I was hoping for by-pass to include PCM MAT as well.
I wonder what the limitation is.
galonzo likes this.
Nvidia Shield - Zidoo X9S - HTPC/MPC-HC
Oppo 203 - Samsung HW-N950 - 7.2.4
LG 86UH9500
ntxoa is offline
post #34672 of 37254 Old 01-05-2019, 07:34 PM
artur9's Avatar
Quoted: 1011 Post(s)
Liked: 392
Thanks for the tip, but no luck. Compiled the c code into a binary using gcc and ran against the index_bdmv , per instruction. Oppo now either starts loading and hangs on clicking on the AVCHD folder..or reports 'unable to play media format. please make sure disc is inserted on the correct side ..etc' . Tried against few movies, same behaviour.
Does anyone on MAC have success with playing full-disk backups of BD disks from USB drives with 203 (or 103)?
Sorry to hear this as I wrote that. But I play the files over NFS from a Linux machine.
artur9 is offline
post #34673 of 37254 Old 01-05-2019, 09:41 PM
claw's Avatar
Liked: 2175
To test out ATV4K Dolby Vision, I moved my ATV4K from my projector room and connected it to my Oppo 203 that was connected to a Denon x4200w to an LG B7A OLED.
First attempts at passing Dolby Vision through the Oppo HDMI input all failed. Routing the Oppo HDMI output through the Denon, or directly to the LG both failed. I would see the Dolby Vision logo light up on my LG, but only a black picture was displayed.
I finally connected the Oppo directly to my LG OLED and ran an HDMI cable from the Oppo audio out to my Denon. After restarting all devices; ATV4K, Oppo, and Denon, I was able to get Netflix Dolby Vision from the ATV through my Oppo and audio to my Denon.
It would appear to me that there must be something about the ATV4K audio that is sent with Dolby Vision content that causes the Oppo to fail to pass through the Dolby Vision picture plus audio out the Video HDMI output. It does seem to be able to pass Dolby Vision and audio separately via the Video and Audio HDMI outputs.
A couple of additional data points:
- There is no issue sending ATV4K audio with HDR10 content through my Oppo HDMI input to my Denon and LG.
- There is no issue sending Oppo UHD disc playback Dolby Vision plus audio through my Denon AVR to my LG.
I have no need for this setup and will return my ATV4K to my projector room where it sends HDR10.
galonzo and Greg TB like this.
CJ
claw is offline
post #34674 of 37254 Old 01-06-2019, 12:31 AM
Quoted: 43 Post(s)
Have you updated to the current beta firmware with DV passthrough on the 203? DV passthrough on the HDMI input was just enabled with this beta
tommyknocker2121 is offline
post #34675 of 37254 Old 01-06-2019, 01:37 AM
Liked: 0
Hi all,
First my equipment:
Panasonic TH-85X940A TV
Yamaha RX-A 3060 sound processor.
OPO UPD-203 (AU)
The Panasonic TV has REC 2020, but the default is REC 709. The only way to get REC 2020 is input a video recorded with REC 2020 or HDR. Soon that video or movie starts playing, the default REC 709 change automatically to REC 2020. I couldn’t find any setting to change it manually.
Now with the problem:
The setting I use to play HDR10 movies is on video setting=> HDR setting I set as forced, Dolby Vision as “Player-led”. Resolution as UHD Auto with Colour Space YCbCr 4:4:4 and 12-bit Colour Depth. On “Device Setup”=> HDMI IN Specs I set as “UHD HDR”.
Wit the last official firmware realised from OPPO (UDP20XAU-60-0625), I play without any problem any movie with HDR10. Movies with Dolby Vision was playing with HDR output. With picture and colour the quality was perfect from my point of view.
Few days ago, I installed the UDP20XAU-64-1221B (Beta) firmware (Australia region). I did the factory reset and reboot the system. Reset my settings as I have them before the update.
After finish, I play a movie with HDR10 = Perfect. Then I play another with Dolby Vision and play… WITHOUT HDR. The INF shows playing with Format as SDR, BT 709, YCbCr 4:4:4 and 12-bit colour. But… WHERE IS HDR…?. With the Beta firmware, OPPO took away HDR from Dolby Vision movies and replace it with a Standard Definition.
That is the only problem: No HDR from movies that have Dolby Vision and HDR.
Another question; where is the HDR10+ setting? I couldn’t find it.
Thank you.
Mr.Eddy is offline
post #34676 of 37254 Old 01-06-2019, 02:59 AM
Quoted: 196 Post(s)
Liked: 297
Originally Posted by Mr.Eddy View Post
Hi all,
First my equipment:
OPO UPD-203 (AU)
Thank you.
As you don't have a Dolby Vision capable TV, what should happen is that when you play a DV disc it should revert to the HDR10 layer instead. If you have any Dolby Vision options enabled in the player, turn them off.
I believe that your scenario can also result from an incorrect HDMI / HDCP handshake, which forces the player output to drop to 1080P/60Hz. Can you check that your output is still 4K in this scenario? Hold down the info button on the 203 to get the extended menu, then go down the list to the output format.
Also, just check that you have actually put the UHD disc into the player and not the Blu-ray... You wouldn't be the first to do this!
galonzo and Madmax67 like this.
Panasonic TX-55EZ952B OLED / Oppo UDP-203 / Onkyo TX-NR555 / B&W 600 Series + Elac A4 Atmos
steverobertsbbc is online now
post #34677 of 37254 Old 01-06-2019, 03:25 AM
SkyCyberguy's Avatar
Quoted: 123 Post(s)
Liked: 74
Hi all,
First my equipment:
OPO UPD-203 (AU)
Thank you.
Something about the Dolby Vision Engine seems pretty messed up with the latest beta.
While most people report no issues, some do indeed experience problems starting from issues like yours, going forward with flashing/green/pixelated video output, up to (like myself) no video on some SDR displays (and superimposes like "This content can not be displayed because your TV does not support HDCP 2.2").
Everything was fine with the last firmware.
I already reported to Oppo CS, so let's hope they'll fix it soon.
Greets
SkyCyberguy
http://www.av-insider.de - Bild und Ton mit Sachverstand (Sound And Vision Expertized)
SkyCyberguy is offline
post #34678 of 37254 Old 01-06-2019, 03:37 AM
wl1
wl1's Avatar
Quoted: 441 Post(s)
Liked: 397
I have seen tinges of magenta in a couple of scenes of Ant Man and The Wasp UHD (playing to a 1080P display), best shown in the picture attached. 21m26s
Can someone with UHD display confirm it is not in the source material?
I can’t understand how the HDR to SDR, or 2020 to 709, or the downscaling could cause this. Anyone else seen it on their 1080p display?
Else I may need to check a few more things in my chain...
galonzo likes this.
Ken Kreisel Twin DXD808, Q125 LCR, x4 Q125 TriFX, x4 QFH - for Atmos 7.2.4/Auro 9.2/DTS:X 11.2
Oppo 93 & 203 & Sony VPLHW55ES PJ with Lumagen 2020, 2.35:1 Seymour AT XD screen. Logitech Ultimate One & Hub, SqBox Touch & Philips Hue. Nakamichi AVP1 with Denon X7200WA. With MiniDSP 2x4.
wl1 is online now
post #34679 of 37254 Old 01-06-2019, 06:52 AM
galonzo's Avatar
Quoted: 1389 Post(s)
Liked: 1797
@wl1 , I actually just watched this Friday night on my 203, and I remember that scene looking good in HDR; I will pop it back in and give that scene a more critical viewing...
wl1 likes this.
Main: UN78HU9000/SEK-3500 | X4500H (Klipsch/HSU 5.1.4) | UDP-203 (fw 65-0131) | TiVo Bolt | Roku P+
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | AppleTV4K | TiVo Mini
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - Scarface and other UHD Digital codes (and some HD codes)
galonzo is online now
post #34680 of 37254 Old 01-06-2019, 07:12 AM
claw's Avatar
Liked: 2175
Duh. How else get I get Dolby Vision passed through?
Oppo with single HDMI cable output: No Picture on LG from Dolby Vision passed through from ATV4K. Dolby Vision Logo lights up on LG so it is getting a signal, just no picture.
Oppo with dual Video + Audio HDMI cable output: Dolby Vision passed through OK to LG.
With the ATV4K connected directly to my Denon AVR, Dolby Vision is passed through OK.
I only performed this test because others reported issues with Dolby Vision pass through from an ATV4K. I don't need it.
galonzo likes this.
CJ
claw is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
