Official OPPO UDP-203 Owner's Thread - Page 1161 - AVS Forum | Home Theater Discussions And Reviews
 279060Likes
post #34801 of 37053 Old 01-14-2019, 09:04 PM
Vader424242's Avatar
Quoted: 143 Post(s)
Liked: 115
OK, after hearing the reports from here on audio dropouts on Star Trek II TWoK, I revisited my copy of the director's cut tonight. Upon my first viewing a couple of years back (Sony BDP-5000ES), I did not recall any dropouts, so I was curious as to whether either of my Oppo players would show these. To put things into context:
1) I keep a custom database of all my titles, and any details or notes I might have from each viewing, including any anomlies (such as audio dropouts), along with the dates they were observed. Yes, I know I have OCD to the nth degree (I prefer the term "collector's psychosis")...
2) Back in 1982, I saw Khan so many times I lost count. Many times, I hid out in the rest room between showings, so that each ticket afforded me two, maybe three, showings. This continued as long as my allowance would support it (which, at 1982 ticket prices, was quite a few viewings). Needless to say that I am totally familiar with the theatrical audio to the point of knowing every sound, dialog timing and inflection. Therefore, the director's additions/modifications stick out like a sore thumb.
I tried the film on both the 103D and 203. I listened intently to both, and I found no dropouts where I would expect one (where the branching would occur). Indeed, the only dropout I heard was on the 103, during the "Genesis" explanation is Kirk's quarters, in the moral debate between Spock and McCoy. It was a split-second dropout in the middle of one of Spock's sentences, almost like a crack in his voice (and not at a branching point). I was also unable to reproduce it on later viewings of the scene...?!? I also tried it back on the 5000ES (which I keep in my rack for CD playback... the DACs are second-to-none) and heard no dropouts there either...
Maybe it's equipment dependent....? Just a guess.... FWIW.
jbrinegar, galonzo and JJ7 like this.
Peace... Vader
"Ya see, we plan ahead. That way we don't do anything right now. Earl explained it to me." - Valentine McKee
One sub to rumble them all. One sub to shake them. One sub to humble them all. And in the darkness break them....
Vader424242 is offline
post #34802 of 37053 Old 01-14-2019, 11:30 PM
Quoted: 192 Post(s)
Liked: 291
Originally Posted by LucaT View Post
2) the Oppo is directly connected to my Sony AF9 and whenever I watch a movie on disc or I play a movie file on Hdd the black level is really high and I have to adjust the Tv black level down of 15-17 steps.
Instead if I play the same movie file on Hdd from the App of the TV or I watch a movie on Netflix the black level is not bad and I need to adjust only 1-2 step on it.
Check your HDMI settings on the TV. If there's a setting for the HDMI video range, the 'Limited' one is the correct one for video sources, not 'Full'.
Edit: Just looked online.
In the AF9: Advanced Settings > Video Options > HDMI Video Range = Auto
In the Oppo: Video Output Setup > Colour Space = Auto
That should do the trick, but these are the defaults anyway.
galonzo and naustin like this.
Panasonic TX-55EZ952B OLED / Oppo UDP-203 / Onkyo TX-NR555 / B&W 600 Series + Elac A4 Atmos
steverobertsbbc is offline
post #34803 of 37053 Old 01-14-2019, 11:36 PM
codyrocco's Avatar
Quoted: 80 Post(s)
Liked: 35
Originally Posted by rdgrimes View Post
It will not.
but is there any software to display hdr10+ characteristics in media file? mediainfo isnt't, as of latest version.
codyrocco is offline
post #34804 of 37053 Old 01-15-2019, 01:20 AM
peteS's Avatar
Originally Posted by claw View Post
Confirmed that Directv 4K60 4:2:0 BT2020 12-bit HLG is successfully passed through the Oppo HDMI input when HDMI IN Bypass is selected. My LG B7A reports HLG HDR. But HDMI IN Bypass disables any up conversion of 720p/1080i channels.
There must have been a behavior change with HDMI IN in one of the past firmware updates. I had never gotten a picture when I tried sending Directv HLG through the Oppo selecting HDMI IN. Now I get a picture, but SDR instead of HLG: 4K60 4:2:2 BT2020 12-bit SDR. 720p/1080i SDR BT2020 channels are successfully up scaled to 4K60 SDR.
Anyway, good news for those trying to pass HLG but don't need any up or down conversion performed by the Oppo.
Yep - sounds like good news indeed. Many thanks for testing. I guess Bypass really is a pure passthru, so will pass anything (hopefully) but would then not process anything. For me, that's actually fine as I'll need to run a script in my remotes to watch 4K from satellite as our stupid Sky boxes don't have an "output 1080p for HD channel and 2160p for UHD channel". If you select 2160p as your output, the box itself will do (terrible) upscaling for all 1080p channels as well. So, script required to switch to 4K can easily also switch to HDMI Bypass as it's configured as a separate input.
galonzo likes this.
peteS is offline
post #34805 of 37053 Old 01-15-2019, 01:29 AM
Drem's Avatar
Quoted: 139 Post(s)
Liked: 116
Anyone have issues with subtitles (.srt) when streaming media från pc? Sometimes I have to stop the file and play it again for the subtitle to show. Sometimes I see the text low, with a gigantic font. Turning off and on subtitle when in this mode does not help, still does not show until I restart the file. Also, in some instances the player frontpanel buttons becomes unresponsive (also remote buttons) while media is still being played normally. This seem to happen with a lot of connections at the same time (USB-hdd, Network stream, Disc in tray etc). I am running the latest official firmware.
Anyone experienced issues similar to these?
Drem is offline
post #34806 of 37053 Old 01-15-2019, 04:06 AM
Quoted: 24 Post(s)
Liked: 3
Not such issue here on the latest official firmware .srt subtitles are always loaded.
Only SUBTITLES related issue for me is I'm unable to set their vertical position so they sit exactly at the bottom of black bar without some letters (y,g,q,j,p,) lower part is cut out...
I'm using a one step bigger font than the default (which is too small for me).
blackie333 is offline
post #34807 of 37053 Old 01-15-2019, 04:41 AM
jqmn's Avatar
Quoted: 406 Post(s)
Liked: 141
I have this issue from time to time but with regular discs. Just happened with The Godfather...in a scene where they are speaking Italian and only Italian I had to stop and restart the disc to get the intended English translation of the conversation. Has happened before on other discs. Haven't seen the text low or large font issues.
jqmn is offline
post #34808 of 37053 Old 01-15-2019, 06:30 AM
LucaT's Avatar
Quoted: 123 Post(s)
Liked: 32
Thanks guys
I have already tried all those set to force the Hdr-10 but it start always in Dolby Vision
About the Black Level with the Hdmi video range on "Auto" it turn back to normal, by the way why is the correct set "limited" and not "Full"?
Shouldn't it be Full to have the complete range for hdr?
LucaT is offline
post #34809 of 37053 Old 01-15-2019, 07:08 AM
Quoted: 192 Post(s)
Liked: 291
Thanks guys
No, it's nothing to do with HDR, it stems from the broadcast world where we want to allow for over and undershoots without clipping. In 8-bit video terms, black level is defined as 16 and white level is 235, so sometimes this is called 'Limited' (64 and 940 in 10-bit video). These are the levels that are encoded on Blu-ray etc. However, if you wanted to use the TV as a PC monitor, you would need to set to 'Full', as PCs have a black level of 0 and a white level of 255.
Hence if you have a TV expecting Full and you're feeding it Limited, the black will be elevated to dark grey.
galonzo, naustin and Matt2026 like this.
post #34810 of 37053 Old 01-15-2019, 08:19 AM
robneal81's Avatar
I just saw posts elsewhere that there's a beta firmware that allows iso playback. Does anyone know if the latest Beta firmware from December 28th has this built-in? If not, can anyone point me to the older (Australian?) firmware that allows it? I'm on a REALLY old firmware, so I'll definitely be able to load whichever works.
It was such a relief to see unofficial iso support out there. I have SO MANY of my old projects archived as ISO and having to convert those files before playing on the Oppo was frustrating to say the least.
robneal81 is offline
post #34811 of 37053 Old 01-15-2019, 08:25 AM
dvzzz's Avatar
Quoted: 166 Post(s)
Liked: 61
Curious to see evidence of it, my stock 203 with v60 does not play ISO from NAS, all of my kids videos are stored as ISOs so no protected content and it still would not play.
dvzzz is offline
post #34812 of 37053 Old 01-15-2019, 08:29 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4608 Post(s)
Liked: 4443
Nothing from OPPO has that. If Australia is different, I haven't heard about it.
-Bill
galonzo likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #34813 of 37053 Old 01-15-2019, 09:14 AM
robneal81's Avatar
Well, if anything it would have been the v64 beta, but I guess that's not the case?: https://www.oppodigital.com/blu-ray-...-64-1221B.aspx
-Bill
Too bad. I have the original hack and the tools to do it, I just haven't had the time I was hoping Oppo would leak us a beta or something, seeing as they have nothing to lose - If they're not making products anymore, no one's going to waste time going after them. If I get the Australian firmware, I'll post my results.
post #34814 of 37053 Old 01-15-2019, 03:28 PM
xiaNaix's Avatar
Quoted: 39 Post(s)
Liked: 36
I'm pretty sure post you are referring to was referring to 4k UHD iso files.
xiaNaix is online now
post #34815 of 37053 Old 01-15-2019, 04:13 PM
robneal81's Avatar
Yeah, you're correct. Damn. Well, I'll post if I ever find a better solution, but the only other thing I have is the older firmware that I've heard is buggy. I guess I'll just flash it and try...then if it gives me trouble, I'll just update to the latest.
I really wish Oppo could throw us a bone on this one. Maybe open-source the firmware or something, now that the products are EOL.
post #34816 of 37053 Old 01-15-2019, 07:39 PM
rdgrimes's Avatar
Quoted: 3824 Post(s)
Liked: 3048
You're confusing Oppo and Mediatek. Oppo has no control over what Mediatek does with firmware in this regard, and MTK has every reason to continue covering their own butt.
galonzo likes this.
rdgrimes is online now
post #34817 of 37053 Old 01-16-2019, 03:28 AM
Drem's Avatar
Quoted: 139 Post(s)
Liked: 116
No info on when the latest beta will be official?
Drem is offline
post #34818 of 37053 Old 01-16-2019, 05:02 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1913 Post(s)
Liked: 2297
Oppo and the employees still working for them also have plenty of reasons to cover their butts as well. If Oppo wants to re-enter the market at some future date, it won't go well for them if they release firmware that exposes functionality that isn't allowed. Similarly, the employees might limit future employment opportunities if they do something like this.
AFAIK, there's no firmware from Oppo in any market that allows ISO support on the UDP-20x players. Any firmware that does is coming from a 3rd party and discussion of that type of firmware isn't allowed by AVS.
galonzo likes this.
gsr is online now
post #34819 of 37053 Old 01-16-2019, 07:54 AM
Super Moderator
teachsac's Avatar
Quoted: 1269 Post(s)
Liked: 2074
Discussion of custom firmware that modifies manufacturer firmware, or hacking manufacturer firmware, is not allowed and has never been. No more discussion on this topic.
mc_avs, Maddog56 and FredsElbow like this.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #34820 of 37053 Old 01-16-2019, 07:55 AM
wmcclain's Avatar
Liked: 4443
Something like the SuperDisk region free mod is a gray area. It does not modify OPPO's firmware but somehow resets the regions in the optical drive itself.
-Bill
meli likes this.
post #34821 of 37053 Old 01-16-2019, 07:58 AM
Super Moderator
teachsac's Avatar
Liked: 2074
-Bill
The superdisc was develop by oppo to meet the laws of Australia and only affects Standard DVD. I know you know this, but others might not . Let's move on from this discussion.
teachsac is offline
post #34822 of 37053 Old 01-16-2019, 08:04 AM
SeeMoreDigital's Avatar
Quoted: 992 Post(s)
Liked: 757
Hardware modifications have been around for many years and are relatively inexpensive and can be purchased from 'real' vendors.
The '3rd party' firmwares cost a small fortune and are provided by 'who knows who and where'. Personally, I find it incredible that people hand-over their credit card details to these invisible people. It's little wonder that their info ends-up on the dark web
galonzo and captainbrent like this.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 2No Audiolab 8000A, 2No Audiolab M-PWR | SPEAKERS: 4No KEF 103.2, 3No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: DS212+
SeeMoreDigital is offline
post #34823 of 37053 Old 01-16-2019, 01:24 PM
Quoted: 22 Post(s)
Liked: 8
Moving on from 3rd party firmware grandstanding...
Has anyone had issues with the revised beta firmware?
FredsElbow is offline
post #34824 of 37053 Old 01-16-2019, 04:03 PM
ph3ng's Avatar
Quoted: 85 Post(s)
Liked: 25
Originally Posted by ph3ng View Post
Thank you, everyone. Easy enough.
So I popped in the Incredibles 2 UHD and I noticed two things.
On the OPPO, there is no HDR / Dolby Vision icon. To be fair, I don't even recall if there was an icon indicator for HDR.
When I check on my TV (Sony 9400e), I also do not see any indicator saying HDR or Dolby Vision (like it normally would when using the internal Netflix app).
Have I got something wrong setup somewhere?
Thanks in advance.
ph3ng is offline
post #34825 of 37053 Old 01-16-2019, 04:07 PM
tngiloy's Avatar
Quoted: 486 Post(s)
Liked: 306
Thanks in advance.
It's possible that you have a setting or two wrong, but it's also possible that you loaded the regular Blu-ray and not the 4K UHD disc.
Neil S. Bulk and galonzo like this.
"When all else fails, read the manual."
tngiloy is offline
post #34826 of 37053 Old 01-16-2019, 05:56 PM
ph3ng's Avatar
Quoted: 85 Post(s)
Liked: 25
I'm a complete fool. I assumed that the fam would have used the first disc in the case (usually the UHD version). Upon checking - after reading your reply - they used the normal BD instead. And this was the 2nd disc in the case. LOL.
Vader424242 and galonzo like this.
ph3ng is offline
post #34827 of 37053 Old 01-16-2019, 05:59 PM
Quoted: 143 Post(s)
Liked: 115
Been there, done that, got the T-shirt... Of course, I have NEVER done that...
PhantomDriver likes this.
Peace... Vader
post #34828 of 37053 Old 01-16-2019, 07:02 PM
wmcclain's Avatar
Liked: 4443
Everyone has done it at least once. That's why we become compulsive about checking the Extended Info popup when starting the main feature. That will quickly make it clear whether you have UHD or Blu-ray or DVD.
It's like the pilot walking around the plane to make sure the wings are bolted on right side up this time.
-Bill
post #34829 of 37053 Old 01-16-2019, 08:07 PM
ph3ng's Avatar
Quoted: 85 Post(s)
Liked: 25
You all sure know how to make me feel a little less of a fool
ph3ng is offline
post #34830 of 37053 Old 01-17-2019, 06:45 AM
RagtopFE's Avatar
Quoted: 252 Post(s)
Liked: 4361
Nope...NEVER happened to me.
Spoiler!
RagtopFE is online now
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
