Official OPPO UDP-203 Owner's Thread - Page 1180 - AVS Forum | Home Theater Discussions And Reviews
 279802Likes
post #35371 of 38032 Old 02-20-2019, 08:46 AM
Quoted: 690 Post(s)
Liked: 167
Originally Posted by Philnick View Post
If you don't like the look of the grain of the film stock in older films, just don't watch older movies shot on film and stick to newer, all-digital productions.
You can always get insight into the specs and image quality of a particular Blu-ray or UHD disk by looking it up at blue-ray.com before you buy it.
There's nothing gained by "yucking the yum" of fans of older films, who want to see them the way they looked when they came out.
Agreed, it’s worth checking out the critical reviews of image/audio quality to avoid disappointment.
I mentioned ‘Mother’ as an example of how grain can be used deliberately for effect even in a very recent movie. I thought it worked really well in this case.
Whirlpool0548 is offline
post #35372 of 38032 Old 02-20-2019, 09:40 AM
Killroy's Avatar
Quoted: 669 Post(s)
Liked: 565
Originally Posted by Sound & Vision View Post
The 4K release of the original Bladerunner... These are two of the most awful 4K releases to date.. Both are heavily loaded with noise.
Re: Blade Runner, that is grain, not noise. And it looks fabulous!!!!
ppasteur, AVfile, Taxcheat and 6 others like this.
Killroy is online now
post #35373 of 38032 Old 02-20-2019, 09:46 AM
lujan's Avatar
Quoted: 4963 Post(s)
Liked: 2979
Originally Posted by Whirlpool0548 View Post
But........
Sometimes it is used for artistic/dramatic effect.....
Watch - “Mother” 4K
“this Ultra HD Blu-ray remains faithful to the director’s intentions by being muted, dark, grainy and soft. Optimum word there is grainy, which gives the film that organic, documentary feel, but some might find it distracting as it does permeate throughout the run time (unsurprisingly since the majority of the film was shot on 16mm)”
Same thing with the 4k version of "Arrival". Very dark but it was intended like that. I personally, don't like it so dark. I prefer light and crisp for 4k HDR video.
lujan
623 Ultra HD
727 HD
4 SD
lujan is online now
post #35374 of 38032 Old 02-20-2019, 11:07 AM
Quoted: 690 Post(s)
Liked: 167
HDR is so much more than light and crisp, when it's mastered well.
post #35375 of 38032 Old 02-20-2019, 11:14 AM
Liked: 5
Originally Posted by fxsavini View Post
Hi guys,
i’m new here. English isn’t my native language, so i hope you understand the following text ;-)
I’m using an Oppo 203 with the latest Firmware (20XEU-60-0625). I have a problem when playing 4K Discs with HDR. I tried my Projector and my TV (bot older models, only Full-HD, not UHD). When playing 4K Discs, there is a bright, small green line on the left side of the picture (it appears to be one pixel wide exactly). But only on 4K Discs with HDR (for example „American Made“, „Die Hard“). 4K Discs with Dolby Vision doesn’t have this problem (for example „Tomb Raider“ from Warner Brothers). Also Blu-ray’s and DVD’s are fine (so i don’t think it’s a damaged hardware).
I think it’s the same problem this guy has at post 31181 (sorry, i can't post links here).
With Firmware UDP20X-56-0224 everything was fine (that means no green line at „American Made“ and „Die Hard“).
Is there something different in the HDR-Section from last Firmware? I usually use „Off (BT.709)“ or „Off“ (BT.2020)“. But also the other settings „Auto“, „Forced“ and „Strip Metadata“ doesn’t solve the problem. After updating to the actual Firmware a couple of weeks ago, i do a „Factory Reset“.
The only solution at the moment is switching on the „Overscan“ Option on my Projector / TV.
Have anyone an explanation/solution for this „phenomenon“?
I see a new firmware UDP20X-65-0131 is out for the US model. I also see a link here in this thread to download this new firmware for the UK model. Is this really official for the UK model? I mean, nothing on oppodigital.co.uk and nothing via "Update via Internet" from the player (still says "you have the actual firmware").
Should i wait till the Firmware is official at oppodigital.co.uk? Or can i use safely the file from this thread and update via USB?
Another question: Does anyone know that this new firmware helps with my "problem" ("green line with Dolby Vision Dics", see above quote)?
Antonino Barbera likes this.
fxsavini is offline
post #35376 of 38032 Old 02-20-2019, 12:34 PM
Keenan's Avatar
Quoted: 4340 Post(s)
Liked: 4011
Originally Posted by Dr Steve View Post
Hey I just bought an Oppo 203. I was surprised to find they removed the HDMI input from the front panel (I have an Oppo 103). Can anyone recommend an HDMI switch that works automatically, when you power on a different input? Specifically for Apple TV and Firestick. Thank you
I've used the Kinivo HDMI switch in the past and I found it to be very reliable and never had any connection issues with it. It does mention an auto-sense capability though I used it with a Harmony remote and selected the input I wanted as part of the Activity so I can't speak to how well the auto-sense feature works.
Keenan is offline
post #35377 of 38032 Old 02-20-2019, 02:39 PM
Quoted: 101 Post(s)
Liked: 54
It's not just old movies. Transformers had a lot of grain.
yobbo is offline
post #35378 of 38032 Old 02-20-2019, 05:52 PM
Quoted: 269 Post(s)
Liked: 53
thank you!
Dr Steve is offline
post #35379 of 38032 Old 02-20-2019, 06:16 PM
Quoted: 107 Post(s)
Liked: 67
Originally Posted by wmcclain View Post
1995 is calling. They want their film grain complaints back.
-Bill
Lol. This is one of the last places I thought I'd see people complaining about grain. The 4k release of the original Blade Runner has been lauded as a great transfer.
Sent from my ONEPLUS A6003 using Tapatalk
AVfile, Taxcheat, galonzo and 2 others like this.
sovereignstar is offline
post #35380 of 38032 Old 02-20-2019, 07:21 PM
galonzo's Avatar
Quoted: 1449 Post(s)
Liked: 1976
Exactly, I couldn't believe what I was seeing from a 35+ year-old film when I first watched it in my Oppo
Which reminds me, I still keep my post updated that lists every single UHD disk that has played successfully from beginning to end in my 203 (in the spoiler), for those who might need to reference it if they ever come across one that gives them issues
Main: UN78HU9000/SEK-3500 | X4500H (5.1.4) | UDP-203 | TiVo Bolt | 2019 Shield | PS4 Pro | Roku P+ (4630)
2nd: UN65JS9500 | LG LAS855M | UBD-K8500 | Chromecast Ultra | TiVo Mini | Roku P+
3rd: 65P-F1 | Klipsch HDT-SB3 | UBP-X700 | Tivo Roamio | AppleTV4K
FS - Hustlers (2019) and other UHD Digital codes (and some HD codes)
galonzo is online now
post #35381 of 38032 Old 02-21-2019, 01:11 AM
hlindstr's Avatar
Quoted: 69 Post(s)
Liked: 97
Yes, it is the official one. Once the link will appear in the UK site you will notice that it links to exatcly same location. You can even compare the current Official and Public Beta download links currently alive in the UK site. They point to same share location. I guess UK/EU office is already operating at very low man-hours and publishing new firmware is not their number 1 priority at the moment. That's how it looks anyway.
galonzo likes this.
Oppo UDP-203 (60-0625) and Oppo BDP-83 both hw region modded, M9702 v3 "Chinoppo" (65-0131), Apple TV 4K 32GB, LG OLED55E6V 55", Asustor 2-Bay NAS currently 8TB
hlindstr is offline
post #35382 of 38032 Old 02-21-2019, 05:24 AM
chrisf16's Avatar
Quoted: 26 Post(s)
Liked: 35
Late last year I bought a 203 on Amazon (at a scalper's price) from an American dealer and I'm an American customer. When I go to check for the new firmware update it says I have the latest available and I see that my current firmware is labelled "20XEU-60-0625". I'm guessing that I was shadily sold a European model?
My question is, can I download the US current new firmware and update this machine to the US firmware via USB?
chrisf16 is offline
post #35383 of 38032 Old 02-21-2019, 05:37 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4742 Post(s)
Liked: 4619
Yes, that is a Euro model.
No, it won't accept it. Contact OPPO and explain the situation, see if they can help. There is a contact form on their web page.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #35384 of 38032 Old 02-21-2019, 05:40 AM
Quoted: 101 Post(s)
Liked: 54
why not just download the European firmware?
captainbrent likes this.
yobbo is offline
post #35385 of 38032 Old 02-21-2019, 06:25 AM
Liked: 7
-Bill
I know it's how the film produced it's all on the filmmaker how they shoot the film is it digital is it 35 mm or 70 mm it's a filmmaker's choice. But please don't tell me with today's equipment how far we've come with TVs projectors Blu-ray players streaming devices that you actually like a grainy picture? I'm not saying you do but I'm just wondering because like I said when you go from a really Beautiful scene to one that looks like somebody standing behind the actor throwing sand in the air and it's a little annoying. Of course that's just my view on the subject some people actually love it. and are not bothered by it I guess to each his own. oh and I'm not talking about old films you expect that and films that are 15 or 20 years old or even older
Joanvan1 is offline
post #35386 of 38032 Old 02-21-2019, 06:27 AM
Super Moderator
teachsac's Avatar
Quoted: 1327 Post(s)
Liked: 2162
This is not the area for discussing film grain. Please stick to discussion of the player. There are many threads on this topic in the software area.
gsr and jazzrock like this.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #35387 of 38032 Old 02-21-2019, 07:10 AM
Quoted: 269 Post(s)
Liked: 53
I hooked up my 203 main hdmi to my Sony TV and the audio hdmi to my Yamaha receiver. It’s only outputting stereo. I think I’ve checked everything in the settings menu, but obviously Im missing something to get five channel audio. Can anyone help here? Thank you
Dr Steve is offline
post #35388 of 38032 Old 02-21-2019, 08:22 AM
SeeMoreDigital's Avatar
Quoted: 1082 Post(s)
Liked: 908
...When I go to check for the new firmware update it says I have the latest available and I see that my current firmware is labelled "20XEU-60-0625". I'm guessing that I was shadily sold a European model?
Sadly, the newest official release of firmware version UDP20XEU-65-0131 is still not available via the OPPO UK/EU web site.
However, if you want to install the newest official release, it can be found here: http://oppofirmware.s3.amazonaws.com...EU-65-0131.zip
Cheers
galonzo and codyrocco like this.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 1No Audiolab 6000A, 3No Audiolab M-PWR | SPEAKERS: 2No KEF 103.2, 6No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: Synology DS212+
SeeMoreDigital is offline
post #35389 of 38032 Old 02-21-2019, 09:16 AM
Liked: 7
My apologies sir you are right this is not thread to be discussing this particular topic
Joanvan1 is offline
post #35390 of 38032 Old 02-21-2019, 10:02 AM
codyrocco's Avatar
Quoted: 82 Post(s)
Liked: 35
quick question: upscaling by oppo, by avr [in my case, a marantz 6010, but let's take it generally] or by tv?
codyrocco is offline
post #35391 of 38032 Old 02-21-2019, 10:28 AM
galonzo's Avatar
Liked: 1976
@codyrocco , most here use the excellent upscaling of the 203 by selecting Custom >> UHD Auto
post #35392 of 38032 Old 02-21-2019, 10:43 AM
codyrocco's Avatar
Quoted: 82 Post(s)
Liked: 35
thanks, it's the setting i'm using now - for video playback
i asked because i want to implement a solution for analogue video capture; inputs will go into avr, outputting to a hdr10 4k video capture card, but i must choose if i'll let avr do the upscaling, or insert oppo in the processing chain. your reply confirmed me what i supposed - that oppo will do a better job, even there will be extra work to move cables and so.
[seems that's all about dedicated/expensive video circuitry in AVRs...]
post #35393 of 38032 Old 02-21-2019, 10:57 AM
Liked: 0
Could anybody help me with explanation why Oppo sometimes can play internal subtitles in mkv files (uhd rips) and sometimes not? And is there any easy solution?
Sorry if the answer is somewhere here in the forum but I just could not find it. Or enywhere else. Thanks
jabbaros is offline
post #35394 of 38032 Old 02-21-2019, 11:13 AM
Quoted: 690 Post(s)
Liked: 167
‘Forced’ subtitles definitely work for BDMV folder playback for HD blu-Ray. E,g Mission Impossible Rogue Nation blu-Ray. I recently checked this for myself with this movie.
I can’t verify if the same applies for ‘forced’ subs on UHD movies, haven’t investigated this yet.
If the Oppo 203 respects the forced flag on mkv playback, you shouldn’t need to select anything, the subs should be displayed automatically. (If the mkv includes the relevant PGS subtitle stream)
You can check whether a particular movie has ‘forced’ subs via the web, there are documented lists.
Firstly, check if the original movie of one of the MKVs you are trying has ‘forced’ subs.
If the original movie has ‘forced’ subs and the Oppo 203 supports the forced flag in MKVs, the subtitles should appear automatically.
Otherwise, if the original movie has separate subtitles, you would need to select subtitles and the PGS stream for the relevant subtitles would have to have been selected for inclusion in the original mkv.
If the movie has embedded subtitles, these are merged with the video and appear automatically.
post #35395 of 38032 Old 02-21-2019, 11:28 AM
Crazytrekker's Avatar
Quoted: 118 Post(s)
Liked: 58
Cheers
How do you install this? Simply pop it on a USB and select to read from the USB via the update screen?
Crazytrekker is offline
post #35396 of 38032 Old 02-21-2019, 12:05 PM
Liked: 908
The UK/EU version of the OPPO's firmware is slightly different to the US version because the 'UDP20XEU.bin file has been placed within a .zip file. So after you've downloaded it you have to unzip/extract it in order to get to the 'UDP20XEU.bin' file.
Then transfer the 'UDP20XEU.bin' file onto the 'root' of a USB pen-drive. After a few seconds you should see an 'on-screen' prompt
Crazytrekker and galonzo like this.
post #35397 of 38032 Old 02-21-2019, 01:08 PM
Liked: 5
Thank you! Firmware-Update for the UK model via USB works fine. I tested a couple of HDR Discs (1080p, SDR conversion). Now, the „green line“ on the left side of the picture is gone. I‘m happy
fxsavini is offline
post #35398 of 38032 Old 02-21-2019, 01:20 PM
Quoted: 269 Post(s)
Liked: 53
It looks like the Oppo 203 will not pass Dolby Atmos from an Apple 4K TV to an AVR? Is that still the case? I'm browsing the thread and see that seems to be true, and I can't do it on mine.
Dr Steve is offline
post #35399 of 38032 Old 02-21-2019, 01:30 PM
ScottAvery's Avatar
Quoted: 840 Post(s)
Liked: 239
Yes, true. You can go through the AVR first and then to the Oppo, then to the display, with the audio only loop back from the Oppo to the AVR for disc audio.
ScottAvery is offline
post #35400 of 38032 Old 02-21-2019, 03:13 PM
rdgrimes's Avatar
Quoted: 3998 Post(s)
Liked: 3281
On those titles where you must rely on subs, the "easy" solution is to rip to BDMV folder. MKV subs are hit and miss, I've never seen an explanation of why that is. but it doesn't seem to matter if its HD or UHD.
giomania and codyrocco like this.
rdgrimes is online now
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
