Official OPPO UDP-203 Owner's Thread - Page 1183 - AVS Forum | Home Theater Discussions And Reviews
 278836Likes
post #35461 of 36769 Old 02-26-2019, 09:47 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5784 Post(s)
Liked: 8258
^ The 7 and 6 series LG panels are different in this regard.
--Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #35462 of 36769 Old 02-26-2019, 09:51 AM
Quoted: 614 Post(s)
Liked: 156
[QUOTE=SeeMoreDigital;57660934]I'm not aware of any 'hardware based' media player supporting the forced subs flag in any container...[/QUOTE
Yes, I wasn’t aware of the general issue with forced subs and mkv on hardware players.
I always use BDMV folders, forced subs work OK with playback via the menu.
Whirlpool0548 is offline
post #35463 of 36769 Old 02-26-2019, 10:08 AM
claw's Avatar
Quoted: 2218 Post(s)
Liked: 2072
Originally Posted by bodosom View Post
The other source of DoVi P5 is the ATV4K which, as far as I know, works with the LG x6 panels. I assumed that the output from the 203 in player-led was the same RGB encapsulated stream but it's not. As I recall I had issues with the first OPPO single stream release on my C7 but at this point both tv and player led work (I believe it was fixed by OPPO not LG).
With my B7A,
ATV Netflix sends RGB 8-bit Dolby Vision
Oppo TV led sends RGB 8-bit Dolby Vision
Oppo Player led sends 422 BT2020 12b Dolby Vision
I believe that only the LG 7 series and newer support player led Dolby Vision from the Oppo.
giomania and galonzo like this.
CJ
JVC RS500|LG B7A OLED|Denon X6400H/X4200W|Panasonic UB820|Two Oppo 203|Samsung K8500|Apple TV 4K|HDfury Diva/Vertex/Linker/Integral
claw is offline
post #35464 of 36769 Old 02-26-2019, 10:34 AM
jupiterstar's Avatar
Originally Posted by adrogoin View Post
I'm also using a Linux Samba server (net-fs/samba-4.9.3).
The first time I connect with my UDP-203 to Samba everything works fine. When I leave the share and want to connect again I'm asked for credentials and cannot login.
As a workaround I've setup a second share name pointing to the same location. If the first one doesn't work I use the second one and vice versa. Are you also experiencing this problem?
If not and if you are not using anonymous access would you be so kind to share your smb.conf?
For my testing, I used a VM without authentication. When I first got the Oppo, I did try and connect it to my Synology NAS via SMB and had the exact same problem. It would "forget" my credentials, but if I went to another share (that had the same password) and came back, it would work fine again. For my current/final configuration, I have my Oppo, a media player/NAS with a built in HD (for playing my DVD ISOs), and my LG tv on a physically separate private network that's not connected to my primary, internet-accessible network so I don't use/need authentication. It also prevents these devices from phoning home.
jupiterstar is offline
post #35465 of 36769 Old 02-26-2019, 11:11 AM
wxman's Avatar
Quoted: 5361 Post(s)
Liked: 3770
Originally Posted by Patsfan123 View Post
There is still a bug in the 0131 production firmware that causes my C6 to not work with Auto setting on DV processing. I must manually set to player-led. The beta FW did not work at all, even if I manually set to player-led manually. Oppo sent me a FW which is based on 0131 which corrects the Auto setting to work again.
That's strange. I have no issue with my E6 and 203 set to Auto. DV works just fine. E6 and C6 are basically the same tv. What is happening to your tv when 203 is set to Auto for DV?
LG 65E6P OLED - LG 65EF9500 OLED - OPPO 203 - OPPO 103D
wxman is online now
post #35466 of 36769 Old 02-26-2019, 12:04 PM
codyrocco's Avatar
Quoted: 80 Post(s)
Liked: 34
isn't necessarily a hardware problem, but software - how mkv is interpreted.
mkv _could_ have menus, forced subs, various 3d material flavors, is a versatile container. but it's the same situation as CSS - some browsers can do rendering better, some don't. for example, i'd like to see an implementation of rich text subtitle rendering in standalone players - colors, formatting, fonts. but probably will never happen.
codyrocco is offline
post #35467 of 36769 Old 02-26-2019, 01:56 PM
David Aiken's Avatar
Quoted: 815 Post(s)
Liked: 1466
Originally Posted by SkyCyberguy View Post
Is Oppo shutting down or just revamping its UK website?
It has not been accessible for more than 24 hours now...
http://www.oppodigital.co.uk/OPPO-Firmware.html
Oppo used to have a site in Australia which became inoperative some time ago. I think the site was actually maintained by Interdyn, the Australian distributors for Oppo. Interdyn made changes to their site as well but they have a general support page which lists Oppo and they are still releasing Oppo FW updates here in Australia.
It could be that something similar is happening in the UK. Check the website for whatever company was the UK distributor and you'll probably find links for Oppo FW updates there.
David Aiken is offline
post #35468 of 36769 Old 02-26-2019, 11:39 PM
hlindstr's Avatar
Quoted: 58 Post(s)
Liked: 92
Oppo UK was/is the distributor in UK and their site as mentioned hasn't been up for few days now. Direct link to FW file share (latest here) still works because it's different domain. Maybe site is just temporarily down or maybe European Oppo support is now moving to continental Europe? Just speculation on my part. I remember reading that the Europe office would be moved at some point due to wind down and possibly also Brexit. Any info about this?
Oppo UDP-203 and Oppo BDP-83 both hw region modded, Apple TV 4K 32GB, LG OLED55E6V 55", Asustor 2-Bay NAS currently 8TB
hlindstr is offline
post #35469 of 36769 Old 02-27-2019, 08:52 AM
Gwing's Avatar
Liked: 1
EU Firmware Update
Hi All
I own a 203 with firmware version 20XEU-60-0625
I see there is a firmware update
Release date: February 8, 2019
Category: Latest Official Release
Main Version: UDP20X-65-0131
Loader Version: TF0035
MCU Version: MCU203-01-1118 (UDP-203), MCU205-01-1220 (UDP-205)
I have tried the UK site and it appears to have vanished.
Will the above firmware work on a UK Oppo 203 or do I have to have an EU version.
If so where would I get it.
Gwing is offline
post #35470 of 36769 Old 02-27-2019, 09:45 AM
SeeMoreDigital's Avatar
Quoted: 967 Post(s)
Liked: 718
Hi @Gwing
I downloaded firmware version UDP20XEU-65-0131 from here: http://oppofirmware.s3.amazonaws.com...EU-65-0131.zip
Just unzip/unpack the .zip file and transfer the 'UDP20XEU.bin' file to an NTFS or FAT-32 formatted USB pen/thumb-drive (preferably no larger than 4GB). Insert the USB pen/thumb-drive into the front USB port of your Oppo. And after a few seconds you should see an 'on-screen' prompt with instructions.
Oh... And don't forget to perform the (highly) recommended 'Restore Factory Defaults' afterwards.
Cheers
galonzo and Madmax67 like this.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 2No Audiolab 8000A, 2No Audiolab M-PWR | SPEAKERS: 4No KEF 103.2, 3No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: DS212+
SeeMoreDigital is online now
post #35471 of 36769 Old 02-27-2019, 11:09 AM
Patsfan123's Avatar
Quoted: 480 Post(s)
Liked: 310
With the new "beta" 0131, auto works as it did on the prior official release. The prior public beta and official 0131 are fully distorted on auto, like when you use the player-led setting.
vavan and samv0808 like this.
LG 65C6P FW: 05.30.70 | Onkyo TX-RZ730 5.1.4 | Oppo UDP-203 | Sony UBP-X700 | Xbox One X | Chromecast Ultra | Apple TV 4K
LG 55EG9100 | LG 60PK550 | Samsung LN-S4095D | Samsung UBD‑K8500 | Philips BDP7501 | Panasonic DMP-BDT110
Patsfan123 is offline
post #35472 of 36769 Old 02-27-2019, 11:25 AM
wxman's Avatar
Liked: 3770
I have the official 0131 release and see no distortion with DV on my E6 when set to auto. I have the 203 directly connected to my E6 if that makes a difference.
wxman is online now
post #35473 of 36769 Old 02-27-2019, 12:46 PM
Wjboshart's Avatar
Quoted: 1354 Post(s)
Liked: 1325
Has anyone had playback issues of inception from the Christopher Nolan box set collection? It is the only uhd issue I've had. Basically handshake issue where everything is blue and pixelated. Resetting just the oppo doesn't work, have to reset both tv and player before it works
Wjboshart is offline
post #35474 of 36769 Old 02-27-2019, 01:26 PM
Liked: 3
That's exactly why it's working for you. I've an E6 as well and got the same issue. Using auto while connected through my AVR-X8500H causes the picture to become purple/pink and the TV doesn't switch to DV at all, switching to TV-led solves the issue. If I connect the player straight to the TV auto works.
vavan likes this.
abrasive01 is offline
post #35475 of 36769 Old 02-27-2019, 01:41 PM
Quoted: 4286 Post(s)
Liked: 5238
Maybe it's something with your AVR? It should pass the DV straight through.
galonzo likes this.
John
Sony 55A1E, A9F / LG 55OLEDC8
Marantz 7012, Ohm Walsh Speakers
Klein K10-A, Jeti 1501, Murideo Six-G Gen2
Calman Ultimate, ISF Level III Certified
jrref is offline
post #35476 of 36769 Old 02-27-2019, 02:04 PM
claw's Avatar
Liked: 2072
I found that if I switch between TV Led and Player Led DV in my Oppo, I typically have to restart both my Denon X4200W and my LG B7A. Some kind of handshaking fails with one of the devices and I get a purple/pink picture as you describe. Power restarting everything resolved it. This has occurred since Player Led option was introduced, so for me it is not related to the latest firmware.
A purple/pink picture is typically seen when DV is sent and the display can't process it.
I have not noticed anyone other than yourself post that they can get Player Led DV to work with a 6 series LG.
galonzo and Spinningbull like this.
CJ
claw is offline
post #35477 of 36769 Old 02-27-2019, 03:51 PM
chrisdack's Avatar
Quoted: 237 Post(s)
Liked: 80
Originally Posted by redsandvb View Post
I use the Android app on a Pixel 2 and SMB to see my shared drives on an old Win 8.1 miniPC. The files and folders are listed alphabetically for me. Sorry it's not much help but just thought I'd mention it.
Originally Posted by bferbrache View Post
I’ve tried the app and I have the same problem as you on my Android phone, the network movies are in a random order on my Synology NAS. The usb drive plugged in to my NAS shows up in the app with all movies in alphabetical order. I have tried the app on my iPad and there is no problem with the app, the network movies are in alphabetical order. Something is wrong with the android version of the app
Cheers
Brian
Hi
It's not random and the explanation easily explains why some people see the issue and others do not.
The sort order is physical order in the fat/Ntfs file allocation tables. Essentially unsorted.
If you copied the files from disk to disk then windows for example probably copied in alphabetical order one at a time, so that's the order you will see.
If you downloaded from a website or app, as I did for my hdtracks download, then you probably did multi thread downloading and you'll get whatever order each file started. The first few will be sequential and then after that all bets are off.
I confirmed this by redownloading an album from hdtracks straight to the Nas shared drive with single and multi thread options.
Oppo know of the issue (I emailed them way back but no reply) but I doubt they're looking at it.
Regards
Chris
chrisdack is offline
post #35478 of 36769 Old 02-27-2019, 05:46 PM
Quoted: 89 Post(s)
Liked: 33
Highly recommend going to NFS (which is easy on a Linux setup). No more login needed, defaults to read-only access (at least on my Synology) and no problems with the old SMB implementation Oppo is running.
Only downside I've encountered is that the NFS servers show up last when it's looking for servers.
tbass2k, vavan and nakkiran like this.
Rob
PT-AE8000U | LG 55C7P | Oppo UDP-203 | Onkyo TX-NR636 | JBL 5.1
robl2 is offline
post #35479 of 36769 Old 02-27-2019, 11:45 PM
Gwing's Avatar
Liked: 1
Originally Posted by SeeMoreDigital View Post
Hi @Gwing
Cheers
Many thnaks for that - Downloaded and updated just fine
galonzo likes this.
Gwing is offline
post #35480 of 36769 Old 02-28-2019, 12:02 AM
Liked: 3
I think you misread, TV-led is what's working for me. I've done factory reset of all devices and cycled power. You might not have the issue since you're on the 2017 model. If Oppo has acknowledged that there is a bug and a fixed firmware has been issued privately that resolves the problem, I don't believe we need to question whether the issue is on the Oppo side or not.
vavan likes this.
post #35481 of 36769 Old 02-28-2019, 12:54 AM
jong1's Avatar
Quoted: 505 Post(s)
Liked: 485
Confirmed here. Auto does not work on my E6 with latest release (going via a RX-A3060). TV-Led works just fine, so not a big deal, but...
galonzo likes this.
LG OLED65E6V, Yamaha RX-A3060 AVR, Oppo UDP-203 UHD Blu-ray player, Apple TV 4K, Sky Q 2TB, Chromecast Ultra
Home-built Ivy Bridge i5-3570K HTPC, 8GB RAM and Nvidia GTX1050 GPU with Plex and Jriver Media Centre,
Ruipro 15M Fiber HDMI cable, B&W FPM speakers, Logitech Harmony Ultimate intelligent remote.
jong1 is online now
post #35482 of 36769 Old 02-28-2019, 07:49 AM
claw's Avatar
Liked: 2072
Yes, I did misunderstand. So it appears Auto might be choosing Player led instead of TV led for you with your 2016 LG. And that results in the pink picture because the 6 series does not support Player led.
galonzo likes this.
CJ
claw is offline
post #35483 of 36769 Old 02-28-2019, 09:02 AM
Liked: 3
Yeah, that's the issue. Drowe me crazy before I read that it's a bug in Oppo's firmware!
post #35484 of 36769 Old 02-28-2019, 03:45 PM
Ranavalone's Avatar
Originally Posted by Gwing View Post
Hi All
The OPPO UK web site is back online - http://www.oppodigital.co.uk/
There's only one model, UDP-203(EU), which comes with both UK and mainland Europe power cords.
galonzo likes this.
Ranavalone is offline
post #35485 of 36769 Old 02-28-2019, 11:23 PM
hlindstr's Avatar
Quoted: 58 Post(s)
Liked: 92
Originally Posted by hlindstr View Post
...or maybe European Oppo support is now moving to continental Europe? Just speculation on my part. I remember reading that the Europe office would be moved at some point due to wind down and possibly also Brexit. Any info about this?
Well, it looks like they did move.
If you check "Contact us" following is shown. And phone number +49 is to Germany.
Contact us
Heimkino Klohs
Inh. Oliver Klohs
Engertstr. 8
04177 Leipzig
Germany
Phone
+49 341 4783 9885
Business Hours
Monday - Friday 9.30 - 17.30 (CET)
Returns/Repairs
If you are in the UK, please contact us at
[email protected]
before sending in your OPPO Digital product.
If you are in the EU, please contact us at
[email protected]
www.oppodigital.de also now redirects to .co.uk site.
Matt2026 and MarcelD like this.
hlindstr is offline
post #35486 of 36769 Old 03-01-2019, 05:05 AM
Quoted: 174 Post(s)
Liked: 67
I do the update via internet but I don’t make factory rest is this OK or i should do a factory reset now ?
any advice pls
A7mad78 is offline
post #35487 of 36769 Old 03-01-2019, 05:11 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4542 Post(s)
Liked: 4376
any advice pls
We recommend doing it after every update. Saving your settings to a USB stick before and restoring them after makes this painless.
-Bill
galonzo likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #35488 of 36769 Old 03-01-2019, 05:34 AM
Quoted: 174 Post(s)
Liked: 67
-Bill
Thx Bill I run again and save the seating and the factory seating done and back up
Thx
A7mad78 is offline
post #35489 of 36769 Old 03-01-2019, 07:36 AM
RickD_99's Avatar
Quoted: 279 Post(s)
Liked: 194
It seems that the latest production firmware has solved the vexing lip sync issues I was experiencing with Dolby Vision discs. Yesterday I watched the 4K DV disc Mary Queen of Scots and experienced no lip sync issues at all from start to finish. Prior to this latest update I would have to set the lip sync setting on my Nakamichi sound bar to +130 to get video and audio properly aligned.
Anyone else noticed this?
LG 55C6P OLED Display
Oppo UDP-203 UHD Blu-ray Player (65-0131 firmware)
ELAC unifi B5 Speakers
NAD C316BEE Stereo Amplifier
Nakamichi Shockwafe 9.2 Sound Bar (3.2 firmware)/Xbox One X 4K Gaming Console/Apple TV 4K
RickD_99 is offline
post #35490 of 36769 Old 03-01-2019, 08:50 AM
tidwelr1's Avatar
Quoted: 396 Post(s)
Liked: 113
Is HDR+ automatically backwards compatible with sets that are just HDR? I thought that’s what I read in the past.
tidwelr1 is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
