Official OPPO UDP-203 Owner's Thread - Page 1197 - AVS Forum | Home Theater Discussions And Reviews
 279158Likes
post #35881 of 37235 Old 04-07-2019, 01:07 PM
Coyote Waits
htwaits's Avatar
Quoted: 1332 Post(s)
Liked: 2364
Originally Posted by Bob Pariseau View Post
We here at Bob Pariseau thank you for your kind words! (Our Avatar is much bigger in real life.)
--Bob
Dear Avatar Bigger In Real Life, can you comment on my post here?
My Components:
Denon X3400H, OPPO UDP-203 & BDP-93, Xfinity XG1-P, Vizio PQ, Roku 3 & Ultra 2018
Calibration Resources:
Customer's Reports -- Professional Calibrations
Calibrator's locations and tour areas.
htwaits is offline
post #35882 of 37235 Old 04-07-2019, 01:29 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5833 Post(s)
Liked: 8309
Originally Posted by htwaits View Post
I want to add our Roku Ultra to the switch attached to our 203's HDMI IN port. The switch is 4:1 and has the OPPO 93 (for ISO), Comcast Xfinity box, and Roku 3 attached and mostly working fine (see below). The 203's firmware is the latest (UDP20X-65-0131) and the HDMI IN spec is set to 1080p. What should I set the HDMI IN spec to if I want the OPPO to upscale everything below 2160p.
One additional issue is that the Roku 3 started distorting the correct aspect ratio probably after I upgraded the firmware. Is that a problem that I should check with OPPO support about? The Roku Ultra is working fine, including aspect ratios. It is directly connected to our 4k AVR. The TV is HDR and DV capable (Visio PQ).
The HDMI Input spec simply dumbs down that input so older source devices don’t get confused with newer HDMI complications. To get lower res input upscaled to 4K output, set the video output resolution of the player as normal. For example Custom > UHD Auto.
For your Aspect Ratio problem, check that you have the OPPO set to TV Aspect Ratio 16:9 Wide / Auto. If that doesn’t fix it, check with OPPO, but odds are the Roku is putting out something strange, like an off by one resolution.
—Bob
galonzo likes this.
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #35883 of 37235 Old 04-07-2019, 02:01 PM
Coyote Waits
htwaits's Avatar
Liked: 2364
—Bob
Thanks for the help. I think that it's a good bet that the Roku 3 is putting out an offset resolution. The best solution for me is to get the Roku Ultra working through HDMI IN and dump the Roku 3.
My Components:
htwaits is offline
post #35884 of 37235 Old 04-07-2019, 03:24 PM
Coyote Waits
htwaits's Avatar
Liked: 2364
—Bob
I checked the OPPO settings and they were already set to TV Aspect Ratio 16:9 Wide / Auto. But it seems that Roku has fixed the Roku 3 because it's working the way it used to.
I'll be adding the Roku Ultra to HDMI IN later and will keep your suggestions in mind. Thanks very much.
My Components:
htwaits is offline
post #35885 of 37235 Old 04-07-2019, 04:47 PM
yanksno1's Avatar
Quoted: 50 Post(s)
Originally Posted by gymnos View Post
Choose Dolby Vision with TV-led option in the menu.
Where, on the TV or disc? Didn't see anything on the disc (just saw Play Movie, Scene Selection, Audio Settings, and Subtitles), and on my LG OLED55C6P I don't see an option to manually switch it. It def looks like it's not in DV though, as switching between picture settings it's what I normally see normal mode. I did switch out the cable for a new one, that didn't help either. Switched it on every input of my receiver and all displayed it there. Haven't tried hooking it up directly to the TV yet, need a longer HDMI cable to do that. It can't be the disc right (something messed up on the HDMI handshake there)? I'm about ready to return it and try again.
SinGA likes this.
yanksno1 is offline
post #35886 of 37235 Old 04-07-2019, 04:59 PM
bguzman's Avatar
Quoted: 141 Post(s)
Liked: 855
In the Dolby Vision section of the Oppo’s setup menu.
jimbo88, galonzo and Madmax67 like this.
HT TCL 55P605, Mitsubishi HC6500, Oppo UDP-203, Panasonic LX1000, Firestick 4K, ATV4K, Onkyo TX-NR787, DefTech, Klipsch, Martin Logan, SVS @ 5.2.4 Atmos
Stereo Sansui SR-4050, Dual 1219, Oppo UDP 203, Emotiva PT-100, Be One Audio MA100, Polk Monitor 10, SVS SB1000
bguzman is offline
post #35887 of 37235 Old 04-07-2019, 08:22 PM
yanksno1's Avatar
Quoted: 50 Post(s)
That was it! Thank you so much!!! Should I leave that set always or just when I want to watch this (or others giving me this issue) disc?
jimbo88 and gymnos like this.
yanksno1 is offline
post #35888 of 37235 Old 04-07-2019, 08:32 PM
bguzman's Avatar
Quoted: 141 Post(s)
Liked: 855
I just leave it that way myself. I see little reason to switch back and forth. Something happened with the recent update that doesn’t allow “Auto” to work properly.
bguzman is offline
post #35889 of 37235 Old 04-08-2019, 03:13 AM
PRO-630HD's Avatar
Quoted: 316 Post(s)
Liked: 207
I have a question specific to this player! Has anyone had any issues with "The Grinch" 4K disc loading? I have an Oppo 203 and a cheap Sanyo BP-807 UHD player and I have gone through two copies of this disc with both failing to load or taking at least 10 attempts to do so. In the past a simple exchange always fixed the problem. I am thinking that Universal must have made a bad lot of discs, but there have been a few titles that required a FW upgrade to play on the 203. I exchanged the disc from the same purchasing store. The Oppo states "Unknown Disc", while the Sanyo states "Disc not Supported." Just curious if anyone else was having these issues?
PRO-630HD is offline
post #35890 of 37235 Old 04-08-2019, 04:19 AM
towerboy's Avatar
Quoted: 21 Post(s)
Liked: 25
Originally Posted by PRO-630HD View Post
Has anyone had any issues with "The Grinch" 4K disc loading? not Supported." Just curious if anyone else was having these issues?
Just tried it. It loaded quickly and played without any issues.
towerboy is online now
post #35891 of 37235 Old 04-08-2019, 07:43 AM
hernanu's Avatar
Quoted: 1279 Post(s)
Liked: 2121
Same here. No problems.
hernanu is online now
post #35892 of 37235 Old 04-08-2019, 08:49 AM
Read the FAQ!
Liked: 8309
Check you have the latest firmware installed in the OPPO. In Setup > Device Setup > Firmware Information, the Main firmware version number should end "65-0131".
If you have not already done a Reset Factory Defaults in the player after installing that firmware, do that now, and then turn the player off and on again. You can speed this up by saving your settings to a USB stick for reload after the Reset and power cycle. See Setup > Device Settings > Settings Management.
If these steps do not cure the problem, and given you've already tried a replacement, odds are you have a disc from a "bad batch". I've not seen reports on-line about this title, but if a store gets a delivery from a bad batch, it is pretty common a replacement disc will also be from that batch.
Your options in that case are to get in touch with the Studio (customer service can usually be found on line) about an exchange from them and/or to get in touch with OPPO Tech Support, which can check if they already have history on this disc. If they don't, they may ask you to send them the disc so they can find out what's bad about it, and help you get a known working disc copy.
--Bob
post #35893 of 37235 Old 04-08-2019, 12:23 PM
Quoted: 96 Post(s)
Liked: 60
So just put in my brand new Aquaman 4K disc and the picture was all messed up. Not happening on any other 4K discs, so think it's specific to the Aquaman disc. Anyone have any idea what's going on? Since it's not the other 4K discs, is it the player? I did update it to the newest firmware. Attached a pic, hopefully you guys can help.
I had this same problem with Aquaman. The only way I could get Dolby Vision to work again was to do a full factory reset. Once the handshake was messed up, none of my other DV discs would work, they were all "messed up" like what you saw, ie, TV was not flipping into DV mode, but Oppo was sending DV.
I never had this problem until the latest ( Feb 19 ) update on the 203. Since applying this update, its happened about 3 times. Each time, I have to completely reset the 203.
Changing the DV settings in the Oppo did not change or fix anything.
yanksno1 and gymnos like this.
SinGA is offline
post #35894 of 37235 Old 04-08-2019, 12:33 PM
Quoted: 96 Post(s)
Liked: 60
Agreed. Glad I'm not the only one experiencing this problem!
SinGA is offline
post #35895 of 37235 Old 04-08-2019, 03:21 PM
mc_avs's Avatar
Quoted: 303 Post(s)
Liked: 308
Which is better, Player Led or TV Led Dolby Vision?
Lounge - Sony 65" A8F OLED, Pioneer SC-LX59 9.2 Receiver, Oppo UDP-203 UHD Blu-Ray Player, JBL Studio 180 Speaker Series, ELAC Debut A4 Atmos Modules setup as 5.1.4, Sony PS4 Pro, Logitech Harmony Elite. Bedroom - Samsung UA55C8000 3D LED, Sony PS3.
mc_avs is offline
post #35896 of 37235 Old 04-08-2019, 04:09 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4642 Post(s)
Liked: 4491
We hope they are identical. How many Dolby Visions does the world need?
-Bill
yanksno1 and mc_avs like this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #35897 of 37235 Old 04-08-2019, 05:02 PM
mc_avs's Avatar
Quoted: 303 Post(s)
Liked: 308
-Bill
Hahaha so do I but have noticed some people going with Player Led & some TV Led??
mc_avs is offline
post #35898 of 37235 Old 04-08-2019, 05:12 PM
wmcclain's Avatar
Liked: 4491
Originally TV-led was the standard and the only version available. Player-led was added for Sony, which could not be bothered to make DV-compliant displays. Later TVs appeared that accepted both types.
Only Dolby knows the difference. They provide the code and nothing can be done with DV except by their permission.
-Bill
galonzo, codyrocco and mc_avs like this.
post #35899 of 37235 Old 04-08-2019, 05:25 PM
mc_avs's Avatar
Quoted: 303 Post(s)
Liked: 308
-Bill
I have an A8F, do recommend leaving it to Player Led?
mc_avs is offline
post #35900 of 37235 Old 04-08-2019, 05:41 PM
wmcclain's Avatar
Liked: 4491
-Bill
bluemoon737 likes this.
post #35901 of 37235 Old 04-08-2019, 05:58 PM
mc_avs's Avatar
Quoted: 303 Post(s)
Liked: 308
Wink
-Bill
Thanks for your reply, I will leave it to TV Led
mc_avs is offline
post #35902 of 37235 Old 04-08-2019, 06:48 PM
cmdrdredd's Avatar
Quoted: 4254 Post(s)
Liked: 4545
Originally Posted by b0rnarian View Post
Awesome. Slightly different question, since there's two layers, does the Oppo allow you to switch between DV and the HDR10 or its DV layer only (when there is one). And I hear HDR10+ is also coming to the player soon?
It defaults to DV if your tv supports it. You can force HDr10 though if you wanted to. HDR10+ is already available on the 203 with the latest firmware.
galonzo and gymnos like this.
LG 65" B7A OLED, Samsung 55" JS9000, Sony 43" x800e, Denon AVR-X2200w 5.1.2, PS4 Pro, Nintendo Switch, Gaming PC(GTX 1080ti + 4.7Ghz 8700k), Sony UBP-x800, Philips BDP-7501, Oppo BDP-203, Nvidia Shield TV
2x Elac F5/Elac C5/2x AR PS2052/2x Pioneer SP-T22A-LR/Power Sound Audio 15v w/ Anti-Mode 8033S-II
cmdrdredd is offline
post #35903 of 37235 Old 04-08-2019, 06:50 PM
cmdrdredd's Avatar
Liked: 4545
Originally Posted by tjenkins95 View Post
A few pages back people were talking about how the OPPO can read BDMV folders. I bought a Synology NAS and I am in the process of ripping my blu-ray discs to ISO file backups. Is there a software product that will convert my ISO files to BDMV folders? I have software to burn ISO to MKV but I like the idea of the BDMV folder since the folder keeps all the previews and special features.
Ray
Use make mkv and do a disc backup to a folder. ISO does not work
post #35904 of 37235 Old 04-08-2019, 07:17 PM
mutelight's Avatar
Quoted: 2244 Post(s)
Liked: 2530
Not trying to be a jerk but we covered this in numerous other posts after the one you quoted and it was meandering into the realm of the topic for another thread but yes, you are absolutely right, ISOs will not work with the Oppo 203.
galonzo likes this.
mutelight is offline
post #35905 of 37235 Old 04-08-2019, 08:52 PM
PRO-630HD's Avatar
Quoted: 316 Post(s)
Liked: 207
--Bob
Thank you for the advise and I will try these! I have the latest FW but did not do a factory reset. I did take my disc into Best Buy today just to see if it would load in any of their players. Sure enough it loaded fine in their Panasonic DP-UB820 hooked up to a 75 Samsung. I had the employee load it twice to make sure. Both times it started up without a hitch. Now I am thinking Oppo may need a FW upgrade to play this disc. Why others are not having an issue I don't know. This is the 2nd disc I have tried.
post #35906 of 37235 Old 04-09-2019, 02:45 AM
Quoted: 52 Post(s)
Liked: 5
I have an Australian 203 and had the same issue with it not loading. I hadn’t updated to the new version but once I did it played perfectly, upgrade firmware and your good to go plus do a factory reset
johnnyboy632 is offline
post #35907 of 37235 Old 04-09-2019, 10:44 PM
Dave-T's Avatar
Quoted: 1169 Post(s)
Liked: 566
I just watched The Grinch yesterday with my son and the disc played fine. I have the latest Firmware on my oppo203 and I have a LG E6 with the latest firmware as well.
galonzo likes this.
Dave-T is offline
post #35908 of 37235 Old 04-10-2019, 07:56 AM
Sound & Vision's Avatar
Quoted: 473 Post(s)
Liked: 286
Yes, absolutely..... There are some bugs with the latest update for sure.. I would imagine Oppo is working on a fix.. I hope all goes well an update gets released soon (as opposed to three months) as I have a new HDR TV.. Besides that, WoW, Still an Amazing picture from this player.. Amazing..... 🙂
jimbo88, Mike_WI, gymnos and 2 others like this.
Sound & Vision is offline
post #35909 of 37235 Old 04-10-2019, 12:45 PM
scottdfay's Avatar
Quoted: 67 Post(s)
Speaking of bugs. I've been watching Game of Thrones on Blu-ray discs the last couple weeks. Twice now I have left one of the discs in the player when shutting it down since I still had an episode left to watch on it. When I powered up the next night, playback starts and all of a sudden the player kicks into DV mode. Happened 2 times with 2 different discs. If I do an eject and then start the disc fresh, it does not go into DV mode. This has never happened before, but to be fair, up to this point I have never left a disc in the player when shutting down. This is with the latest firmware and I did a factory reset afterward. Anyone else have this happen?
As a side note, while the picture looks sharper in DV, it's unwatchable to me because it adds the dreaded soap opera effect.
Main system (7.2): Krell Foundation 4K, Bryston 4BSST2, Bryston 9BST, Oppo UDP-203, Magneplanar 1.7i (mains), Martin Logan Motion 30 (center), Definitive Technology ProMonitor 1000 (sides), Klipsch R-14S (rears), HSU ULS-15-MK2 (dual subs), AC Infinity T8 and S8 fans, Bryston BIT15 power conditioner. LG OLED65B7A. Martin Logan Motion Vision soundbar.
scottdfay is offline
post #35910 of 37235 Old 04-10-2019, 01:40 PM
wl1
wl1's Avatar
Quoted: 440 Post(s)
Liked: 396
Your display will have a completely different set of parameters specific to the signal it is receiving, ie. I suspect it is your display that needs setting up.
Play actual DV content, ensure your display is in that DV mode, and then Disable the Motion parameters causing the SOE in your display.
These settings will stick for DV content for that input.
The same is true for HDR being displayed - a different set of parameters per input per signal received.
Ken Kreisel Twin DXD808, Q125 LCR, x4 Q125 TriFX, x4 QFH - for Atmos 7.2.4/Auro 9.2/DTS:X 11.2
Oppo 93 & 203 & Sony VPLHW55ES PJ with Lumagen 2020, 2.35:1 Seymour AT XD screen. Logitech Ultimate One & Hub, SqBox Touch & Philips Hue. Nakamichi AVP1 with Denon X7200WA. With MiniDSP 2x4.
wl1 is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
