Official OPPO UDP-203 Owner's Thread - Page 1199 - AVS Forum | Home Theater Discussions And Reviews
 278828Likes
post #35941 of 36750 Old 04-14-2019, 01:39 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4539 Post(s)
Liked: 4369
Originally Posted by Jesshakti View Post
Hello all. I recently acquired an Oppo 203. This morning I plugged an Apple TV 4K into the HDMI input and it worked fine. Later I tried to plug a Firestick into the input_ now it won't display the Firestick, or the Apple TV. I ve tried a different HDMI high speed cable, tried rebooting everything in the chain. Nothing displays from the HDMI input though the rest of the unit works fine. Any help from anyone would be greatly appreciated!
There are four choices under Setup -> Device Setup -> HDMI IN Specs. Do you get anything by varying that?
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #35942 of 36750 Old 04-14-2019, 03:14 PM
Quoted: 269 Post(s)
Liked: 53
-Bill
Hmm, I don’t have an HDMI IN specs option. The last firmware update looks like me 2017. I generally avoid updates when things are working ok. I see there are a lot of complaints about updates on this thread. Does anyone know when the last unproblematic update was? Perhaps I could install that?
Dr Steve is offline
post #35943 of 36750 Old 04-14-2019, 03:33 PM
Quoted: 71 Post(s)
-Bill
I just unplugged everything and tried again and it's working now. Thanks for your help. So still I would ask , since there some complaints about updates on this thread. Does anyone know when the last stable update was? Perhaps I could install that from a USB stick?
Jesshakti is offline
post #35944 of 36750 Old 04-14-2019, 04:09 PM
Quoted: 82 Post(s)
Liked: 56
Is this a troll? Who has been complaining about problems with firmware in this thread?
LG OLED E8
Oppo UDP-203
Samsung HW-N950
sovereignstar is offline
post #35945 of 36750 Old 04-14-2019, 04:32 PM
Quoted: 71 Post(s)
John Archer at Forbes https://www.forbes.com/sites/johnarc.../#304a6fbf4219
I See a number of people mentioned bugs in updates on 4/11, 4/10,2/18 etc . So was there an update at some point that no one had an problems with? Updates often cause issues for some people.
post #35946 of 36750 Old 04-14-2019, 04:33 PM
Quoted: 71 Post(s)
Those dates I quoted were in this thread- I only went back a couple months, there were a lot more listed. Type in "update" in the search function.
vavan likes this.
post #35947 of 36750 Old 04-14-2019, 07:29 PM
rdgrimes's Avatar
Quoted: 3773 Post(s)
Liked: 2973
The latest official update is the only one you should be using. That linked article is WAY too old to be relevant in any way. Please update your player. https://www.oppodigital.com/blu-ray-...e-65-0131.aspx
tngiloy, bguzman, galonzo and 5 others like this.
rdgrimes is offline
post #35948 of 36750 Old 04-15-2019, 04:31 AM
Liked: 2
Digital to analog conversion from HDMI in?
Hi all,
I’m struggling to pass the audio from a TV through the Oppo-203 and over to an amplifier.
As my amplifier is analog only, the Oppo is connected through analog connectors.
Every source played directly from within the Oppo to the amplifier works fine. However, I have connected a Samsung Q9F TV to the Oppo with an HDMI from the Samsungs ARC HDMI-connection - to the HDMI input on the Oppo. I have not succeeded in passing the audio signal from the TV to the amplifier.
Is this even possible?
I’m grateful for any ideas!
Harald Hasner is offline
post #35949 of 36750 Old 04-15-2019, 04:37 AM
wmcclain's Avatar
Liked: 4369
Originally Posted by Harald Hasner View Post
Hi all,
Welcome to AVSForum.
Have you selected the "HDMI ARC" option with the Input button?
-Bill
wmcclain is offline
post #35950 of 36750 Old 04-15-2019, 07:24 AM
SeeMoreDigital's Avatar
Quoted: 966 Post(s)
Liked: 716
Hi all,
I can assure you that what you want to do is possible, as I do it all the time
As Bill has already mentioned, you need to select your OPPO's "HDMI ARC" option via the remote control. And you'll need to make sure your Samsung TV's CEC (Anynet+) option is enabled too.
Also (and this is very important) you need to make sure that the HDMI lead between your TV and OPPO supports ARC (not all do) and is connected your TV's dedicated HDMI ARC port, which is usually port #2 . And that your TV's 'audio output' options are set to 'Auto'...
Cheers
galonzo likes this.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 2No Audiolab 8000A, 2No Audiolab M-PWR | SPEAKERS: 4No KEF 103.2, 3No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: DS212+
SeeMoreDigital is offline
post #35951 of 36750 Old 04-15-2019, 08:23 AM
Liked: 2
Fantastic! Thank you, both Bill and "SeeMoreDigital" - it now works!
I do however only get stereo, and I have tried changing under setup for both the tv and Oppo - without getting any wiser.
Please see the attached picture (sorry, blurry...) - do you know how to get some kind of "surround"?
post #35952 of 36750 Old 04-15-2019, 08:43 AM
Quoted: 966 Post(s)
Liked: 716
First things first... Are you 100% sure that the content you've tried playing from your TV is actually in 'surround sound'?
And as mentioned in my previous post, you need to make sure that (all) your TV's 'audio output' options are set to 'Auto'... If they are set to PCM your AVR will only receive a 2 channel PCM signal.
galonzo likes this.
post #35953 of 36750 Old 04-15-2019, 10:46 AM
chrisdack's Avatar
Quoted: 237 Post(s)
Liked: 80
Hi all,
-Bill
Hello Harald
Did you mean to say you connected TV to the oppo input. I'd have thought you meant to connect the the oppo hdmi out and then enable the arc function
chrisdack is offline
post #35954 of 36750 Old 04-15-2019, 10:48 AM
Liked: 2
Everything's working properly now! I actually had the setup straight, but when previewing media on Netflix they were only presented in stereo. When duly selected they all play multi-channel.
Thank you!
SeeMoreDigital and Matt2026 like this.
post #35955 of 36750 Old 04-15-2019, 11:44 AM
Quoted: 270 Post(s)
Liked: 189
Under Device Setup, you have to scroll down to find the HDMI IN Specs choice. It is right after Power On Input and before Front Panel Brightness.
Edit: The four choices are:
1080p
UHD 24Hz
UHD
UHD HDR
Hope this helps.
Spoiler!
RetiredandLovingIt is online now
post #35956 of 36750 Old 04-15-2019, 05:07 PM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5783 Post(s)
Liked: 8256
Don't be scared off by that outdated article you spotted. Install the latest Official firmware in your 203, and then do a Reset Factory Defaults after the install, followed by turning the player Off and back On again. Then re-establish your personal settings choices.
Follow the instructions on OPPO's Support page for the firmware here:
If your current firmware is ancient, as appears to be the case, please take careful note of Item 2 in the "Special Notice" section:
"For players with firmware version 42-0329 or earlier, please install the UDP20X-45-0605 firmware first. You will then be able to upgrade from version 45-0605 to the latest version, 65-0131."
--Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is offline
post #35957 of 36750 Old 04-15-2019, 06:09 PM
Quoted: 269 Post(s)
Liked: 53
Originally Posted by mutelight View Post
They can either watch the HDR10 base layer but if they want to retain Dolby Vision, they have to put it in a MP4 container which results in lossy audio due to container restrictions.
If you get an Oppo you don't have to worry about any of it. Just do a full backup.
May I please ask a question about full back ups? I assume people are referring here to a BMVD folder made with MakeMKV? There are so many files in there when you do that, some are only jpegs, HOW do you get the Oppo 203 to play this as a movie with menus, lossless audio, etc? thanks for your help!
Dr Steve is offline
post #35958 of 36750 Old 04-15-2019, 06:12 PM
Quoted: 269 Post(s)
Liked: 53
--Bob
Thank you, Bob. I always appreciate your thoughtful input. It wasn't just the one article, but several mentions in this and other AV threads about a few people having various problems with updates on the Oppo. (On a different note, a recent Apple TV update caused a number of people to lose DV support. Updates scare me.) Oppo support very kindly and patiently explained to me each case I sent them of why people had problems, mostly HDMI cabling (no surprise- the Usual Suspect). What terrific tech support, and what a great product! So sad to be losing it.
Dr Steve is offline
post #35959 of 36750 Old 04-15-2019, 06:30 PM
mutelight's Avatar
Quoted: 2173 Post(s)
Liked: 2460
It was requested that discussion around backups were taken to the appropriate thread but I would refer to wmcclain's excellent FAQ.
Follow those steps and you just select the AVCHD folder and it starts like a disc.
mutelight is offline
post #35960 of 36750 Old 04-15-2019, 11:44 PM
Quoted: 269 Post(s)
Liked: 53
Thank you!
Dr Steve is offline
post #35961 of 36750 Old 04-16-2019, 12:14 AM
Jim Parys's Avatar
Quoted: 90 Post(s)
Liked: 49
Tonight out of nowhere my oppo 203 stops working. Getting unknown disc message on every disc. Any tricks to fix this that anyone knows? Very upsetting as it just went past 2 years now and never had a problem till now.
Jim Parys is Living the dream...
La Sirena III Theater
Jim Parys is offline
post #35962 of 36750 Old 04-16-2019, 02:07 AM
Quoted: 51 Post(s)
Liked: 5
Have you updated to latest firmware? I had issues with grinch 2019, updated to latest and works perfectly now. Give it a try
johnnyboy632 is offline
post #35963 of 36750 Old 04-16-2019, 03:13 AM
DanBa's Avatar
Quoted: 274 Post(s)
Liked: 897
Some results from the upcoming disc "Spears & Munsil UHD HDR Benchmark"
https://forum.blu-ray.com/showthread...6#post16300966
giomania and KC-Technerd like this.
Universal audio/video receiver (Dolby Atmos, DTS:X, etc.) is achieved.
Universal HDR TV (HDR10, Dolby Vision, HEVC HLG HDR, VP9-HLG / VP9-PQ YouTube HDR, Dynamic HDR) is required.
Push for universal HDR TV!
DanBa is offline
post #35964 of 36750 Old 04-16-2019, 04:23 AM
chi_guy50's Avatar
Quoted: 2167 Post(s)
Liked: 2188
Is there any scuttlebutt regarding a release date?
Living Room: Sony XBR-65Z9D; Oppo UDP-203; Nvidia Shield TV; Roku Ultra; Denon AVR-X8500H (9.1.4/13.1); Polk Audio RTiA7 (Fl/r), CSiA6 (C), RTiA5 (Sl/r & FW), OWM5 (SB), 80F/X-RT (FH, RH); SVS SB-2000 (SW)
Bedroom: Sony XBR-55HX929, DarbeeVision DVP 5000S, Amazon Fire TV 4K, Yamaha R-N402 Network Receiver, Polk Audio LSiM703
chi_guy50 is offline
post #35965 of 36750 Old 04-16-2019, 04:24 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 5931
Not surprised that the Sony and Panny just "pass". Sony has been good about accuracy for many years.
XBR65A9G / XBR65A8F
Oppo UDP-203 / Sony X800M2
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is offline
post #35966 of 36750 Old 04-16-2019, 04:33 AM
DanBa's Avatar
Quoted: 274 Post(s)
Liked: 897
"Hopefully its out in May." [Stacey Spears]
https://forum.blu-ray.com/showthread...8#post16222578
chi_guy50 likes this.
DanBa is offline
post #35967 of 36750 Old 04-16-2019, 05:51 AM
Quoted: 269 Post(s)
Liked: 53
Originally Posted by Sound & Vision View Post
DV restricts zoom from within the disc authoring. So far, the newer LG OLEDS seem to zoom via its own built in TV zoom function. Otherwise, you can set the 203 to 21:9 and then 16:9 content will zoom full screen via the 203's zoom button but with a slight vertical stretch.. Its a workaround... not perfect but works.
Could someone tell me if the zoom function on the Oppo is disabled for Dolby Vision content coming through the HDMI port, e.g. from an Apple TV or Firestick? Thank you.
Dr Steve is offline
post #35968 of 36750 Old 04-16-2019, 06:33 AM
Read the FAQ!
Liked: 8256
Zoom (and all other video processing) has to be disabled when the player is playing Dolby Vision content.
Simply put, the magic parts of Dolby Vision won't survive "normal" video processing. (To the video processor, Dolby Vision looks like a stream of traditional, simple, 8-bit, RGB video. But in reality it is no such thing.) A display, on the other hand, can (within limits) process the video because the magic has already been used by that point.
In the case of content coming in on the HDMI Input, to get Dolby Vision to pass through at all you must select the new HDMI Input Bypass choice in the OPPO's Input menu pop-up -- what comes up when you press the Input button. As you might expect, that bypasses ALL video processing in the player. The HDMI Input hardware in the player is actually quite difficult to configure to "do nothing", which is why OPPO had to resort to this bigger hammer.
--Bob
galonzo likes this.
post #35969 of 36750 Old 04-16-2019, 08:15 AM
Cortiz's Avatar
Quoted: 125 Post(s)
Liked: 98
Anyone knows what this Chroma alignment issue means? Hard to believe Oppo has processing issues when they have always been perfect.
KC-Technerd likes this.
Cortiz is offline
post #35970 of 36750 Old 04-16-2019, 08:19 AM
Wjboshart's Avatar
Quoted: 1354 Post(s)
Liked: 1325
I think this is so very minor of a thing that unless you have the oppo running on one tv and a Panasonic running on the same tv next to it would you maybe see a difference. It by itself you most likely wouldn't know that it's not aligned because it's probably a real small decimal difference
galonzo likes this.
Wjboshart is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
