Official OPPO UDP-203 Owner's Thread - Page 1210 - AVS Forum | Home Theater Discussions And Reviews
 278655Likes
post #36271 of 36533 Old 05-18-2019, 11:44 AM
chi_guy50's Avatar
Quoted: 2141 Post(s)
Liked: 2135
Originally Posted by AVfile View Post
Is there a region free kit that does automatic blu-ray region switching (i.e. no 5-key remote sequence required to manually switch region) ?
Originally Posted by steverobertsbbc View Post
There's no automatic region switching for any Blu-ray player, as far as I'm aware.
I have a multi-region Sony BDP-S5200 that I have had for years and kept around for just this purpose. It can play any DVD or Blu-ray disc automatically with at most "one-button" selection.
If interested, you can find this particular seller's Amazon storefront here.
AVfile likes this.
Living Room: Sony XBR-65Z9D; Oppo UDP-203; Nvidia Shield TV; Roku Ultra; Denon AVR-X8500H (9.1.4/13.1); Polk Audio RTiA7 (Fl/r), CSiA6 (C), RTiA5 (Sl/r & FW), OWM5 (SB), 80F/X-RT (FH, RH); SVS SB-2000 (SW)
Bedroom: Sony XBR-55HX929, DarbeeVision DVP 5000S, Amazon Fire TV 4K, Yamaha R-N402 Network Receiver, Polk Audio LSiM703
chi_guy50 is offline
post #36272 of 36533 Old 05-18-2019, 12:52 PM
Keenan's Avatar
Quoted: 3753 Post(s)
Liked: 3443
If you have a programmable remote like a Harmony you can program a sequence to do all the button pressing required to switch regions. I've done it and it actually works but it took a bit of fiddling with delays to get it right. It was more of a "see if I can do it" exercise rather than actually needing it.
AVfile likes this.
Keenan is online now
post #36273 of 36533 Old 05-18-2019, 03:56 PM
Crazytrekker's Avatar
Quoted: 101 Post(s)
Liked: 58
I did this and it works like dream. You just need one longer pause in the sequence between switch off and switch on again, I think I did 14 seconds which is the precise time it takes. You need to keep the harmony pointed at the player throughout, but so much easier.
I programmed a Zone A and Zone B sequence.
AVfile and Keenan like this.
Crazytrekker is offline
post #36274 of 36533 Old 05-18-2019, 03:58 PM
Keenan's Avatar
Liked: 3443
I use a Harmony Hub along with my 950 so all I need to do is press the button and the Hub takes over, no need to point the remote anywhere.
Crazytrekker and stikle like this.
post #36275 of 36533 Old 05-19-2019, 12:47 AM
Quoted: 191 Post(s)
Liked: 281
If you have to use a button to select it, it's not automatic then, is it?
Edit: Oh, sorry, misunderstand your point I think - I think you're saying that to avoid the complexity of region changing on the Oppo, you use the Sony instead?
Panasonic TX-55EZ952B OLED / Oppo UDP-203 / Onkyo TX-NR555 / B&W 600 Series + Elac A4 Atmos
steverobertsbbc is online now
post #36276 of 36533 Old 05-19-2019, 04:39 AM
chi_guy50's Avatar
Liked: 2135
It's as automatic as selecting "Play" to start playback.
Correct.
AVfile likes this.
post #36277 of 36533 Old 05-20-2019, 06:44 AM
AVfile's Avatar
Quoted: 346 Post(s)
Liked: 174
I have a multi-region Sony ...
Thanks, I had forgotten about those Sonys!
I‘ll probably get a 3700 which will come in handy since the 203 doesn’t have Internet apps, and the cheap 3100 in my bedroom system is dying.
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
post #36278 of 36533 Old 05-20-2019, 06:49 AM
AVfile's Avatar
Quoted: 346 Post(s)
Liked: 174
I could do the remote programming too, if I really wanted to mod the Oppo, but I don’t need it to be my only player. Now that they’re not making any more Oppos I’m leaning towards not putting any unnecessary hours on it. Considering the price of some of those mod kits, I was hoping one would truly be “region free” as opposed to “multi region” (selectable).
Thank you, all.
Stefan
AVfile is offline
post #36279 of 36533 Old 05-20-2019, 09:23 AM
chi_guy50's Avatar
Liked: 2135
YMMV, but for app performance and overall functionality, nothing beats a dedicated media streamer. Unless your sole focus is on reducing the number of devices and complexity of your A/V set-up, you will probably be better served getting something like an Amazon Fire TV Stick 4K, Roku Ultra, Nvidia Shield TV, or similar device for your video streaming needs despite the inherent redundancy.
post #36280 of 36533 Old 05-20-2019, 01:37 PM
Quoted: 163 Post(s)
Liked: 88
I'm finally considering getting rid of my UDP-203 and replacing it with a Panasonic UB820.
The primary function of my 203 now is to do tone mapping for UHD Blu-ray and for Apple TV. The problem obviously is that Oppo never fixed the tone mapping. And since they won't commit one way or another, or at least tapping out and saying "we're done here with these updates", then it really seems it may never get fixed.
So now I'm considering tossing the 203 and just using the UB820 to tone map discs, and route the Apple TV directly to my projector (since Panasonic doesn't have an hdmi input).
Are there any other reasons I should be sticking with the 203? It seems for my use it's pretty much dead?
For anyone who has made the switch, is the BT2020 color differences noticeably better with the UB820?
weboperations is online now
post #36281 of 36533 Old 05-20-2019, 05:26 PM
rightintel's Avatar
Quoted: 905 Post(s)
Liked: 350
For some reason only when using my 203 I always have to turn the volume way up on my TV(no surround sound). Is there a setting in audio that I'm missing causing this?
Xbox Live: General PATT0N
rightintel is offline
post #36282 of 36533 Old 05-21-2019, 02:41 AM
hlindstr's Avatar
Quoted: 58 Post(s)
Liked: 92
I wonder why region switching had to be changed so complex. I have Oppo 83 and hw region mod for it. It requires only that you push remote's 1, 2 or 3 in stand-by mode to switch BD region. After hitting 1, 2 or 3 it auto starts and voilà. Now, I also have Oppo 203 and region mod from same Bluraychip.dk company. Now you are required to give 5-key sequence and after that run power off and power on.
AVfile likes this.
Oppo UDP-203 and Oppo BDP-83 both hw region modded, Apple TV 4K 32GB, LG OLED55E6V 55", Asustor 2-Bay NAS currently 8TB
hlindstr is offline
post #36283 of 36533 Old 05-21-2019, 04:08 AM
QuadMersed in bass!
giomania's Avatar
Quoted: 571 Post(s)
Liked: 406
If you enjoy the 203’s network file playback capabilities that would be a reason to keep it.
Sent from my iPhone using Tapatalk Pro
giomania is offline
post #36284 of 36533 Old 05-21-2019, 05:51 AM
b0rnarian's Avatar
Quoted: 1939 Post(s)
Liked: 1145
If you have a programmable remote like a Harmony you can program a sequence to do all the button pressing required to switch regions. I've done it and it actually works but it took a bit of fiddling with delays to get it right. It was more of a "see if I can do it" exercise rather than actually needing it.[IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Thank you, all.
Stefan
Whats it mean to be putting hours on the player... I believe there's no real way to check how many hour the player has so it doesn't really matter. Unless you just mean putting wear and tear on it.
Best,
Main Living Room: Samsung 65 KS9800 + Denon X4500H 11.1 + Sony UBP-X800 + PS4
Other Living Room: Panasonic Plasma 55 + Onkyo Home Theater System 5.1 + PS3
Discs For SALE : 4Ks And 2Ks!
b0rnarian is offline
post #36285 of 36533 Old 05-21-2019, 06:25 AM
Read the FAQ!
Bob Pariseau's Avatar
Quoted: 5760 Post(s)
Liked: 8231
Odds are what you are hearing is the "down mix attenuation" that's applied when multi-channel content is down mixed to stereo to keep from clipping when the multiple channels are summed into just left/right speakers. This is normal, and you compensate by raising the TV volume just as you are doing.
Try playing a movie with a stereo sound track and see if the TV volume is more what you'd expect.
--Bob
Need personal consultation/training? Or just curious about my Blog? Check out my web site!
Bob Pariseau is online now
post #36286 of 36533 Old 05-21-2019, 08:59 AM
AVfile's Avatar
Quoted: 346 Post(s)
Liked: 174
Originally Posted by b0rnarian View Post
Whats it mean to be putting hours on the player... Unless you just mean putting wear and tear on it.
That’s all I meant. Time before failure of electronics is typically measured in hours, not that I’m counting the hours
AVfile is offline
post #36287 of 36533 Old 05-21-2019, 05:51 PM
Sound & Vision's Avatar
Quoted: 463 Post(s)
Liked: 277
I agree...... The 203 is total junk!! I'll be glad to take it off your hands for $200.. You won't have to worry about the awful tone mapping anymore.. lol 😉
RickD_99, dianebrat, dcbii and 8 others like this.
Sound & Vision is offline
post #36288 of 36533 Old 05-21-2019, 05:56 PM
Quoted: 552 Post(s)
Liked: 298
I'm in the same boat as you.. I'm thinking of just rerouting the roku directly to the projector and getting the 820..
Sent from my SM-G930T using Tapatalk
jorgebetancourt is offline
post #36289 of 36533 Old 05-22-2019, 08:11 AM
edub90's Avatar
Quoted: 39 Post(s)
Liked: 5
Anyone have any issues playing It in 4K? Tried the other night and it stutters all the way through. I’ve played the disc a couple times before and never had a issue. I’m running the latest firmware.
edub90 is offline
post #36290 of 36533 Old 05-22-2019, 11:21 AM
hungq's Avatar
Just this past week, my player is unable to play 4K UHD discs. I recently played John Wick 2 and it stuttered at a few place during the movie. Now it will not recognize any of my 4K UHD discs. The player would try to load the disc but would not even start to get into the disc main screen. I would get an Unknown Disc Message on the screen and No Disc in the menu.
The player would still be able to play Blu-ray disc but not the 4K UHD. I am also running the latest firmware. I have contacted Oppo and they said to do a factory reset. I did the factory reset and I am still not able to play 4K UHD. Now Oppo is asking me to use a nonabrasive cloth and warm water to clean the disc. I am not sure if this will work because all my discs are in new condition. I will give it a try and see if this will help.
hungq is offline
post #36291 of 36533 Old 05-22-2019, 08:55 PM
Quoted: 463 Post(s)
Liked: 277
"All mighty Genie of the 203" please don't worry about the Stutta.... Stut... Stuttering.... I'm sure the magical folks at Oppo will conjure up a new firmware release soon.. 🙏🏻
post #36292 of 36533 Old 05-23-2019, 08:18 AM
hernanu's Avatar
Quoted: 1185 Post(s)
Liked: 1973
As another kind soul who's willing to do a good deed, I'll take it off your hands for a kingly $200. Get that offending thing out of sight.
muzz, galonzo, pappaduke and 1 others like this.
hernanu is offline
post #36293 of 36533 Old 05-23-2019, 08:52 AM
Quoted: 463 Post(s)
Liked: 277
Your reasons may be different than mine........ I see the 203/205 as being very beneficial in having a powerful and useful "ZOOM" option in which no other 4K player (besides Pioneer LX500) have a zoom option.. Also......... No other player on the market supports the true 21:9 movie aspect ratio besides the 203/205.. The future will indeed bring us 8K HDR 21:9 TV's for sure... That's the logical next step... You can already purchase 21:9 projectors.. And "only" the 203/205 will be able to be used on them correctly.. 😀🍿🍿🍿🍿🍿
post #36294 of 36533 Old 05-23-2019, 09:02 AM
SeeMoreDigital's Avatar
Quoted: 954 Post(s)
Liked: 699
I guess you're not using the OPPO's excellent networking media file playback features...
giomania and galonzo like this.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 2No Audiolab 8000A, 2No Audiolab M-PWR | SPEAKERS: 4No KEF 103.2, 3No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: DS212+
SeeMoreDigital is offline
post #36295 of 36533 Old 05-23-2019, 11:47 AM
pappaduke's Avatar
Quoted: 337 Post(s)
Liked: 348
Food for thought
I recently met a Comcast Engineer at an audio event. He invited me to visit Comcast technology center in downtown Philadelphia. They have multiple demo rooms for their products with Atmos setups to show off what their new boxes are capable of doing. They also have Oppo 205’s in their setups. He casually stated they only wanted to use the best equipment in their setups. Just sayin’........
Man cave-Marantz 8012, Oppo 203, 4K ATV, Sony XBR-75X940E, Bluesound Vault 2, Harmony One, 2 Paradigm Monitor 9's, CC-390, 2ADP 390's/190's, 2 PDR 100's,
4 SVS Prime elevations. B&W P5. Living room- Yamaha 2010, Bluesound Node 2, Paradigm SE-1's, Zone 2-Paradigm-Stylus 370-SM
Bedroom- Samsung UN60ES7100F, Oppo 103D, Pulse Mini, JBL Bar Studio, ATV3 and Harmony 650
pappaduke is offline
post #36296 of 36533 Old 05-23-2019, 12:31 PM
Bittermidget's Avatar
Quoted: 62 Post(s)
Liked: 66
Did he have to do 2 or 3 system refreshes on his set top boxes while you were there? Just kidding (sort of).
tngiloy and galonzo like this.
JVC DLA-X790R, Seymour AV Centerstage UF 2.40:1 tensioned electric screen w/ motorized masking, Anthem AVM 60, Jim Holtz Statements L/C/R, SVS SB-16 Ultra (X2), Oppo UDP-203, Parasound Halo A-21, Parasound Halo A-51, Bluesound Node 2i, miniDSP 2X4 HD, NVIDIA Shield 2015, QNAP 453Pro
Bittermidget is offline
post #36297 of 36533 Old 05-23-2019, 12:33 PM
Quoted: 163 Post(s)
Liked: 88
Haha very funny. I will probably sell it on eBay for the $~1000 price that they are currently going for.
I understand Oppo has NDA's with their beta testers, etc. But this product is no longer in production?? I wish they would just come out and say what they're continuing to work on, and what they are abandoning, so that I can make a conscious decision as to what other device I could switch to.
At this point, I'd be more happy if Oppo just said "we're totally abandoning the tone mapping feature, and is no longer being worked on".
What would suck, is if I sold the Oppo, then a month later they actually fix the issue.
galonzo, hernanu, mc_avs and 1 others like this.
post #36298 of 36533 Old 05-23-2019, 01:35 PM
hernanu's Avatar
Liked: 1973
I understand, it is hairy to own something which is not being sold any more. They are committed to supporting it for x number of years and have come out before with amazing things without telling any of us (except those persnickety beta testers).
Can''t tell you how to go. A few people have lamented that they gave up their 20X's and found only lesser stuff out there. Maybe buy one of the other players and keep the 203 while you hash out whether you want to make the transition.
Given the price of re-entry, though... it is hard to return to paradise
Anyways - the prices for sale are good, but there is a reason for that. Good luck.
galonzo likes this.
hernanu is offline
post #36299 of 36533 Old 05-23-2019, 01:52 PM
Cortiz's Avatar
Quoted: 117 Post(s)
Liked: 96
Honestly, I would not worry about product support. Companies like Sony and Panasonic releases new players almost every year and after a while they stop supporting their players.
Cortiz is offline
post #36300 of 36533 Old 05-23-2019, 04:46 PM
pappaduke's Avatar
Quoted: 337 Post(s)
Liked: 348
😂, I’ve had my issues with Comcast over the years so I hear ya, but lately I’ve been somewhat happier. But this topic quite obviously should take place in the xfinity thread.
krauley likes this.
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
