Official OPPO UDP-203 Owner's Thread - Page 1211 - AVS Forum | Home Theater Discussions And Reviews
 279046Likes
post #36301 of 37039 Old 05-24-2019, 11:15 AM
cemo62's Avatar
Quoted: 178 Post(s)
Liked: 49
Hello friends
2 years ago when i was in usa i bought oppo 203.
I have a question. Some of the guys in my country tell me this mode improves video and audio quality? Is that true or placebo effect?
UDP-203/205 LPM SE - $360
This is the 'Special Edition' version of our Linear Power Module for the new Oppo UDP-203/205 4k players.
gymnos likes this.
cemo62 is offline
post #36302 of 37039 Old 05-24-2019, 02:34 PM
rdgrimes's Avatar
Quoted: 3822 Post(s)
Liked: 3039
Originally Posted by cemo62 View Post
Hello friends
Snake oil IMO. Mainly functions as a way to separate the user from his money.
dianebrat, Keenan, gwsat and 6 others like this.
rdgrimes is offline
post #36303 of 37039 Old 05-24-2019, 03:18 PM
chrisdack's Avatar
Quoted: 237 Post(s)
Liked: 81
Hi. Has anti anyone had issues with Guardians of the galaxy vol2 UHD hanging at around 1:04.40 (where groot is failing to fetch things for his buddies). The disc then skips forward 5 minutes. I can rewind 2 of those and then it crashes.
I've not done recent upgrades and the last official wiped settings etc.
It's repeatable always at that exact spot.
Thank you
Chris
chrisdack is offline
post #36304 of 37039 Old 05-24-2019, 03:43 PM
tomhayes's Avatar
Quoted: 26 Post(s)
Liked: 27
Thank you
Chris
I had a problem with my GotG2 disc with my OPPO back when I got it. The scene with Yondu's needle killing everyone had major issues. I exchanged the disc and it cleared it up. Never had problems since then.
veger69, galonzo and chrisdack like this.
tomhayes is offline
post #36305 of 37039 Old 05-24-2019, 04:15 PM
chrisdack's Avatar
Quoted: 237 Post(s)
Liked: 81
Thank you
Chris
Exactly that point.
Damn. Mine is a UHD + 3D French import
post #36306 of 37039 Old 05-24-2019, 04:48 PM
Quoted: 83 Post(s)
Guys, I have a question regarding color depth on 4K UHD Blu-ray.
I’m aware that 4K UHD Blu-rays which have HDR10 supports WCG (Wide Color Gamut) which is 10-bit color depth.
However, 4K Blu-ray titles with Dolby Vision enhancement layer is what confuses me.
They say DV supports “up to” 12-bit color depth.
From my searching, it seems that 12-bit color is used at filming/editing/mastering stage in the studio for DV.
However, it looks like they encode into 10-bit HEVC for 4K blu-rays. This part isn’t clear.
Are DV enhanced blu-ray titles encoded in 10-bit or 12-bit color depth?
EC1602 is offline
post #36307 of 37039 Old 05-24-2019, 07:32 PM
rdgrimes's Avatar
Liked: 3039
Thank you
Chris
Try a deep/thorough cleaning and polishing of the disc, pay particular attention to the outer edge.
rdgrimes is offline
post #36308 of 37039 Old 05-25-2019, 09:21 AM
Liked: 1
Hi, the home screen randomly displays. Regardless if the home screen displys or not, it plays dvds fine. When the home screen display is not showing it is a black screen after the OPPO logo comes on. Anyone have any ideas?
Agoju is offline
post #36309 of 37039 Old 05-25-2019, 10:49 AM
rdgrimes's Avatar
Liked: 3039
This is a handshake issue. Start with swapping in new HDMI cables (Certified Premium) between player and AVR and AVR to TV.
galonzo, Hairsonfire and Madmax67 like this.
rdgrimes is offline
post #36310 of 37039 Old 05-25-2019, 02:41 PM
Quoted: 192 Post(s)
Liked: 291
Just had my first disc freeze in two and a half years of use. New UHD release of 'Alien' froze at 55' 14" into the 1979 theatrical version, just as Kane is starting to choke prior to the chest burster scene. Reinserted and tried reversing back to about 55' 20" from the subsequent chapter point, but that froze as well. Gave the disc a wipe and repeated and then I was able to play the rest of the film without issue. However, when it finished I tried that section again and it froze again.
I'll get Amazon to ship a replacement but I just wondered if anyone else has had an issue with this disc? Latest firmware etc.
galonzo likes this.
Panasonic TX-55EZ952B OLED / Oppo UDP-203 / Onkyo TX-NR555 / B&W 600 Series + Elac A4 Atmos
steverobertsbbc is offline
post #36311 of 37039 Old 05-25-2019, 03:48 PM
Digione's Avatar
Quoted: 104 Post(s)
Liked: 79
Have the same disc and no problems playing it on my 205....same hardware and software as the 203.
galonzo and steverobertsbbc like this.
Digione is offline
post #36312 of 37039 Old 05-25-2019, 04:02 PM
Liked: 1
Thank you for you're reply. I will give that a try
Agoju is offline
post #36313 of 37039 Old 05-25-2019, 04:23 PM
QuadMersed in bass!
giomania's Avatar
Quoted: 624 Post(s)
Liked: 382
It is complicated, and here is a little write-up I made for myself to reference after some research.
Dolby Vision HDR RGB Tunneling
The method Dolby Vision HDR (DV) uses to transport the signal over HDMI is referred to as “RGB Tunneling”. The 12-bit ICtCp or ITP colorspace DV signal + Metadata is encapsulated inside the regular RGB 8-bit video signal. The DV “tunneling” carries 12-bit YCbCr 4:2:2 data in an RGB 4:4:4 8-bit transport. This is possible because both signal formats have the same 8.9 Gbps data rate requirements.
https://www.dolby.com/us/en/technolo...hite-paper.pdf
DV requires dynamic luminance data which cannot be explicitly carried in an HDMI 2.0 (18 Gbps max) data stream, so it is designed to transport over HDMI 1.4 (8.9 Gbps max); at least up to [email protected] DV base content and DV luminance (meta) data is encapsulated in an HDMI 1.4 compatible (except HDCP 2.2) RGB 4:4:4 8-bit video stream. That's why Dolby claims that DV can be sent via HDMI v 1.4, but in reality, HDMI v2.0 is needed due to the HDCP v2.2 encryption.
The DV metadata is encoded into the least significant bits of the chroma channels. Upon the HDMI EDID exchange (handshake), the sink (AVR, Display, or HDMI switch) signals the source that it supports Dolby Vision HDR "tunneling". The source then signals the sink that it's transmitting Dolby Vision HDR through an AVI Infoframe, which therefore triggers the Dolby Vision HDR mode in the sink. The display DV engine extracts the components and produces a tone mapped image.
As a result, video pass-through components must be DV 'aware' to not alter the signal, which is in effect 'hidden' inside the 8 bit RGB 'container'.
AVR’s may report DV signals in one of two ways, but both are correct:
Resolution: 4k:24Hz ->4k:24Hz
HDR: Dolby Vision
Color Space: RGB 4:4:4 -> RGB 4:4:4 -OR- YCbCr 4:2:2 -> YCbCr 4:2:2
Color Depth: 8 bits -> 8 bits -OR- 12 bits -> 12 bits
giomania is offline
post #36314 of 37039 Old 05-25-2019, 07:36 PM
BobDyl's Avatar
Quoted: 106 Post(s)
Liked: 94
Played perfectly on my 203.
Cheers
BobDyl is online now
post #36315 of 37039 Old 05-26-2019, 04:07 AM
chrisdack's Avatar
Quoted: 237 Post(s)
Liked: 81
This is the exact behaviour I had on the UHD Guardians of the Galaxy 2. Except at 1:04.
I think there's a layer change issue on some discs.
post #36316 of 37039 Old 05-26-2019, 06:09 AM
Wjboshart's Avatar
Quoted: 1355 Post(s)
Liked: 1323
I haven't had a freeze yet, but did have some audio drop out/issues with uhd Blackhawk down
Wjboshart is offline
post #36317 of 37039 Old 05-26-2019, 06:29 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 6024
It's def on the transport side. I've been playing all of mine off my NAS and there are no issues.
giomania and Paul Cordingley like this.
XBR65A9G / XBR65A8F / 55R615
ATV4K (3) / PS Vue
AVRX6500H / RP-8000F / RP-504C / RP-502S / FV15HP
gadgtfreek is offline
post #36318 of 37039 Old 05-26-2019, 07:20 AM
Sound & Vision's Avatar
Quoted: 472 Post(s)
Liked: 281
Thank you
Chris
Yup, at the exact same point, I gave up on playing the 4K version and just play the included Blu Ray version... Bad disc authoring. 😕
Sound & Vision is offline
post #36319 of 37039 Old 05-26-2019, 10:05 AM
chrisdack's Avatar
Quoted: 237 Post(s)
Liked: 81
Thank you
Chris
What don't they test then before distribution of each version? Ridiculous.
Anyhow presuming not oppo or is there a form we can fill in for oppo to take a look. My old saved url don't go anywhere now
post #36320 of 37039 Old 05-26-2019, 10:08 AM
tassop's Avatar
Quoted: 98 Post(s)
Liked: 103
Hello friends
There are improvements using the linear power supply over the SMPS but whether everyone notices or cares enough about the difference is another question. I use a projector on a 140" screen which will reveal the slightest change to anything upstream and I'm happy with the Oppo LPS, but the difference is still incremental and might not matter as much to others.
The interesting thing is when I was doing A-B comparisons with the Panasonic UB820 after installing the LPS in the Oppo, the Oppo picture had consistently less noise and seemed more natural than the Panasonic compared to the comparisons before the LPS was installed.
Drem and gymnos like this.
tassop is offline
post #36321 of 37039 Old 05-26-2019, 10:20 AM
Quoted: 472 Post(s)
Liked: 281
Yet another reason to support Samsung's and Oppo's decision to stop making 4k players as online Streaming is clearly going to be the wave of the future.. Although I always felt physical media to be much better and will continue making purchases. 😀🍿🍿🍿🍿
post #36322 of 37039 Old 05-26-2019, 10:26 AM
Quoted: 192 Post(s)
Liked: 291
Just to draw a line under this, I just received a replacement from Amazon (isn't Prime same-day delivery wonderful?) and it plays absolutely fine through the same section. When I examined the faulty disc closely I could see that there was a small defect or scratch in the shape of a '9' towards the edge of the disc, which I assume was the cause of the problem. As an aside, I'd never noticed how transparent these discs are before and I believe this one is even a triple layer!
It's a superb looking transfer, by the way. The colour and detail are extremely good. In the scene where the three crew members first discover the space jockey, you can see quite clearly into the helmet and see that there's a child playing Kane.
BobDyl and galonzo like this.
post #36323 of 37039 Old 05-26-2019, 11:25 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 4605 Post(s)
Liked: 4441
OPPO contact page: https://www.oppodigital.com/ContactUs.aspx
I'd certainly give them of the details of your problem. If they see a pattern it helps with diagnosis.
Note that bad batches of discs do make it into the wild sometimes.
And would you believe: sometimes the advance discs the studios provide to test player compatibility do not have the same authoring as the ones that go to market?
-Bill
galonzo and gymnos like this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is offline
post #36324 of 37039 Old 05-26-2019, 01:17 PM
Madmax67's Avatar
Quoted: 2151 Post(s)
Liked: 2466
The only way you'd be able to guarantee you weren't suffering from confirmation bias is to remove yourself from the setup/comparison process. I highly doubt OPPO engineers designed a power supply that offered a lesser picture on the 203 over the 205. Plus when you add a linear power supply you also add heat and many stack their 203's with other older OPPO players. OPPO's are one of the most over engineered piece of electronics I've owned but the aftermarket business has to have hope for gain to sell their wares.
There's a certain engineer who was working a sound board for a self confessed golden eared supervisor who asked him to raise or lower levels at certain frequencies so he could get the levels just right. After a bit of compliance the engineer responded to one request to raise a level by dropping his arms underneath the console and saying "How's that sound?" The response by the supervisor was "Much better!"
Much better indeed.
veger69, galonzo and RagtopFE like this.
Chane A5 towers,Chane A2.4 center,RBH bipole side surrounds, Rythmik LV12R x2,Denon X4300H, Outlaw 5000,Front B speakers: Wharfedale Diamond 10.1 books. https://www.avsforum.com/forum/90-rec...d-part-ii.html
Madmax67 is offline
post #36325 of 37039 Old 05-26-2019, 01:54 PM
vld
vld's Avatar
Quoted: 114 Post(s)
Liked: 87
I have had 1 or 2 freezes playing from a hard drive over a year or so, so I wouldn't say 100% that it's a transport issue. I believe the most recent freeze was Black Hawk Down, had no issues with 4K Alien.
vld is offline
post #36326 of 37039 Old 05-26-2019, 03:53 PM
blairy's Avatar
Quoted: 206 Post(s)
Liked: 91
I've piggy backed an old BDP-93 to my Oppo UDP-203 via HDMI.
Playing music videos (BD and DVD) from an attached HDD which I've formatted the way the BDP-93 likes it (MBR NTFS). HDD is 2TB.
When I play movies with ATMOS track (and I've only got one - Roger Waters The Wall) I get drop outs in the audio. Same happens when I play the disc in the BDP-93.
Can the BDP-93 play ATMOS tracks and if so should it work in this setup: Oppo BDP-93>Oppo UDP-203>Denon AVR6300>LG OLED 65" B6
Also posted in BDP-93 thread.
Cheers
blairy is offline
post #36327 of 37039 Old 05-26-2019, 03:58 PM
bluechunks's Avatar
Quoted: 203 Post(s)
Liked: 263
Cheers
Call me crazy, but why not just connect the HDD to the 203?
galonzo and seggers like this.
__________
Visio P65-C1 / Oppo UDP-203 / Apple TV 4K / TiVo Bolt
Yamaha RX-A2060 5.1.4 / KEF iQ / Speakercraft (Ceiling) / Hsu sub / Ruipro 15 Meter Fiber HDMI
bluechunks is offline
post #36328 of 37039 Old 05-26-2019, 04:00 PM
blairy's Avatar
Quoted: 206 Post(s)
Liked: 91
You're not crazy but the file format works with the 93 but not the 203.
blairy is offline
post #36329 of 37039 Old 05-26-2019, 06:55 PM
calentz's Avatar
Quoted: 193 Post(s)
Liked: 124
I owned a "93" (Which served me well) When I got my "203", I found another home for the "93". The only thing not
supported on the "203" I am aware of that was on the "93" is: HDCD
--Carl
calentz is offline
post #36330 of 37039 Old 05-27-2019, 01:34 AM
SeeMoreDigital's Avatar
Quoted: 992 Post(s)
Liked: 757
Eh??? The OPPO UDP-203 supports FAT, FAT32, NTFS and exFAT file systems via USB connected HDD's.
I SUPPORT 'FAIR USE'. MY MORALS PREVENT ME FROM HELPING ANYONE WHO OBTAINS COPYRIGHTED CONTENT ILLEGITIMATELY
TV: LG 65UH770V | DISC SPINNER: OPPO UDP-203 | STB: VU+ UNO 4K SE
AMPS: 2No Audiolab 8000A, 2No Audiolab M-PWR | SPEAKERS: 4No KEF 103.2, 3No Wharfedale Diamond 10
ISP: Virgin Media @ 100Mbps | NETWORK: 1000Mbps | NAS: DS212+
SeeMoreDigital is offline
Reply Blu-ray Players
203 , 203 uhd , blu-ray , denon x4300h , dsd streaming , failure , Oppo , oppo 203 , sacd dsd hdmi , troubleshooting , UDP-203 , uhd , usb
